Snaus Posted April 14, 2017 Posted April 14, 2017 Hello, Please help. I am new to the arcade world and am very close to completing my setup for hyperspin. I have managed to link RocketlauncheUI with HyperSpin... Ive populated the column under Global, my emulators tab is also full and has the red exclamation points, but when I try to apply my mame emulator (the first one I tried) it says: FILE C:\RocketLauncherUI\HyperSpin\Emulators\mame\mame64.exe doesn't exist. Ive tried several times as well as tried different mame emulator downloads, it just wont recognize the location for some reason. Im running windows 7. Also have issue (maybe related) when opening Rocketlauncher when updates are applied. Everyrthing seems as it should until the final re-write and then I get this: X ACCESS TO THE PATH C:\ChangeLog.txt is denied. Got any suggestions? Thanks, Snaus
rastan Posted April 14, 2017 Posted April 14, 2017 14 hours ago, Snaus said: Hello, Please help. I am new to the arcade world and am very close to completing my setup for hyperspin. I have managed to link RocketlauncheUI with HyperSpin... Ive populated the column under Global, my emulators tab is also full and has the red exclamation points, but when I try to apply my mame emulator (the first one I tried) it says: FILE C:\RocketLauncherUI\HyperSpin\Emulators\mame\mame64.exe doesn't exist. Ive tried several times as well as tried different mame emulator downloads, it just wont recognize the location for some reason. Im running windows 7. Also have issue (maybe related) when opening Rocketlauncher when updates are applied. Everyrthing seems as it should until the final re-write and then I get this: X ACCESS TO THE PATH C:\ChangeLog.txt is denied. Got any suggestions? Thanks, Snaus I haven't messed with my setup in a while but I don't think the red !'s are a good thing? are your file paths correct? also I could be off here but shouldn't the RL and HS be in their own folders.. like the path to emulators shouldn't be under the RLUI\HS\Emu it should be HS\Emulators (at least I think so) I do know that HS and RL shouldn't be sub folders of each other.
Snaus Posted April 14, 2017 Author Posted April 14, 2017 Weird, when I look to properties hyperspin is a root, not in rocketlauncherui... Gonna start over hopefully have better luck... Ill let ya know. Thanks
