mothergoose729 Posted July 1, 2017 Posted July 1, 2017 Hi, new to the whole setup, Sorry if this is the wrong place to post. I am using rocket launcher with retroarch 1.60. I have a paid copy of both xpadder and joy2key piece in the utilities/joy2key and utilities/xpadder directory, and the RL path is set to them in the UI settings. I can create and edit profiles for each of my systems, and they work provided that I live either xpadder or joy2key open. Rocket launcher will not switch profiles or launch either software if they are closed. I looked through my log and I don't see any mention of xpadder or joy2key when I launch the game. The module says its version 1.36, but that is the most recent I could find. I had to modify it a little to add support for MSX2+, but otherwise I haven't changed it. I am using the fuse core for ZX sinclair. I want to map keyboard inputs to my xbox one joypad for each game, so I don't have to mess around with all the different joysticks that have to be set manually every time. I have a profile labeled p1 in "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\Xpadder\Sinclair ZX Spectrum\Atic Atac (1983)(Ultimate)" 18:39:41:438 | RL | INFO | +N/A | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com) 18:39:41:508 | RL | INFO | +62 | Main - System Specs: RocketLauncher Dir: D:\RocketLauncher\RL 1.2 Standard Setup RocketLauncher is: 32-bit OS: Microsoft Windows 10 Pro SKU: Professional Total Memory: 16338.11 MB Free Memory: 10290.47 MB Used Memory: 6047.645 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: NVIDIA GeForce GTX 1080 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 22.21.13.8253 Sound 1 Device: NVIDIA High Definition Audio Sound 1 Status: Enabled Sound 2 Device: Realtek High Definition Audio Sound 2 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: ~ HIGHDPIAWARE Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 3840x2160 (3840x2160 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 3840 Current AHK Desktop Height: 2160 Monitor #1 DPI: 300 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 18:39:41:508 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\RL 1.2 Standard Setup\RocketLauncher.exe exists 18:39:41:512 | RL | INFO | +0 | Main - RocketLauncher received "Sinclair ZX Spectrum" and "Atic Atac (1983)(Ultimate)" 18:39:41:515 | RL | INFO | +0 | Main - Did not find a "D:\RocketLauncher\RL 1.2 Standard Setup\Settings\Sinclair ZX Spectrum\Game Options.ini" file, skipping any game-specific options. 18:39:41:515 | RL | INFO | +0 | Main - Atic Atac (1983)(Ultimate) is using the default emulator: Retroarch 1.60 18:39:41:515 | RL | INFO | +0 | Main - Checking for a [Retroarch 1.60] section in D:\RocketLauncher\RL 1.2 Standard Setup\Settings\Sinclair ZX Spectrum\Emulators.ini 18:39:41:515 | RL | INFO | +0 | Main - Found [Retroarch 1.60] in D:\RocketLauncher\RL 1.2 Standard Setup\Settings\Sinclair ZX Spectrum\Emulators.ini 18:39:41:515 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\RL 1.2 Standard Setup\Modules\RetroArch\RetroArch.ahk exists 18:39:41:518 | RL | WARNING | +0 | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk. 18:39:41:518 | RL | INFO | +0 | Main - Atic Atac (1983)(Ultimate) will use module: D:\RocketLauncher\RL 1.2 Standard Setup\Modules\RetroArch\RetroArch.ahk 18:39:41:526 | RL | INFO | +16 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 18:39:41:527 | RL | INFO | +0 | CheckFile - Checking if D:\Emulators\Retroarch\1.60\retroarch.exe exists 18:39:41:527 | RL | INFO | +0 | Main - INI Keys read 18:39:41:528 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\7z.exe exists 18:39:41:528 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\7z.dll exists 18:39:41:530 | RL | INFO | +0 | Main - "Atic Atac (1983)(Ultimate)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 18:39:41:530 | RL | INFO | +0 | CheckPaths - Started 18:39:41:530 | RL | INFO | +0 | CheckPaths - Not scanning to find the rom because a full path was supplied to RocketLauncher via CLI 18:39:41:530 | RL | INFO | +0 | CheckPaths - Ended 18:39:41:531 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event Global RLLog Global RLObject 0 := "8" rlPath := "D:\RocketLauncher\RL 1.2 Standard Setup" pluginPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Plugins" pluginExt := ".plugin" contextOnExit := "" rlMode := "" rlTitle := "RocketLauncher" rlVersion := "1.2.0.1" rlAuthor := "djvj" rlURL := "www.rlauncher.com" langFile := "D:\RocketLauncher\RL 1.2 Standard Setup\Data\Language\Localization.ini" primMonitor := "1" exitEmulatorKey := "~Esc" restoreFE := "false" exitScriptKey := "~q & ~s" toggleCursorKey := "~e & ~t" emuFullPath := "D:\Emulators\Retroarch\1.60\retroarch.exe" emuPath := "D:\Emulators\Retroarch\1.60" emuName := "Retroarch 1.60" emuExt := "exe" baseRomPath := "" romPath := "D:\Games\Sinclair ZX Spectrum" romPathFromIni := "D:\Games\Sinclair ZX Spectrum" romExtension := ".z80" romExtensionOrig := ".z80" romExtensions := "tap|z80" executable := "retroarch.exe" systemDbName := "Sinclair ZX Spectrum" systemName := "Sinclair ZX Spectrum" dbPath := "D:\Games\Sinclair ZX Spectrum" dbName := "Atic Atac (1983)(Ultimate)" dbExt := "z80" romFoundByExt := "" romName := "Atic Atac (1983)(Ultimate)" romMapPath := "" romMappingEnabled := "false" romMappingLaunchMenuEnabled := "false" romMappingFirstMatchingExt := "false" romMappingShowAllRomsInArchive := "true" romMappingNumberOfGamesByScreen := "7" romMappingHideParent := "false" romMappingMenuWidth := "400" romMappingMenuMargin := "65" romMappingTextFont := "Bebas Neue" romMappingTextOptions := "cFFFFFFFF r4 s60 Bold" romMappingDisabledTextColor := "ff888888" romMappingTextSizeDifference := "7" romMappingTextMargin := "15" romMappingTitleTextFont := "Bebas Neue" romMappingTitleTextOptions := "cFFFFFFFF r4 s90 Bold" romMappingTitle2TextFont := "Bebas Neue" romMappingTitle2TextOptions := "cFFFFFFFF r4 s22 Bold" romMappingGameInfoTextFont := "Bebas Neue" romMappingGameInfoTextOptions := "cFFFFFFFF r4 s22 Regular" romMappingGameNameTextFont := "Bebas Neue" romMappingGameNameTextOptions := "cFFFFFFFF r4 s40 Regular" romMappingBackgroundBrush := "aa000000" romMappingColumnBrush := "33000000" romMappingButtonBrush1 := "6f000000" romMappingButtonBrush2 := "33000000" romMappingBackgroundAlign := "Stretch and Lose Aspect" romMappingMenuFlagWidth := "55" romMappingMenuFlagSeparation := "7" romMappingDefaultMenuList := "FullList" romMappingSingleFilteredRomAutomaticLaunch := "false" altArchiveNameOnly := "" altRomNameOnly := "" altArchiveAndRomName := "" altArchiveAndManyRomNames := "" altRomNamesOnly := "" romMapScenario := "" skipchecks := "false" romMatchExt := "false" blockInputTime := "0" blockInputFile := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\BlockInput.exe" errorLevelReporting := "false" lockLaunch := "false" lockLaunchGame := "" screenRotationAngle := "0" screenRotationAngleGame := "" setResolution := "" logFile := "" logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel := "3" logShowDebugConsole := "false" logShowCommandWindow := "false" logCommandWindow := "false" logIncludeModule := "true" logIncludeFileProperties := "true" logIncludeDLLLogs := "false" errorSounds := "true" rlDebugConsoleStdout := "" sysLang := "English_United_States" sysType := "64-bit" broadcastWindowTitle := "" navUpKey := "Up" navDownKey := "Down" navLeftKey := "Left" navRightKey := "Right" navSelectKey := "Enter" navP2UpKey := "Numpad8" navP2DownKey := "Numpad2" navP2LeftKey := "Numpad4" navP2RightKey := "Numpad6" navP2SelectKey := "NumpadEnter" originalWidth := "3840" originalHeight := "2160" vdEnabled := "false" vdFullPath := "" vdUseSCSI := "true" vdDriveLetter := "" vdDriveLetterScsi := "" vdAddDrive := "true" demulShooterPath := "" servoStikEnabled := "false" servoStikExitMode := "false" ledblinkyEnabled := "false" ledblinkySystemName := "" ledblinkyFullPath := "" ledblinkyProfilePath := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\LEDBlinky" ledblinkyRLProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\LEDBlinky\RocketLauncher" winIPACFullPath := "" ultraMapEnabled := "false" ultraMapFullPath := "" emuIdleShutdown := "0" launchPasswordHash := "UpUpDownDownLeftRightLeftRight" cursorSize := "" hideCursor := "true" hideEmu := "false" hideFE := "false" suspendFE := "false" fadeIn := "false" fadeInDuration := "500" fadeInTransitionAnimation := "DefaultAnimateFadeIn" fadeInDelay := "0" fadeInExitDelay := "0" fadeOutExitDelay := "0" fadeOut := "false" fadeOutExtraScreen := "false" fadeOutDuration := "500" fadeOutTransitionAnimation := "DefaultAnimateFadeOut" fadeOutDelay := "0" fadeLyrInterpolation := "7" fadeMuteEmulator := "false" fadeUseBackgrounds := "false" fadeClickThrough := "false" fadeSounds := "true" fade7zProgressMode := "extraction" fadeWidthBaseRes := "1920" fadeHeightBaseRes := "1080" fadeLyr1Color := "FF000000" fadeLyr1AlignImage := "Stretch and Lose Aspect" fadeLyr2Pos := "Stretch and Lose Aspect" fadeLyr2X := "0" fadeLyr2Y := "0" fadeLyr2W := "" fadeLyr2H := "" fadeLyr2Adjust := "1" fadeLyr2PicPad := "0" fadeLyr2Prefix := "Extra Layer 1 - Console" fadeLyr3Pos := "Center" fadeLyr3X := "450" fadeLyr3Y := "450" fadeLyr3W := "" fadeLyr3H := "" fadeLyr3Adjust := "1" fadeLyr3PicPad := "0" fadeLyr3Speed := "750" fadeLyr3Animation := "DefaultFadeAnimation" fadeLyr37zAnimation := "DefaultFadeAnimation" fadeLyr3Type := "imageandbar" fadeLyr3ImgFollow7zProgress := "true" fadeLyr3Repeat := "1" fadeLyr3BackImageTransparency := "30" fadeLyr3StaticPos := "No Alignment" fadeLyr3StaticX := "0" fadeLyr3StaticY := "870|1575" fadeLyr3StaticW := "" fadeLyr3StaticH := "" fadeLyr3StaticAdjust := "1" fadeLyr3StaticPicPad := "0" fadeLyr3StaticPrefix := "Info Bar" fadeLyr4Adjust := "1" fadeLyr4X := "1792|952" fadeLyr4Y := "891|1596" fadeLyr4W := "128" fadeLyr4H := "" fadeLyr4Pos := "No Alignment" fadeLyr4FPS := "50" fadeLyr4PicPad := "0" fadeTranspGifColor := "FFFFFF" fadeBarWindow := "Image" fadeBarWindowX := "" fadeBarWindowY := "" fadeBarWindowW := "900" fadeBarWindowH := "" fadeBarWindowR := "30" fadeBarWindowM := "30" fadeBarWindowHatchStyle := "8" fadeBar := "7zOnly" fadeProgressDuration := "0" fadeBarBack := "true" fadeBarBackColor := "FF555555" fadeBarH := "30" fadeBarR := "10" fadeBarColor := "DD00BFFF" fadeBarHatchStyle := "8" fadeBarPercentageText := "true" fadeBarInfoText := "true" fadeBarXOffset := "0" fadeBarYOffset := "150" fadeRomInfoDescription := "filtered text" fadeRomInfoSystemName := "image" fadeRomInfoYear := "text with label" fadeRomInfoDeveloper := "disabled" fadeRomInfoPublisher := "disabled" fadeRomInfoGenre := "disabled" fadeRomInfoRating := "image" fadeRomInfoOrder := "Description|SystemName|Year|Developer|Genre|Rating|Publisher" fadeRomInfoTextPlacement := "User Defined" fadeRomInfoTextMargin := "7" fadeRomInfoText1Options := "w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular" fadeRomInfoText2Options := "w400 x8 y15 cFF555555 r4 s60 Bold" fadeRomInfoText3Options := "w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular" fadeRomInfoText4Options := "w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular" fadeRomInfoText5Options := "cFF555555 r4 s42 Bold" fadeRomInfoText6Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular" fadeRomInfoText7Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular" fadeStats_Number_of_Times_Played := "text with label" fadeStats_Last_Time_Played := "text with label" fadeStats_Average_Time_Played := "text with label" fadeStats_Total_Time_Played := "text with label" fadeStats_System_Total_Played_Time := "text with label" fadeStats_Total_Global_Played_Time := "text with label" fadeStatsInfoOrder := "Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time" fadeStatsInfoTextPlacement := "topRight" fadeStatsInfoTextMargin := "7" fadeStatsInfoText1Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText2Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText3Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText4Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText5Options := "cFFB4B4B4 r4 s22 Bold" fadeStatsInfoText6Options := "cFFB4B4B4 r4 s22 Bold" fadeText1X := "0" fadeText1Y := "0" fadeText1Options := "cFFB4B4B4 r4 s30 Right Bold" fadeText1 := "Loading Game" fadeText2X := "0" fadeText2Y := "0" fadeText2Options := "cFFB4B4B4 r4 s30 Right Bold" fadeText2 := "Extraction Complete, Ready" fadeText3 := "Loading Game" fadeText4 := "Loading Complete" fadeFont := "Bebas Neue" fadeSystemAndRomLayersOnly := "false" fadeExtractionTime := "disabled" fadeExtractionTimeTextX := "0" fadeExtractionTimeTextY := "0" fadeExtractionTimeTextOptions := "cFF555555 r4 s20 Bold" fadeInterruptKey := "" detectFadeErrorEnabled := "true" fadeImgPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Media\Fade" RLDataPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Data" RLMediaPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Media" RLErrSoundPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Media\Sounds\Error" modulesPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Modules" moduleFullName := "D:\RocketLauncher\RL 1.2 Standard Setup\Modules\RetroArch\RetroArch.ahk" moduleName := "RetroArch" modulePath := "D:\RocketLauncher\RL 1.2 Standard Setup\Modules\RetroArch" moduleExtension := "ahk" moduleExtensionsPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions" libPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Lib" sevenZEnabled := "false" sevenZPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\7z.exe" sevenZDllPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\7z.dll" sevenZExtractPath := "C:\Users\Michael\AppData\Local\Temp\HS" sevenZExtractPathOrig := "" sevenZAttachSystemName := "false" sevenZDelTemp := "true" sevenZFormats := ".zip|.rar|.7z|.lha|.lzh|.gzip|.tar" sevenZFormatsNoP := "zip|rar|7z|lha|lzh|gzip|tar" sevenZFormatsRegEx := "\.zip|\.rar|\.7z|\.lha|\.lzh|\.gzip|\.tar" sevenZGamesToKeep := "" sevenZDeletePerSystem := "false" sevenZExtensions := "zip|rar|7z|lha|lzh|gzip|tar" 7zExtractPath := "C:\Users\Michael\AppData\Local\Temp\HS" mgEnabled := "false" mgKey := "~NumpadSub" mgBackgroundColor := "FF000000" mgSidePadding := "0.2" mgWidthBaseRes := "1920" mgHeightBaseRes := "1080" mgYOffset := "500|800" mgFont := "Arial" mgText1Options := "x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic" mgText1Text := "Please select a game" mgText2Options := "w96p cFFFFFFFF r4 s50 Center BoldItalic" mgText2Offset := "100" mgUseSound := "true" mgSoundfreq := "300" mgExitEffect := "none" mgSelectedEffect := "rotate" mgUseGameArt := "false" mgCandidate := "" mgValidTypes := "\(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side" mgOnLaunch := "false" pauseEnabled := "false" pauseKey := "~NumpadAdd" pauseBackToMenuBarKey := "X" pauseZoomInKey := "C" pauseZoomOutKey := "V" pauseScreenshotKey := "~PrintScreen" pauseHiToTextPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\HiToText.exe" pauseSaveStateKeyCodes := "" pauseLoadStateKeyCodes := "" keyboardEncoder := "" keyboardEncoderEnabled := "false" keymapperEnabled := "false" keymapperAHKMethod := "false" keymapper := "xpadder" xpadderFullPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Utilities\Xpadder\Xpadder.exe" joyToKeyFullPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Utilities\JoyToKey\JoyToKey.exe" profilePath := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles" keymapperProfilePath := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder" keymapperFrontEndProfileName := "RocketLauncherUI" keymapperFrontEndProfile := "xpadder" keymapperRocketLauncherProfileEnabled := "true" joyIDsEnabled := "false" joyIDsPreferredControllersGlobal := "" joyIDsPreferredControllersSystem := "use_global" joyIDsPreferredControllersOnExit := "" CustomJoyNamesEnabled := "false" CustomJoyNames := "" rotateMethod := "false" FEProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\RocketLauncherUI" defaultProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\_Default" systemProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\Sinclair ZX Spectrum" xPadderSystemProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\Sinclair ZX Spectrum\_Default" emuProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\Sinclair ZX Spectrum\Retroarch 1.60" romProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\Sinclair ZX Spectrum\Atic Atac (1983)(Ultimate)" RocketLauncherProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\RocketLauncher" blankProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\xpadder\_Default\blank" ahkFEProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\AHK\RocketLauncherUI" ahkDefaultProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\AHK\_Default" ahkSystemProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\AHK\Sinclair ZX Spectrum" ahkEmuProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\AHK\Sinclair ZX Spectrum\Retroarch 1.60" ahkRomProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\AHK\Sinclair ZX Spectrum\Atic Atac (1983)(Ultimate)" ahkRocketLauncherProfile := "D:\RocketLauncher\RL 1.2 Standard Setup\Profiles\AHK\RocketLauncher" bezelEnabled := "false" bezelICEnabled := "false" shaderName := "false" shaderColor := "" shaderTransparency := "" statisticsEnabled := "true" pressDuration := "-1" emuVolume := "1" dxwndIni := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\dxwnd\dxwnd.ini" dxwndFullPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\dxwnd\dxwnd.exe" qResFullPath := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\QRes.exe" mon1O := "" pacDrivedllFile := "D:\RocketLauncher\RL 1.2 Standard Setup\Module Extensions\PacDrive32.dll" userFadeAnimIniFile := "D:\RocketLauncher\RL 1.2 Standard Setup\Lib\User Fade Animations.ini" testFile := "" testDuration := "" initialErrorMode := "0" 18:39:41:534 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 18:39:41:534 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 18:39:41:534 | RL | INFO | +0 | BuildScript - Validating module 18:39:41:536 | RL | INFO | +0 | BuildScript - Validation complete 18:39:41:536 | RL | INFO | +0 | BuildScript - Module: MEmu := "RetroArch" MEmuV := "v1.3.6" MURL := ["http://themaister.net/retroarch.html"] MAuthor := ["djvj","zerojay","SweatyPickle"] MVersion := "2.4.3" MCRC := "699AB8F7" iCRC := "FB2DB971" MID := "635038268922229162" MSystem := ["Arcade","Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Arcade Classics","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Microsoft MSX2+","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sharp X68000","Sinclair ZX Spectrum","Sinclair ZX81","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"] ;---------------------------------------------------------------------------- ; Notes: ; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working! ; Devs stated they will never add support for mounted images (like via DT) ; Fullscreen is controlled via the module setting in RocketLauncherUI ; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe). ; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect ; Enable 7z support for archived roms ; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1 ; ; LibRetro DLLs: ; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/ ; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system. ; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores ; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270 ; ; SRM files: ; The srm files location is determined by the configuration file used (savefile_directory = ":\whatever") The default RetroArch srm directory is ":\saves" You can select to sort into core folders (ie: :/saves/Mednafen PSX) by changing sort_savefiles_enable = "true" in the configuration file. ; ; Save states: ; The save state files location is determined by the configuration file used (savestate_directory = ":\whatever") The default RetroArch savestate directory is ":\states" You can select to sort into core folders (ie: :/states/Mednafen PSX) by changing sort_savestates_enable = "true" in the configuration file. ; ; Config files: ; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI. This will be the config folder for the module and will NOT change the location of RetroArch's own /config directory. ; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg). ; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg ; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg. ; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config. ; ; Core Options: ; By default, RetroArch creates a retroarch-core-options.cfg in it's root directory. Example: C:\emus\RetroArch\retroarch-core-options.cfg. This will always be used if the default RetroArch.cfg is loaded. If a configuration file from any other location is used, RetroArch will create a retroarch-core-options.cfg file in the root of that directory. The module has an option to have RetroArch use only the default retroarch-core-options.cfg file no matter the path of the config directory or location of the configuiration file being used. To enable this option set Single_Core_Options to true. ; MultiGame: ; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch. ; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind. ; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12. ; ; MAME: ; MAME BIOS roms should be placed in Rom Path's directory. Some systems require the BIOS roms be placed in the MAME internal name directory. (Example: :\Rom Folder\a5200). The MAME BIOS_Roms_Folder option will have no effect unless you are using an older version of the mess core. ; ; System Specific Notes: ; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine. ; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg. ; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg. ; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these. ; NEC TurboGrafx-CD (using pce fast core) - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg. ; NEC TurboGrafx-CD (using MAME core) ; - You'll need to update a couple mame specific options in the Retroarch core options file to get it to boot from the cli. These should probably be updated automagically by the module. Turning softlists off, but might not need to. ; mame_boot_from_cli = "enabled" ; mame_softlists_enable = "disabled" ; mame_softlists_auto_media = "disabled" ; - Requires hash folder from MAME/MESS/UME, either from the source or release package. Save this in the system_directory you've defined for RetroArch. Something like \RetroArch\system\mame\hash\ ; - Requires the CD bios file(s) saved in the mame bios folder you've defined. Usually \RetroArch\system\mame\bios\ ; For PC Engine-CD you'll need the file "[cd] cd-rom system (japan) (v2.1).pce" zipped as cdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\cdsys.zip ; For PC Engine SuperGrafx-CD you'll need the file "[cd] super cd-rom system (japan) (v3.0).pce" zipped as scdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\scdsys.zip ; For TurboGrafx-CD you'll need the file "[cd] turbografx cd system card (usa) (v2.0).pce" zipped as cdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\cdsys.zip ; For TurboDuo you'll need the file "[cd] turbografx cd super system card (usa) (v3.0).pce" zipped as scdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\scdsys.zip ; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode. ; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory. ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() primaryExe := new Emulator(emuPath . "\" . executable) ; instantiate emulator executable object emuPrimaryWindow := new Window(new WindowTitle("RetroArch","RetroArch")) ; instantiate primary emulator window object emuConsoleWindow := new Window(new WindowTitle("","ConsoleWindowClass")) ; instantiate emulator console window object ; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt. ; 1 - Official System Name in RocketLauncher ; 2 - Short name used only for easy referencing within module ; 3 - Default core ; 4 - The system ID MAME core recognizes RLLog.Debug("Module - Started building the " . MEmu . " object") mTypeVar:=" ( LTrim AAE|LibRetro_AAE|mame_libretro Acorn BBC Micro|LibRetro_BBCB|mame_libretro|bbcb Amstrad CPC|LibRetro_CPC|mame_libretro|cpc464 Amstrad GX4000|LibRetro_GX4K|mame_libretro|gx4000 APF Imagination Machine|LibRetro_APF|mame_libretro|apfimag Apple IIGS|LibRetro_AIIGS|mame_libretro|apple2gs Applied Technology MicroBee|LibRetro_MBEE|mame_libretro|mbeeic Arcade Classics|LibRetro_ARCADE|mame_libretro Atari 2600|LibRetro_2600|stella_libretro|a2600 Atari 5200|LibRetro_5200|mame_libretro|a5200 Atari 7800|LibRetro_7800|prosystem_libretro|a7800 Atari 8-Bit|LibRetro_ATARI8|mame_libretro|a800 Atari Classics|LibRetro_ACLS|mame_libretro Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar Atari Lynx|LibRetro_LYNX|handy_libretro|lynx Atari ST|LibRetro_ST|hatari_libretro Atari XEGS|LibRetro_XEGS|mame_libretro|xegs Bally Astrocade|LibRetro_BAST|mame_libretro|astrocde Bandai Gundam RX-78|LibRetro_BGRX|mame_libretro|rx78 Bandai Super Vision 8000|LibRetro_SV8K|mame_libretro|sv8000 Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor Canon X07|LibRetro_CX07|mame_libretro|x07 Capcom Classics|LibRetro_CAPC|mame_libretro Capcom Play System|LibRetro_CPS1|fbalpha_libretro Capcom Play System II|LibRetro_CPS2|fbalpha_libretro Capcom Play System III|LibRetro_CPS3|mame_libretro Casio PV-1000|LibRetro_CAS1K|mame_libretro|pv1000 Casio PV-2000|LibRetro_CAS2K|mame_libretro|pv2000 Cave|LibRetro_CAVE|mame_libretro Coleco ADAM|LibRetro_ADAM|mame_libretro|adam ColecoVision|LibRetro_COLEC|mame_libretro|coleco Commodore Amiga|LibRetro_PUAE|puae_libretro Commodore Max Machine|LibRetro_CMAX|mame_libretro|vic10 Creatronic Mega Duck|LibRetro_DUCK|mame_libretro|megaduck Data East Classics|LibRetro_DATA|mame_libretro Dragon Data Dragon|LibRetro_DRAG64|mame_libretro|dragon64 Elektronika BK|LibRetro_EBK|mame_libretro|bk0010 Elektronska Industrija Pecom 64|LibRetro_P64|mame_libretro|pecom64 Emerson Arcadia 2001|LibRetro_A2001|mame_libretro|arcadia Entex Adventure Vision|LibRetro_AVISION|mame_libretro|advision Epoch Game Pocket Computer|LibRetro_GPCKET|mame_libretro|gamepock Epoch Super Cassette Vision|LibRetro_SCV|mame_libretro|scv Exidy Sorcerer|LibRetro_SORCR|mame_libretro|sorcerer Fairchild Channel F|LibRetro_CHANF|mame_libretro|channelf Final Burn Alpha|LibRetro_FBA|fbalpha_libretro Funtech Super Acan|LibRetro_SACAN|mame_libretro|supracan GamePark 32|LibRetro_GP32|mame_libretro|gp32 GCE Vectrex|LibRetro_VECTX|mame_libretro|vectrex Hartung Game Master|LibRetro_GMASTR|mame_libretro|gmaster Interton VC 4000|LibRetro_VC4K|mame_libretro|vc4000 Irem Classics|LibRetro_IREM|mame_libretro JungleTac Sport Vii|LibRetro_SPORTV|mame_libretro|vii Konami Classics|LibRetro_KONC|mame_libretro Magnavox Odyssey 2|LibRetro_ODYS2|mame_libretro|odyssey2 MAME|LibRetro_MAME|mame_libretro|mame Matra & Hachette Alice|LibRetro_ALICE|mame_libretro|alice32 Mattel Aquarius|LibRetro_AQUA|mame_libretro|aquarius Mattel Intellivision|LibRetro_INTV|mame_libretro|intv MGT Sam Coupe|LibRetro_SAMCP|mame_libretro| Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro Microsoft MSX|LibRetro_MSX|bluemsx_libretro Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro Microsoft MSX2+|LibRetro_MSX2|bluemsx_libretro Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro Midway Classics|LibRetro_MIDC|mame_libretro Namco Classics|LibRetro_NAMC|mame_libretro Namco System 22|LibRetro_NAM2|mame_libretro NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce,cart NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce,cdrom NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx,cart NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16,cart NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16,cdrom Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64 Nintendo 64DD|LibRetro_N64|mupen64plus_libretro Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro Nintendo Classics|LibRetro_NINC|mame_libretro Nintendo DS|LibRetro_DS|desmume_libretro Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes Nintendo Famicom|LibRetro_NFAM|nestopia_libretro Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy Nintendo Game & Watch|LibRetro_GW|gw_libretro Nintendo Pokemon Mini|LibRetro_POKE|mame_libretro|pokemini Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro Panasonic 3DO|LibRetro_3DO|4do_libretro Philips CD-i|LibRetro_CDI|mame_libretro|cdimono1 Philips Videopac|LibRetro_PVID|mame_libretro|videopac RCA Studio II|LibRetro_STUD2|mame_libretro|studio2 SCUMMVM|LibRetro_SCUMM|scummvm_libretro Sega 32X|LibRetro_32X|picodrive_libretro|32x Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd Sega Classics|LibRetro_SEGC|mame_libretro Sega Dreamcast|LibRetro_DCAST|reicast_libretro Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro Sega Meganet|LibRetro_GEN|genesis_plus_gx_libretro|genesis Sega Nomad|LibRetro_GEN|genesis_plus_gx_libretro|genesis Sega Pico|LibRetro_PICO|picodrive_libretro Sega Saturn|LibRetro_SAT|yabause_libretro|saturn Sega Saturn Japan|LibRetro_SAT|yabause_libretro|saturnjp Sega SC-3000|LibRetro_SC3K|mame_libretro|sc3000 Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro Sega ST-V|LibRetro_STV|mame_libretro Sega VMU|LibRetro_SVMU|mame_libretro|svmu Sharp X1|LibRetro_SX1|mame_libretro|x1 Sharp X68000|LibRetro_SX68000|mame_libretro|x68000 Sinclair ZX Spectrum|LibRetro_SPECZX|mame_libretro|spectrum Sinclair ZX81|LibRetro_ZX81|81_libretro|zx81 SNK Classics|LibRetro_SNKC|mame_libretro SNK Neo Geo|LibRetro_NEO|fbalpha_libretro SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes SNK Neo Geo CD|LibRetro_NEOCD|mame_libretro|neocdz SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psu Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro Sony PocketStation|LibRetro_POCKS|mame_libretro|pockstat Sony PSP|LibRetro_PSP|ppsspp_libretro Sony PSP Minis|LibRetro_PSP|ppsspp_libretro Sord M5|LibRetro_SORD|mame_libretro|m5 Spectravideo|LibRetro_SV328|mame_libretro|svi328n Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes Taito Classics|LibRetro_TAIC|mame_libretro Tandy TRS-80 Color Computer|LibRetro_TRS80|mame_libretro|coco3 Technos|LibRetro_TECHN|mame_libretro Texas Instruments TI 99-4A|LibRetro_TI99|mame_libretro|ti99_4a Thomson MO5|LibRetro_MO5|mame_libretro|mo5 Thomson TO7|LibRetro_TO7|mame_libretro|to7 Tiger Game.com|LibRetro_TCOM|mame_libretro|gamecom Tiki-100|LibRetro_TIKI|mame_libretro|kontiki Tomy Tutor|LibRetro_TOMY|mame_libretro|tutor VTech CreatiVision|LibRetro_VTECH|mame_libretro|crvision Watara Supervision|LibRetro_SUPRV|mame_libretro|svision Williams Classics|LibRetro_WILLS|mame_libretro )" mType := Object() Loop, Parse, mTypeVar, `n, `r { obj := {} Loop, Parse, A_LoopField, | { If (A_Index = 1) obj.System := A_LoopField Else If (A_Index = 2) obj.ID := A_LoopField Else If (A_Index = 3) obj.Core := A_LoopField Else { ; 4 StringSplit, tmp, A_LoopField, `, obj.MAMEID := tmp1 obj.MAMEMedia := tmp2 } } mType.Insert(obj["System"], obj) } RLLog.Debug("Module - Finished building the " . MEmu . " object") ; For easier use throughout the module retroSystem := mType[systemName].System retroID := mType[systemName].ID retroCore := mType[systemName].Core retroMAMEID := mType[systemName].MAMEID retroMAMEMedia := mType[systemName].MAMEMedia RLLog.Info("Module - Using these system variables:") RLLog.Info("Module - retroSystem: " . retroSystem) RLLog.Info("Module - retroID: " . retroID) RLLog.Info("Module - retroCore: " . retroCore) RLLog.Info("Module - retroMAMEID: " . retroMAMEID) RLLog.Info("Module - retroMAMEMedia: " . retroMAMEMedia) If !retroSystem ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName) If !retroCore ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.") Fullscreen := moduleIni.Read("Settings", "Fullscreen","true",,1) configFolder := moduleIni.Read("Settings", "ConfigFolder",emuPath . "\config",,1) singlecoreoptions := moduleIni.Read("Settings", "single_core_options","false",,1) = "true" ? ":\retroarch-core-options.cfg" : """" mameRomPath := moduleIni.Read("MAME", "BIOS_Roms_Folder",,,1) mameHideNag := If moduleIni.Read("MAME", "Hide_Nag_Screen","false",,1) = "true" ? "enabled" : "disabled" mameHideInfo := If moduleIni.Read("MAME", "Hide_Info_Screen","false",,1) = "true" ? "enabled" : "disabled" mameHideWarn := If moduleIni.Read("MAME", "Hide_Warning_Screen","false",,1) = "true" ? "enabled" : "disabled" hideConsole := moduleIni.Read("Settings", "HideConsole","true",,1) ejectToggleKey := moduleIni.Read("Settings", "Eject_Toggle_Key",,,1) nextDiskKey := moduleIni.Read("Settings", "Next_Disk_Key",,,1) prevDiskKey := moduleIni.Read("Settings", "Previous_Disk_Key",,,1) core := moduleIni.Read(romName . "|" . systemName, "LibRetro_Core",retroCore,,1) superGB := moduleIni.Read(romName . "|" . systemName, "SuperGameBoy","false",,1) enableNetworkPlay := moduleIni.Read(romName . "|Network", "Enable_Network_Play","false",,1) overlay := moduleIni.Read(romName . "|" . systemName, "Overlay",,,1) videoShader := moduleIni.Read(romName . "|" . systemName, "VideoShader",,,1) aspectRatioIndex := moduleIni.Read(romName . "|" . systemName, "AspectRatioIndex",,,1) customViewportWidth := moduleIni.Read(romName . "|" . systemName, "CustomViewportWidth",,,1) customViewportHeight := moduleIni.Read(romName . "|" . systemName, "CustomViewportHeight",,,1) customViewportX := moduleIni.Read(romName . "|" . systemName, "CustomViewportX",,,1) customViewportY := moduleIni.Read(romName . "|" . systemName, "CustomViewportY",,,1) stretchToFillBezel := moduleIni.Read(romName . "|" . systemName, "StretchToFillBezel","false",,1) rotation := moduleIni.Read(romName . "|" . systemName, "Rotation",0,,1) cropOverscan := moduleIni.Read(romName . "|" . systemName, "CropOverscan",,,1) threadedVideo := moduleIni.Read(romName . "|" . systemName, "ThreadedVideo",,,1) vSync := moduleIni.Read(romName . "|" . systemName, "VSync",,,1) integerScale := moduleIni.Read(romName . "|" . systemName, "IntegerScale",,,1) configurationPerCore := moduleIni.Read(romName . "|" . systemName, "ConfigurationPerCore","false",,1) If (StringUtils.Contains(core, "^(mame|mess|ume)") && !retroMAMEID) { retroMAMEID := "mame" ; set all systems that use a mame core to the default mame ID so any system name is supported RLLog.Warning("Module - Setting MAMEID to default ""mame"" for """ . retroSystem . """") } configFolder := RLObject.getFullPathFromRelative(rlPath,configFolder) mameRomPath := If mameRomPath ? RLObject.getFullPathFromRelative(rlPath,mameRomPath) : romPath overlay := RLObject.getFullPathFromRelative(rlPath,overlay) videoShader := RLObject.getFullPathFromRelative(rlPath,videoShader) rotateBezel := false configFolder := new Folder(configFolder) If (retroID = "LibRetro_SGB" || superGB = "true") ; if system or rom is set to use Super Game Boy { superGB := "true" ; setting this just in case it's false and the system is Nintendo Super Game Boy sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system") CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system") retroID := "LibRetro_SGB" ; switching to Super Game Boy mode retroSystem := "Nintendo Super Game Boy" } ; Find the dll for this system libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll") ; Find the cfg file to use If !configFolder.Exist() ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder.FilePath . """") globalRetroCfg := emuPath . "\retroarch.cfg" systemRetroCfg := configFolder.FilePath . "\" . retroSystem . ".cfg" coreRetroCfg := configFolder.FilePath . "\" . core . ".cfg" RLLog.Info("Module - Global cfg should be: " . globalRetroCfg) RLLog.Info("Module - System cfg should be: " . systemRetroCfg) RLLog.Info("Module - Core cfg should be: " . coreRetroCfg) foundCfg := "" systemRetroCfg := new File(systemRetroCfg) coreRetroCfg := new File(coreRetroCfg) globalRetroCfg := new File(globalRetroCfg) If systemRetroCfg.Exist() { ; check for system cfg first retroCFGFile := systemRetroCfg foundCfg := 1 RLLog.Info("Module - Found a System cfg!") } Else If coreRetroCfg.Exist() { ; 2nd option is a core config retroCFGFile := coreRetroCfg foundCfg := 1 RLLog.Info("Module - Found a Core cfg!") } Else If globalRetroCfg.Exist() { ; 3rd is global cfg retroCFGFile := globalRetroCfg foundCfg := 1 RLLog.Info("Module - Found a Global cfg!") } If foundCfg { RLLog.Info("Module - " . MEmu . " is using " . retroCFGFile.FileFullPath . " as its config file.") retroCFG := LoadProperties(retroCFGFile.FileFullPath) } Else RLLog.Warning("Module - Could not find a cfg file to update settings. RetroArch will make one for you.") If StringUtils.Contains(rotation,"1|3") ; use vertical bezel if RA rotation is set to 90 or 270 degrees rotateBezel := true If StringUtils.Contains(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") { ; these systems require the retroarch settings to be read retroSysDir := ReadProperty(retroCFG,"system_directory") ; read value retroSysDir := ConvertRetroCFGKey(retroSysDir) ; remove dbl quotes retroSysDirLeft := StringUtils.Left(retroSysDir, 2) If (retroSysDirLeft = ":\") { ; if retroarch is set to use a default folder retroSysDir := StringUtils.TrimLeft(retroSysDir, 1) RLLog.Info("Module - RetroArch is using a relative system path: """ . retroSysDir . """") retroSysDir := emuPath . retroSysDir } If !retroSysDir ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.") checkForSlash := StringUtils.Right(retroSysDir, 1) If (checkForSlash = "\") ; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders retroSysDir := StringUtils.TrimRight(retroSysDir, 1) } If (StringUtils.Contains(core, "^(mame|mess|ume)")) || (StringUtils.Contains(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX")) || (StringUtils.Contains(retroID, "LibRetro_NES") && (StringUtils.Contains(core, "nestopia_libretro"))) { ; these systems will use an ini to store game specific settings RLLog.Info("Module - Reading / creating system ini for specific settings.") If !StringUtils.Contains(core, "^(mame|mess|ume)") { If !SystemModuleIni.Exist() SystemModuleIni.Append ; create a new blank ini file if one does not exist } coreOptionsCFG := LoadProperties(coreOptionsCFGFile.FileFullPath) If StringUtils.Contains(core, "^(mame|mess|ume)") { ; Set some MAME/MESS/UME core options. tmpCore := If StringUtils.Contains(core, "mame") ? "mame" : "mess" WriteProperty(coreOptionsCFG, tmpCore . "_read_config", """enabled""", 1) WriteProperty(coreOptionsCFG, tmpCore . "_boot_from_cli", """enabled""", 1) ; This needs to be enabled in order to run games with RLauncher WriteProperty(coreOptionsCFG, tmpCore . "_hide_nagscreen", "" . mameHideNag . "", 1) WriteProperty(coreOptionsCFG, tmpCore . "_hide_infoscreen", "" . mameHideInfo . "", 1) WriteProperty(coreOptionsCFG, tmpCore . "_hide_warnings", "" . mameHideWarn . "", 1) } Else If StringUtils.Contains(retroID, "LibRetro_N64") { ; Nintendo 64 mupenGfx := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Plugin", "auto",,1) mupenRsp := moduleIni.Read(romName . "|" . systemName, "Mupen_RSP_Plugin", "auto",,1) mupenCpu := moduleIni.Read(romName . "|" . systemName, "Mupen_CPU_Core", "dynamic_recompiler",,1) mupenPak1 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_1", "memory",,1) mupenPak2 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_2", "memory",,1) mupenPak3 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_3", "memory",,1) mupenPak4 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_4", "memory",,1) mupenGfxAccur := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Accuracy", "high",,1) mupenExpMem := moduleIni.Read(romName . "|" . systemName, "Mupen_Disable_Exp_Memory", "no",,1) mupenTexturFilt := moduleIni.Read(romName . "|" . systemName, "Mupen_Texture_Filtering", "nearest",,1) mupenViRefresh := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Refresh", "2200",,1) mupenFramerate := moduleIni.Read(romName . "|" . systemName, "Mupen_Framerate", "fullspeed",,1) mupenResolution := moduleIni.Read(romName . "|" . systemName, "Mupen_Resolution", "640x480",,1) mupenPolyOffstFctr := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Factor", "-3.0",,1) mupenPolyOffstUnts := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Units", "-3.0",,1) mupenViOverlay := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Overlay", "disabled",,1) mupenAnalogDzone := moduleIni.Read(romName . "|" . systemName, "Mupen_Analog_Deadzone", "15",,1) WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1) WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1) WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1) WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1) WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1) WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1) WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1) WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1) WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1) WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1) WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1) WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1) WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1) WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1) WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1) WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1) WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1) } Else If StringUtils.Contains(retroID, "LibRetro_NES") { ; these systems will use an ini to store game specific settings If StringUtils.Contains(core, "nestopia_libretro") { ; Nestopia nestopiaBlargg := moduleIni.Read(romName . "|Nestopia", "Nestopia_Blargg_NTSC_Filter", "disabled",,1) nestopiaPalette := moduleIni.Read(romName . "|Nestopia", "Nestopia_Palette", "canonical",,1) nestopiaNoSprteLimit := moduleIni.Read(romName . "|Nestopia", "Nestopia_Remove_Sprites_Limit", "disabled",,1) WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1) WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1) WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1) } } Else If StringUtils.Contains(retroID, "LibRetro_LYNX") { ; Atari Lynx If StringUtils.Contains(core, "handy_libretro") { ; Handy handyRotate := moduleIni.Read(romName . "|" . systemName, "Handy_Rotation", "None",,1) If StringUtils.Contains(handyRotate, "240") or StringUtils.Contains(handyRotate, "90") rotateBezel := true WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1) } } Else If StringUtils.Contains(retroID, "LibRetro_PSX") { ; Sony PlayStation psxCdImageCache := moduleIni.Read(romName . "|" . systemName, "PSX_CD_Image_Cache", """enabled""",,1) psxMemcardHandling := moduleIni.Read(romName . "|" . systemName, "PSX_Memcard_Handling", """libretro""",,1) psxDualshockAnalogToggle := moduleIni.Read(romName . "|" . systemName, "PSX_Dualshock_Analog_Toggle", """enabled""",,1) WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1) WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1) WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1) } SaveProperties(coreOptionsCFGFile.FileFullPath, coreOptionsCFG) } hideEmuObj := Object(emuConsoleWindow,0,emuPrimaryWindow,1) 7z(romPath, romName, romExtension, sevenZExtractPath) mgM3UFile := new File(romPath . "\" . romTable[1,4] . ".m3u") mgRomExtensions := "cue|iso|ccd" mgValidExtension := false Loop, Parse, mgRomExtensions, | If (romExtension = "." . A_LoopField) mgValidExtension := true If (StringUtils.Contains(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated m3uRomIndex := Object() mgType := romTable[1,6] . " " mgMaxIndex := romTable.MaxIndex() mgRomIndex := 0 If mgM3UFile.Exist() mgM3UFile.Delete() Loop % mgMaxIndex { If (romTable[A_Index, 3] = romName) { tempType := romTable[A_Index, 5] mgRomIndex := StringUtils.TrimLeft(tempType, StringUtils.StringLength(mgType)) RLLog.Info("Found rom index in rom set in romTable: " . mgRomIndex) Break } } If (mgRomIndex > 0) { tempRomIndex := mgRomIndex Loop % mgMaxIndex { mgTypeIndex := mgType . tempRomIndex m3uRomIndex.Insert(tempRomIndex) Loop % mgMaxIndex { If (romTable[A_Index, 5] = mgTypeIndex) { tempRomPath := romTable[A_Index, 1] mgM3UFile.Append(tempRomPath . "`n") RLLog.Info("Module - Appending rom path to m3u: " . tempRomPath) Break } } If (tempRomIndex < mgMaxIndex) tempRomIndex++ Else tempRomIndex := 1 } } } ; MAME/MESS/UME core options MAMEParam1 := "" MAMEParam2 := "" MAMEParam3 := "" If StringUtils.Contains(core, "^(mame|mess|ume)") { ; if a MAME/MESS/UME core is used If !retroMAMEID ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MAME/MESS/UME LibRetro core") Else RLLog.Info("Module - MAME/MESS/UME mode using a known ident: " . retroMAMEID) If !mameRomPath ScriptError("Please set the RetroArch module setting ""BIOS_Roms_Folder"" to the folder that contains your MAME/MESS/UME BIOS roms to use with RetroArch.") If (retroMAMEID = "mame") { ; want this for arcade mame only RLLog.Info("Module - Retroarch MAME/MESS/UME Arcade mode enabled") fullRomPath := " """ . romPath . "\" . romName . romExtension . """" } Else { RLLog.Info("Module - Retroarch MAME/MESS/UME Console/PC mode enabled") MAMEParam1 := "" MAMEParam2 := " -rompath \""" . mameRomPath . "\""" ; If we already have a media type, then use it. If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cart") { ;MAMEParam3 := " -cart \" . """" . romPath . "\" . romName . romExtension . "\" . """" MAMEParam3 := " -cart \""" . romPath . "\" . romName . romExtension . "\""""" ; TODO: This needs a better way to handle the cdrom bios files, in my opinion. As it is, there's no clean way to pick between the v2.00 or v3.00 bios. ; Defaulting to the TurboDuo cdrom bios since it will play 2.00 or 3.00 games. } Else If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cdrom") { ;MAMEParam3 := " -cart cdsys -cdrm \" . """" . romPath . "\" . romName . romExtension . "\" . """" MAMEParam3 := " -cart scdsys -cdrm \""" . romPath . "\" . romName . romExtension . "\""""" } Else { ; Build a key/value object containing the different MAMEParam3 choices MAMEP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","saturn","cdrm","saturnjp","cdrm","svi328n","cass","pecom64","cass","psu","cdrm","svmu","quik","gamecom","cart1","mbeeic","quik1") MAMEParam3 := MAMEP3[retroMAMEID] ; search object for the retroMAMEID pair MAMEParam3 := " -" . (If MAMEParam3 ? MAMEParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """" } If (retroMAMEID = "mbeeic") ; Applied Technology MicroBee { microbeeModel := IniReadCheck(MAMESysINI, romName, "MicroBee_Model","mbeeic",,1) If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56 ScriptError("This is not a known MicroBee model value: " . microbeeModel) Else If (microbeeModel != "mbeeic") retroMAMEID := microbeeModel If romExtension in .mwb,.com,.bee mediaDeviceType := "quik1" Else If romExtension in .wav,.tap mediaDeviceType := "cass" Else If romExtension in .rom mediaDeviceType := "cart" Else If romExtension in .dsk mediaDeviceType := "flop1" Else ; .bin format mediaDeviceType := "quik2" MAMEParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """" } If (retroMAMEID = "x68000") ; Sharp X68000 { If romExtension in .xdf,.hdm,.2hd,.dim,.d77,.d88,.1dd,.dfi,.imd,.ipf,.mfi,.mfm,.td0,.cqm,.cqi,.dsk mediaDeviceType := "flop1" Else ; .bin format mediaDeviceType := "sasi" MAMEParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """" } fullRomPath := MAMEParam1 . MAMEParam2 . MAMEParam3 } } Else If (superGB = "true") { RLLog.Info("Module - Retroarch Super Game Boy mode enabled") fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """" } Else { RLLog.Info("Module - Retroarch standard mode enabled") fullRomPath := " """ . romPath . "\" . romName . romExtension . """" } If (retroID = "LibRetro_NFDS") ; Nintendo Famicom Disk System { disksysRom := new File(retroSysDir . "\disksys.rom") If !disksysRom.Exist() ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If (retroID = "LibRetro_SCD") ; Sega CD { If !StringUtils.Contains(romExtension, "\.bin|\.cue|\.iso") ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension) biosCDEBin := new File(retroSysDir . "\bios_CD_E.bin") biosCDUBin := new File(retroSysDir . "\bios_CD_U.bin") biosCDJBin := new File(retroSysDir . "\bios_CD_J.bin") If !biosCDEBin.Exist() ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") If !biosCDUBin.Exist() ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") If !biosCDJBin.Exist() ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If StringUtils.Contains(retroID,"LibRetro_PCECD|LibRetro_TGCD") ; NEC PC Engine-CD and NEC TurboGrafx-CD { If !StringUtils.Contains(romExtension,"\.ccd|\.cue") ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension) sysCard3Pce := new File(retroSysDir . "\syscard3.pce") If !sysCard3Pce.Exist() ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If (retroID = "LibRetro_PCFX") { If !StringUtils.Contains(romExtension,"\.ccd|\.cue") ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension) pcfxBios := new File(retroSysDir . "\pcfx.bios") If !pcfxBios.Exist() ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If (retroID = "LibRetro_SCUMM") { scummFile := new File(romPath . "\" . romName . ".scummvm") If !scummFile.Exist() scummFile.Append("""" . romName . """") } networkSession := "" If (enableNetworkPlay = "true") { RLLog.Info("Module - Network Multi-Player is an available option for " . dbName) netplayNickname := moduleIni.Read("Network", "NetPlay_Nickname","Player",,1) getWANIP := moduleIni.Read("Network", "Get_WAN_IP","false",,1) If (getWANIP = "true") myPublicIP := GetPublicIP() RLLog.Warning("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE") defaultServerIP := moduleIni.Read("Network", "Default_Server_IP", myPublicIP,,1) defaultServerPort := moduleIni.Read("Network", "Default_Server_Port",,,1) lastIP := moduleIni.Read("Network", "Last_IP", defaultServerIP,,1) ; does not need to be on the ISD lastPort := moduleIni.Read("Network", "Last_Port", defaultServerPort,,1) ; does not need to be on the ISD mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,,0) If (mpMenuStatus = -1) { ; if user exited menu early RLLog.Warning("Module - Cancelled MultiPlayer Menu. Exiting module.") ExitModule() } If networkSession { RLLog.Info("Module - Using a Network for " . dbName) moduleIni.Write(networkPort, "GlobalModuleIni", "Network", "Last_Port") ; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort% If (networkType = "client") { moduleIni.Write(networkIP, "GlobalModuleIni", "Network", "Last_IP") ; Save last used IP and Port for quicker launching next time netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """" ; -C = connect as client } Else { ; server netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """" ; -H = host as server } RLLog.Warning("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE") RLLog.Info("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """") } Else RLLog.Info("Module - User chose Single Player mode for this session") } BezelStart(,,(If rotateBezel ? 1:"")) If foundCfg { If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath) { customViewportWidth := bezelScreenWidth customViewportHeight := bezelScreenHeight customViewportX := 0 customViewportY := 0 aspectRatioIndex := 22 RLLog.Info("Stretching viewport to fit bezel") } raCfgHasChanges := "" WriteRetroProperty("core_options_path", singlecoreoptions) WriteRetroProperty("input_overlay", overlay) WriteRetroProperty("video_shader", videoShader) WriteRetroProperty("aspect_ratio_index", aspectRatioIndex) WriteRetroProperty("custom_viewport_width", customViewportWidth) WriteRetroProperty("custom_viewport_height", customViewportHeight) WriteRetroProperty("custom_viewport_x", customViewportX) WriteRetroProperty("custom_viewport_y", customViewportY) WriteRetroProperty("video_rotation", rotation) WriteRetroProperty("video_crop_overscan", cropOverscan) WriteRetroProperty("video_threaded", threadedVideo) WriteRetroProperty("video_vsync", vSync) WriteRetroProperty("video_scale_integer", integerScale) WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey) WriteRetroProperty("input_disk_next", nextDiskKey) WriteRetroProperty("input_disk_prev", prevDiskKey) If StringUtils.Contains(retroID, "LibRetro_PSX") { Loop, 8 ; Loop 8 times for 8 controllers { p%A_Index%ControllerType := moduleIni.Read(romName . "|" . systemName, "P" . A_Index . "_Controller_Type", 517,,1) WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType) } } If raCfgHasChanges { RLLog.Info("Module - Saving changed settings to: """ . retroCFGFile.FileFullPath . """") SaveProperties(retroCFGFile.FileFullPath, retroCFG) } } fullscreen := If fullscreen = "true" ? " -f" : "" retroCFGFileCLI := If foundCfg ? " -c """ . retroCFGFile.FileFullPath . """" : "" HideAppStart(hideEmuObj,hideEmu) If (StringUtils.Contains(core, "^(mame|mess|ume)") && (retroMAMEID != "mame")) { ; if a MAME/MESS/UME core is used primaryExe.Run(" """ . (retroMAMEID ? retroMAMEID : "") . fullRomPath . """ " . fullscreen . retroCFGFileCLI . " -L """ . libDll . netCommand, "Hide") } Else If (retroID = "LibRetro_SCUMM") { primaryExe.Run(" """ . scummFile . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . "" . netCommand, "Hide") } Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case. primaryExe.Run(fullscreen . retroCFGFileCLI . " -L """ . libDll . fullRomPath . netCommand, "Hide") } Else If mgM3UFile.Exist() { primaryExe.Run(" """ . mgM3UFile.FileFullPath . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . netCommand, "Hide") } Else { primaryExe.Run(" " . fullRomPath . fullscreen . retroCFGFileCLI . " -L """ . libDll . netCommand, "Hide") } mpMenuStatus := "" If networkSession { canceledServerWait := false multiplayerMenuExit := false TimerUtils.SetTimer("NetworkConnectedCheck", 500) If (networkType = "server") { RLLog.Info("Module - Waiting for a client to connect to your server") mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.") } Else { ; client RLLog.Info("Module - Trying to contact the server to establish a connection.") mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...") } If (mpMenuStatus = -1) { ; if user exited menu early before a client connected RLLog.Warning("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.") If primaryExe.Process("Exist") primaryExe.Process("Close") ; must close process as the exe is waiting for a client to connect and no window was drawn yet ExitModule() } Else { ; blank response from MultiPlayerMenu, exited properly RLLog.Info("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server") emuPrimaryWindow.Wait() emuPrimaryWindow.WaitActive() } TimerUtils.SetTimer("NetworkConnectedCheck", "Off") } Else { ; single player emuPrimaryWindow.Wait() emuPrimaryWindow.WaitActive() } If (hideConsole = "true") emuConsoleWindow.Set("Transparent", "On") ; makes the console window transparent so you don't see it on exit BezelDraw() HideAppEnd(hideEmuObj,hideEmu) FadeInExit() primaryExe.Process("WaitClose") 7zCleanUp() BezelExit() FadeOutExit() ExitModule() ; Writes new properties into the retroCFG if defined by user WriteRetroProperty(key,value="") { If (value != "") { Global retroCFG,raCfgHasChanges WriteProperty(retroCFG, key, value,1,1) raCfgHasChanges := 1 } } ; Used to convert between RetroArch keys and usable data ConvertRetroCFGKey(txt,direction="read"){ Global emuPath,RLLog If (direction = "read") { newtxt := StringUtils.TrimLeft(txt,1,0) ; removes the " from the left of the txt newtxt := StringUtils.TrimRight(newtxt,1,0) ; removes the " from the right of the txt relativeCheck := StringUtils.SubStr(newtxt,1,1,0) If StringUtils.Contains(relativeCheck,":",0) { ; if the path contains a ":" then it is a relative path RLLog.Debug("ConvertRetroCFGKey - " . newtxt . " is a relative path") newtxt := StringUtils.TrimLeft(newtxt,1,0) ; removes the : from the left of the txt newtxt := AbsoluteFromRelative(emuPath, "." . newtxt) ; convert relative to absolute } If StringUtils.Contains(newtxt,"/",0) newtxt := StringUtils.Replace(newtxt,"/","\",1,,0) ; replaces all forward slashes with backslashes } Else If (direction = "write") { newtxt := """" . txt . """" ; wraps the txt with "" If StringUtils.Contains(newtxt,"\\",0) newtxt := StringUtils.Replace(newtxt,"\","/",1,,0) ; replaces all backslashes with forward slashes } Else ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.") RLLog.Debug("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt) Return newtxt } MultiGame: KeyUtils.SetKeyDelay(100) emuPrimaryWindow.Activate() KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; eject disc in Retroarch If (!mgLastRomIndex) { mgLastRomIndex := mgRomIndex } selectedRomIndex := 0 selectedRomIndex := StringUtils.TrimLeft(selectedRomNum, StringUtils.StringLength(mgType,0)) Loop % mgMaxIndex { If (m3uRomIndex[A_index] = mgLastRomIndex) { tempLastRomIndex := A_index RLLog.Debug("Module - Last index: " . tempLastRomIndex) } If (m3uRomIndex[A_index] = selectedRomIndex) { tempSelectedRomIndex := A_index RLLog.Debug("Module - Selected index: " . tempSelectedRomIndex) } } mgNewIndex := tempLastRomIndex - tempSelectedRomIndex If (mgNewIndex < 0) { mgNewIndex := mgNewIndex * -1 Loop % mgNewIndex { RLLog.Debug("Module - Sending the next disk key: " . nextDiskKey) KeyUtils.Send("{" . nextDiskKey . " down}{" . nextDiskKey . " up}") } } Else If (mgNewIndex > 0) { Loop % mgNewIndex { RLLog.Debug("Module - Sending the previous disk key: " . mgNewIndex) KeyUtils.Send("{" . prevDiskKey . " down}{" . prevDiskKey . " up}") } } KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; close disc in Retroarch mgLastRomIndex := selectedRomIndex Return NetworkConnectedCheck: If clientConnected multiplayerMenuExit := true Else If emuPrimaryWindow.Exist() { RLLog.Info("Module - RetroArch session started, closing the MultiPlayer menu") multiplayerMenuExit := true } Return CloseProcess: FadeOutStart() emuPrimaryWindow.Close() Return 18:39:41:539 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 18:39:41:539 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 18:39:41:539 | RL | INFO | +0 | BuildScript - "D:\RocketLauncher\RL 1.2 Standard Setup\Lib\User Functions\Global.ahk" not found 18:39:41:539 | RL | INFO | +0 | BuildScript - "D:\RocketLauncher\RL 1.2 Standard Setup\Lib\User Functions\Sinclair ZX Spectrum.ahk" not found 18:39:41:539 | RL | INFO | +0 | BuildScript - "D:\RocketLauncher\RL 1.2 Standard Setup\Lib\User Functions\Emulators\Retroarch 1.60.ahk" not found 18:39:41:539 | RL | INFO | +0 | BuildScript - "D:\RocketLauncher\RL 1.2 Standard Setup\Lib\User Functions\Sinclair ZX Spectrum\Emulators\Retroarch 1.60.ahk" not found 18:39:41:539 | RL | INFO | +0 | BuildScript - "D:\RocketLauncher\RL 1.2 Standard Setup\Lib\User Functions\Sinclair ZX Spectrum\Atic Atac (1983)(Ultimate).ahk" not found 18:39:41:539 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 18:39:41:539 | RL | INFO | +0 | Main - Module is built 18:39:41:539 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\RL 1.2 Standard Setup\AutoHotkey.dll exists 18:39:41:540 | RL | INFO | +0 | Main - Running module 18:39:41:656 | MD | INFO | +N/A | Module initialized 18:39:41:656 | MD | INFO | +0 | StartModule - Started 18:39:41:656 | MD | INFO | +0 | StartModule - MEmu: RetroArch MEmuV: v1.3.6 MURL: http://themaister.net/retroarch.html MAuthor: djvj|zerojay|SweatyPickle MVersion: 2.4.3 MCRC: 699AB8F7 iCRC: FB2DB971 MID: 635038268922229162 MSystem: Arcade|Acorn BBC Micro|AAE|Amstrad CPC|Amstrad GX4000|APF Imagination Machine|Applied Technology MicroBee|Apple IIGS|Arcade Classics|Atari 2600|Atari 5200|Atari 7800|Atari 8-Bit|Atari Classics|Atari Jaguar|Atari Lynx|Atari ST|Atari XEGS|Bally Astrocade|Bandai Gundam RX-78|Bandai Super Vision 8000|Bandai Wonderswan|Bandai Wonderswan Color|Canon X07|Capcom Classics|Capcom Play System|Capcom Play System II|Capcom Play System III|Casio PV-1000|Casio PV-2000|Cave|Coleco ADAM|ColecoVision|Commodore MAX Machine|Commodore Amiga|Creatronic Mega Duck|Data East Classics|Dragon Data Dragon|Emerson Arcadia 2001|Entex Adventure Vision|Elektronika BK|Epoch Game Pocket Computer|Epoch Super Cassette Vision|Exidy Sorcerer|Fairchild Channel F|Final Burn Alpha|Funtech Super Acan|GamePark 32|GCE Vectrex|Hartung Game Master|Interton VC 4000|Irem Classics|JungleTac Sport Vii|Konami Classics|MAME|Magnavox Odyssey 2|Microsoft MSX|Microsoft MSX2|Microsoft MSX2+|Matra & Hachette Alice|Mattel Aquarius|Mattel Intellivision|Midway Classics|Namco Classics|Namco System 22|NEC PC Engine|NEC PC Engine-CD|NEC PC-FX|NEC TurboGrafx-16|NEC SuperGrafx|NEC TurboGrafx-CD|Nintendo 64|Nintendo 64DD|Nintendo Arcade Systems|Nintendo Classics|Nintendo DS|Nintendo Entertainment System|Nintendo Famicom|Nintendo Famicom Disk System|Nintendo Game Boy|Nintendo Game Boy Color|Nintendo Game Boy Japan|Nintendo Game Boy Advance|Nintendo Game & Watch|Nintendo Super Game Boy|Nintendo Pokemon Mini|Nintendo Virtual Boy|Nintendo Super Famicom|Nintendo Satellaview|Nintendo SuFami Turbo|Panasonic 3DO|Elektronska Industrija Pecom 64|Philips CD-i|Philips Videopac|RCA Studio II|ScummVM|Sega 32X|Sega Classics|Sega Mega Drive 32X|Sega Mark III|Sega SC-3000|Sega SG-1000|Sega CD|Sega Dreamcast|Sega Game Gear|Sega Genesis|Sega Master System|Sega Mega Drive|Sega Meganet|Sega Nomad|Sega Pico|Sega Saturn|Sega Saturn Japan|Sega VMU|Sega ST-V|Sharp X1|Sharp X68000|Sinclair ZX Spectrum|Sinclair ZX81|Sony PlayStation|Sony PlayStation Minis|Sony PocketStation|Sony PSP|Sony PSP Minis|Sord M5|SNK Classics|SNK Neo Geo|SNK Neo Geo AES|SNK Neo Geo MVS|SNK Neo Geo Pocket|SNK Neo Geo CD|SNK Neo Geo Pocket Color|Spectravideo|Super Nintendo Entertainment System|Taito Classics|Tandy TRS-80 Color Computer|Technos|Texas Instruments TI 99-4A|Thomson MO5|Thomson TO7|Tiger Game.com|Tiki-100|Tomy Tutor|VTech CreatiVision|Watara Supervision|Williams Classics 18:39:41:656 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sinclair ZX Spectrum" 18:39:41:656 | MD | INFO | +0 | LocaleUtils.i18n - Started 18:39:41:657 | MD | INFO | +0 | LocaleUtils.i18n - Ended, using "Open" for "dialog.open" 18:39:41:657 | MD | INFO | +0 | LocaleUtils.i18n - Started 18:39:41:657 | MD | INFO | +0 | LocaleUtils.i18n - Ended, using "Start" for "dialog.start" 18:39:41:657 | MD | INFO | +0 | PluginInit - Started 18:39:41:660 | MD | INFO | +0 | CheckFile - Checking if D:\Data\Platforms\Sinclair ZX Spectrum.xml exists 18:39:41:664 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo 18:39:41:664 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:664 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-01 18:39:41:664 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:664 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-02 18:39:41:664 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:664 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-03 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-04 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-05 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-06 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-07 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-08 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo-09 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-01 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-02 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-03 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-04 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-05 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-06 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-07 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-08 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Game Logo-09 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:665 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-01 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-02 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-03 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-04 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-05 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-06 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-07 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-08 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo-09 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-01 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-02 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-03 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-04 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-05 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-06 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-07 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Background-08 18:39:41:666 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +31 | BuildAssetsTable - Started - Building Table for: Background-09 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-01 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-02 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-03 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-04 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-05 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-06 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-07 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-08 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Background-09 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-01 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-02 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-03 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:684 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-04 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-05 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-06 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-07 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-08 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Fanart - Background-09 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-01 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-02 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-03 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-04 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-05 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-06 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-07 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-08 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:685 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Rom Fanart - Background-09 18:39:41:686 | MD | INFO | +0 | BuildAssetsTable - Ended 18:39:41:686 | MD | INFO | +0 | PluginInit - Ended 18:39:41:686 | MD | INFO | +0 | SystemCursor - Hiding mouse cursor 18:39:41:729 | MD | INFO | +31 | StartModule - Ended 18:39:41:756 | MD | INFO | +31 | Module - Using these system variables: 18:39:41:756 | MD | INFO | +0 | Module - retroSystem: Sinclair ZX Spectrum 18:39:41:756 | MD | INFO | +0 | Module - retroID: LibRetro_SPECZX 18:39:41:756 | MD | INFO | +0 | Module - retroCore: mame_libretro 18:39:41:756 | MD | INFO | +0 | Module - retroMAMEID: spectrum 18:39:41:756 | MD | INFO | +0 | Module - retroMAMEMedia: cdrom 18:39:41:756 | MD | INFO | +0 | RIniFile.Read - Module - Fullscreen: true (DEFAULT) 18:39:41:756 | MD | INFO | +0 | RIniFile.Read - Module - ConfigFolder: D:\Emulators\Retroarch\1.60\config (DEFAULT) 18:39:41:756 | MD | INFO | +0 | RIniFile.Read - Module - single_core_options: false (DEFAULT) 18:39:41:756 | MD | INFO | +0 | RIniFile.Read - Module - BIOS_Roms_Folder: (NO VALUE) 18:39:41:756 | MD | INFO | +0 | RIniFile.Read - Module - Hide_Nag_Screen: false (DEFAULT) 18:39:41:756 | MD | INFO | +0 | RIniFile.Read - Module - Hide_Info_Screen: false (DEFAULT) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - Hide_Warning_Screen: false (DEFAULT) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - HideConsole: true (DEFAULT) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - Eject_Toggle_Key: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - Next_Disk_Key: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - Previous_Disk_Key: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Sinclair ZX Spectrum] - LibRetro_Core: fuse_libretro 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - SuperGameBoy: false (DEFAULT) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - Enable_Network_Play: false (DEFAULT) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - Overlay: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - VideoShader: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - AspectRatioIndex: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - CustomViewportWidth: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - CustomViewportHeight: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - CustomViewportX: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - CustomViewportY: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - StretchToFillBezel: false (DEFAULT) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - Rotation: 0 (DEFAULT) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - CropOverscan: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - ThreadedVideo: (NO VALUE) 18:39:41:757 | MD | INFO | +0 | RIniFile.Read - Module - VSync: (NO VALUE) 18:39:41:758 | MD | INFO | +0 | RIniFile.Read - Module - IntegerScale: (NO VALUE) 18:39:41:758 | MD | INFO | +0 | RIniFile.Read - Module - ConfigurationPerCore: false (DEFAULT) 18:39:41:758 | MD | INFO | +0 | CheckFile - Checking if D:\Emulators\Retroarch\1.60\cores\fuse_libretro.dll exists 18:39:41:758 | MD | INFO | +0 | Module - Global cfg should be: D:\Emulators\Retroarch\1.60\retroarch.cfg 18:39:41:758 | MD | INFO | +0 | Module - System cfg should be: D:\Emulators\Retroarch\1.60\config\Sinclair ZX Spectrum.cfg 18:39:41:758 | MD | INFO | +0 | Module - Core cfg should be: D:\Emulators\Retroarch\1.60\config\fuse_libretro.cfg 18:39:41:758 | MD | INFO | +0 | Module - Found a Global cfg! 18:39:41:758 | MD | INFO | +0 | Module - RetroArch is using D:\Emulators\Retroarch\1.60\retroarch.cfg as its config file. 18:39:41:758 | MD | INFO | +0 | LoadProperties - Started and loading this cfg into memory: D:\Emulators\Retroarch\1.60\retroarch.cfg 18:39:41:759 | MD | INFO | +0 | LoadProperties - Ended 18:39:41:759 | MD | INFO | +0 | Module - Retroarch standard mode enabled 18:39:41:782 | MD | INFO | +32 | Module - Saving changed settings to: "D:\Emulators\Retroarch\1.60\retroarch.cfg" 18:39:41:782 | MD | INFO | +0 | SaveProperties - Started and saving this cfg to disk: D:\Emulators\Retroarch\1.60\retroarch.cfg 18:39:41:786 | MD | INFO | +0 | SaveProperties - Ended 18:39:41:786 | MD | INFO | +0 | Process.Run - Running: D:\Emulators\Retroarch\1.60\retroarch.exe "D:\Games\Sinclair ZX Spectrum\Atic Atac (1983)(Ultimate).z80" -f -c "D:\Emulators\Retroarch\1.60\retroarch.cfg" -L "D:\Emulators\Retroarch\1.60\cores\fuse_libretro.dll 18:39:41:809 | MD | INFO | +31 | Window.Wait - Waiting for window "RetroArch ahk_class RetroArch" 18:39:42:019 | MD | INFO | +203 | Window.WaitActive - Waiting for "RetroArch ahk_class RetroArch" 18:39:42:697 | MD | INFO | +672 | Process.Process - "WaitClose" "retroarch.exe" 18:39:44:978 | MD | INFO | +2281 | CloseProcess - Started, user requested to end launched application 18:39:45:326 | MD | INFO | +360 | CloseProcess - Ended 18:39:45:326 | MD | INFO | +0 | ExitModule - Started 18:39:45:326 | MD | INFO | +0 | UpdateStatistics - Starting Updating Statistics 18:39:45:398 | MD | INFO | +62 | UpdateStatistics - Game section statistics updated. 18:39:45:398 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 18:39:45:438 | RL | INFO | +3906 | Main - Module ended, exiting RocketLauncher normally 18:39:45:438 | RL | INFO | +0 | ExitScript - Started 18:39:45:440 | RL | INFO | +0 | ExitScript - Checking what application is currently in focus. 18:39:45:450 | RL | INFO | +16 | SystemCursor - Restoring mouse cursor 18:39:45:465 | RL | INFO | +15 | ExitScript - Restored cursor 18:39:45:465 | RL | INFO | +0 | ExitScript - Ended
mothergoose729 Posted July 1, 2017 Author Posted July 1, 2017 1 minute ago, agent47 said: You need to enable keymapping on the Settings -> Mapping tab. You're a good person, I want you to know that.
