(fixed kind of) DEmul v0.7A 180816 w/ a M2929D CRT full screen issues
acpowell
I recently got my 27" CRT working.  It runs in 800x600.  Mame works fine, but when I go to launch demul games it changes the resolution and possibly the refresh rate to something my monitor doesn't support.  Is there is a way to force it to be 800x600 at 60Hz.  I have tried playing with settings but I cannot seem to get it.  The games do run in windowed mode.
I am using the latest version of demul: DEmul v0.7A 180816
Any help would be greatly appreciated!
41 minutes ago, Avar said:
Is it not letting you manually set a lower resolution in the config?
I am probably not doing it properly.  My monitor is under the knife at the moment.  When it is fixed I will revisit and let you know where a am changing it.
  • 1 month later...
I said I would update when I knew more and now I know more.  First things first:  It is clearly a setting on my machine because a friend has an exact copy of my build with the same hardware and a similar CRT and his works fine.
I did get a new monitor (different model) and it also works now.  I have a completely different demul issue I need to deal with now and I will make a separate post about that.
Not really sure what the issue was.  When I posted this I was using a SVGA CRT.  I am now using a Tri-Sync CGA/EGA/VGA CRT and I have no issues.  My friend who has a similar SVGA to mine had no issues to.  I guess it was user error.
