Brandon
dramafreesince83
Hello, I'm hoping to find some help getting HyperSpin to load nes roms. It's where I started as I've followed Avar's tutorials parts 1 thru 5. I can load the rom thru Rocket Launcher but when trying to select the game in HyperSpin I've had a few different problems.
At first just nothing would happen, it seemed as if pressing enter wasn't being recognized once I navigated to the game. I tried to investigate and downloaded the "Hyperspin and RocketLauncher Compatibility Fix.zip" that created a HyperLaunch.exe, and HyperLaunch.ini in the RocketLauncher folder. (In my case I have Hyperspin files in d:\Hyperspin, and RocketLauncher files in d:\RocketLauncher) This didn't fix the  problem.
I noticed in HyperHQ the wheel for Nintendo Entertainment System had blank entries under Executable and Rom path. Would that be an issue? I didn't see anything about entering anything here during the tutorials. Any help would be greatly appreciated, thank you.
Edit, this is the Log file from Hyperspin:
03:36:19 PM |  HyperSpin Started
03:36:19 PM |  Going FullScreen
03:36:19 PM |  Checking for updates
03:36:19 PM |  Update Check Complete
03:36:19 PM |  Startup program unavailable
03:36:19 PM |  Playing intro video
03:36:21 PM |  Error intializing joysticks
03:36:21 PM |  Menu Mode is multi
03:36:21 PM |  Loading Main Menu.xml
03:36:21 PM |  Main Menu.xml successfully loaded
03:36:21 PM |  Main Menu wheel loaded successfully
03:36:22 PM |  Loading Nintendo Entertainment System.xml
03:36:22 PM |  Main Menu.xml successfully loaded
03:36:23 PM |  Nintendo Entertainment System wheel loaded successfully
03:36:23 PM |  Launching Game
03:36:23 PM |  Not using HyperLaunch
03:36:23 PM |  Running in normal rom mode
03:36:23 PM |  Excecutable is RocketLauncher.exe
03:36:23 PM |  Command Line is: "D:\RocketLauncher\RocketLauncher.exe" "10-Yard Fight (USA, Europe)."
03:36:55 PM |  Loading Main Menu.xml
03:36:55 PM |  Main Menu.xml successfully loaded
03:36:55 PM |  Main Menu wheel loaded successfully
03:36:56 PM |  Exit program unavailable
03:36:56 PM |  Quiting Hyperspin
03:36:56 PM |  Bye!
EDIT #2, Log from Rocketlauncher:
15:36:23:819 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com)
15:36:23:998 | RL |      INFO  | +172   | Main - System Specs:
                    RocketLauncher Dir: D:\RocketLauncher
                    RocketLauncher is: 32-bit
                    OS: Microsoft Windows 10 Home
                    SKU: Windows 8
                    Total Memory: 16336.28 MB
                    Free Memory: 6418.92 MB
                    Used Memory: 9917.359 MB
                    SystemType: 64-bit
                    Physical Processors: 1
                    Logical Processors: 8
                    GPU 1 Name: NVIDIA GeForce GTX 970M
                    GPU 1 RAM: -1.00 MB
                    GPU 1 Driver Version: 21.21.13.7654
                    GPU 2 Name: NVIDIA GeForce GTX 970M
                    GPU 2 RAM: -1.00 MB
                    GPU 2 Driver Version: 21.21.13.7654
                    Sound 1 Device: Xtreme Audio DAC
                    Sound 1 Status: Enabled
                    Sound 2 Device: Realtek High Definition Audio
                    Sound 2 Status: Enabled
                    Sound 3 Device: NVIDIA High Definition Audio
                    Sound 3 Status: Enabled
                    System Locale: en-US
                    Formats Locale: en-US
                    Windows UI Language: en-US
                    Text Encoding: Windows-1252
                    OS Admin Status: Yes
                    RL Compatibility Flags: ~ RUNASADMIN HIGHDPIAWARE
                    Latest .Net Version: v4.0.30319
                    Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1030 work) [32bit] [60hz] [Landscape]  (Primary)
                    Current AHK Desktop Width: 1920
                    Current AHK Desktop Height: 1080
                    Monitor #1 DPI: 125
                    ErrorMode: 0
                    AutoHotkey Path:
                    AHK Version: 1.1.13.00
                    Unicode: No
15:36:23:998 | RL |      INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\RocketLauncher.exe exists
15:36:23:999 | RL |      INFO  | +0     | GetSystems - Started
15:36:23:999 | RL |      INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml exists
15:36:23:999 | RL |      INFO  | +0     | GetSystems - Found a RocketLauncher Systems.xml: "D:\RocketLauncher\RocketLauncherUI\Databases\Systems.xml"
15:36:23:999 | RL |      INFO  | +0     | GetSystems - Parsing the systems xml
15:36:23:006 | RL |      INFO  | +15    | GetSystems - Ended
15:36:24:037 | RL |      INFO  | +16    | Main - RocketLauncher launched directly
15:36:42:778 | RL |      INFO  | +18750 | Main - Loading Front End Plugin: "RocketLauncherUI"
15:36:42:778 | RL |      INFO  | +0     | Process.Process - "Exist" "HyperSpin.exe"
15:36:42:783 | RL |      INFO  | +0     | Main - Detected HyperSpin.exe is currently running
15:36:42:783 | RL |      INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080
15:36:42:783 | RL |      INFO  | +0     | Main - RocketLauncher received "1942 (Japan, USA)." and "Nintendo Entertainment System"
15:36:42:783 | RL |      INFO  | +0     | CreateNewIni - Checking if an example file exists for Games.ini
15:36:42:784 | RL |   WARNING  | +0     | CreateNewIni - D:\RocketLauncher\Settings\1942 (Japan, USA).\Games.ini file not found, creating a new one.
15:36:42:784 | RL |      INFO  | +0     | CreateNewIni - Checking if an example file exists for Emulators.ini
15:36:42:784 | RL |   WARNING  | +0     | CreateNewIni - D:\RocketLauncher\Settings\1942 (Japan, USA).\Emulators.ini file not found, creating a new one.
15:36:42:784 | RL |      INFO  | +0     | CreateNewIni - Checking if an example file exists for RocketLauncher.ini
15:36:42:784 | RL |   WARNING  | +0     | CreateNewIni - D:\RocketLauncher\Settings\1942 (Japan, USA).\RocketLauncher.ini file not found, creating a new one.
15:36:42:784 | RL |      INFO  | +0     | Main - Did not find a "D:\RocketLauncher\Settings\1942 (Japan, USA).\Game Options.ini" file, skipping any game-specific options.
15:36:42:784 | RL |   WARNING  | +0     | RIniReadCheck - Created missing RocketLauncher ini key: "Default_Emulator" in section: "Roms" in "D:\RocketLauncher\Settings\1942 (Japan, USA).\Emulators.ini"
15:36:52:950 | RL |     ERROR  | +10172 | No Default_Emulator found in "D:\RocketLauncher\Settings\1942 (Japan, USA).\Emulators.ini" Please set one so RocketLauncher knows what module to use.
15:36:52:950 | RL |      INFO  | +0     | ExitScript - Started
15:36:52:954 | RL |      INFO  | +0     | ExitScript - Restoring HyperSpin.exe to x0 y0 w h1080
15:36:52:954 | RL |      INFO  | +0     | ExitScript - Checking what application is currently in focus.
15:36:52:954 | RL |      INFO  | +0     | ExitScript - ErrorLayer is currently active. Putting focus back on HyperSpin.exe with PID of 6056
15:36:53:191 | RL |      INFO  | +234   | SystemCursor - Restoring mouse cursor
15:36:53:205 | RL |      INFO  | +16    | ExitScript - Restored cursor
15:36:53:205 | RL |      INFO  | +0     | ExitScript - Ended
Did you make HyperSpin your default and active frontend in RLUI? If so, was that a clean install? You shouldn't need any sort of "fix" download at all.
The HyperHQ entries aren't required at all for running games and can be left blank. The one purpose the rom path entry in HyperHQ serves is in concert with the "Roms Only" wheel filter, but that's just aesthetic and doesn`t affect what you`re trying to do right now.
Hello Avar and thank you for the dedication you have! Yes HyperSpin is set as the active frontend I believe. I took a screenshot of my RLUI. The install was clean as far as I can tell. I noticed in the log for Rocketlauncher starting at 15:36:42:784 it starts looking for an .ini file that I'm not familiar with, is that any kind of lead?
Do the games show up green when audited and do they run from RLUI when you test them?
I'm with agent47. That "fix" clearly mucked quite a bit up. I'd trash your build and start from scratch. If you don't see me do it in the video, it's likely not a good idea.
Avar, yes they are green and run from RLUI when tested.
Agent47,
1. Where can I change the execution off of normal mode and to HyperLaunch?
2. It am running HyperSpin 1.4.16, I downloaded that to update from 1.3.3, so what method should I be using?
3. I've included a screenshot of the tab to which you are referring, RLUI crashes when I click the magnifying glass to change it!
4. As far as the fix I attempted, I searched this site support forums before creating a topic,
The file came from Ghutch92 address is  http://www.hyperspin-fe.com/applications/core/interface/file/attachment.php?id=21879
I'm definitely new to this and I hope the information I've shared can help prevent this problem from happening to anyone in the future. Thanks again for your help.
You need to reinstall both HyperSpin and RocketLauncher from scratch. That threat you linked is hella old and anything you overwrote will have totally mucked up your everything. In general, be super careful when it comes to overwriting anything using a non-official source.
Those videos are GOSPEL! I was reluctant to do it again but I gave it a fresh install. :bad:I must have missed something the first go around :bad:.
 NES is working, onto SNES and game videos! Thanks again!
np! I'm glad you chose to start again from scratch. Nothing worse then dealing with bugs later on down the road and not knowing why. Cheers!
