Having an issue with running Playstation 2 through hyperspin
gingertips
Hi there
Im having an issue with Hyperspin trying to run Playstation 2 games.
Initially I thought it was to do with uncompressing games, but it isnt that as I tried ones already uncompressed.
When I try and run a game,   it doesnt work just sits at the loading screen with the rocket logo. At first I thought it might be because the file was zipped, but then tried unzipping and got the same. When I run directly using PCSX2, it runs fine, just not through hyperspin. Checked the Hyperlaunchhq.log file & it had this error:
DEBUG 2017-01-30 08:48:42 [1] HyperEmu.App HyperEmu.App.validateApp(:0) – Frontend executable is ..\HyperSpin.exe
DEBUG 2017-01-30 08:48:42 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni..ctor(:0) – HyperLaunchHQ ini file path is H:\Arcade\hyperlaunchhq\Settings\HyperLaunchHQ.ini
DEBUG 2017-01-30 08:48:42 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\hyperlaunchhq\Settings\HyperLaunchHQ.ini
DEBUG 2017-01-30 08:48:42 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni.readIniValues(:0) – Window coordinates are : 1150|935|648|81
DEBUG 2017-01-30 08:48:42 [1] HyperEmu.Forms.BaseWindow HyperEmu.Forms.BaseWindow..ctor(:0) – Main Folder is H:\Arcade\Hyperlaunch
DEBUG 2017-01-30 08:48:42 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\HyperLaunch.ini
DEBUG 2017-01-30 08:48:46 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Global Emulators.ini
DEBUG 2017-01-30 08:48:46 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Global HyperLaunch.ini
DEBUG 2017-01-30 08:48:46 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Global HyperPause.ini
DEBUG 2017-01-30 08:48:46 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Global Bezel.ini
WARN 2017-01-30 08:48:46 [1] HyperEmu.Ini.ISDLoader HyperEmu.Ini.ISDLoader.loadISDFile(:0) – Error parsing ISD file H:\Arcade\Hyperlaunch\Modules\PSXfin\PSXfin.isd
System.InvalidOperationException: There is an error in XML document (20, 1). ---> System.Xml.XmlException: Data at the root level is invalid. Line 20, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitesp ace()
at System.Xml.XmlTextReaderImpl.ParseDocumentContent( )
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlReader.ReadEndElement()
at System.Xml.Serialization.XmlSerializationReader.Re adEndElement()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlS erializationReaderINISCHEMA.Read10_INISCHEMA(Boole an isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlS erializationReaderINISCHEMA.Read11_INISCHEMA()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize (XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at System.Xml.Serialization.XmlSerializer.Deserialize (TextReader textReader)
at HyperEmu.Ini.ISDLoader.loadISDFile(String filepath, Boolean throwException)
DEBUG 2017-01-30 08:48:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Sony Playstation 2\Emulators.ini
DEBUG 2017-01-30 08:48:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Sony Playstation 2\Games.ini
DEBUG 2017-01-30 08:48:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Sony Playstation 2\HyperLaunch.ini
DEBUG 2017-01-30 08:48:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Sony Playstation 2\HyperPause.ini
DEBUG 2017-01-30 08:48:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Sony Playstation 2\Bezel.ini
DEBUG 2017-01-30 08:49:20 [5] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Global Emulators.ini
DEBUG 2017-01-30 08:49:20 [5] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File H:\Arcade\Hyperlaunch\Settings\Sony Playstation 2\Emulators.ini
Any suggestions or ideas what is causing the problem? Not really sure why its saying theres a problem with Error parsing ISD file H:\Arcade\Hyperlaunch\Modules\PSXfin\PSXfin.isd as I have hyperlaunchhq configured to use PCSX2 as the emulator for PS2...
thanks
Try setting it up in RocketLauncher. It likely has a considerably more up to date module available, especially considering the development of PCSX2.
