R5GAMER Posted April 16, 2017 Posted April 16, 2017 Hello Everyone ! I need you help with Daphne\Singe i use a hyperspin but i have a problem with a launch a Laser games... I hear the game sound but he doesn't show the game lock in my picture ... I have Windows 7 x64 I7 950 & GTX970 4GB & 12GB RAM DDR3. Thanks ..
Avar Posted April 16, 2017 Posted April 16, 2017 Does it work from RLUI? How long ago did you create your HyperSpin build and how long has this been an issue for?
R5GAMER Posted April 16, 2017 Author Posted April 16, 2017 In RLUI i doesn't work too .. I have create my hyperSpin build in 2015 and i have this problem recently (2 week).. And i have update latest git on RLUI.. But i doesn't change...
Avar Posted April 16, 2017 Posted April 16, 2017 Do you remember any changes you made when it stopped working?
R5GAMER Posted April 16, 2017 Author Posted April 16, 2017 I juste reinstall windows 7 x64 and i have all latest driver
Avar Posted April 18, 2017 Posted April 18, 2017 Try setting compatibility mode and running as admin.
Avar Posted April 18, 2017 Posted April 18, 2017 And just to confirm, has this ever worked correctly for you?
R5GAMER Posted April 18, 2017 Author Posted April 18, 2017 Ok i tested with compatibility Windows XP/Vista/7 & admin and doesn't change ... Yes, he worked before installing windows 7 x64 i have installed latest directx, drivers.
Avar Posted April 18, 2017 Posted April 18, 2017 And were you running the same OS before? I'm on Win 10 x64 and has worked fine for me so not sure what might be causing that. If you haven't done it yet, make sure various runtimes are installed and up to date post-install as per the links in the video description for the HS Install vid. Lemme know if it still doesn't work with up to date C++ / .net / etc
R5GAMER Posted April 18, 2017 Author Posted April 18, 2017 Log Daphne daphne_log.txt I use Windows 7x64 below and i don't use update because i modified all windows for use bartop i go install latest c++/vb and other..
R5GAMER Posted April 18, 2017 Author Posted April 18, 2017 Ok i have installed all latest c++/.net/directx(10/9)/etc But i doesn't change... i go to download/install latest daphne....
R5GAMER Posted April 18, 2017 Author Posted April 18, 2017 Ok i found problem in moddog.bat i don't update change Disk drive .... But i changed and now if i launch directly on .bat it worked but in hyperspin daphne "-script bad command line...."
R5GAMER Posted April 18, 2017 Author Posted April 18, 2017 Ok i resolved my problem : Thanks for the help !
