Hypersync will work once
someguynavarre
I'm stumped.... Mame works in rocklauncherUI.  When I boot hyperspin I can select & open a game.  When I exit a game & go back to the wheel I can maneuver through hyperspin but it will not let me open another game.  I need to restart the computer and it will do the same thing.
i can enter & exit games in rocket launcher at will.  What did I miss?  Hopefully this makes sense.
Yes sorry, I meant Hyperspin...
Here is the log:
01:29:32 PM |  HyperSpin Started
01:29:32 PM |  Going FullScreen
01:29:32 PM |  Checking for updates
01:29:32 PM |  Update Check Complete
01:29:32 PM |  Startup program unavailable
01:29:32 PM |  Playing intro video
01:29:35 PM |  Menu Mode is multi
01:29:35 PM |  Loading Main Menu.xml
01:29:35 PM |  Main Menu.xml successfully loaded
01:29:35 PM |  Main Menu wheel loaded successfully
01:29:40 PM |  Loading MAME.xml
01:29:40 PM |  Main Menu.xml successfully loaded
01:29:40 PM |  MAME wheel loaded successfully
01:29:42 PM |  Launching Game
01:29:42 PM |  Using HyperLaunch
01:29:42 PM |  Getting Launcher path
01:29:42 PM |  Launcher located at C:\rocketlauncher\rocketlauncher.exe
01:29:42 PM |  Running Launcher
01:29:42 PM |  Launcher Command Line is: C:\rocketlauncher\rocketlauncher.exe "MAME" "mspacman"
01:30:24 PM |  Launching Game
01:30:24 PM |  Using HyperLaunch
01:30:24 PM |  Getting Launcher path
01:30:24 PM |  Launcher located at C:\rocketlauncher\rocketlauncher.exe
01:30:24 PM |  Running Launcher
01:30:24 PM |  Launcher Command Line is: C:\rocketlauncher\rocketlauncher.exe "MAME" "mspacman"
I have restarted the computer since this happened last
So just did a fresh reboot, I opened hyperspin and I was able to start a game.  I checked task manager and I have the following running:
joytokey
hyperspin
mame
rocketlauncher is not running and I'm not sure it should be.
i exited the game and tried to relaunch and it doesn't work.  Any ideas?
I just noticed something in the log
That is not pointed at the correct location.  Where do I change this?
ok so I do have hyperspin installed 2 times but I gave you the wrong log file...  Here is the most recent one...  Maybe this will help:
11:19:17 AM |  HyperSpin Started
11:19:17 AM |  Going FullScreen
11:19:17 AM |  Checking for updates
11:19:17 AM |  Update Check Complete
11:19:17 AM |  Startup program: JoyToKey.exe
11:19:17 AM |  Startup params not set
11:19:17 AM |  Working directory: C:\arcade\hyperspin133\rocketlauncher\Profiles\JoyToKey\
11:19:17 AM |  Window State: NORMAL
11:19:17 AM |  Launching JoyToKey.exe
11:19:17 AM |  Command Line is JoyToKey.exe
11:19:17 AM |  Playing intro video
11:19:20 AM |  Error intializing joysticks
11:19:20 AM |  Menu Mode is multi
11:19:20 AM |  Loading Main Menu.xml
11:19:20 AM |  Main Menu.xml successfully loaded
11:19:21 AM |  Main Menu wheel loaded successfully
11:19:25 AM |  Loading MAME.xml
11:19:25 AM |  Main Menu.xml successfully loaded
11:19:26 AM |  MAME wheel loaded successfully
11:19:34 AM |  Launching Game
11:19:34 AM |  Using HyperLaunch
11:19:34 AM |  Getting Launcher path
11:19:34 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
11:19:34 AM |  Launcher located at C:\arcade\hyperspin133\HyperLaunch.exe
11:19:34 AM |  Running Launcher
11:19:34 AM |  Launcher Command Line is: C:\arcade\hyperspin133\HyperLaunch.exe "MAME" "mspacman"
11:19:59 AM |  Launching Game
11:19:59 AM |  Using HyperLaunch
11:19:59 AM |  Getting Launcher path
11:19:59 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
11:19:59 AM |  Launcher located at C:\arcade\hyperspin133\HyperLaunch.exe
11:19:59 AM |  Running Launcher
11:19:59 AM |  Launcher Command Line is: C:\arcade\hyperspin133\HyperLaunch.exe "MAME" "mspacman"
11:20:00 AM |  Launching Game
11:20:00 AM |  Using HyperLaunch
11:20:00 AM |  Getting Launcher path
11:20:00 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
11:20:00 AM |  Launcher located at C:\arcade\hyperspin133\HyperLaunch.exe
11:20:00 AM |  Running Launcher
11:20:00 AM |  Launcher Command Line is: C:\arcade\hyperspin133\HyperLaunch.exe "MAME" "mspacman"
11:20:13 AM |  Loading Main Menu.xml
11:20:13 AM |  Main Menu.xml successfully loaded
11:20:14 AM |  Main Menu wheel loaded successfully
11:20:21 AM |  Loading MAME.xml
11:20:21 AM |  Main Menu.xml successfully loaded
11:20:22 AM |  MAME wheel loaded successfully
11:20:26 AM |  Loading MAME.xml
11:20:27 AM |  Main Menu.xml successfully loaded
11:20:27 AM |  MAME wheel loaded successfully
11:20:33 AM |  Launching Game
11:20:33 AM |  Using HyperLaunch
11:20:33 AM |  Getting Launcher path
11:20:33 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
11:20:33 AM |  Launcher located at C:\arcade\hyperspin133\HyperLaunch.exe
11:20:33 AM |  Running Launcher
11:20:33 AM |  Launcher Command Line is: C:\arcade\hyperspin133\HyperLaunch.exe "MAME" "mkprot4"
11:20:34 AM |  Launching Game
11:20:34 AM |  Using HyperLaunch
11:20:34 AM |  Getting Launcher path
11:20:34 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
11:20:34 AM |  Launcher located at C:\arcade\hyperspin133\HyperLaunch.exe
11:20:34 AM |  Running Launcher
11:20:34 AM |  Launcher Command Line is: C:\arcade\hyperspin133\HyperLaunch.exe "MAME" "mkprot4"
11:20:35 AM |  Launcher Command Line is: C:\arcade\hyperspin133\HyperLaunch.exe "MAME" "mkprot4"
11:20:49 AM |  Loading Main Menu.xml
11:20:49 AM |  Main Menu.xml successfully loaded
11:20:49 AM |  Main Menu wheel loaded successfully
11:20:51 AM |  Exit program unavailable
11:20:51 AM |  Quiting Hyperspin
11:20:51 AM |  Bye!
I notice that it says that it can't fine hyperlaunch.exe, shouldn't it be looking for rocketlauncher.exe?
here is what the settings.ini file says (first few lines)
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=MAME
Hyperlaunch_Path=C:\arcade\hyperspin133\rocketlauncher\
Does this look right?
