Amiga emulator boots to black screen
mikemelo
Im running my amiga emulator using winUAE3.1 every time it loads a game it boots to a black screen and i can hear game play in the back ground. I downloaded the emulator from Simply Austin and followed his tutorial to a T and still cant get it to work. What am I doing wrong here is my log
[code]
08:26:15:283 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
08:26:15:417 | RL |     INFO  | +125   | Main - System Specs:
					RocketLauncher Dir: D:\Arcade\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8163.35 MB
					Free Memory: 5297.19 MB
					Used Memory: 2866.164 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: NVIDIA GeForce 210
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 21.21.13.4201
					Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
					Sound 1 Status: Enabled
					Sound 2 Device: NVIDIA High Definition Audio
					Sound 2 Status: Enabled
					Sound 3 Device: NVIDIA High Definition Audio
					Sound 3 Status: Enabled
					Sound 4 Device: Realtek High Definition Audio
					Sound 4 Status: Enabled
					Sound 5 Device: Bluetooth Audio
					Sound 5 Status: Enabled
					Sound 6 Device: NVIDIA High Definition Audio
					Sound 6 Status: Enabled
					Sound 7 Device: NVIDIA High Definition Audio
					Sound 7 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
08:26:15:419 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
08:26:15:421 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.3
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2061824 bytes
					Created:			9/23/2015 - 10:21:14 PM
					Modified:			8/30/2015 - 6:53:55 AM
08:26:15:422 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk exists
08:26:15:428 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:475 | RL |   DEBUG1  | +47    | CheckFile - Attributes:
					File Size:			4961 bytes
					Modified:			12/28/2014 - 12:53:36 PM
08:26:15:478 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe exists
08:26:15:487 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
08:26:15:490 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk exists
08:26:15:513 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
08:26:15:516 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Modified:			8/30/2015 - 6:53:49 AM
08:26:15:519 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
08:26:15:535 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:26:15:538 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
08:26:15:541 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk exists
08:26:15:559 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
08:26:15:563 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
08:26:15:566 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk exists
08:26:15:579 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:583 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5895 bytes
					Modified:			7/6/2015 - 6:15:22 AM
08:26:15:586 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
08:26:15:588 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gsdll32.dll exists
08:26:15:592 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			13090816 bytes
					Modified:			1/8/2015 - 5:54:04 PM
08:26:15:594 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\itextsharp.dll exists
08:26:15:598 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			9/23/2015 - 10:21:15 PM
08:26:15:600 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Java.ahk exists
08:26:15:605 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:609 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
08:26:15:611 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
08:26:15:614 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk exists
08:26:15:619 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
08:26:15:623 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			9203 bytes
08:26:15:625 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk exists
08:26:15:630 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:633 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
					Modified:			5/4/2015 - 9:16:07 AM
08:26:15:636 | RL |   DEBUG1  | +15    | Origin.ahk Version: 1.0.2
08:26:15:639 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk exists
08:26:15:668 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
08:26:15:672 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
08:26:15:675 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk exists
08:26:15:692 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:26:15:696 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
08:26:15:699 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
08:26:15:703 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
08:26:15:706 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk exists
08:26:15:712 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:716 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			5347 bytes
					Modified:			5/4/2015 - 9:16:38 AM
08:26:15:719 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
08:26:15:722 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA.ahk exists
08:26:15:736 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:26:15:740 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
08:26:15:742 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk exists
08:26:15:757 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:761 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			3833 bytes
					Modified:			1/30/2015 - 8:39:01 PM
08:26:15:763 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
08:26:15:766 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\7z.ahk exists
08:26:15:781 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:785 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29013 bytes
					Modified:			8/30/2015 - 6:53:50 AM
08:26:15:788 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.1
08:26:15:791 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Bezel.ahk exists
08:26:15:800 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:821 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			102587 bytes
					Modified:			7/6/2015 - 6:15:20 AM
08:26:15:825 | RL |   DEBUG1  | +15    | Bezel.ahk Version: 1.1.2
08:26:15:828 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade.ahk exists
08:26:15:847 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:851 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			38048 bytes
					Modified:			9/18/2015 - 8:22:33 AM
08:26:15:854 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.2
08:26:15:857 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Init.ahk exists
08:26:15:868 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:872 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			999 bytes
08:26:15:875 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
08:26:15:877 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk exists
08:26:15:892 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:897 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			79882 bytes
08:26:15:900 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.8
08:26:15:903 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause.ahk exists
08:26:15:922 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:926 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392698 bytes
08:26:15:929 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.4
08:26:15:932 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause Init.ahk exists
08:26:15:937 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:953 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			553 bytes
					Modified:			8/30/2015 - 6:53:41 AM
08:26:15:956 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
08:26:15:964 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper.ahk exists
08:26:15:991 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:26:15:009 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			33453 bytes
					Modified:			5/21/2015 - 10:33:10 PM
08:26:16:012 | RL |   DEBUG1  | +16    | Keymapper.ahk Version: 1.1.2
08:26:16:019 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk exists
08:26:16:046 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:050 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
08:26:16:053 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
08:26:16:055 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame.ahk exists
08:26:16:069 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:074 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			40753 bytes
					Modified:			8/30/2015 - 6:53:37 AM
08:26:16:076 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
08:26:16:080 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk exists
08:26:16:090 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:094 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
08:26:16:097 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
08:26:16:100 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk exists
08:26:16:107 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:110 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			58770 bytes
					Modified:			7/9/2015 - 7:36:01 AM
08:26:16:113 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
08:26:16:116 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Password.ahk exists
08:26:16:122 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:133 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10025 bytes
					Modified:			8/30/2015 - 6:53:44 AM
08:26:16:136 | RL |   DEBUG1  | +15    | Password.ahk Version: 1.0.2
08:26:16:153 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
08:26:16:170 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:174 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			73772 bytes
08:26:16:177 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
08:26:16:180 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Shared.ahk exists
08:26:16:188 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:192 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			116503 bytes
					Modified:			8/30/2015 - 6:53:45 AM
08:26:16:195 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.2
08:26:16:198 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics.ahk exists
08:26:16:205 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:209 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26143 bytes
					Modified:			5/4/2015 - 9:16:52 AM
08:26:16:211 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
08:26:16:214 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk exists
08:26:16:219 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:223 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33 bytes
08:26:16:226 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
08:26:16:229 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk exists
08:26:16:245 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:249 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			17070 bytes
08:26:16:252 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.1
08:26:16:254 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey.ahk exists
08:26:16:268 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:271 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26540 bytes
					Modified:			8/30/2015 - 6:53:48 AM
08:26:16:275 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
08:26:16:277 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk exists
08:26:16:289 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:26:16:293 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			1063 bytes
					Modified:			8/30/2015 - 6:53:38 AM
08:26:16:296 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
08:26:16:299 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Sony Playstation 2 -r Castlevania - Lament of Innocence (USA) -f D:\Arcade\HyperSpin.exe -p HyperSpin -c 1"
08:26:16:301 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "Castlevania - Lament of Innocence (USA)"
08:26:16:304 | RL |   DEBUG1  | +0     | Main - dbName: Castlevania - Lament of Innocence (USA)
08:26:16:306 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
08:26:16:309 | RL |     INFO  | +16    | Main - RocketLauncher received "Sony Playstation 2" and "Castlevania - Lament of Innocence (USA)"
08:26:16:323 | RL |     INFO  | +16    | Main - Did not find a "D:\Arcade\RocketLauncher\Settings\Sony Playstation 2\Game Options.ini" file, skipping any game-specific options.
08:26:16:343 | RL |     INFO  | +15    | Main - Castlevania - Lament of Innocence (USA) is using the default emulator: PCSX2
08:26:16:346 | RL |     INFO  | +0     | Main - Checking for a [PCSX2] section in D:\Arcade\RocketLauncher\Settings\Sony Playstation 2\Emulators.ini
08:26:16:349 | RL |     INFO  | +0     | Main - Checking for a [PCSX2] section in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:26:16:353 | RL |     INFO  | +0     | Main - Found [PCSX2] in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:26:16:356 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Modules\PCSX2\PCSX2.ahk exists
08:26:16:364 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			16693 bytes
					Modified:			8/30/2015 - 6:53:56 AM
08:26:16:376 | RL |     INFO  | +15    | Main - CRC Check - CRC matches, this is an official unedited module.
08:26:16:379 | RL |     INFO  | +0     | Main - Castlevania - Lament of Innocence (USA) will use module: D:\Arcade\RocketLauncher\Modules\PCSX2\PCSX2.ahk
08:26:16:404 | RL |     INFO  | +32    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
08:26:16:448 | RL |     INFO  | +46    | CheckFile - Checking if D:\Arcade\emulators\PCSX2\pcsx2-r5875.exe exists
08:26:16:456 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5374336 bytes
					Created:			4/12/2015 - 2:46:36 AM
					Modified:			2/3/2014 - 8:55:40 AM
08:26:16:459 | RL |     INFO  | +0     | Main - INI Keys read
08:26:16:463 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.exe exists
08:26:16:467 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
08:26:16:474 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.dll exists
08:26:16:478 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
08:26:16:503 | RL |     INFO  | +31    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\FontReg.exe exists
08:26:16:525 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
					FileDescription         	Font Registration Utility (x86-32)
					FileVersion             	2.1.3.0
					OriginalFilename        	FontReg.exe
					File Size:			6144 bytes
08:26:16:602 | RL |     INFO  | +63    | Main - "Castlevania - Lament of Innocence (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
08:26:16:605 | RL |     INFO  | +15    | CheckPaths - Started
08:26:16:608 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Sony Playstation 2\roms\Castlevania - Lament of Innocence (USA).7z
08:26:16:611 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Arcade\Sony Playstation 2\roms\Castlevania - Lament of Innocence (USA).7z
08:26:16:614 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: Castlevania - Lament of Innocence (USA)
08:26:16:617 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Arcade\Sony Playstation 2\roms
08:26:16:619 | RL |   DEBUG1  | +16    | CheckPaths - Current romExtension: .7z
08:26:16:622 | RL |     INFO  | +0     | CheckPaths - Ended
08:26:16:626 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Arcade\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.3
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Arcade\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Arcade
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc|H1000:1joy7
					restoreFE = Restore
					exitScriptKey = `
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Arcade\emulators\PCSX2\pcsx2-r5875.exe
					emuPath = D:\Arcade\emulators\PCSX2
					emuName = PCSX2
					emuExt = exe
					romPath = D:\Arcade\Sony Playstation 2\roms
					romPathFromIni = D:\Arcade\Sony Playstation 2\roms
					romExtension = .7z
					romExtensionOrig = .7z
					romExtensions = 7z|zip|iso|bin|rar
					executable = pcsx2-r5875.exe
					systemDbName = Sony Playstation 2
					systemName = Sony Playstation 2
					dbPath =
					dbName = Castlevania - Lament of Innocence (USA)
					dbExt =
					romName = Castlevania - Lament of Innocence (USA)
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = true
					blockInputTime = 0
					blockInputFile = D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Arcade\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = true
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = false
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Arcade\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Arcade\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = true
					fadeInDuration = 500
					fadeInDelay = 5000
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Arial
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Arcade\RocketLauncher\Media\Fade
					RLDataPath = D:\Arcade\RocketLauncher\Data
					RLMediaPath = D:\Arcade\RocketLauncher\Media
					RLErrSoundPath = D:\Arcade\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Arcade\RocketLauncher\Modules
					moduleFullName = D:\Arcade\RocketLauncher\Modules\PCSX2\PCSX2.ahk
					moduleName = PCSX2
					modulePath = D:\Arcade\RocketLauncher\Modules\PCSX2
					moduleExtension = ahk
					moduleExtensionsPath = D:\Arcade\RocketLauncher\Module Extensions
					libPath = D:\Arcade\RocketLauncher\Lib
					7zEnabled = true
					7zPath = D:\Arcade\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Arcade\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = D:\Arcade\cache
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = Pause
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Arcade\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes = {F1 down}{F1 up}
					pauseLoadStateKeyCodes = {F1 down}{F1 up}
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Arcade\Tools\Xpadder\xpadder.exe
					joyToKeyFullPath = C:\Windows\Utilities\VJoy\VJoy.exe
					keymapperProfilePath = D:\Arcade\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = ahk
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Rock Candy Gamepad for Xbox 360)|Controller (XBOX 360 For Windows)|Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit = Controller (Rock Candy Gamepad for Xbox 360)|Controller (Xbox 360 Wireless Receiver for Windows)
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Sony Playstation 2
					xPadderSystemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Sony Playstation 2\_Default
					emuProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Sony Playstation 2\PCSX2
					romProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Sony Playstation 2\Castlevania - Lament of Innocence (USA)
					RocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Arcade\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Arcade\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Sony Playstation 2
					ahkEmuProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Sony Playstation 2\PCSX2
					ahkRomProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Sony Playstation 2\Castlevania - Lament of Innocence (USA)
					ahkRocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Arcade\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Arcade\RocketLauncher\Lib\User Fade Animations.ini
08:26:16:631 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
08:26:16:634 | RL |     INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
08:26:16:636 | RL |     INFO  | +16    | BuildScript - Loaded Pause Init.ahk scripts
08:26:16:638 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
08:26:16:640 | RL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
08:26:16:642 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
08:26:16:644 | RL |     INFO  | +0     | BuildScript - Validating module
08:26:16:648 | RL |     INFO  | +0     | BuildScript - Validation complete
08:26:16:650 | RL |     INFO  | +15    | BuildScript - Module:
					MEmu = PCSX2
					MEmuV = Git-20150807
					MURL = http://pcsx2.net/
					MAuthor = djvj
					MVersion = 2.1.5
					MCRC = 3747C6AD
					iCRC = 776E3DD9
					MID = 635038268913291718
					MSystem = "Sony PlayStation 2"
					; Notes:
					; This module has many settings that can be controlled via RocketLauncherUI
					; If you want to customize settings per game, add the game to the module's ini using RocketLauncherUI
					; If you use Daemon Tools, make sure you have a SCSI virtual drive setup. Not a DT one.
					; Tested Virtual Drive support with the cdvdGigaherz CDVD plugin. Make sure you set it to use your SCSI Virtual Drive letter.
					; Module will set the CdvdSource to Plugin or Iso depending on if you have Virtual Drive enabled or not.
					; If you have any problems closing the emulator, make sure noGUI module setting in RocketLauncherUI is set to default or false.
					; Per-game memory cards
					; This module supports per-game memory cards to prevent them from ever becoming full
					; To use this feature, set the PerGameMemoryCards to true in RocketLauncherUI
					; You need to create a default blank memory card in the path you have defined in pcsx's ini found in section [Folders], key MemoryCards.
					; Make sure one of the current memory cards are blank, then copy it in that folder and rename it to "default.ps2". The module will copy this file to a romName.ps2 for each game launched.
					; The module will only insert memory cards into Slot 1. So save your games there.
					; Linuz cdvd plugin stores its settings in the registry @ HKEY_CURRENT_USER\Software\PS2Eplugin\CDVD\CDVDiso
					; Run pcsx2 with the --help option to see current CLI parameters
					; Known CLI options not currently supported by this module:
					;  --console        	forces the program log/console to be visible
					;  --portable       	enables portable mode operation (requires admin/root access)
					;  --elf=<str>      	executes an ELF image
					;  --forcewiz       	forces PCSX2 to start the First-time Wizard
					StartModule()
					BezelGUI()
					FadeInStart()
					; PCSX2_ui.ini = default ini that contains memory card info and general settings
					If FileExist(emuPath . "\portable.ini") {	; portable install
						Log("Module - PCSX2 is operating in a portable mode")
						pcsx2IniFile := CheckFile(emuPath . "\inis\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.")
					} Else {	; default not portable install
						Log("Module - PCSX2 is operating in a standard installation mode")
						RegRead, pcsx2IniFolder, HKCU, Software\PCSX2, SettingsFolder
						pcsx2IniFile := CheckFile(pcsx2IniFolder . "\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.")
					; global settings
					noGUI := IniReadCheck(settingsFile, "Settings", "noGUI","false",,1)	; disables display of the gui while running games
					fullboot := IniReadCheck(settingsFile, "Settings", "fullboot","false",,1)	; disables the quick boot feature, forcing you to sit through the PS2 startup splash screens
					perGameMemCards := IniReadCheck(settingsFile, "Settings", "PerGameMemoryCards","true",,1)
					hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)	; Hides console window from view if it shows up
					cfgPath := IniReadCheck(settingsFile, "Settings", "cfgpath", emuPath . "\Game Configs",,1)	; specifies the config folder; applies to pcsx2 + plugins
					autoCreateINIDir := IniReadCheck(settingsFile, "Settings", "AutoCreateINIDir","false",,1)  ; Enables the module to auto-create of per game ini files and directories
					defaultINISPath := IniReadCheck(settingsFile, "Settings", "DefaultINISPath",,,1)  ; Path to default INIS folder of PCSX2.
					gs := IniReadCheck(settingsFile, "Settings|" . romName, "gs",,,1)	; override for the GS plugin
					pad := IniReadCheck(settingsFile, "Settings|" . romName, "pad",,,1)	; override for the PAD plugin
					spu2 := IniReadCheck(settingsFile, "Settings|" . romName, "spu2",,,1)	; override for the SPU2 plugin
					cdvd := IniReadCheck(settingsFile, romName, "cdvd",,,1)	; override for the CDVD plugin
					usb := IniReadCheck(settingsFile, "Settings|" . romName, "usb",,,1)	; override for the USB plugin
					fw := IniReadCheck(settingsFile, "Settings|" . romName, "fw",,,1)	; override for the FW plugin
					dev9 := IniReadCheck(settingsFile, "Settings|" . romName, "dev9",,,1)	; override for the DEV9 plugin
					vdOveride := IniReadCheck(settingsFile, romName, "VDOveride",,,1)
					nohacks := IniReadCheck(settingsFile, romName, "nohacks","false",,1)	; disables all speedhacks
					gamefixes := IniReadCheck(settingsFile, romName, "gamefixes",,,1)	; Enable specific gamefixes for this session. Use the specified comma or pipe-delimited list of gamefixes: VuAddSub,VuClipFlag,FpuCompare,FpuMul,FpuNeg,EETiming,SkipMpeg,OPHFlag,DMABusy,VIFFIFO,VI,FMVinSoftware
					cfgPath := GetFullName(cfgPath)
					IfNotExist % cfgPath
						FileCreateDir, %cfgPath%	; create the cfg folder if it does not exist
					; Create INIs subfolder for the game if it does not exist and if AutoCreateINIDir is true
					If (autoCreateINIDir = "true") {
						perINIPath := cfgPath . "\" . romName
						Log("Module - PerGameIni - perINIPath = " . perINIPath,4)
						If !FileExist(perINIPath) {
							If (defaultINISPath != "") {
								Log("Module - PerGameIni - perINIPath does not exist.  So we will create it at " . PerINIPath,4)
								FileCreateDir, %perINIPath%
								Log("Module - PerGameIni - Now to copy the ini files from " . defaultINISPath . " to " . perINIPath . ".",4)
								FileCopy, %defaultINISPath%\*.ini, %perINIPath%
							} Else {
								Log("Module - PerGameIni - Now to copy the ini files from " . emuPath . "\inis" . " to " . perINIPath . ".",4)
								FileCopy, %emuPath%\inis\*.ini, %perINIPath%
					BezelStart()
					Fullscreen := If Fullscreen = "true" ? " --fullscreen" : ""
					noGUI := If noGUI = "true" ? " --nogui" : ""
					If (noGUI != "")
						Log("Module - noGUI is set to true, THIS MAY PREVENT PCSX2 FROM CLOSING PROPERLY. If you have any issues, set it to false or default in RocketLauncherUI.",2)
					fullboot := If fullboot = "true" ? " --fullboot" : ""
					nohacks := If nohacks = "true" ? " --nohacks" : ""
					gamefixes := If gamefixes ? " --gamefixes=" . gamefixes : ""
					gs := If gs ? " --gs=""" . GetFullName(gs) . """" : ""
					pad := If pad ? " --pad=""" . GetFullName(pad) . """" : ""
					spu2 := If spu2 ? " --spu2=""" . GetFullName(spu2) . """" : ""
					usb := If usb ? " --usb=""" . GetFullName(usb) . """" : ""
					fw := If fw ? " --fw=""" . GetFullName(fw) . """" : ""
					dev9 := If dev9 ? " --dev9=""" . GetFullName(dev9) . """" : ""
					cfgRomPath := cfgPath . "\" . romName
					cfgPathCLI := If FileExist(cfgRomPath) ? " --cfgpath=""" . GetFullName(cfgRomPath) . """" : ""
					; Specify what main ini PCSX2 should use
					If (cfgPathCLI && FileExist(cfgRomPath . "\PCSX2_ui.ini")) {
						;We can't set both cfgpath and cfg CLI switches, so if only PCSX2_ui.ini file exists we use cfg otherwise we use cfgpath
						;--cfg specifies a custom configuration file to use instead of PCSX2.ini (does not affect plugins)
						filecount := 0
						Loop, %cfgRomPath%\*.ini
							filecount++
						If (filecount == 1)
							;Only PCSX2_ui.ini found
							pcsx2IniFile := cfgRomPath . "\PCSX2_ui.ini"
							Log("Module - Found a game-specific PCSX2_ui.ini in the cfgPath. Telling PCSX2 to use this one instead: " . pcsx2IniFile)
							cfg := " --cfg=""" . pcsx2IniFile . """"
							cfgPathCLI := ""
					Log("Module - " . (If cfgPathCLI != "" ? "Setting PCSX2's config path to """ . cfgRomPath . """" : "Using PCSX2's default configuration folder: """ . emuPath . "\inis"""))
					; Memory Cards
					If perGameMemCards = true
					{	IniRead, currentMemCard1, %pcsx2IniFile%, MemoryCards, Slot1_Filename
						IniRead, memCardPath, %pcsx2IniFile%, Folders, MemoryCards	; folder where memory cards are stored
						StringLeft, memCardPathLeft, memCardPath, 3
						memCardPathIsAbsolute := If (RegExMatch(memCardPathLeft, "[a-zA-Z]:\\") && (StrLen(memCardPath) >= 3))	; this is 1 only when path looks like this "C:\"
						memCardPath := If memCardPathIsAbsolute ? memCardPath : emuPath . "\" . memCardPath	; if only a folder name is defined for the memory card path, tack on the emuPath to find the memory cards, otherwise leave the full path as is
						defaultMemCard := memCardPath . "\default.ps2"	; defining default blank memory card for slot 1
						Log("Module - Default memory card for Slot 1 should be: " . defaultMemCard,4)
						romMemCard1 := memCardPath . "\" . romName . ".ps2"	; defining name for rom's memory card for slot 1
						Log("Module - Rom memory card for Slot 1 should be: " . romMemCard1,4)
						Log("Module - Current memory card inserted in PCSX2's ini in Slot 1 is: " . currentMemCard1)
						If (currentMemCard1 != romName . ".ps2") {	; if current memory card in slot 1 does not match this romName, switch to one that does if exist or load a default one
							IfNotExist, %romMemCard1%	; first check if romName.ps2 memory card exists
								IfNotExist, %defaultMemCard%
									Log("Module - A default memory card for Slot 1 was not found in """ . memCardPath . """. Please create an empty memory card called ""default.ps2"" in this folder for per-game memory card support.",3)
								Else {
									FileCopy, %defaultMemCard%, %romMemCard1%	; create a new blank memory card for this game
									Log("Module - Creating a new blank memory card for this game in Slot 1: " . romMemCard1)
							IniWrite, %romName%.ps2, %pcsx2IniFile%, MemoryCards, Slot1_Filename	; update the ini to use this rom's card
							Log("Module - Switched memory card in Slot 1 to: " . romMemCard1)
					hideEmuObj := Object("ahk_class wxWindowNR",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					pcsx2Ini := LoadProperties(pcsx2IniFile)	; load the config into memory
					dvdSource := ReadProperty(pcsx2Ini,"CdvdSource")	; read value
					; Mount the CD using a Virtual Drive
					If vdOveride	; this allows per-game Virtual Drive support because some games boot to black when Virtual Drive is enabled
						vdEnabled := vdOveride
					If (vdEnabled = "true" && InStr(".mds|.mdx|.b5t|.b6t|.bwt|.ccd|.cue|.isz|.nrg|.cdi|.iso|.ape|.flac", romExtension)) {	; if Virtual Drive is enabled and using an image type Virtual Drive can load
						If !cdvd {
							vdCDVDPlugin := IniReadCheck(settingsFile, "Settings", "VD_CDVD_Plugin",,,1)
							If vdCDVDPlugin
								cdvd := vdCDVDPlugin
						cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : ""
						If dvdSource != Plugin
						{	Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can read from Virtual Drive.")
							WriteProperty(pcsx2Ini,"CdvdSource","Plugin")	; write a new value to the pcsx2IniFile
							SaveProperties(pcsx2IniFile,pcsx2Ini)	; save pcsx2IniFile to disk
						VirtualDrive("mount",romPath . "\" . romName . romExtension)
						HideEmuStart()
						errLvl := Run(executable . " --usecd" . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath,  "UseErrorLevel")
						usedVD = 1	; tell the rest of the script to use VD methods
					} Else If romExtension in .iso,.mdf,.nrg,.bin,.img,.gz	; the only formats PCSX2 supports loading directly
						If !cdvd {
							imageCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Image_CDVD_Plugin",,,1)
							If imageCDVDPlugin
								cdvd := imageCDVDPlugin
						If dvdSource != Iso
						{	Log("Module - CdvdSource was not set to ""Iso"", changing it so PCSX2 can launch this " . romExtension . " image directly")
							WriteProperty(pcsx2Ini,"CdvdSource","Iso")	; write a new value to the pcsx2IniFile
						HideEmuStart()
						errLvl := Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath,  "UseErrorLevel")
					} Else If romExtension in .bz2	; special case format that requires plugin mode and pcsx2 loads it directly
						If !cdvd {
							linuzCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Linuz_CDVD_Plugin",,,1)
							If linuzCDVDPlugin
								cdvd := linuzCDVDPlugin
						If dvdSource != plugin
						{	Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can launch this " . romExtension . " image directly")
						oldHex := ReadReg("IsoFile")	; read last used bz2 image
						newHex := StrToHex(romPath . "\" . romName . romExtension)	; convert new bz2 image path to hex
						i := 512 - StrLen(newHex)	; get total amount of 0's to add to end of hex to make it 512 bytes
						Loop, %i%
							newHex := newHex . "0"	; add required bytes to end
						If (oldHex != newHex) {
							Log("Module - Writing new bz2 path to registry",4)
							WriteReg("IsoFile", newHex)	; write new bz2 path to registry
						HideEmuStart()
					} Else
						ScriptError("You are trying to run a rom type of """ . romExtension . """ but PCSX2 only supports loading iso|mdf|nrg|bin|img|gz directly. Please turn on Virtual Drive and/or 7z support or put ""cue"" last in your rom extensions for " . MEmu . " instead.")
					If errLvl
						ScriptError("Error launching emulator, closing script.")
					WinWait("ahk_class wxWindowNR",,, "PCSX2")
					WinWaitActive("ahk_class wxWindowNR",,, "PCSX2")
					BezelDraw()
					If hideConsole = true
						SetTimer, HideConsole, 10
					SetTitleMatchMode 2 ;Wrong window might be detected in the next loop if we only use the class name for WinGetTitle so we will add fps to it
					Loop { ; looping until pcsx2 is done loading game
						; tooltip, loop %A_Index%,0,0
						Sleep, 200
						WinGetTitle, winTitle, fps ahk_class wxWindowNR,, PCSX2 ; excluding the title of the GUI window so we can read the title of the game window instead
						Log("Detected Window Title is " . winTitle,4)
						StringSplit, winTextSplit, winTitle, |, %A_Space%
						If (winTextSplit10 != "") ; 10th position in the array is empty until game actually starts
							break
						If A_Index > 150	; after 30 seconds, error out
							ScriptError("There was an error detecting when PCSX2 finished loading your game. Please report this so the module can be fixed.")
					HideEmuEnd()
					FadeInExit()
					If usedVD
						VirtualDrive("unmount")
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					ReadReg(var1) {
						regValue := RegRead("HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1)
						Return %regValue%
					WriteReg(var1, var2, ValueType="REG_BINARY") {
						RegWrite(ValueType, "HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1, var2)
					StrToHex(S) {
						Return S="" ? "":Chr((*&S>>4)+48) Chr((x:=*&S&15)+48+(x>9)*7) StrToHex(SubStr(S,2))
					MultiGame:
						; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = "  . mgRomName
						; Unmount the CD from Virtual Drive
						If usedVD
						Sleep, 500	; Required to prevent your Virtual Drive from bugging
						; Mount the CD using Virtual Drive
						If usedVD
							VirtualDrive("mount",selectedRom)
					Return
					HideConsole:
						hideConsoleTimer++
						IfWinExist, Booting ahk_class wxWindowNR
						{	Log("Module - HideConsole - Console window found, hiding it out of view.")
							WinSet, Transparent, 0, Booting ahk_class wxWindowNR,,fps:,fps:	; hiding the console window
							WinSet, Transparent, 0, PCSX2 ahk_class wxWindowNR,,fps:,fps:	; hiding the GUI window with the menubar
							SetTimer, HideConsole, Off
						} Else If hideConsoleTimer >= 200
					Return
					CloseProcess:
						FadeOutStart()
						WinMenuSelectItem, PCSX2 ahk_class wxWindowNR,, System, Pause
						WinClose("PCSX2 ahk_class wxWindowNR") ; sending command to the GUI window to properly close the entire emu
					Return
08:26:16:663 | RL |     INFO  | +0     | BuildScript - Loaded Pause scripts
08:26:16:667 | RL |     INFO  | +16    | BuildScript - Loaded Multi-Player scripts
08:26:16:671 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
08:26:16:674 | RL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
08:26:16:696 | RL |     INFO  | +15    | BuildScript - Finished injecting functions into module
08:26:16:700 | RL |     INFO  | +16    | Main - Module is built
08:26:16:707 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\AutoHotkey.dll exists
08:26:16:710 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			12/28/2014 - 12:53:35 PM
08:26:16:719 | RL |     INFO  | +16    | Main - Hiding taskbar
08:26:16:952 | RL |     INFO  | +234   | Main - Running module
08:26:16:954 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
08:26:17:126 | MD |     INFO  | +N/A   | Module initialized
08:26:17:130 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:26:17:154 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
08:26:17:163 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:26:17:182 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Post loop 2 check
08:26:17:185 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
08:26:17:189 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:26:17:192 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:26:17:195 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 not in TableKeyGroups ~Esc,
08:26:17:219 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 1 check
08:26:17:249 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
08:26:17:279 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
08:26:17:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:26:17:345 | MD |   DEBUG1  | +63    | fadeInTransitionAnimation: DefaultAnimateFadeIn
08:26:17:349 | MD |   DEBUG1  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
08:26:17:375 | MD |   DEBUG1  | +31    | fadeLyr3Animation: DefaultFadeAnimation
08:26:17:405 | MD |   DEBUG1  | +31    | fadeLyr37zAnimation: DefaultFadeAnimation
08:26:17:409 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:26:17:413 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Pause not in TableKeyGroups ~Esc,~1joy7,
08:26:17:455 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 1 check
08:26:17:485 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
08:26:17:515 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Pause" to call label: "TogglePauseMenuStatus"
08:26:17:518 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:26:17:522 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:26:17:545 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1joy7,~Pause,
08:26:17:553 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:26:17:575 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Post loop 2 check
08:26:17:578 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
08:26:17:585 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:26:17:605 | MD |     INFO  | +31    | StartModule - Started
08:26:17:608 | MD |     INFO  | +0     | StartModule - MEmu: PCSX2
					MEmuV: Git-20150807
					MURL: http://pcsx2.net/
					MAuthor: djvj
					MVersion: 2.1.5
					MCRC: 3747C6AD
					iCRC: 776E3DD9
					MID:
					MSystem: "Sony PlayStation 2"
08:26:17:611 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Sony Playstation 2"
08:26:17:634 | MD |     INFO  | +31    | PluginInit - Started
08:26:17:641 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
08:26:17:644 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\Databases\Sony Playstation 2\Sony Playstation 2.xml exists
08:26:17:674 | MD |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			158643 bytes
					Created:			1/10/2014 - 5:42:43 PM
					Modified:			9/7/2015 - 11:24:36 AM
08:26:17:702 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
08:26:17:728 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Found "Game Name" in the database!
08:26:17:731 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
08:26:17:734 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Castlevania - Lament of Innocence (USA)"
08:26:17:758 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Cloneof
08:26:17:798 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Cloneof
08:26:17:828 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Manufacturer
08:26:17:856 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Manufacturer
08:26:17:906 | MD |   DEBUG1  | +47    | BuildDatabaseTable - Searching database for: Year
08:26:17:909 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
08:26:17:946 | MD |   DEBUG1  | +47    | BuildDatabaseTable - Searching database for: Genre
08:26:17:976 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Genre
08:26:17:016 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Rating
08:26:18:044 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Could not find: Rating
08:26:18:086 | MD |   DEBUG2  | +46    | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value:
08:26:18:095 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
08:26:18:099 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
08:26:18:125 | MD |   DEBUG1  | +32    | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\Media\Sony Playstation 2\Images\Wheel\Castlevania - Lament of Innocence (USA).png
08:26:18:165 | MD |   DEBUG1  | +46    | BuildAssetsTable - Searching for a System Logo: D:\Arcade\Media\Main Menu\Images\Wheel\Sony Playstation 2.png
08:26:18:172 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Arcade\Media\Sony Playstation 2\Images\Wheel\Castlevania - Lament of Innocence (USA).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Arcade\Media\Main Menu\Images\Wheel\Sony Playstation 2.png | Asset Extension1:  png | Asset Type1:  system
08:26:18:175 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:26:18:178 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
08:26:18:215 | MD |   DEBUG1  | +47    | BuildAssetsTable - Searching for a Artwork1: D:\Arcade\Media\Sony Playstation 2\Images\Artwork1\Castlevania - Lament of Innocence (USA).png
08:26:18:245 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Box Art: D:\Arcade\Media\Sony Playstation 2\Images\Artwork2\Castlevania - Lament of Innocence (USA).png
08:26:18:248 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Arcade\Media\Sony Playstation 2\Images\Artwork3\Castlevania - Lament of Innocence (USA).png
08:26:18:252 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: D:\Arcade\Media\Sony Playstation 2\Images\Artwork4\Castlevania - Lament of Innocence (USA).png
08:26:18:255 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Arcade\Media\Sony Playstation 2\Images\Letters
08:26:18:345 | MD |   DEBUG1  | +94    | BuildAssetsTable - Searching for a Other: D:\Arcade\Media\Sony Playstation 2\Images\Other
08:26:18:371 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Cartridge | Asset Path1:  D:\Arcade\Media\Sony Playstation 2\Images\Artwork3\Castlevania - Lament of Innocence (USA).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Letters | Asset Path1:  D:\Arcade\media\Sony Playstation 2\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Arcade\media\Sony Playstation 2\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Arcade\media\Sony Playstation 2\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Arcade\media\Sony Playstation 2\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Arcade\media\Sony Playstation 2\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Arcade\media\Sony Playstation 2\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Arcade\media\Sony Playstation 2\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Arcade\media\Sony Playstation 2\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Arcade\media\Sony Playstation 2\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Arcade\media\Sony Playstation 2\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Arcade\media\Sony Playstation 2\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Arcade\media\Sony Playstation 2\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Arcade\media\Sony Playstation 2\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Arcade\media\Sony Playstation 2\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Arcade\media\Sony Playstation 2\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Arcade\media\Sony Playstation 2\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Arcade\media\Sony Playstation 2\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Arcade\media\Sony Playstation 2\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Arcade\media\Sony Playstation 2\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Arcade\media\Sony Playstation 2\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Arcade\media\Sony Playstation 2\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Arcade\media\Sony Playstation 2\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Arcade\media\Sony Playstation 2\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Arcade\media\Sony Playstation 2\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Arcade\media\Sony Playstation 2\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Arcade\media\Sony Playstation 2\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Arcade\media\Sony Playstation 2\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Arcade\media\Sony Playstation 2\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Arcade\media\Sony Playstation 2\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Arcade\media\Sony Playstation 2\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Arcade\media\Sony Playstation 2\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Arcade\media\Sony Playstation 2\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Arcade\media\Sony Playstation 2\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Arcade\media\Sony Playstation 2\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Arcade\media\Sony Playstation 2\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Arcade\media\Sony Playstation 2\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Arcade\media\Sony Playstation 2\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Arcade\media\Sony Playstation 2\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Arcade\media\Sony Playstation 2\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Arcade\media\Sony Playstation 2\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
08:26:18:399 | MD |   DEBUG1  | +31    | BuildAssetsTable - Ended
08:26:18:402 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
08:26:18:449 | MD |   DEBUG1  | +47    | BuildAssetsTable - Searching for a MP4 Game Video: D:\Arcade\Media\Sony Playstation 2\Video\Castlevania - Lament of Innocence (USA).*
08:26:18:569 | MD |   DEBUG1  | +125   | BuildAssetsTable - Searching for a FLV Game Video: D:\Arcade\Media\Main Menu\Video\Sony Playstation 2.*
08:26:18:573 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  D:\Arcade\Media\Main Menu\Video\Sony Playstation 2.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Arcade\Media\Sony Playstation 2\Video\Castlevania - Lament of Innocence (USA).mp4 | Asset Extension1:  mp4 | Asset Type1:  game
08:26:18:576 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:26:18:580 | MD |     INFO  | +0     | PluginInit - Ended
08:26:18:583 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Castlevania - Lament of Innocence (USA)
08:26:18:609 | MD |     INFO  | +31    | Hiding mouse cursor
08:26:18:670 | MD |   DEBUG2  | +63    | XHotkeyTableCreation - Started
08:26:18:674 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,
08:26:18:677 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:26:18:694 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
08:26:18:698 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
08:26:18:701 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:26:18:729 | MD |     INFO  | +31    | StartModule - Ended
08:26:18:732 | MD |   DEBUG1  | +0     | FadeInStart - Started
08:26:18:736 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:26:18:739 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Pause is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:26:18:759 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 10 check
08:26:18:762 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Pause"
08:26:18:765 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
08:26:18:789 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~Pause"
08:26:18:839 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 12 check
08:26:18:842 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:26:18:871 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:26:18:875 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:26:18:879 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
08:26:18:901 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
08:26:18:951 | MD |   DEBUG2  | +46    | XHotkeyTableCreation - Post loop 11 check
08:26:18:954 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
08:26:18:991 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 12 check
08:26:18:021 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Ended
08:26:19:057 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Started
08:26:19:064 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:26:19:067 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
08:26:19:087 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 11 check
08:26:19:137 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7"
08:26:19:142 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
08:26:19:177 | MD |   DEBUG2  | +46    | XHotkeyTableCreation - Ended
08:26:19:209 | MD |   DEBUG1  | +32    | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
08:26:19:249 | MD |   DEBUG2  | +31    | FadeInStart - Fade screen scale factor: X=0.750000, Y= 0.833333
08:26:19:253 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\Castlevania - Lament of Innocence (USA)\Layer 1*.*
08:26:19:273 | MD |   DEBUG1  | +31    | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Horizontal\Layer 1*.*
08:26:19:276 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 1*.*
08:26:19:280 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Layer 1*.*
08:26:19:285 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.*
08:26:19:303 | MD |   DEBUG1  | +31    | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.png
08:26:19:307 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1.png
08:26:19:310 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.gif
08:26:19:333 | MD |   DEBUG1  | +31    | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.tif
08:26:19:336 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.bmp
08:26:19:340 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.jpg
08:26:19:343 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1.png
08:26:19:346 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\Castlevania - Lament of Innocence (USA)\Extra Layer 1 - Console*.*
08:26:19:373 | MD |   DEBUG1  | +32    | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Horizontal\Extra Layer 1 - Console*.*
08:26:19:413 | MD |   DEBUG1  | +46    | GetFadePicFile - Checking if any Fade Extra Layer 1 - Console images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console*.*
08:26:19:443 | MD |   DEBUG1  | +32    | GetFadePicFile - Looking for Fade Extra Layer 1 - Console pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console*.png
08:26:19:483 | MD |   DEBUG1  | +31    | GetFadePicFile - Found Fade Extra Layer 1 - Console pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console.png
08:26:19:523 | MD |   DEBUG1  | +47    | GetFadePicFile - Looking for Fade Extra Layer 1 - Console pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console*.gif
08:26:19:571 | MD |   DEBUG1  | +46    | GetFadePicFile - Looking for Fade Extra Layer 1 - Console pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console*.tif
08:26:19:576 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Extra Layer 1 - Console pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console*.bmp
08:26:19:601 | MD |   DEBUG1  | +32    | GetFadePicFile - Looking for Fade Extra Layer 1 - Console pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console*.jpg
08:26:19:608 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Extra Layer 1 - Console.png
08:26:19:854 | MD |     INFO  | +249   | DefaultAnimateFadeIn - Started, direction is: in
08:26:19:856 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
08:26:20:391 | MD |     INFO  | +531   | DefaultAnimateFadeIn - Ended
08:26:20:450 | MD |   DEBUG1  | +62    | FadeInStart - Ended
08:26:20:454 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
08:26:20:477 | MD |     INFO  | +31    | StartGlobalUserFeatures - Ending
08:26:20:527 | MD |   DEBUG1  | +47    | CoverFE - Started
08:26:20:533 | MD |   DEBUG1  | +0     | CoverFE - Ended
08:26:20:567 | MD |     INFO  | +47    | Module - PCSX2 is operating in a portable mode
08:26:20:617 | MD |     INFO  | +47    | CheckFile - Checking if D:\Arcade\emulators\PCSX2\inis\PCSX2_ui.ini exists
08:26:20:621 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4558 bytes
					Modified:			7/1/2017 - 8:23:08 AM
08:26:20:625 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
08:26:20:647 | MD |     INFO  | +31    | Module Setting - [Settings] - noGUI: false
08:26:20:651 | MD |     INFO  | +0     | Module Setting - [Settings] - fullboot: false
08:26:20:654 | MD |     INFO  | +0     | Module Setting - [Settings] - PerGameMemoryCards: true
08:26:20:677 | MD |     INFO  | +31    | Module Setting - [Settings] - HideConsole: true
08:26:20:681 | MD |     INFO  | +0     | Module Setting - [Settings] - cfgpath: D:\Arcade\emulators\PCSX2\Game Configs
08:26:20:684 | MD |     INFO  | +0     | Module Setting - [Settings] - AutoCreateINIDir: false
08:26:20:687 | MD |     INFO  | +0     | Module Setting - [Settings] - DefaultINISPath:
08:26:20:712 | MD |     INFO  | +31    | Module Setting - [Settings] - gs:
08:26:20:762 | MD |     INFO  | +47    | Module Setting - [Castlevania - Lament of Innocence (USA)] - gs:
08:26:20:802 | MD |     INFO  | +47    | Module Setting - [Settings] - pad:
08:26:20:810 | MD |     INFO  | +0     | Module Setting - [Castlevania - Lament of Innocence (USA)] - pad:
08:26:20:834 | MD |     INFO  | +31    | Module Setting - [Settings] - spu2:
08:26:20:841 | MD |     INFO  | +0     | Module Setting - [Castlevania - Lament of Innocence (USA)] - spu2:
08:26:20:845 | MD |     INFO  | +0     | Module Setting - [Castlevania - Lament of Innocence (USA)] - cdvd:
08:26:20:864 | MD |     INFO  | +31    | Module Setting - [Settings] - usb:
08:26:20:867 | MD |     INFO  | +0     | Module Setting - [Castlevania - Lament of Innocence (USA)] - usb:
08:26:20:874 | MD |     INFO  | +0     | Module Setting - [Settings] - fw:
08:26:20:877 | MD |     INFO  | +0     | Module Setting - [Castlevania - Lament of Innocence (USA)] - fw:
08:26:20:898 | MD |     INFO  | +31    | Module Setting - [Settings] - dev9:
08:26:20:948 | MD |     INFO  | +47    | Module Setting - [Castlevania - Lament of Innocence (USA)] - dev9:
08:26:20:953 | MD |     INFO  | +0     | Module Setting - [Castlevania - Lament of Innocence (USA)] - VDOveride:
08:26:20:978 | MD |     INFO  | +31    | Module Setting - [Castlevania - Lament of Innocence (USA)] - nohacks: false
08:26:20:008 | MD |     INFO  | +32    | Module Setting - [Castlevania - Lament of Innocence (USA)] - gamefixes:
08:26:21:058 | MD |     INFO  | +47    | Module - Using PCSX2's default configuration folder: "D:\Arcade\emulators\PCSX2\inis"
08:26:21:105 | MD |   DEBUG1  | +46    | Module - Default memory card for Slot 1 should be: D:\Arcade\emulators\PCSX2\memcards\default.ps2
08:26:21:145 | MD |   DEBUG1  | +47    | Module - Rom memory card for Slot 1 should be: D:\Arcade\emulators\PCSX2\memcards\Castlevania - Lament of Innocence (USA).ps2
08:26:21:154 | MD |     INFO  | +0     | Module - Current memory card inserted in PCSX2's ini in Slot 1 is: Castlevania - Curse of Darkness (USA).ps2
08:26:21:195 | MD |    ERROR  | +47    | Module - A default memory card for Slot 1 was not found in "D:\Arcade\emulators\PCSX2\memcards". Please create an empty memory card called "default.ps2" in this folder for per-game memory card support.
08:26:21:229 | MD |     INFO  | +31    | Module - Switched memory card in Slot 1 to: D:\Arcade\emulators\PCSX2\memcards\Castlevania - Lament of Innocence (USA).ps2
08:26:21:276 | MD |     INFO  | +47    | 7z - Started, received D:\Arcade\Sony Playstation 2\roms\Castlevania - Lament of Innocence (USA).7z. If rom is an archive, it will extract to D:\Arcade\cache
08:26:21:316 | MD |   DEBUG1  | +47    | 7z - Using Standard method to extract this rom
08:26:21:319 | MD |   DEBUG1  | +0     | 7z - ".7z" found in .zip,.rar,.7z,.lzh,.gzip,.tar
08:26:21:323 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\Sony Playstation 2\roms\Castlevania - Lament of Innocence (USA).7z exists
08:26:21:381 | MD |   DEBUG1  | +62    | CheckFile - Attributes:
					File Size:			2143591344 bytes
					Created:			6/24/2015 - 4:31:29 PM
					Modified:			7/12/2015 - 6:01:02 PM
08:26:21:522 | MD |     INFO  | +141   | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "Castlevania - Lament of Innocence (USA).iso"
08:26:21:554 | MD |   DEBUG1  | +31    | 7z - Invoked COM Object, ROM extracted size: 3027042304 bytes
08:26:21:556 | MD |   DEBUG1  | +0     | 7z - Checking if this archive has already been extracted in D:\Arcade\cache\Castlevania - Lament of Innocence (USA)
08:26:21:560 | MD |   DEBUG1  | +0     | 7z - File does not already exist in D:\Arcade\cache\Castlevania - Lament of Innocence (USA), proceeding to extract it.
08:26:21:563 | MD |   DEBUG1  | +0     | 7z - File found in archive
08:26:21:584 | MD |     INFO  | +31    | 7z - Extracted path of rom will be 99 in length and within the 255 character limit.
08:26:21:587 | MD |     INFO  | +0     | 7z - The 7zExtractPath has 185343 MB of free space which is enough to extract this game: 3027 MB
08:26:21:590 | MD |   DEBUG1  | +0     | 7z - FadeIn is true, starting timer to update Layer 3 animation with 7z.exe statistics
08:26:21:614 | MD |     INFO  | +31    | DefaultFadeAnimation - Started
08:26:21:619 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\Castlevania - Lament of Innocence (USA)\Info Bar*.*
08:26:21:623 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Horizontal\Info Bar*.*
08:26:21:644 | MD |   DEBUG1  | +31    | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Info Bar*.*
08:26:21:697 | MD |   DEBUG1  | +47    | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
08:26:21:700 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.*
08:26:21:704 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.png
08:26:21:727 | MD |   DEBUG1  | +31    | GetFadePicFile - Found Fade Info Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar.png
08:26:21:731 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
08:26:21:734 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
08:26:21:757 | MD |   DEBUG1  | +32    | GetFadePicFile - Looking for Fade Info Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
08:26:21:761 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
08:26:21:764 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar.png
08:26:21:817 | MD |   DEBUG1  | +62    | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\Castlevania - Lament of Innocence (USA)\Layer 3*.*
08:26:21:821 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Horizontal\Layer 3*.*
08:26:21:824 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3*.*
08:26:21:827 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3*.png
08:26:21:847 | MD |   DEBUG1  | +31    | GetFadePicFile - Found Fade Layer 3 pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3.png
08:26:21:877 | MD |   DEBUG1  | +31    | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3*.gif
08:26:21:913 | MD |   DEBUG1  | +32    | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3*.tif
08:26:21:917 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3*.bmp
08:26:21:921 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3*.jpg
08:26:21:943 | MD |     INFO  | +31    | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Layer 3.png
08:26:21:952 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Progress Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\Castlevania - Lament of Innocence (USA)\Progress Bar*.*
08:26:21:973 | MD |   DEBUG1  | +31    | GetFadePicFile - Checking if any Fade Progress Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Horizontal\Progress Bar*.*
08:26:21:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Progress Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\Sony Playstation 2\_Default\Progress Bar*.*
08:26:21:003 | MD |   DEBUG1  | +31    | GetFadePicFile - Checking if any Fade Progress Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Progress Bar*.*
08:26:22:053 | MD |   DEBUG1  | +47    | GetFadePicFile - Checking if any Fade Progress Bar images exist in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar*.*
08:26:22:056 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Progress Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar*.png
08:26:22:080 | MD |   DEBUG1  | +31    | GetFadePicFile - Found Fade Progress Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar.png
08:26:22:087 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Progress Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar*.gif
08:26:22:090 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Progress Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar*.tif
08:26:22:093 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Progress Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar*.bmp
08:26:22:120 | MD |   DEBUG1  | +31    | GetFadePicFile - Looking for Fade Progress Bar pic: D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar*.jpg
08:26:22:160 | MD |     INFO  | +47    | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\_Default\Progress Bar.png
08:26:22:259 | MD |     INFO  | +94    | DefaultFadeAnimation - Playing D:\Arcade\RocketLauncher\Media\Fade\_Default\7z extracting.mp3
08:26:22:488 | MD |   DEBUG1  | +234   | FadeInDelay - Started
08:26:22:586 | MD |   DEBUG1  | +93    | DefaultFadeAnimationLoop - Starting 7zTimeout Timer
08:26:23:116 | MD |   DEBUG1  | +531   | 7zTimeout - 7z.exe is no longer running
08:26:25:516 | MD |   DEBUG1  | +2402  | FadeInDelay - Ended
08:26:25:519 | MD |     INFO  | +0     | DefaultFadeAnimation - Ended
08:26:25:523 | MD |   DEBUG1  | +0     | 7z - Logging is debug or higher, dumping 7z Extraction info to log
08:26:25:526 | MD |   DEBUG1  | +0     | 7z - Starting 7z extraction of D:\Arcade\Sony Playstation 2\roms\Castlevania - Lament of Innocence (USA).7z  to D:\Arcade\cache\Castlevania - Lament of Innocence (USA)
08:26:25:576 | MD |     INFO  | +63    | Process - Wait 7z.exe 2
08:26:27:660 | MD |   DEBUG1  | +2074  | 7z - Starting 7zTimeout Timer
08:26:27:738 | MD |   DEBUG1  | +78    | Extracting file:		|	Percentage Extracted:   0%
08:26:27:874 | MD |   DEBUG1  | +141   | 7zTimeout - 7z.exe is no longer running
08:26:27:881 | MD |   DEBUG1  | +0     | Extracting file:		|	Percentage Extracted:   0%
08:26:27:902 | MD |   DEBUG1  | +31    | 7z - 7z.exe is no longer running, assuming extraction is complete
08:28:49:967 | MD |   DEBUG1  | +142054 | DefaultFadeAnimationLoop - Progress bar reached 100%
08:28:50:037 | MD |     INFO  | +78    | DefaultFadeAnimationLoop - Playing 7z fade complete sound: D:\Arcade\RocketLauncher\Media\Fade\_Default\7z complete.mp3
08:28:53:412 | MD |   DEBUG1  | +3370  | 7z - Finished 7z extraction
08:28:53:451 | MD |   DEBUG1  | +47    | 7z - Found file in D:\Arcade\cache\Castlevania - Lament of Innocence (USA)\Castlevania - Lament of Innocence (USA).iso
08:28:53:532 | MD |   DEBUG1  | +78    | 7z - romPath changed from "D:\Arcade\Sony Playstation 2\roms" to "D:\Arcade\cache\Castlevania - Lament of Innocence (USA)"
08:28:53:535 | MD |   DEBUG1  | +0     | 7z - romName changed from "Castlevania - Lament of Innocence (USA)" to "Castlevania - Lament of Innocence (USA)"
08:28:53:595 | MD |   DEBUG1  | +62    | 7z - romExtension changed from ".7z" to ".iso"
08:28:53:599 | MD |     INFO  | +0     | 7z - Ended
08:28:53:602 | MD |   DEBUG1  | +0     | LoadProperties - Started and loading this cfg into memory: D:\Arcade\emulators\PCSX2\inis\PCSX2_ui.ini
08:28:53:689 | MD |   DEBUG1  | +94    | LoadProperties - Ended
08:28:53:693 | MD |   DEBUG1  | +0     | ReadProperty - Started
08:28:53:799 | MD |     INFO  | +109   | Module Setting - [Settings] - VD_CDVD_Plugin:
08:28:53:802 | MD |     INFO  | +0     | VirtualDrive - Started - action is mount
08:28:53:805 | MD |   DEBUG1  | +0     | VirtualDrive - Received file: D:\Arcade\cache\Castlevania - Lament of Innocence (USA)\Castlevania - Lament of Innocence (USA).iso
08:28:53:872 | MD |     INFO  | +78    | CheckFile - Checking if C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe exists
08:28:53:921 | MD |   DEBUG1  | +47    | CheckFile - Attributes:
					FileDescription         	DAEMON Tools Lite
					FileVersion             	4.48.1.0347
					InternalName            	DTLite.exe
					LegalCopyright          	� 2000-2013 Disc Soft Ltd.
					OriginalFilename        	DTLite.exe
					ProductName             	DAEMON Tools Lite
					ProductVersion          	4.48.1.0347
					CompanyName             	Disc Soft Ltd
					File Size:			3675352 bytes
					Created:			10/28/2013 - 1:29:38 AM
					Modified:			10/28/2013 - 1:29:38 AM
08:28:53:928 | MD |   DEBUG1  | +0     | VirtualDrive - Using DAEMON Tools Lite version 4.48.1.0347 found at: C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
08:28:53:994 | MD |   DEBUG1  | +78    | VirtualDrive - All VirtualDrive calls will use mode DT4
08:28:53:998 | MD |     INFO  | +0     | RunWait - Started - running: C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe -get_count scsi
08:28:54:744 | MD |   DEBUG1  | +749   | RunWait - "DTLite.exe -get_count scsi" Process ID: 5868 and ErrorLevel reported as: 1
08:28:54:747 | MD |     INFO  | +0     | VirtualDrive - Running your DT4 Virtual Drive with: C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe -mount scsi, 0, "D:\Arcade\cache\Castlevania - Lament of Innocence (USA)\Castlevania - Lament of Innocence (USA).iso"
08:28:54:749 | MD |     INFO  | +0     | RunWait - Started - running: C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe -mount scsi, 0, "D:\Arcade\cache\Castlevania - Lament of Innocence (USA)\Castlevania - Lament of Innocence (USA).iso"
08:28:59:755 | MD |   DEBUG1  | +5007  | RunWait - "DTLite.exe -mount scsi, 0, "D:\Arcade\cache\Castlevania - Lament of Innocence (USA)\Castlevania - Lament of Innocence (USA).iso"" Process ID: 1772 and ErrorLevel reported as: 0
08:28:59:759 | MD |     INFO  | +0     | VirtualDrive - Ended
08:28:59:762 | MD |     INFO  | +0     | Run - Running: D:\Arcade\emulators\PCSX2\pcsx2-r5875.exe --usecd --fullscreen
08:29:00:167 | MD |   DEBUG1  | +406   | Run - "pcsx2-r5875.exe --usecd --fullscreen" Process ID: 6348
08:29:00:170 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x60318 | Process ID: 5676 | Process Path: D:\Arcade\RocketLauncher\RocketLauncher.exe
08:29:00:239 | MD |     INFO  | +78    | WinWait - Waiting for "ahk_class wxWindowNR"
08:29:30:236 | MD |   DEBUG1  | +29999 | GetActiveWindowStatus - Title: PCSX2  1.2.1 | Class: wxWindowClassNR | State: 0 | X: 701 | Y: 201 | Width: 386 | Height: 251 | Window HWND: 0x9034a | Process ID: 6348 | Process Path: D:\Arcade\emulators\PCSX2\pcsx2-r5875.exe
08:29:30:240 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:29:30:242 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:30:245 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
08:29:30:246 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
08:29:30:285 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 11 check
08:29:30:316 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
08:29:30:319 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
08:29:30:321 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:29:30:323 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:29:30:355 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:30:381 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 10 check
08:29:30:430 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 11 check
08:29:30:432 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7"
08:29:30:499 | MD |   DEBUG2  | +78    | XHotkeyTableCreation - Post loop 12 check
08:29:30:510 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:29:30:512 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:29:30:574 | MD |   DEBUG2  | +63    | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:30:688 | MD |   DEBUG2  | +124   | XHotkeyTableCreation - Post loop 10 check
08:29:30:699 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
08:29:30:847 | MD |   DEBUG2  | +156   | XHotkeyTableCreation - Post loop 11 check
08:29:30:851 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError"
08:29:30:854 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
08:29:30:944 | MD |   DEBUG2  | +94    | XHotkeyTableCreation - Ended
08:29:30:948 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:29:31:000 | MD |   DEBUG2  | +62    | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:31:097 | MD |   DEBUG2  | +94    | XHotkeyTableCreation - Post loop 10 check
08:29:31:101 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
08:29:31:104 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
08:29:31:189 | MD |   DEBUG2  | +94    | XHotkeyTableCreation - Post loop 12 check
08:29:31:193 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:29:31:593 | MD |   DEBUG1  | +405   | ScriptError - Playing error sound:
08:29:31:644 | MD |     INFO  | +47    | 7zCleanUp - Started
08:29:32:889 | MD |   DEBUG1  | +1248  | 7zCleanUp - Deleted D:\Arcade\cache\Castlevania - Lament of Innocence (USA)
08:29:32:893 | MD |     INFO  | +0     | 7zCleanUp - Ended
08:29:43:204 | MD |   DEBUG2  | +10312 | XHotkeyTableCreation - Started
08:29:43:208 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:43:262 | MD |   DEBUG2  | +62    | XHotkeyTableCreation - Post loop 10 check
08:29:43:267 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
08:29:43:270 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
08:29:43:273 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc"
08:29:43:393 | MD |   DEBUG2  | +125   | XHotkeyTableCreation - Post loop 12 check
08:29:43:396 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:29:43:533 | MD |   DEBUG2  | +140   | XHotkeyTableCreation - Started
08:29:43:536 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:43:538 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
08:29:43:730 | MD |   DEBUG2  | +203   | XHotkeyTableCreation - Post loop 11 check
08:29:43:732 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7"
08:29:43:735 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
08:29:43:737 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:29:43:739 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:29:43:741 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:43:771 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 10 check
08:29:43:789 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
08:29:43:796 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
08:29:43:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
08:29:43:800 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
08:29:43:802 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:29:43:886 | MD |   DEBUG2  | +94    | XHotkeyTableCreation - Started
08:29:43:891 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,~e&~t,
08:29:43:894 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
08:29:43:897 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
08:29:43:968 | MD |   DEBUG2  | +78    | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
08:29:43:972 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
08:29:44:105 | MD |   DEBUG2  | +140   | XHotkeyTableCreation - Ended
08:29:44:110 | MD |    ERROR  | +0     | ScriptError - There was an error waiting for the window "ahk_class wxWindowNR". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
08:29:44:114 | MD |     INFO  | +0     | ExitModule - Started
08:29:44:214 | MD |     INFO  | +110   | Starting Updating Statistics:
08:29:44:218 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
08:29:44:221 | MD |   DEBUG2  | +0     | gameSectionStartTime:2306989
08:29:44:224 | MD |   DEBUG2  | +0     | ElapsedTime:205
08:29:44:301 | MD |   DEBUG2  | +78    | Statistics cleared game name: Castlevania - Lament of Innocence
08:29:44:909 | MD |   DEBUG2  | +608   | Loaded game statistics from ini files:
					Number_of_Times_Played: 0
					Last_Time_Played: 0
					Average_Time_Played: 0
					Total_Time_Played: 0
					System_Total_Played_Time: 6389
					Total_Global_Played_Time: 2399
08:29:44:965 | MD |   DEBUG2  | +62    | Updated Statistics: Number_of_Times_Played: 1
					Last_Time_Played: Saturday July 1, 2017 08:26:18 AM
					Average_Time_Played: 205
					Total_Time_Played: 205
					System_Total_Played_Time: 6594
					Total_Global_Played_Time: 2604
08:29:45:605 | MD |     INFO  | +640   | Game section statistics updated.
08:29:45:728 | MD |     INFO  | +125   | Restoring mouse cursor
08:29:45:732 | MD |     INFO  | +0     | ExitModule - Ended
08:29:45:734 | MD |     INFO  | +0     | End of Module Logs
08:29:45:788 | RL |     INFO  | +208838 | Main - Module ended, exiting RocketLauncher normally
08:29:45:792 | RL |     INFO  | +0     | ExitScript - Started
08:29:45:799 | RL |   DEBUG1  | +0     | ExitScript - Unhiding taskbar
08:29:46:031 | RL |     INFO  | +234   | SystemCursor - Restoring mouse cursor
08:29:46:048 | RL |     INFO  | +16    | ExitScript - Ended
[/code]
[code]
08:49:21:477 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
08:49:21:822 | RL |     INFO  | +343   | Main - System Specs:
					RocketLauncher Dir: D:\Arcade\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8163.35 MB
					Free Memory: 5350.47 MB
					Used Memory: 2812.883 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: NVIDIA GeForce 210
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 21.21.13.4201
					Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
					Sound 1 Status: Enabled
					Sound 2 Device: NVIDIA High Definition Audio
					Sound 2 Status: Enabled
					Sound 3 Device: NVIDIA High Definition Audio
					Sound 3 Status: Enabled
					Sound 4 Device: Realtek High Definition Audio
					Sound 4 Status: Enabled
					Sound 5 Device: Bluetooth Audio
					Sound 5 Status: Enabled
					Sound 6 Device: NVIDIA High Definition Audio
					Sound 6 Status: Enabled
					Sound 7 Device: NVIDIA High Definition Audio
					Sound 7 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
08:49:21:822 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
08:49:21:822 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.3
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2061824 bytes
					Created:			9/23/2015 - 10:21:14 PM
					Modified:			8/30/2015 - 6:53:55 AM
08:49:21:822 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk exists
08:49:21:837 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:21:837 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4961 bytes
					Modified:			12/28/2014 - 12:53:36 PM
08:49:21:837 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
08:49:21:837 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk exists
08:49:21:869 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
08:49:21:869 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Modified:			8/30/2015 - 6:53:49 AM
08:49:21:869 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
08:49:21:884 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:49:21:884 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
08:49:21:884 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk exists
08:49:21:915 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
08:49:21:915 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
08:49:21:915 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk exists
08:49:21:931 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:21:931 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5895 bytes
					Modified:			7/6/2015 - 6:15:22 AM
08:49:21:931 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
08:49:21:947 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gsdll32.dll exists
08:49:21:947 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			13090816 bytes
					Modified:			1/8/2015 - 5:54:04 PM
08:49:21:947 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\itextsharp.dll exists
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			9/23/2015 - 10:21:15 PM
08:49:21:962 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Java.ahk exists
08:49:21:978 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:21:978 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
08:49:21:993 | RL |   DEBUG1  | +16    | Java.ahk Version: 1.0.0
08:49:21:993 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk exists
08:49:21:009 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:49:22:009 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			9203 bytes
08:49:22:009 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk exists
08:49:22:025 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:040 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			4904 bytes
					Modified:			5/4/2015 - 9:16:07 AM
08:49:22:040 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
08:49:22:040 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk exists
08:49:22:040 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
08:49:22:056 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			6915 bytes
08:49:22:056 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk exists
08:49:22:056 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
08:49:22:071 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			67561 bytes
08:49:22:071 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
08:49:22:071 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
08:49:22:071 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk exists
08:49:22:087 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:087 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5347 bytes
					Modified:			5/4/2015 - 9:16:38 AM
08:49:22:087 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
08:49:22:103 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA.ahk exists
08:49:22:103 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
08:49:22:118 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			34688 bytes
08:49:22:118 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk exists
08:49:22:134 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:134 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Modified:			1/30/2015 - 8:39:01 PM
08:49:22:134 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
08:49:22:134 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\7z.ahk exists
08:49:22:149 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:165 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			29013 bytes
					Modified:			8/30/2015 - 6:53:50 AM
08:49:22:165 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.1
08:49:22:165 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Bezel.ahk exists
08:49:22:165 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:181 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			102587 bytes
					Modified:			7/6/2015 - 6:15:20 AM
08:49:22:181 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.2
08:49:22:181 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade.ahk exists
08:49:22:181 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:196 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			38048 bytes
					Modified:			9/18/2015 - 8:22:33 AM
08:49:22:196 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.2
08:49:22:196 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Init.ahk exists
08:49:22:212 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:212 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			999 bytes
08:49:22:227 | RL |   DEBUG1  | +16    | Fade Init.ahk Version: 1.0.1
08:49:22:227 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk exists
08:49:22:243 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:243 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			79882 bytes
08:49:22:259 | RL |   DEBUG1  | +15    | Fade Animations.ahk Version: 1.1.8
08:49:22:259 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause.ahk exists
08:49:22:274 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:274 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392698 bytes
08:49:22:274 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.4
08:49:22:274 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause Init.ahk exists
08:49:22:290 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:290 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			553 bytes
					Modified:			8/30/2015 - 6:53:41 AM
08:49:22:290 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
08:49:22:290 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper.ahk exists
08:49:22:321 | RL |   DEBUG1  | +32    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:321 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Modified:			5/21/2015 - 10:33:10 PM
08:49:22:321 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
08:49:22:337 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk exists
08:49:22:352 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:352 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
08:49:22:352 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
08:49:22:368 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame.ahk exists
08:49:22:383 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:383 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			40753 bytes
					Modified:			8/30/2015 - 6:53:37 AM
08:49:22:383 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
08:49:22:383 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk exists
08:49:22:399 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:399 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
08:49:22:399 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
08:49:22:415 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk exists
08:49:22:430 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:430 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			58770 bytes
					Modified:			7/9/2015 - 7:36:01 AM
08:49:22:430 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
08:49:22:430 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Password.ahk exists
08:49:22:446 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:446 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10025 bytes
					Modified:			8/30/2015 - 6:53:44 AM
08:49:22:461 | RL |   DEBUG1  | +16    | Password.ahk Version: 1.0.2
08:49:22:461 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
08:49:22:461 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:477 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			73772 bytes
08:49:22:477 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
08:49:22:477 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Shared.ahk exists
08:49:22:508 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:508 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			116503 bytes
					Modified:			8/30/2015 - 6:53:45 AM
08:49:22:524 | RL |   DEBUG1  | +15    | Shared.ahk Version: 1.3.2
08:49:22:524 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics.ahk exists
08:49:22:524 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:539 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			26143 bytes
					Modified:			5/4/2015 - 9:16:52 AM
08:49:22:539 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
08:49:22:555 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk exists
08:49:22:571 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:571 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33 bytes
08:49:22:586 | RL |   DEBUG1  | +16    | Statistics Init.ahk Version: 1.0.1
08:49:22:586 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk exists
08:49:22:602 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:602 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			17070 bytes
08:49:22:602 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.1
08:49:22:602 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey.ahk exists
08:49:22:617 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:633 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			26540 bytes
					Modified:			8/30/2015 - 6:53:48 AM
08:49:22:633 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
08:49:22:664 | RL |     INFO  | +31    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk exists
08:49:22:680 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:49:22:680 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1063 bytes
					Modified:			8/30/2015 - 6:53:38 AM
08:49:22:680 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
08:49:22:680 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r 4x4OffRoadRacing_v1.00_1480 -f D:\Arcade\HyperSpin.exe -p HyperSpin -c 1"
08:49:22:695 | RL |   DEBUG1  | +16    | Main - Received this dbName with no path via CLI: "4x4OffRoadRacing_v1.00_1480"
08:49:22:695 | RL |   DEBUG1  | +0     | Main - dbName: 4x4OffRoadRacing_v1.00_1480
08:49:22:695 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
08:49:22:695 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "4x4OffRoadRacing_v1.00_1480"
08:49:22:711 | RL |     INFO  | +16    | Main - Did not find a "D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.
08:49:22:711 | RL |     INFO  | +0     | Main - 4x4OffRoadRacing_v1.00_1480 is using the default emulator: WinUAE
08:49:22:727 | RL |     INFO  | +15    | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Emulators.ini
08:49:22:727 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:49:22:727 | RL |     INFO  | +0     | Main - Found [WinUAE] in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:49:22:727 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists
08:49:22:727 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			23651 bytes
					Created:			9/23/2015 - 10:21:16 PM
					Modified:			8/30/2015 - 6:53:51 AM
08:49:22:742 | RL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
08:49:22:758 | RL |     INFO  | +15    | Main - 4x4OffRoadRacing_v1.00_1480 will use module: D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
08:49:22:773 | RL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
08:49:22:805 | RL |     INFO  | +31    | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\winuae.exe exists
08:49:23:118 | RL |   DEBUG1  | +312   | CheckFile - Attributes:
					FileDescription         	WinUAE
					FileVersion             	3.1.0.0
					InternalName            	WinUAE
					LegalCopyright          	� 1996-2015 under the GNU Public License (GPL)
					OriginalFilename        	WinUAE.exe
					ProductName             	WinUAE
					ProductVersion          	3.1.0.0
					File Size:			12417112 bytes
					Created:			6/30/2017 - 10:03:59 PM
					Modified:			6/7/2015 - 6:41:10 AM
08:49:23:118 | RL |     INFO  | +0     | Main - INI Keys read
08:49:23:118 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.exe exists
08:49:23:118 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
08:49:23:133 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.dll exists
08:49:23:133 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
08:49:23:149 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\FontReg.exe exists
08:49:23:180 | RL |   DEBUG1  | +32    | CheckFile - Attributes:
					FileDescription         	Font Registration Utility (x86-32)
					FileVersion             	2.1.3.0
					OriginalFilename        	FontReg.exe
					File Size:			6144 bytes
08:49:23:242 | RL |     INFO  | +62    | Main - "4x4OffRoadRacing_v1.00_1480" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
08:49:23:242 | RL |     INFO  | +0     | CheckPaths - Started
08:49:23:242 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.adf
08:49:23:274 | RL |   DEBUG1  | +31    | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\4x4OffRoadRacing_v1.00_1480.adf
08:49:23:274 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\*.adf
08:49:23:274 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.hdf
08:49:23:274 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\4x4OffRoadRacing_v1.00_1480.hdf
08:49:23:274 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\*.hdf
08:49:23:274 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.cue
08:49:23:274 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\4x4OffRoadRacing_v1.00_1480.cue
08:49:23:289 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\*.cue
08:49:23:289 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.iso
08:49:23:289 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\4x4OffRoadRacing_v1.00_1480.iso
08:49:23:289 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480\*.iso
08:49:23:289 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.zip
08:49:23:289 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.zip
08:49:23:289 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: 4x4OffRoadRacing_v1.00_1480
08:49:23:289 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Arcade\Commodore Amiga\roms
08:49:23:320 | RL |   DEBUG1  | +31    | CheckPaths - Current romExtension: .zip
08:49:23:320 | RL |     INFO  | +0     | CheckPaths - Ended
08:49:23:320 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Arcade\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.3
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Arcade\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Arcade
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc|H1000:1joy7
					restoreFE = Restore
					exitScriptKey = `
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Arcade\emulators\WinUAE 3.1\winuae.exe
					emuPath = D:\Arcade\emulators\WinUAE 3.1
					emuName = WinUAE
					emuExt = exe
					romPath = D:\Arcade\Commodore Amiga\roms
					romPathFromIni = D:\Arcade\Commodore Amiga\roms
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = adf|hdf|cue|iso|zip|lha|7z|uae|adz|dms|fdi|uss|slave
					executable = winuae.exe
					systemDbName = Commodore Amiga
					systemName = Commodore Amiga
					dbPath =
					dbName = 4x4OffRoadRacing_v1.00_1480
					dbExt =
					romName = 4x4OffRoadRacing_v1.00_1480
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = true
					blockInputTime = 0
					blockInputFile = D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Arcade\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = false
					vdDriveLetter =
					vdAddDrive = false
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Arcade\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Arcade\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 5000
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Arial
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Arcade\RocketLauncher\Media\Fade
					RLDataPath = D:\Arcade\RocketLauncher\Data
					RLMediaPath = D:\Arcade\RocketLauncher\Media
					RLErrSoundPath = D:\Arcade\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Arcade\RocketLauncher\Modules
					moduleFullName = D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
					moduleName = WinUAE
					modulePath = D:\Arcade\RocketLauncher\Modules\WinUAE
					moduleExtension = ahk
					moduleExtensionsPath = D:\Arcade\RocketLauncher\Module Extensions
					libPath = D:\Arcade\RocketLauncher\Lib
					7zEnabled = false
					7zPath = D:\Arcade\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Arcade\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = D:\Arcade\cache
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = false
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = Pause
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Arcade\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Arcade\Tools\Xpadder\xpadder.exe
					joyToKeyFullPath = C:\Windows\Utilities\VJoy\VJoy.exe
					keymapperProfilePath = D:\Arcade\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = ahk
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Rock Candy Gamepad for Xbox 360)|Controller (XBOX 360 For Windows)|Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit = Controller (Rock Candy Gamepad for Xbox 360)|Controller (Xbox 360 Wireless Receiver for Windows)
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga
					xPadderSystemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default
					emuProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE
					romProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\4x4OffRoadRacing_v1.00_1480
					RocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Arcade\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Arcade\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga
					ahkEmuProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAE
					ahkRomProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\4x4OffRoadRacing_v1.00_1480
					ahkRocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Arcade\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Arcade\RocketLauncher\Lib\User Fade Animations.ini
08:49:23:336 | RL |     INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts
08:49:23:336 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
08:49:23:336 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
08:49:23:336 | RL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
08:49:23:336 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
08:49:23:336 | RL |     INFO  | +0     | BuildScript - Validating module
08:49:23:352 | RL |     INFO  | +15    | BuildScript - Validation complete
08:49:23:352 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = WinUAE
					MEmuV =  v3.0.0
					MURL = http://www.winuae.net/
					MAuthor = brolly,Turranius
					MVersion = 2.1.9
					MCRC = 4C755A18
					iCRC = AFD49B34
					mId = 635138307631183750
					MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
					; Notes:
					; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
					; Just name them the same as the game name on the XML file.
					; Make sure you create a host config files with these names:
					; CD32 : cd32host.uae and cd32mousehost.uae;
					; CDTV : cdtvhost.uae and cdtvmousehost.uae;
					; Amiga : amigahost.uae;
					; Amiga CD : amigacdhost.uae;
					; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
					; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
					; a joystick and a mouse on Port1 and only a joystick on Port2.
					; Set all your other preferences like video display settings. And make sure you are saving a HOST
					; configuration file and not a general configuration file.
					; If you want to configure an exit key through WinUAE:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
					; If you want to configure a key to toggle fullscreen/windowed mode:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
					; CD32 and CDTV:
					; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
					; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
					; [Lemmings (Europe)]
					; UseMouse=true
					; [Project-X & F17 Challenge (Europe)]
					; DelayHack=true
					; Amiga:
					; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
					; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
					; END+SHIFT+1-0 = insert image from swapper slot 11-20
					; END+CTRL+1-4 = select drive
					; To do that follow the same procedure as above for the exit
					; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
					; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
					; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
					; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
					; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
					; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
					; Amiga CD:
					; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.
					; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).
					; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set
					; RequiresWB to false.
					; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:
					; http://www.winuae.net/
					; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory
					StartModule()
					BezelGUI()
					FadeInStart()
					settingsFile := modulePath . "\" . systemName . ".ini"
					; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.
					mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
					ident := mType[systemName]	; search object for the systemName identifier MESS uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
					specialcfg = %emuPath%\Configurations\%romName%.uae
					If romExtension in .hdf,.vhd
						DefaultRequireWB := "true"
					Else
						DefaultRequireWB := "false"
					If romExtension in .zip,.lha,.rar,.7z
						SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")
						If (SlaveFile) {
							If romName contains (AGA)
								defaultCycleExact := "false"
								defaultCpuSpeed := "max"
							} Else {
								defaultCycleExact := "true"
								defaultCpuSpeed := "real"
							defaultImmediateBlittler = "false"
							defaultCpuCompatible := "false"
							defaultCacheSize := "0" ;8192
					If (ident = "amigacd") {
						DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to true
						defaultz3Ram := "128"
						isAmigaCd := "true"
					; Settings
					FS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)
					quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)
					kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)
					options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)
					bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)
					bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)
					bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)
					bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)
					use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)
					floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)
					PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
					PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
					pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)
					If (pathtoextradrive)
						pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive)
					usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32
					delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32
					requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
					; Display
					videomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)
					gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)
					gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)
					gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)
					gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)
					gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)
					gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)
					gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)
					gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)
					gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)
					gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)
					gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1)
					; CPU
					cpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)
					cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)
					cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)
					cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)
					mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)
					cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)
					fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)
					fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)
					fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)
					cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)
					24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1)
					; Chipset
					cycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)
					immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
					blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)
					collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1)
					; RAM
					chipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)
					fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)
					autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)
					slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)
					z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)
					megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)
					processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1)
					; Expansions
					rtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)
					rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)
					rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1)
					; WHDLoad
					PathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
					PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
					whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)
					neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1)
					BezelStart()
					; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modes
					If bezelPath {
						FS := "fullwindow"
						gfx_filter_autoscale := "scale"
					windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
					If (FS = "true" or FS = "fullwindow")
						windowClass = AmigaPowah
					If (cpucycleexact and blittercycleexact)
						cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
					if (cpu != "68060" and cpu_no_unimplemented)
						cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.}
					; Make sure 24bitaddressing is false if using Z3 memory.
					If z3fastmemory
						24bitaddressing := "false"
					;Fill both z3 slots when amount of RAM requires it
					If (z3fastmemory = "384") {
						z3fastmemory = "256"
						z3fastmemoryb = "128"
					} Else If (z3fastmemory = "768") {
						z3fastmemory = "512"
						z3fastmemoryb = "256"
					} Else If (z3fastmemory = "1536") {
						z3fastmemory = "1024"
						z3fastmemoryb = "512"
					videomode := If videomode = "NTSC" ? "-s ntsc=true" : ""
					If (requireswb = "true") {
						ident := "a1200"
						CheckFile(PathToWorkBenchBase)
						wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
						ident := "a1200"
						gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
						CheckFile(pathtoextradrive,,,,,,1) ;allow folders
						If InStr(FileExist(pathtoextradrive), "D") ;it's a folder
							extraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"
						Else ;it's a file
							SplitPath, pathtoextradrive,,,extradriveExtension
							If extradriveExtension in .hdf,.vhd
								extraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"
							Else
								extraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"
					options := options . " " . videomode
					If (ident = "a500" or ident = "a1200") {
						If romName contains (AGA),(LW)
							ident := "a1200"
						If (SlaveFile) {
							CheckFolder(PathToWHDFolder)
							ident := "a1200"
							;Create the user-startup file to launch the game
							WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
							SplitPath, SlaveFile, SlaveName, SlaveFolder
							FileDelete, %WHDUserStartupFile%
							FileAppend, echo "";`n, %WHDUserStartupFile%
							FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
							FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
							FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
					hideEmuObj := Object("ahk_class " . windowClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
					If FileExist(specialcfg) {
						;Game specific configuration file exists
						configFile = %romName%.uae
					} Else {
						;Game specific configuration file doesn't exist
						If (ident = "cd32" or ident = "cdtv") {
							configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
							quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						} Else {
							;Amiga or Amiga CD game
							configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
							If quickstartmode
								quickcfg := "-s quickstart=" . quickstartmode
							Else
								quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")
					;--- Setting up command line arguments to use ---
					; Global command line arguments.
					If use_gui
						options := options . " -s use_gui=" . use_gui
					If (FS = "true") {
						options := options . " -s gfx_width_fullscreen=" . gfx_width
						options := options . " -s gfx_height_fullscreen=" . gfx_height
					} Else If (FS = "false") {
						If (gfx_width != "native" and gfx_height != "native") {
							options := options . " -s gfx_width_windowed=" . gfx_width
							options := options . " -s gfx_height_windowed=" . gfx_height
					If gfx_linemode
						options := options . " -s gfx_linemode=" . gfx_linemode
					If gfx_filter_autoscale
						options := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscale
					If gfx_blacker_than_black
						options := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_black
					If gfx_flickerfixer
						options := options . " -s gfx_flickerfixer=" . gfx_flickerfixer
					If gfx_filter_mode
						options := options . " -s gfx_filter_mode=" . gfx_filter_mode
					If (gfx_lores_mode = "true")
						options := options . " -s gfx_lores_mode=filtered"
					Else If (gfx_lores_mode = "false")
						options := options . " -s gfx_lores_mode=normal"
					If gfx_resolution {
						options := options . " -s gfx_resolution=" . gfx_resolution
						If (gfx_resolution = "lores") {
							options := options . " -s gfx_autoresolution_vga=false"
							options := options . " -s gfx_lores=true"
						Else {
							options := options . " -s gfx_lores=false"
					If gfx_filter_mask {
						gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_mask
						LOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)
						If FileExist(gfx_filter_mask_path)
							options := options . " -s gfx_filter_mask=" . gfx_filter_mask
					If gfx_filter {
						If (SubStr(gfx_filter, 1, 4) = "D3D:") {
							StringTrimLeft, FilterFileName, gfx_filter, 4
							FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileName
							If FileExist(FilterFile)
								options := options . " -s gfx_filter=" . gfx_filter
						} Else {
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					} Else {
						If floppyspeed
							options := options . " -s floppy_speed=" . floppyspeed
						If kickstart_rom_file
							options := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"
						If (cachesize || cachesize = "0")
							options := options . " -s cachesize=" . cachesize
						If immediateblitter
							options := options . " -s immediate_blits=" . immediateblitter
						If cycleexact
							options := options . " -s cycle_exact=" . cycleexact
						If cpucycleexact
							options := options . " -s cpu_cycle_exact=" . cpucycleexact
						If blittercycleexact
							options := options . " -s blitter_cycle_exact=" . blittercycleexact
						If cpucompatible
							options := options . " -s cpu_compatible=" . cpucompatible
						If cpuspeed
							options := options . " -s cpu_speed=" . cpuspeed
						If cpu
							options := options . " -s cpu_model=" . cpu
						If cpu_no_unimplemented
							options := options . " -s cpu_no_unimplemented=" . cpu_no_unimplemented
						If (mmu_model = "true")
							options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.
						If 24bitaddressing
							options := options . " -s cpu_24bit_addressing=" . 24bitaddressing
						If fpu
							options := options . " -s fpu_model=" . fpu
						If fpu_strict
							options := options . " -s fpu_strict=" . fpu_strict
						If fpu_no_unimplemented
							options := options . " -s fpu_no_unimplemented=" . fpu_no_unimplemented
						If collisionlevel
							options := options . " -s collision_level=" . collisionlevel
						If chipmemory
							options := options . " -s chipmem_size=" . chipmemory
						If fastmemory
							options := options . " -s fastmem_size=" . fastmemory
						If autoconfigfastmemory
							options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
						If slowmemory
							options := options . " -s bogomem_size=" . slowmemory
						If z3fastmemory
							options := options . " -s z3mem_size=" . z3fastmemory
						If z3fastmemoryb
							options := options . " -s z3mem2_size=" . z3fastmemoryb
						If megachipmemory
							options := options . " -s megachipmem_size=" . megachipmemory
						If processorslotfastmemory
							options := options . " -s mbresmem_size=" . processorslotfastmemory
						If rtgcardtype
							options := options . " -s gfxcard_type=" . rtgcardtype
						If rtgvramsize
							options := options . " -s gfxcard_size=" . rtgvramsize
						If rtghardwaresprite
							options := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite
						If (SlaveFile) {
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive) {
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
							;Check if there's also a CD to load
							IfExist, %romPath%\%romName%.cue
								cdDrive := romPath . "\" . romName . ".cue"
							IfExist, %romPath%\%romName%.iso
								cdDrive := romPath . "\" . romName . ".iso"
							IfExist, %romPath%\%romName%.mds
								cdDrive := romPath . "\" . romName . ".mds"
							If extraDrive
								options := options . " " . extraDrive
							If cdDrive
								options := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else If romExtension in .cue,.iso,.mds
							;Amiga CD game
							;Check if game has a HDD installation
							IfExist, %romPath%\%romName%.hdf
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"
							IfExist, %romPath%\%romName%.vhd
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """"
							options := options . " " . wbDrive . installedHdd
							If extraDrive
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else {
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menu
								If romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							If romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
					configFileFullPath := EmuPath . "\Configurations\" . configFile
					;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfg
					If FileExist(configFileFullPath)
					param1 := param1 . " " . quickcfg
					param2 := "-s gfx_fullscreen_amiga=" . FS
					param3 := options
					HideEmuStart()
					Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
					If (use_gui = "true") {
						WinWait("WinUAE Properties",,60)
						FadeInExit()
						WinWaitClose("WinUAE Properties")
						Sleep, 100
						Process("Exist",executable)
						If (ErrorLevel=0) {
							7zCleanUp()
							ExitModule()
					WinWait("ahk_class " . windowClass)
					WinWaitActive("ahk_class " . windowClass)
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					Process("WaitClose",executable)
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					MultiGame:
						If currentButton = 10
							diskslot = 0
						Else If currentButton > 10
							diskslot := currentButton - 10
						Else
							Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
						Else
							Send, {End Down}%diskslot%{End Up}
					Return
					CloseProcess:
							If (SlaveFile) {
								;Copy default-user-startup to user-startup if file exists
								IfExist, %PathToWHDFolder%\S\default-user-startup
									FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
						FadeOutStart()
						WinClose, ahk_class %windowClass%
					Return
08:49:23:352 | RL |     INFO  | +0     | BuildScript - Loaded Pause scripts
08:49:23:367 | RL |     INFO  | +16    | BuildScript - Loaded Multi-Player scripts
08:49:23:367 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
08:49:23:367 | RL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
08:49:23:367 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
08:49:23:367 | RL |     INFO  | +0     | Main - Module is built
08:49:23:367 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\AutoHotkey.dll exists
08:49:23:383 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			12/28/2014 - 12:53:35 PM
08:49:23:383 | RL |     INFO  | +0     | Main - Hiding taskbar
08:49:23:601 | RL |     INFO  | +219   | Main - Hiding desktop
08:49:23:601 | RL |     INFO  | +0     | Main - Running module
08:49:23:601 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
08:49:23:757 | MD |     INFO  | +N/A   | Module initialized
08:49:23:757 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:49:23:788 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
08:49:23:788 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:49:23:788 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:49:23:788 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
08:49:23:820 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Ended
08:49:23:820 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:49:23:820 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 not in TableKeyGroups ~Esc,
08:49:23:820 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:49:23:851 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
08:49:23:851 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
08:49:23:851 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:49:23:913 | MD |   DEBUG2  | +63    | XHotkeyTableCreation - Started
08:49:23:976 | MD |   DEBUG2  | +62    | XHotkeyTableCreation - KeyGroup ~Pause not in TableKeyGroups ~Esc,~1joy7,
08:49:23:976 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:49:23:976 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:49:23:976 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Pause" to call label: "TogglePauseMenuStatus"
08:49:23:976 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:49:23:007 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:49:24:007 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1joy7,~Pause,
08:49:24:038 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Post loop 1 check
08:49:24:038 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:49:24:038 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
08:49:24:038 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:49:24:038 | MD |     INFO  | +0     | StartModule - Started
08:49:24:069 | MD |     INFO  | +31    | StartModule - MEmu: WinUAE
					MEmuV: v3.0.0
					MURL: http://www.winuae.net/
					MAuthor: brolly,Turranius
					MVersion: 2.1.9
					MCRC: 4C755A18
					iCRC: AFD49B34
					MID:
					MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
08:49:24:069 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
08:49:24:069 | MD |     INFO  | +0     | PluginInit - Started
08:49:24:069 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
08:49:24:069 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\Databases\Commodore Amiga\Commodore Amiga.xml exists
08:49:24:163 | MD |   DEBUG1  | +93    | CheckFile - Attributes:
					File Size:			568042 bytes
					Created:			4/5/2014 - 6:11:31 AM
					Modified:			3/20/2015 - 5:37:41 PM
08:49:24:163 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
08:49:24:163 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
08:49:24:194 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Searching database for: Name
08:49:24:194 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "4x4 Off-Road Racing"
08:49:24:225 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Cloneof
08:49:24:225 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
08:49:24:256 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Manufacturer
08:49:24:256 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Manufacturer
08:49:24:288 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Year
08:49:24:288 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
08:49:24:288 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
08:49:24:319 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Genre
08:49:24:350 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Searching database for: Rating
08:49:24:350 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
08:49:24:350 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value:
					GameInfo Label: Rating | GameInfo Value:
08:49:24:350 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
08:49:24:350 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
08:49:24:381 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\Media\Commodore Amiga\Images\Wheel\4x4OffRoadRacing_v1.00_1480.png
08:49:24:381 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png
08:49:24:412 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Wheel\4x4OffRoadRacing_v1.00_1480.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system
08:49:24:444 | MD |   DEBUG1  | +31    | BuildAssetsTable - Ended
08:49:24:475 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
08:49:24:506 | MD |   DEBUG1  | +32    | BuildAssetsTable - Searching for a Artwork1: D:\Arcade\Media\Commodore Amiga\Images\Artwork1\4x4OffRoadRacing_v1.00_1480.png
08:49:24:506 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Arcade\Media\Commodore Amiga\Images\Artwork2\4x4OffRoadRacing_v1.00_1480.png
08:49:24:506 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Arcade\Media\Commodore Amiga\Images\Artwork3\4x4OffRoadRacing_v1.00_1480.png
08:49:24:506 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: D:\Arcade\Media\Commodore Amiga\Images\Artwork4\4x4OffRoadRacing_v1.00_1480.png
08:49:24:506 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Arcade\Media\Commodore Amiga\Images\Letters
08:49:24:600 | MD |   DEBUG1  | +93    | BuildAssetsTable - Searching for a Other: D:\Arcade\Media\Commodore Amiga\Images\Other
08:49:24:600 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Arcade\media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Arcade\media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Arcade\media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Arcade\media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Arcade\media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Arcade\media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Arcade\media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Arcade\media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Arcade\media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Arcade\media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Arcade\media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Arcade\media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Arcade\media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Arcade\media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Arcade\media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Arcade\media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Arcade\media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Arcade\media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Arcade\media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Arcade\media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Arcade\media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Arcade\media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Arcade\media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Arcade\media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Arcade\media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Arcade\media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Arcade\media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Arcade\media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Arcade\media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Arcade\media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Arcade\media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Arcade\media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Arcade\media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Arcade\media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Arcade\media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Arcade\media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Arcade\media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Arcade\media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
08:49:24:631 | MD |   DEBUG1  | +31    | BuildAssetsTable - Ended
08:49:24:631 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
08:49:24:631 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a MP4 Game Video: D:\Arcade\Media\Commodore Amiga\Video\4x4OffRoadRacing_v1.00_1480.*
08:49:24:631 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a FLV Game Video: D:\Arcade\Media\Main Menu\Video\Commodore Amiga.*
08:49:24:631 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  D:\Arcade\Media\Main Menu\Video\Commodore Amiga.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Video\4x4OffRoadRacing_v1.00_1480.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
08:49:24:631 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:49:24:631 | MD |     INFO  | +0     | PluginInit - Ended
08:49:24:662 | MD |   DEBUG1  | +32    | StartModule - Setting romName to the dbName sent to RocketLauncher: 4x4OffRoadRacing_v1.00_1480
08:49:24:662 | MD |     INFO  | +0     | Hiding mouse cursor
08:49:24:693 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:49:24:740 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,
08:49:24:771 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 1 check
08:49:24:771 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:49:24:771 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
08:49:24:771 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:49:24:802 | MD |     INFO  | +31    | StartModule - Ended
08:49:24:802 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
08:49:24:802 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
08:49:24:912 | MD |     INFO  | +109   | Module Setting - [Settings] - ScreenMode: true
08:49:24:912 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - ScreenMode: true
08:49:24:912 | MD |     INFO  | +0     | Module Setting - [Settings] - QuickStartMode:
08:49:24:912 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - QuickStartMode:
08:49:24:912 | MD |     INFO  | +0     | Module Setting - [Settings] - KickstartFile:
08:49:24:912 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - KickstartFile:
08:49:24:912 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:
08:49:24:912 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - Options:
08:49:24:943 | MD |     INFO  | +31    | Module Setting - [Settings] - Bezel_Top_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - Bezel_Top_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Bottom_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - Bezel_Bottom_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Right_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - Bezel_Right_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - Bezel_Left_Offset: 0
08:49:24:943 | MD |     INFO  | +0     | Module Setting - [Settings] - UseGui: false
08:49:24:974 | MD |     INFO  | +32    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - UseGui: false
08:49:24:974 | MD |     INFO  | +0     | Module Setting - [Settings] - FloppySpeed: turbo
08:49:24:974 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - FloppySpeed: turbo
08:49:24:974 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:49:24:974 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:49:24:974 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToExtraDrive:
08:49:24:974 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - PathToExtraDrive:
08:49:24:974 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - UseMouse: false
08:49:24:005 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - DelayHack: false
08:49:25:005 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - RequiresWB: false
08:49:25:005 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: NTSC
08:49:25:052 | MD |     INFO  | +47    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - VideoMode: NTSC
08:49:25:052 | MD |     INFO  | +0     | Module Setting - [Display] - XResolution: 1920
08:49:25:052 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - XResolution: 1920
08:49:25:052 | MD |     INFO  | +0     | Module Setting - [Display] - YResolution: 1080
08:49:25:052 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - YResolution: 1080
08:49:25:083 | MD |     INFO  | +31    | Module Setting - [Display] - BlackerThanBlack: false
08:49:25:083 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - BlackerThanBlack: false
08:49:25:083 | MD |     INFO  | +0     | Module Setting - [Display] - RemoveInterlaceArtifacts: false
08:49:25:083 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - RemoveInterlaceArtifacts: false
08:49:25:083 | MD |     INFO  | +0     | Module Setting - [Display] - LineMode:
08:49:25:114 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - LineMode:
08:49:25:114 | MD |     INFO  | +0     | Module Setting - [Display] - AutoScale: scale
08:49:25:146 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - AutoScale: scale
08:49:25:146 | MD |     INFO  | +0     | Module Setting - [Display] - ShaderMask:
08:49:25:146 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - ShaderMask:
08:49:25:146 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:
08:49:25:177 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - FilterShader:
08:49:25:177 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShaderScale:
08:49:25:177 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - FilterShaderScale:
08:49:25:177 | MD |     INFO  | +0     | Module Setting - [Display] - FilteredLowResolution:
08:49:25:177 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - FilteredLowResolution:
08:49:25:208 | MD |     INFO  | +32    | Module Setting - [Display] - ResolutionMode: superhires
08:49:25:208 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - ResolutionMode: superhires
08:49:25:208 | MD |     INFO  | +0     | Module Setting - [CPU] - CPU:
08:49:25:208 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - CPU:
08:49:25:239 | MD |     INFO  | +31    | Module Setting - [CPU] - CpuSpeed: real
08:49:25:239 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - CpuSpeed: real
08:49:25:239 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCycleExact:
08:49:25:239 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - CpuCycleExact:
08:49:25:239 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCompatible: false
08:49:25:270 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - CpuCompatible: false
08:49:25:270 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false
08:49:25:270 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - MMU: false
08:49:25:302 | MD |     INFO  | +31    | Module Setting - [CPU] - DisableUnimplementedCPU: true
08:49:25:302 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - DisableUnimplementedCPU: true
08:49:25:302 | MD |     INFO  | +0     | Module Setting - [CPU] - FPU:
08:49:25:302 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - FPU:
08:49:25:333 | MD |     INFO  | +31    | Module Setting - [CPU] - MoreCompatibleFPU: false
08:49:25:333 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - MoreCompatibleFPU: false
08:49:25:364 | MD |     INFO  | +32    | Module Setting - [CPU] - DisableUnimplementedFPU: true
08:49:25:364 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - DisableUnimplementedFPU: true
08:49:25:364 | MD |     INFO  | +0     | Module Setting - [CPU] - CacheSize: 0
08:49:25:364 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - CacheSize: 0
08:49:25:395 | MD |     INFO  | +31    | Module Setting - [CPU] - 24-BitAddressing: true
08:49:25:395 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - 24-BitAddressing: true
08:49:25:395 | MD |     INFO  | +0     | Module Setting - [Chipset] - CycleExact: true
08:49:25:395 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - CycleExact: true
08:49:25:395 | MD |     INFO  | +0     | Module Setting - [Chipset] - ImmediateBlitter: "false"
08:49:25:426 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - ImmediateBlitter: "false"
08:49:25:426 | MD |     INFO  | +0     | Module Setting - [Chipset] - BlitterCycleExact:
08:49:25:426 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - BlitterCycleExact:
08:49:25:426 | MD |     INFO  | +0     | Module Setting - [Chipset] - CollisionLevel:
08:49:25:458 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - CollisionLevel:
08:49:25:458 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:
08:49:25:458 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - ChipMemory:
08:49:25:458 | MD |     INFO  | +0     | Module Setting - [RAM] - FastMemory:
08:49:25:458 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - FastMemory:
08:49:25:489 | MD |     INFO  | +31    | Module Setting - [RAM] - AutoConfigFastMemory:
08:49:25:489 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - AutoConfigFastMemory:
08:49:25:489 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:
08:49:25:520 | MD |     INFO  | +32    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - SlowMemory:
08:49:25:567 | MD |     INFO  | +46    | Module Setting - [RAM] - Z3FastMemory:
08:49:25:567 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - Z3FastMemory:
08:49:25:598 | MD |     INFO  | +32    | Module Setting - [RAM] - MegaChipMemory:
08:49:25:598 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - MegaChipMemory:
08:49:25:598 | MD |     INFO  | +0     | Module Setting - [RAM] - ProcessorSlotFast:
08:49:25:598 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - ProcessorSlotFast:
08:49:25:598 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGCardType:
08:49:25:629 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - RTGCardType:
08:49:25:660 | MD |     INFO  | +31    | Module Setting - [Expansions] - RTGVRAMSize:
08:49:25:660 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - RTGVRAMSize:
08:49:25:692 | MD |     INFO  | +31    | Module Setting - [Expansions] - RTGHardwareSprite:
08:49:25:692 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - RTGHardwareSprite:
08:49:25:692 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - PathToWHDFolder: .\HDD\WHD
08:49:25:723 | MD |     INFO  | +31    | Module Setting - [4x4OffRoadRacing_v1.00_1480] - PathToWHDFolder: .\HDD\WHD
08:49:25:723 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD
08:49:25:723 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - WHDLoadOptions: PRELOAD
08:49:25:723 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - NeverExtract: false
08:49:25:723 | MD |     INFO  | +0     | Module Setting - [4x4OffRoadRacing_v1.00_1480] - NeverExtract: false
08:49:25:754 | MD |     INFO  | +32    | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:49:25:801 | MD |   DEBUG1  | +46    | CheckFile - Attributes:
					File Size:			0 bytes
					Created:			6/30/2017 - 10:03:57 PM
					Modified:			6/30/2017 - 10:07:49 PM
08:49:25:910 | MD |     INFO  | +110   | Run - Running: D:\Arcade\emulators\WinUAE 3.1\winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.zip"  -portable
08:49:26:222 | MD |   DEBUG1  | +312   | Run - "winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\4x4OffRoadRacing_v1.00_1480.zip"  -portable" Process ID: 6620
08:49:26:222 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: BlackScreen | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0xb034a | Process ID: 3476 | Process Path: D:\Arcade\RocketLauncher\RocketLauncher.exe
08:49:26:222 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"
08:49:26:963 | MD |   DEBUG1  | +748   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x70340 | Process ID: 6620 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:49:26:965 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x70340 | Process ID: 6620 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:49:26:967 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
08:49:27:075 | MD |   DEBUG1  | +110   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x70340 | Process ID: 6620 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:49:27:108 | MD |     INFO  | +31    | Process - WaitClose winuae.exe
08:49:42:415 | MD |   DEBUG1  | +15303 | CloseProcess - Started, user requested to end launched application
08:49:42:418 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:49:42:421 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			0 bytes
08:49:42:567 | MD |   DEBUG1  | +156   | CloseProcess - Ended
08:49:42:683 | MD |     INFO  | +110   | StopGlobalUserFeatures - Starting
08:49:42:683 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
08:49:42:683 | MD |     INFO  | +0     | ExitModule - Started
08:49:42:683 | MD |     INFO  | +0     | Starting Updating Statistics:
08:49:42:714 | MD |   DEBUG2  | +31    | Total Elapsed Time in Pause in seconds: 0
08:49:42:714 | MD |   DEBUG2  | +0     | gameSectionStartTime:3693058
08:49:42:714 | MD |   DEBUG2  | +0     | ElapsedTime:17
08:49:42:714 | MD |   DEBUG2  | +0     | Statistics cleared game name: 4x4OffRoadRacing_v1.00_1480
08:49:42:839 | MD |   DEBUG2  | +125   | Loaded game statistics from ini files:
					Number_of_Times_Played: 14
					Last_Time_Played: Friday June 30, 2017 10:10:16 PM
					Average_Time_Played: 24
					Total_Time_Played: 336
					System_Total_Played_Time: 948
					Total_Global_Played_Time: 2604
08:49:42:839 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 15
					Last_Time_Played: Saturday July 1, 2017 08:49:24 AM
					Total_Time_Played: 353
					System_Total_Played_Time: 965
					Total_Global_Played_Time: 2621
08:49:42:933 | MD |     INFO  | +93    | Game section statistics updated.
08:49:42:933 | MD |     INFO  | +0     | Restoring mouse cursor
08:49:42:933 | MD |     INFO  | +0     | ExitModule - Ended
08:49:42:964 | MD |     INFO  | +31    | End of Module Logs
08:49:43:073 | RL |     INFO  | +19469 | Main - Module ended, exiting RocketLauncher normally
08:49:43:073 | RL |     INFO  | +0     | ExitScript - Started
08:49:43:104 | RL |   DEBUG1  | +31    | ExitScript - Unhiding taskbar
08:49:43:369 | RL |     INFO  | +265   | SystemCursor - Restoring mouse cursor
08:49:43:401 | RL |     INFO  | +31    | ExitScript - Ended
[/code]
[code]
08:50:47:029 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
08:50:47:155 | RL |     INFO  | +125   | Main - System Specs:
					RocketLauncher Dir: D:\Arcade\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8163.35 MB
					Free Memory: 5311.32 MB
					Used Memory: 2852.027 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: NVIDIA GeForce 210
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 21.21.13.4201
					Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
					Sound 1 Status: Enabled
					Sound 2 Device: NVIDIA High Definition Audio
					Sound 2 Status: Enabled
					Sound 3 Device: NVIDIA High Definition Audio
					Sound 3 Status: Enabled
					Sound 4 Device: Realtek High Definition Audio
					Sound 4 Status: Enabled
					Sound 5 Device: Bluetooth Audio
					Sound 5 Status: Enabled
					Sound 6 Device: NVIDIA High Definition Audio
					Sound 6 Status: Enabled
					Sound 7 Device: NVIDIA High Definition Audio
					Sound 7 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
08:50:47:155 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
08:50:47:155 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.3
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2061824 bytes
					Created:			9/23/2015 - 10:21:14 PM
					Modified:			8/30/2015 - 6:53:55 AM
08:50:47:155 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk exists
08:50:47:171 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:171 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4961 bytes
					Modified:			12/28/2014 - 12:53:36 PM
08:50:47:171 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
08:50:47:171 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk exists
08:50:47:186 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:50:47:186 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Modified:			8/30/2015 - 6:53:49 AM
08:50:47:186 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
08:50:47:202 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:50:47:202 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
08:50:47:218 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk exists
08:50:47:218 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
08:50:47:218 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
08:50:47:218 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk exists
08:50:47:218 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:233 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			5895 bytes
					Modified:			7/6/2015 - 6:15:22 AM
08:50:47:233 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
08:50:47:233 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gsdll32.dll exists
08:50:47:233 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			13090816 bytes
					Modified:			1/8/2015 - 5:54:04 PM
08:50:47:233 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\itextsharp.dll exists
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			9/23/2015 - 10:21:15 PM
08:50:47:233 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Java.ahk exists
08:50:47:264 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:264 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
08:50:47:264 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
08:50:47:264 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk exists
08:50:47:280 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:50:47:280 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			9203 bytes
08:50:47:296 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk exists
08:50:47:311 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:311 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
					Modified:			5/4/2015 - 9:16:07 AM
08:50:47:311 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
08:50:47:311 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk exists
08:50:47:327 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
08:50:47:327 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
08:50:47:327 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk exists
08:50:47:358 | RL |   DEBUG1  | +32    | CRC Check - CRC matches, this is an official unedited Extension.
08:50:47:358 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
08:50:47:358 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
08:50:47:358 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk exists
08:50:47:374 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:389 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			5347 bytes
					Modified:			5/4/2015 - 9:16:38 AM
08:50:47:389 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
08:50:47:389 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA.ahk exists
08:50:47:405 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
08:50:47:405 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
08:50:47:420 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk exists
08:50:47:436 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:436 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Modified:			1/30/2015 - 8:39:01 PM
08:50:47:452 | RL |   DEBUG1  | +15    | VA_Extension.ahk Version: 1.0.1
08:50:47:452 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\7z.ahk exists
08:50:47:467 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:467 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29013 bytes
					Modified:			8/30/2015 - 6:53:50 AM
08:50:47:467 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.1
08:50:47:467 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Bezel.ahk exists
08:50:47:483 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:483 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			102587 bytes
					Modified:			7/6/2015 - 6:15:20 AM
08:50:47:498 | RL |   DEBUG1  | +16    | Bezel.ahk Version: 1.1.2
08:50:47:498 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade.ahk exists
08:50:47:498 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:514 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			38048 bytes
					Modified:			9/18/2015 - 8:22:33 AM
08:50:47:514 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.2
08:50:47:514 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Init.ahk exists
08:50:47:530 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:530 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			999 bytes
08:50:47:530 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
08:50:47:530 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk exists
08:50:47:545 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:545 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			79882 bytes
08:50:47:545 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.8
08:50:47:545 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause.ahk exists
08:50:47:561 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:576 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			392698 bytes
08:50:47:592 | RL |   DEBUG1  | +16    | Pause.ahk Version: 1.1.4
08:50:47:592 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause Init.ahk exists
08:50:47:592 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:592 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			553 bytes
					Modified:			8/30/2015 - 6:53:41 AM
08:50:47:592 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
08:50:47:608 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper.ahk exists
08:50:47:608 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:623 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			33453 bytes
					Modified:			5/21/2015 - 10:33:10 PM
08:50:47:623 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
08:50:47:623 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk exists
08:50:47:639 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:639 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
08:50:47:654 | RL |   DEBUG1  | +16    | Keymapper Init.ahk Version: 1.0.4
08:50:47:654 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame.ahk exists
08:50:47:670 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:670 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			40753 bytes
					Modified:			8/30/2015 - 6:53:37 AM
08:50:47:670 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
08:50:47:686 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk exists
08:50:47:686 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:686 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
08:50:47:701 | RL |   DEBUG1  | +16    | MultiGame Init.ahk Version: 1.0.0
08:50:47:701 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk exists
08:50:47:701 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:701 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			58770 bytes
					Modified:			7/9/2015 - 7:36:01 AM
08:50:47:717 | RL |   DEBUG1  | +16    | MultiPlayer.ahk Version: 1.0.6
08:50:47:717 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Password.ahk exists
08:50:47:717 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:748 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			10025 bytes
					Modified:			8/30/2015 - 6:53:44 AM
08:50:47:748 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
08:50:47:748 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
08:50:47:779 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:779 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			73772 bytes
08:50:47:779 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
08:50:47:779 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Shared.ahk exists
08:50:47:795 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:810 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			116503 bytes
					Modified:			8/30/2015 - 6:53:45 AM
08:50:47:810 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.2
08:50:47:810 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics.ahk exists
08:50:47:826 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:842 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			26143 bytes
					Modified:			5/4/2015 - 9:16:52 AM
08:50:47:842 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
08:50:47:842 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk exists
08:50:47:873 | RL |   DEBUG1  | +32    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:888 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			33 bytes
08:50:47:888 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
08:50:47:888 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk exists
08:50:47:904 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:904 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			17070 bytes
08:50:47:904 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.1
08:50:47:904 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey.ahk exists
08:50:47:920 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:920 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26540 bytes
					Modified:			8/30/2015 - 6:53:48 AM
08:50:47:935 | RL |   DEBUG1  | +16    | XHotkey.ahk Version: 1.0.4
08:50:47:935 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk exists
08:50:47:951 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:50:47:951 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1063 bytes
					Modified:			8/30/2015 - 6:53:38 AM
08:50:47:951 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
08:50:47:951 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r 688AttackSub_v1.1_0093 -f D:\Arcade\HyperSpin.exe -p HyperSpin -c 1"
08:50:47:966 | RL |   DEBUG1  | +15    | Main - Received this dbName with no path via CLI: "688AttackSub_v1.1_0093"
08:50:47:966 | RL |   DEBUG1  | +0     | Main - dbName: 688AttackSub_v1.1_0093
08:50:47:966 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
08:50:47:966 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "688AttackSub_v1.1_0093"
08:50:47:982 | RL |     INFO  | +16    | Main - Did not find a "D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.
08:50:47:982 | RL |     INFO  | +0     | Main - 688AttackSub_v1.1_0093 is using the default emulator: WinUAE
08:50:47:982 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Emulators.ini
08:50:47:998 | RL |     INFO  | +15    | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:50:47:013 | RL |     INFO  | +16    | Main - Found [WinUAE] in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:50:48:029 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists
08:50:48:029 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			23651 bytes
					Created:			9/23/2015 - 10:21:16 PM
					Modified:			8/30/2015 - 6:53:51 AM
08:50:48:044 | RL |     INFO  | +15    | Main - CRC Check - CRC matches, this is an official unedited module.
08:50:48:044 | RL |     INFO  | +0     | Main - 688AttackSub_v1.1_0093 will use module: D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
08:50:48:077 | RL |     INFO  | +31    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
08:50:48:079 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\winuae.exe exists
08:50:48:079 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	WinUAE
					FileVersion             	3.1.0.0
					InternalName            	WinUAE
					LegalCopyright          	� 1996-2015 under the GNU Public License (GPL)
					OriginalFilename        	WinUAE.exe
					ProductName             	WinUAE
					ProductVersion          	3.1.0.0
					File Size:			12417112 bytes
					Created:			6/30/2017 - 10:03:59 PM
					Modified:			6/7/2015 - 6:41:10 AM
08:50:48:094 | RL |     INFO  | +16    | Main - INI Keys read
08:50:48:094 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.exe exists
08:50:48:094 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
08:50:48:125 | RL |     INFO  | +31    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.dll exists
08:50:48:125 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
08:50:48:141 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\FontReg.exe exists
08:50:48:141 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	Font Registration Utility (x86-32)
					FileVersion             	2.1.3.0
					OriginalFilename        	FontReg.exe
					File Size:			6144 bytes
08:50:48:188 | RL |     INFO  | +47    | Main - "688AttackSub_v1.1_0093" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
08:50:48:203 | RL |     INFO  | +15    | CheckPaths - Started
08:50:48:203 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.adf
08:50:48:203 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\688AttackSub_v1.1_0093.adf
08:50:48:203 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\*.adf
08:50:48:203 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.hdf
08:50:48:203 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\688AttackSub_v1.1_0093.hdf
08:50:48:219 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\*.hdf
08:50:48:219 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.cue
08:50:48:219 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\688AttackSub_v1.1_0093.cue
08:50:48:219 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\*.cue
08:50:48:219 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.iso
08:50:48:219 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\688AttackSub_v1.1_0093.iso
08:50:48:235 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093\*.iso
08:50:48:235 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.zip
08:50:48:235 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.zip
08:50:48:235 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: 688AttackSub_v1.1_0093
08:50:48:235 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Arcade\Commodore Amiga\roms
08:50:48:235 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
08:50:48:235 | RL |     INFO  | +0     | CheckPaths - Ended
08:50:48:250 | RL |     INFO  | +16    | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Arcade\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.3
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Arcade\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Arcade
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc|H1000:1joy7
					restoreFE = Restore
					exitScriptKey = `
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Arcade\emulators\WinUAE 3.1\winuae.exe
					emuPath = D:\Arcade\emulators\WinUAE 3.1
					emuName = WinUAE
					emuExt = exe
					romPath = D:\Arcade\Commodore Amiga\roms
					romPathFromIni = D:\Arcade\Commodore Amiga\roms
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = adf|hdf|cue|iso|zip|lha|7z|uae|adz|dms|fdi|uss|slave
					executable = winuae.exe
					systemDbName = Commodore Amiga
					systemName = Commodore Amiga
					dbPath =
					dbName = 688AttackSub_v1.1_0093
					dbExt =
					romName = 688AttackSub_v1.1_0093
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = true
					blockInputTime = 0
					blockInputFile = D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Arcade\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = false
					vdDriveLetter =
					vdAddDrive = false
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Arcade\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Arcade\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 5000
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Arial
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Arcade\RocketLauncher\Media\Fade
					RLDataPath = D:\Arcade\RocketLauncher\Data
					RLMediaPath = D:\Arcade\RocketLauncher\Media
					RLErrSoundPath = D:\Arcade\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Arcade\RocketLauncher\Modules
					moduleFullName = D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
					moduleName = WinUAE
					modulePath = D:\Arcade\RocketLauncher\Modules\WinUAE
					moduleExtension = ahk
					moduleExtensionsPath = D:\Arcade\RocketLauncher\Module Extensions
					libPath = D:\Arcade\RocketLauncher\Lib
					7zEnabled = false
					7zPath = D:\Arcade\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Arcade\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = D:\Arcade\cache
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = false
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = Pause
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Arcade\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Arcade\Tools\Xpadder\xpadder.exe
					joyToKeyFullPath = C:\Windows\Utilities\VJoy\VJoy.exe
					keymapperProfilePath = D:\Arcade\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = ahk
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Rock Candy Gamepad for Xbox 360)|Controller (XBOX 360 For Windows)|Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit = Controller (Rock Candy Gamepad for Xbox 360)|Controller (Xbox 360 Wireless Receiver for Windows)
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga
					xPadderSystemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default
					emuProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE
					romProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\688AttackSub_v1.1_0093
					RocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Arcade\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Arcade\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga
					ahkEmuProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAE
					ahkRomProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\688AttackSub_v1.1_0093
					ahkRocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Arcade\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Arcade\RocketLauncher\Lib\User Fade Animations.ini
08:50:48:250 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
08:50:48:250 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
08:50:48:250 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
08:50:48:250 | RL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
08:50:48:250 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
08:50:48:250 | RL |     INFO  | +0     | BuildScript - Validating module
08:50:48:266 | RL |     INFO  | +16    | BuildScript - Validation complete
08:50:48:266 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = WinUAE
					MEmuV =  v3.0.0
					MURL = http://www.winuae.net/
					MAuthor = brolly,Turranius
					MVersion = 2.1.9
					MCRC = 4C755A18
					iCRC = AFD49B34
					mId = 635138307631183750
					MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
					; Notes:
					; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
					; Just name them the same as the game name on the XML file.
					; Make sure you create a host config files with these names:
					; CD32 : cd32host.uae and cd32mousehost.uae;
					; CDTV : cdtvhost.uae and cdtvmousehost.uae;
					; Amiga : amigahost.uae;
					; Amiga CD : amigacdhost.uae;
					; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
					; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
					; a joystick and a mouse on Port1 and only a joystick on Port2.
					; Set all your other preferences like video display settings. And make sure you are saving a HOST
					; configuration file and not a general configuration file.
					; If you want to configure an exit key through WinUAE:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
					; If you want to configure a key to toggle fullscreen/windowed mode:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
					; CD32 and CDTV:
					; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
					; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
					; [Lemmings (Europe)]
					; UseMouse=true
					; [Project-X & F17 Challenge (Europe)]
					; DelayHack=true
					; Amiga:
					; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
					; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
					; END+SHIFT+1-0 = insert image from swapper slot 11-20
					; END+CTRL+1-4 = select drive
					; To do that follow the same procedure as above for the exit
					; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
					; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
					; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
					; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
					; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
					; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
					; Amiga CD:
					; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.
					; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).
					; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set
					; RequiresWB to false.
					; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:
					; http://www.winuae.net/
					; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory
					StartModule()
					BezelGUI()
					FadeInStart()
					settingsFile := modulePath . "\" . systemName . ".ini"
					; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.
					mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
					ident := mType[systemName]	; search object for the systemName identifier MESS uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
					specialcfg = %emuPath%\Configurations\%romName%.uae
					If romExtension in .hdf,.vhd
						DefaultRequireWB := "true"
					Else
						DefaultRequireWB := "false"
					If romExtension in .zip,.lha,.rar,.7z
						SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")
						If (SlaveFile) {
							If romName contains (AGA)
								defaultCycleExact := "false"
								defaultCpuSpeed := "max"
							} Else {
								defaultCycleExact := "true"
								defaultCpuSpeed := "real"
							defaultImmediateBlittler = "false"
							defaultCpuCompatible := "false"
							defaultCacheSize := "0" ;8192
					If (ident = "amigacd") {
						DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to true
						defaultz3Ram := "128"
						isAmigaCd := "true"
					; Settings
					FS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)
					quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)
					kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)
					options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)
					bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)
					bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)
					bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)
					bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)
					use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)
					floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)
					PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
					PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
					pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)
					If (pathtoextradrive)
						pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive)
					usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32
					delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32
					requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
					; Display
					videomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)
					gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)
					gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)
					gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)
					gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)
					gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)
					gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)
					gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)
					gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)
					gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)
					gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)
					gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1)
					; CPU
					cpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)
					cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)
					cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)
					cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)
					mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)
					cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)
					fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)
					fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)
					fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)
					cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)
					24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1)
					; Chipset
					cycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)
					immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
					blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)
					collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1)
					; RAM
					chipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)
					fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)
					autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)
					slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)
					z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)
					megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)
					processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1)
					; Expansions
					rtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)
					rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)
					rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1)
					; WHDLoad
					PathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
					PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
					whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)
					neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1)
					BezelStart()
					; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modes
					If bezelPath {
						FS := "fullwindow"
						gfx_filter_autoscale := "scale"
					windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
					If (FS = "true" or FS = "fullwindow")
						windowClass = AmigaPowah
					If (cpucycleexact and blittercycleexact)
						cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
					if (cpu != "68060" and cpu_no_unimplemented)
						cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.}
					; Make sure 24bitaddressing is false if using Z3 memory.
					If z3fastmemory
						24bitaddressing := "false"
					;Fill both z3 slots when amount of RAM requires it
					If (z3fastmemory = "384") {
						z3fastmemory = "256"
						z3fastmemoryb = "128"
					} Else If (z3fastmemory = "768") {
						z3fastmemory = "512"
						z3fastmemoryb = "256"
					} Else If (z3fastmemory = "1536") {
						z3fastmemory = "1024"
						z3fastmemoryb = "512"
					videomode := If videomode = "NTSC" ? "-s ntsc=true" : ""
					If (requireswb = "true") {
						ident := "a1200"
						CheckFile(PathToWorkBenchBase)
						wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
						ident := "a1200"
						gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
						CheckFile(pathtoextradrive,,,,,,1) ;allow folders
						If InStr(FileExist(pathtoextradrive), "D") ;it's a folder
							extraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"
						Else ;it's a file
							SplitPath, pathtoextradrive,,,extradriveExtension
							If extradriveExtension in .hdf,.vhd
								extraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"
							Else
								extraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"
					options := options . " " . videomode
					If (ident = "a500" or ident = "a1200") {
						If romName contains (AGA),(LW)
							ident := "a1200"
						If (SlaveFile) {
							CheckFolder(PathToWHDFolder)
							ident := "a1200"
							;Create the user-startup file to launch the game
							WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
							SplitPath, SlaveFile, SlaveName, SlaveFolder
							FileDelete, %WHDUserStartupFile%
							FileAppend, echo "";`n, %WHDUserStartupFile%
							FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
							FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
							FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
					hideEmuObj := Object("ahk_class " . windowClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
					If FileExist(specialcfg) {
						;Game specific configuration file exists
						configFile = %romName%.uae
					} Else {
						;Game specific configuration file doesn't exist
						If (ident = "cd32" or ident = "cdtv") {
							configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
							quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						} Else {
							;Amiga or Amiga CD game
							configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
							If quickstartmode
								quickcfg := "-s quickstart=" . quickstartmode
							Else
								quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")
					;--- Setting up command line arguments to use ---
					; Global command line arguments.
					If use_gui
						options := options . " -s use_gui=" . use_gui
					If (FS = "true") {
						options := options . " -s gfx_width_fullscreen=" . gfx_width
						options := options . " -s gfx_height_fullscreen=" . gfx_height
					} Else If (FS = "false") {
						If (gfx_width != "native" and gfx_height != "native") {
							options := options . " -s gfx_width_windowed=" . gfx_width
							options := options . " -s gfx_height_windowed=" . gfx_height
					If gfx_linemode
						options := options . " -s gfx_linemode=" . gfx_linemode
					If gfx_filter_autoscale
						options := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscale
					If gfx_blacker_than_black
						options := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_black
					If gfx_flickerfixer
						options := options . " -s gfx_flickerfixer=" . gfx_flickerfixer
					If gfx_filter_mode
						options := options . " -s gfx_filter_mode=" . gfx_filter_mode
					If (gfx_lores_mode = "true")
						options := options . " -s gfx_lores_mode=filtered"
					Else If (gfx_lores_mode = "false")
						options := options . " -s gfx_lores_mode=normal"
					If gfx_resolution {
						options := options . " -s gfx_resolution=" . gfx_resolution
						If (gfx_resolution = "lores") {
							options := options . " -s gfx_autoresolution_vga=false"
							options := options . " -s gfx_lores=true"
						Else {
							options := options . " -s gfx_lores=false"
					If gfx_filter_mask {
						gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_mask
						LOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)
						If FileExist(gfx_filter_mask_path)
							options := options . " -s gfx_filter_mask=" . gfx_filter_mask
					If gfx_filter {
						If (SubStr(gfx_filter, 1, 4) = "D3D:") {
							StringTrimLeft, FilterFileName, gfx_filter, 4
							FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileName
							If FileExist(FilterFile)
								options := options . " -s gfx_filter=" . gfx_filter
						} Else {
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					} Else {
						If floppyspeed
							options := options . " -s floppy_speed=" . floppyspeed
						If kickstart_rom_file
							options := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"
						If (cachesize || cachesize = "0")
							options := options . " -s cachesize=" . cachesize
						If immediateblitter
							options := options . " -s immediate_blits=" . immediateblitter
						If cycleexact
							options := options . " -s cycle_exact=" . cycleexact
						If cpucycleexact
							options := options . " -s cpu_cycle_exact=" . cpucycleexact
						If blittercycleexact
							options := options . " -s blitter_cycle_exact=" . blittercycleexact
						If cpucompatible
							options := options . " -s cpu_compatible=" . cpucompatible
						If cpuspeed
							options := options . " -s cpu_speed=" . cpuspeed
						If cpu
							options := options . " -s cpu_model=" . cpu
						If cpu_no_unimplemented
							options := options . " -s cpu_no_unimplemented=" . cpu_no_unimplemented
						If (mmu_model = "true")
							options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.
						If 24bitaddressing
							options := options . " -s cpu_24bit_addressing=" . 24bitaddressing
						If fpu
							options := options . " -s fpu_model=" . fpu
						If fpu_strict
							options := options . " -s fpu_strict=" . fpu_strict
						If fpu_no_unimplemented
							options := options . " -s fpu_no_unimplemented=" . fpu_no_unimplemented
						If collisionlevel
							options := options . " -s collision_level=" . collisionlevel
						If chipmemory
							options := options . " -s chipmem_size=" . chipmemory
						If fastmemory
							options := options . " -s fastmem_size=" . fastmemory
						If autoconfigfastmemory
							options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
						If slowmemory
							options := options . " -s bogomem_size=" . slowmemory
						If z3fastmemory
							options := options . " -s z3mem_size=" . z3fastmemory
						If z3fastmemoryb
							options := options . " -s z3mem2_size=" . z3fastmemoryb
						If megachipmemory
							options := options . " -s megachipmem_size=" . megachipmemory
						If processorslotfastmemory
							options := options . " -s mbresmem_size=" . processorslotfastmemory
						If rtgcardtype
							options := options . " -s gfxcard_type=" . rtgcardtype
						If rtgvramsize
							options := options . " -s gfxcard_size=" . rtgvramsize
						If rtghardwaresprite
							options := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite
						If (SlaveFile) {
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive) {
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
							;Check if there's also a CD to load
							IfExist, %romPath%\%romName%.cue
								cdDrive := romPath . "\" . romName . ".cue"
							IfExist, %romPath%\%romName%.iso
								cdDrive := romPath . "\" . romName . ".iso"
							IfExist, %romPath%\%romName%.mds
								cdDrive := romPath . "\" . romName . ".mds"
							If extraDrive
								options := options . " " . extraDrive
							If cdDrive
								options := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else If romExtension in .cue,.iso,.mds
							;Amiga CD game
							;Check if game has a HDD installation
							IfExist, %romPath%\%romName%.hdf
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"
							IfExist, %romPath%\%romName%.vhd
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """"
							options := options . " " . wbDrive . installedHdd
							If extraDrive
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else {
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menu
								If romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							If romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
					configFileFullPath := EmuPath . "\Configurations\" . configFile
					;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfg
					If FileExist(configFileFullPath)
					param1 := param1 . " " . quickcfg
					param2 := "-s gfx_fullscreen_amiga=" . FS
					param3 := options
					HideEmuStart()
					Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
					If (use_gui = "true") {
						WinWait("WinUAE Properties",,60)
						FadeInExit()
						WinWaitClose("WinUAE Properties")
						Sleep, 100
						Process("Exist",executable)
						If (ErrorLevel=0) {
							7zCleanUp()
							ExitModule()
					WinWait("ahk_class " . windowClass)
					WinWaitActive("ahk_class " . windowClass)
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					Process("WaitClose",executable)
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					MultiGame:
						If currentButton = 10
							diskslot = 0
						Else If currentButton > 10
							diskslot := currentButton - 10
						Else
							Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
						Else
							Send, {End Down}%diskslot%{End Up}
					Return
					CloseProcess:
							If (SlaveFile) {
								;Copy default-user-startup to user-startup if file exists
								IfExist, %PathToWHDFolder%\S\default-user-startup
									FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
						FadeOutStart()
						WinClose, ahk_class %windowClass%
					Return
08:50:48:266 | RL |     INFO  | +0     | BuildScript - Loaded Pause scripts
08:50:48:281 | RL |     INFO  | +15    | BuildScript - Loaded Multi-Player scripts
08:50:48:281 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
08:50:48:281 | RL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
08:50:48:281 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
08:50:48:281 | RL |     INFO  | +0     | Main - Module is built
08:50:48:281 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\AutoHotkey.dll exists
08:50:48:297 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			12/28/2014 - 12:53:35 PM
08:50:48:297 | RL |     INFO  | +0     | Main - Hiding taskbar
08:50:48:515 | RL |     INFO  | +218   | Main - Hiding desktop
08:50:48:515 | RL |     INFO  | +0     | Main - Running module
08:50:48:515 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
08:50:48:687 | MD |     INFO  | +N/A   | Module initialized
08:50:48:687 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:50:48:687 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
08:50:48:718 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 1 check
08:50:48:718 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:50:48:749 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
08:50:48:749 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:50:48:749 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:50:48:749 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 not in TableKeyGroups ~Esc,
08:50:48:749 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:50:48:781 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
08:50:48:784 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
08:50:48:813 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Ended
08:50:48:876 | MD |   DEBUG2  | +62    | XHotkeyTableCreation - Started
08:50:48:907 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~Pause not in TableKeyGroups ~Esc,~1joy7,
08:50:48:907 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:50:48:907 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:50:48:907 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Pause" to call label: "TogglePauseMenuStatus"
08:50:48:907 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:50:48:938 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:50:48:938 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1joy7,~Pause,
08:50:48:938 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:50:48:938 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:50:48:938 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
08:50:48:969 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Ended
08:50:48:969 | MD |     INFO  | +0     | StartModule - Started
08:50:48:969 | MD |     INFO  | +0     | StartModule - MEmu: WinUAE
					MEmuV: v3.0.0
					MURL: http://www.winuae.net/
					MAuthor: brolly,Turranius
					MVersion: 2.1.9
					MCRC: 4C755A18
					iCRC: AFD49B34
					MID:
					MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
08:50:48:969 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
08:50:48:000 | MD |     INFO  | +31    | PluginInit - Started
08:50:49:000 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
08:50:49:000 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\Databases\Commodore Amiga\Commodore Amiga.xml exists
08:50:49:000 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			568042 bytes
					Created:			4/5/2014 - 6:11:31 AM
					Modified:			3/20/2015 - 5:37:41 PM
08:50:49:032 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
08:50:49:032 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
08:50:49:032 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
08:50:49:032 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "688 Attack Sub"
08:50:49:063 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Cloneof
08:50:49:063 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
08:50:49:063 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
08:50:49:063 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Manufacturer
08:50:49:063 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
08:50:49:094 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Year
08:50:49:125 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Searching database for: Genre
08:50:49:125 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre
08:50:49:125 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
08:50:49:125 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
08:50:49:125 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value:
					GameInfo Label: Rating | GameInfo Value:
08:50:49:156 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Ended
08:50:49:156 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
08:50:49:156 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\Media\Commodore Amiga\Images\Wheel\688AttackSub_v1.1_0093.png
08:50:49:156 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png
08:50:49:188 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Wheel\688AttackSub_v1.1_0093.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system
08:50:49:188 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:50:49:188 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
08:50:49:219 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Artwork1: D:\Arcade\Media\Commodore Amiga\Images\Artwork1\688AttackSub_v1.1_0093.png
08:50:49:270 | MD |   DEBUG1  | +63    | BuildAssetsTable - Searching for a Box Art: D:\Arcade\Media\Commodore Amiga\Images\Artwork2\688AttackSub_v1.1_0093.png
08:50:49:275 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Arcade\Media\Commodore Amiga\Images\Artwork3\688AttackSub_v1.1_0093.png
08:50:49:306 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Flyers: D:\Arcade\Media\Commodore Amiga\Images\Artwork4\688AttackSub_v1.1_0093.png
08:50:49:306 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Arcade\Media\Commodore Amiga\Images\Letters
08:50:49:400 | MD |   DEBUG1  | +93    | BuildAssetsTable - Searching for a Other: D:\Arcade\Media\Commodore Amiga\Images\Other
08:50:49:400 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Box Art | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Artwork2\688AttackSub_v1.1_0093.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Cartridge | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Artwork3\688AttackSub_v1.1_0093.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Letters | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Arcade\media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Arcade\media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Arcade\media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Arcade\media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Arcade\media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Arcade\media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Arcade\media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Arcade\media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Arcade\media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Arcade\media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Arcade\media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Arcade\media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Arcade\media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Arcade\media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Arcade\media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Arcade\media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Arcade\media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Arcade\media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Arcade\media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Arcade\media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Arcade\media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Arcade\media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Arcade\media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Arcade\media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Arcade\media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Arcade\media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Arcade\media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Arcade\media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Arcade\media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Arcade\media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Arcade\media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Arcade\media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Arcade\media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Arcade\media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Arcade\media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Arcade\media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Arcade\media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Arcade\media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
08:50:49:431 | MD |   DEBUG1  | +32    | BuildAssetsTable - Ended
08:50:49:431 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
08:50:49:462 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a MP4 Game Video: D:\Arcade\Media\Commodore Amiga\Video\688AttackSub_v1.1_0093.*
08:50:49:525 | MD |   DEBUG1  | +62    | BuildAssetsTable - Searching for a FLV Game Video: D:\Arcade\Media\Main Menu\Video\Commodore Amiga.*
08:50:49:525 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  D:\Arcade\Media\Main Menu\Video\Commodore Amiga.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Video\688AttackSub_v1.1_0093.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
08:50:49:525 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:50:49:525 | MD |     INFO  | +0     | PluginInit - Ended
08:50:49:525 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: 688AttackSub_v1.1_0093
08:50:49:556 | MD |     INFO  | +31    | Hiding mouse cursor
08:50:49:587 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Started
08:50:49:634 | MD |   DEBUG2  | +46    | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,
08:50:49:634 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:50:49:681 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 2 check
08:50:49:681 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
08:50:49:681 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:50:49:681 | MD |     INFO  | +0     | StartModule - Ended
08:50:49:712 | MD |     INFO  | +31    | StartGlobalUserFeatures - Starting
08:50:49:759 | MD |     INFO  | +47    | StartGlobalUserFeatures - Ending
08:50:49:946 | MD |     INFO  | +187   | Module Setting - [Settings] - ScreenMode: true
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - ScreenMode: true
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [Settings] - QuickStartMode:
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - QuickStartMode:
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [Settings] - KickstartFile:
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - KickstartFile:
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - Options:
08:50:49:946 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Top_Offset: 0
08:50:49:977 | MD |     INFO  | +32    | Module Setting - [688AttackSub_v1.1_0093] - Bezel_Top_Offset: 0
08:50:49:977 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Bottom_Offset: 0
08:50:49:977 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - Bezel_Bottom_Offset: 0
08:50:49:977 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Right_Offset: 0
08:50:49:977 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - Bezel_Right_Offset: 0
08:50:49:977 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 0
08:50:49:977 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - Bezel_Left_Offset: 0
08:50:49:008 | MD |     INFO  | +31    | Module Setting - [Settings] - UseGui: false
08:50:50:008 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - UseGui: false
08:50:50:039 | MD |     INFO  | +31    | Module Setting - [Settings] - FloppySpeed: turbo
08:50:50:086 | MD |     INFO  | +47    | Module Setting - [688AttackSub_v1.1_0093] - FloppySpeed: turbo
08:50:50:117 | MD |     INFO  | +31    | Module Setting - [Settings] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:50:50:149 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:50:50:149 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToExtraDrive:
08:50:50:149 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - PathToExtraDrive:
08:50:50:149 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - UseMouse: false
08:50:50:149 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - DelayHack: false
08:50:50:180 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - RequiresWB: false
08:50:50:180 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: NTSC
08:50:50:180 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - VideoMode: NTSC
08:50:50:211 | MD |     INFO  | +32    | Module Setting - [Display] - XResolution: 1920
08:50:50:258 | MD |     INFO  | +46    | Module Setting - [688AttackSub_v1.1_0093] - XResolution: 1920
08:50:50:258 | MD |     INFO  | +0     | Module Setting - [Display] - YResolution: 1080
08:50:50:305 | MD |     INFO  | +47    | Module Setting - [688AttackSub_v1.1_0093] - YResolution: 1080
08:50:50:305 | MD |     INFO  | +0     | Module Setting - [Display] - BlackerThanBlack: false
08:50:50:305 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - BlackerThanBlack: false
08:50:50:305 | MD |     INFO  | +0     | Module Setting - [Display] - RemoveInterlaceArtifacts: false
08:50:50:305 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - RemoveInterlaceArtifacts: false
08:50:50:336 | MD |     INFO  | +31    | Module Setting - [Display] - LineMode:
08:50:50:336 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - LineMode:
08:50:50:336 | MD |     INFO  | +0     | Module Setting - [Display] - AutoScale: scale
08:50:50:367 | MD |     INFO  | +32    | Module Setting - [688AttackSub_v1.1_0093] - AutoScale: scale
08:50:50:367 | MD |     INFO  | +0     | Module Setting - [Display] - ShaderMask:
08:50:50:367 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - ShaderMask:
08:50:50:367 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:
08:50:50:367 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - FilterShader:
08:50:50:398 | MD |     INFO  | +31    | Module Setting - [Display] - FilterShaderScale:
08:50:50:445 | MD |     INFO  | +47    | Module Setting - [688AttackSub_v1.1_0093] - FilterShaderScale:
08:50:50:492 | MD |     INFO  | +46    | Module Setting - [Display] - FilteredLowResolution:
08:50:50:523 | MD |     INFO  | +32    | Module Setting - [688AttackSub_v1.1_0093] - FilteredLowResolution:
08:50:50:554 | MD |     INFO  | +31    | Module Setting - [Display] - ResolutionMode: superhires
08:50:50:554 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - ResolutionMode: superhires
08:50:50:585 | MD |     INFO  | +31    | Module Setting - [CPU] - CPU:
08:50:50:632 | MD |     INFO  | +47    | Module Setting - [688AttackSub_v1.1_0093] - CPU:
08:50:50:663 | MD |     INFO  | +31    | Module Setting - [CPU] - CpuSpeed: real
08:50:50:663 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - CpuSpeed: real
08:50:50:695 | MD |     INFO  | +31    | Module Setting - [CPU] - CpuCycleExact:
08:50:50:741 | MD |     INFO  | +47    | Module Setting - [688AttackSub_v1.1_0093] - CpuCycleExact:
08:50:50:773 | MD |     INFO  | +31    | Module Setting - [CPU] - CpuCompatible: false
08:50:50:773 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - CpuCompatible: false
08:50:50:773 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false
08:50:50:804 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - MMU: false
08:50:50:851 | MD |     INFO  | +47    | Module Setting - [CPU] - DisableUnimplementedCPU: true
08:50:50:882 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - DisableUnimplementedCPU: true
08:50:50:882 | MD |     INFO  | +0     | Module Setting - [CPU] - FPU:
08:50:50:882 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - FPU:
08:50:50:913 | MD |     INFO  | +32    | Module Setting - [CPU] - MoreCompatibleFPU: false
08:50:50:960 | MD |     INFO  | +46    | Module Setting - [688AttackSub_v1.1_0093] - MoreCompatibleFPU: false
08:50:50:007 | MD |     INFO  | +47    | Module Setting - [CPU] - DisableUnimplementedFPU: true
08:50:51:007 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - DisableUnimplementedFPU: true
08:50:51:007 | MD |     INFO  | +0     | Module Setting - [CPU] - CacheSize: 0
08:50:51:007 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - CacheSize: 0
08:50:51:007 | MD |     INFO  | +0     | Module Setting - [CPU] - 24-BitAddressing: true
08:50:51:038 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - 24-BitAddressing: true
08:50:51:038 | MD |     INFO  | +0     | Module Setting - [Chipset] - CycleExact: true
08:50:51:038 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - CycleExact: true
08:50:51:069 | MD |     INFO  | +32    | Module Setting - [Chipset] - ImmediateBlitter: "false"
08:50:51:069 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - ImmediateBlitter: "false"
08:50:51:069 | MD |     INFO  | +0     | Module Setting - [Chipset] - BlitterCycleExact:
08:50:51:069 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - BlitterCycleExact:
08:50:51:100 | MD |     INFO  | +31    | Module Setting - [Chipset] - CollisionLevel:
08:50:51:147 | MD |     INFO  | +47    | Module Setting - [688AttackSub_v1.1_0093] - CollisionLevel:
08:50:51:147 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:
08:50:51:178 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - ChipMemory:
08:50:51:225 | MD |     INFO  | +47    | Module Setting - [RAM] - FastMemory:
08:50:51:225 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - FastMemory:
08:50:51:272 | MD |     INFO  | +46    | Module Setting - [RAM] - AutoConfigFastMemory:
08:50:51:272 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - AutoConfigFastMemory:
08:50:51:272 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:
08:50:51:272 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - SlowMemory:
08:50:51:303 | MD |     INFO  | +32    | Module Setting - [RAM] - Z3FastMemory:
08:50:51:303 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - Z3FastMemory:
08:50:51:303 | MD |     INFO  | +0     | Module Setting - [RAM] - MegaChipMemory:
08:50:51:303 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - MegaChipMemory:
08:50:51:334 | MD |     INFO  | +31    | Module Setting - [RAM] - ProcessorSlotFast:
08:50:51:334 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - ProcessorSlotFast:
08:50:51:334 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGCardType:
08:50:51:365 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - RTGCardType:
08:50:51:365 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGVRAMSize:
08:50:51:365 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - RTGVRAMSize:
08:50:51:365 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGHardwareSprite:
08:50:51:365 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - RTGHardwareSprite:
08:50:51:397 | MD |     INFO  | +31    | Module Setting - [WHDLoad] - PathToWHDFolder: .\HDD\WHD
08:50:51:397 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - PathToWHDFolder: .\HDD\WHD
08:50:51:397 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD
08:50:51:397 | MD |     INFO  | +0     | Module Setting - [688AttackSub_v1.1_0093] - WHDLoadOptions: PRELOAD
08:50:51:397 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - NeverExtract: false
08:50:51:428 | MD |     INFO  | +31    | Module Setting - [688AttackSub_v1.1_0093] - NeverExtract: false
08:50:51:428 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:50:51:428 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			0 bytes
					Created:			6/30/2017 - 10:03:57 PM
					Modified:			6/30/2017 - 10:07:49 PM
08:50:51:521 | MD |     INFO  | +94    | Run - Running: D:\Arcade\emulators\WinUAE 3.1\winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.zip"  -portable
08:50:51:755 | MD |   DEBUG1  | +234   | Run - "winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\688AttackSub_v1.1_0093.zip"  -portable" Process ID: 4356
08:50:51:755 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: BlackScreen | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0xa032e | Process ID: 1696 | Process Path: D:\Arcade\RocketLauncher\RocketLauncher.exe
08:50:51:755 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"
08:50:52:378 | MD |   DEBUG1  | +624   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x1702da | Process ID: 4356 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:50:52:381 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x1702da | Process ID: 4356 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:50:52:385 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
08:50:52:516 | MD |   DEBUG1  | +140   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x1702da | Process ID: 4356 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:50:52:549 | MD |     INFO  | +32    | Process - WaitClose winuae.exe
08:51:31:623 | MD |   DEBUG1  | +39078 | CloseProcess - Started, user requested to end launched application
08:51:31:626 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:51:31:628 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			0 bytes
08:51:31:748 | MD |   DEBUG1  | +125   | CloseProcess - Ended
08:51:31:862 | MD |     INFO  | +109   | StopGlobalUserFeatures - Starting
08:51:31:862 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
08:51:31:862 | MD |     INFO  | +0     | ExitModule - Started
08:51:31:862 | MD |     INFO  | +0     | Starting Updating Statistics:
08:51:31:893 | MD |   DEBUG2  | +31    | Total Elapsed Time in Pause in seconds: 0
08:51:31:893 | MD |   DEBUG2  | +0     | gameSectionStartTime:3777938
08:51:31:893 | MD |   DEBUG2  | +0     | ElapsedTime:42
08:51:31:924 | MD |   DEBUG2  | +31    | Statistics cleared game name: 688AttackSub_v1.1_0093
08:51:32:018 | MD |   DEBUG2  | +94    | Loaded game statistics from ini files:
					Number_of_Times_Played: 2
					Last_Time_Played: Monday October 5, 2015 07:50:31 PM
					Average_Time_Played: 41
					Total_Time_Played: 82
					System_Total_Played_Time: 965
					Total_Global_Played_Time: 2621
08:51:32:018 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 3
					Last_Time_Played: Saturday July 1, 2017 08:50:49 AM
					Total_Time_Played: 124
					System_Total_Played_Time: 1007
					Total_Global_Played_Time: 2663
08:51:32:142 | MD |     INFO  | +125   | Game section statistics updated.
08:51:32:142 | MD |     INFO  | +0     | Restoring mouse cursor
08:51:32:174 | MD |     INFO  | +31    | ExitModule - Ended
08:51:32:174 | MD |     INFO  | +0     | End of Module Logs
08:51:32:236 | RL |     INFO  | +43727 | Main - Module ended, exiting RocketLauncher normally
08:51:32:236 | RL |     INFO  | +0     | ExitScript - Started
08:51:32:252 | RL |   DEBUG1  | +16    | ExitScript - Unhiding taskbar
08:51:32:470 | RL |     INFO  | +218   | SystemCursor - Restoring mouse cursor
08:51:32:486 | RL |     INFO  | +16    | ExitScript - Ended
[/code]
[code]
08:52:35:381 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
08:52:35:490 | RL |     INFO  | +110   | Main - System Specs:
					RocketLauncher Dir: D:\Arcade\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8163.35 MB
					Free Memory: 5323.65 MB
					Used Memory: 2839.703 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: NVIDIA GeForce 210
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 21.21.13.4201
					Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
					Sound 1 Status: Enabled
					Sound 2 Device: NVIDIA High Definition Audio
					Sound 2 Status: Enabled
					Sound 3 Device: NVIDIA High Definition Audio
					Sound 3 Status: Enabled
					Sound 4 Device: Realtek High Definition Audio
					Sound 4 Status: Enabled
					Sound 5 Device: Bluetooth Audio
					Sound 5 Status: Enabled
					Sound 6 Device: NVIDIA High Definition Audio
					Sound 6 Status: Enabled
					Sound 7 Device: NVIDIA High Definition Audio
					Sound 7 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
08:52:35:490 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
08:52:35:490 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.3
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2061824 bytes
					Created:			9/23/2015 - 10:21:14 PM
					Modified:			8/30/2015 - 6:53:55 AM
08:52:35:506 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk exists
08:52:35:506 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:506 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4961 bytes
					Modified:			12/28/2014 - 12:53:36 PM
08:52:35:506 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
08:52:35:521 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk exists
08:52:35:537 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
08:52:35:537 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Modified:			8/30/2015 - 6:53:49 AM
08:52:35:537 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
08:52:35:537 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			5716 bytes
08:52:35:537 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk exists
08:52:35:553 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:52:35:553 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
08:52:35:553 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk exists
08:52:35:553 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5895 bytes
					Modified:			7/6/2015 - 6:15:22 AM
08:52:35:553 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
08:52:35:568 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gsdll32.dll exists
08:52:35:568 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			13090816 bytes
					Modified:			1/8/2015 - 5:54:04 PM
08:52:35:568 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\itextsharp.dll exists
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			9/23/2015 - 10:21:15 PM
08:52:35:568 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Java.ahk exists
08:52:35:615 | RL |   DEBUG1  | +46    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:615 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
08:52:35:615 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
08:52:35:615 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk exists
08:52:35:631 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:52:35:631 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			9203 bytes
08:52:35:631 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk exists
08:52:35:646 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:662 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			4904 bytes
					Modified:			5/4/2015 - 9:16:07 AM
08:52:35:662 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
08:52:35:662 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk exists
08:52:35:677 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:52:35:677 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
08:52:35:677 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk exists
08:52:35:693 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
08:52:35:709 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			67561 bytes
08:52:35:709 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
08:52:35:709 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
08:52:35:709 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk exists
08:52:35:724 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:724 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5347 bytes
					Modified:			5/4/2015 - 9:16:38 AM
08:52:35:724 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
08:52:35:724 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA.ahk exists
08:52:35:740 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
08:52:35:740 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
08:52:35:755 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk exists
08:52:35:755 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:755 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Modified:			1/30/2015 - 8:39:01 PM
08:52:35:755 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
08:52:35:755 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\7z.ahk exists
08:52:35:802 | RL |   DEBUG1  | +47    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:818 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			29013 bytes
					Modified:			8/30/2015 - 6:53:50 AM
08:52:35:818 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.1
08:52:35:818 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Bezel.ahk exists
08:52:35:833 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:833 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			102587 bytes
					Modified:			7/6/2015 - 6:15:20 AM
08:52:35:849 | RL |   DEBUG1  | +15    | Bezel.ahk Version: 1.1.2
08:52:35:849 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade.ahk exists
08:52:35:849 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:865 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			38048 bytes
					Modified:			9/18/2015 - 8:22:33 AM
08:52:35:865 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.2
08:52:35:865 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Init.ahk exists
08:52:35:880 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:896 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			999 bytes
08:52:35:896 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
08:52:35:896 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk exists
08:52:35:911 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:911 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			79882 bytes
08:52:35:911 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.8
08:52:35:927 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause.ahk exists
08:52:35:943 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:943 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392698 bytes
08:52:35:943 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.4
08:52:35:958 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause Init.ahk exists
08:52:35:958 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:958 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			553 bytes
					Modified:			8/30/2015 - 6:53:41 AM
08:52:35:958 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
08:52:35:974 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper.ahk exists
08:52:35:974 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:35:974 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Modified:			5/21/2015 - 10:33:10 PM
08:52:35:989 | RL |   DEBUG1  | +16    | Keymapper.ahk Version: 1.1.2
08:52:35:989 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk exists
08:52:35:021 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:021 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
08:52:36:021 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
08:52:36:036 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame.ahk exists
08:52:36:036 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:052 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			40753 bytes
					Modified:			8/30/2015 - 6:53:37 AM
08:52:36:052 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
08:52:36:052 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk exists
08:52:36:067 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:067 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
08:52:36:067 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
08:52:36:067 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk exists
08:52:36:083 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:083 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			58770 bytes
					Modified:			7/9/2015 - 7:36:01 AM
08:52:36:083 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
08:52:36:099 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Password.ahk exists
08:52:36:099 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:099 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10025 bytes
					Modified:			8/30/2015 - 6:53:44 AM
08:52:36:114 | RL |   DEBUG1  | +16    | Password.ahk Version: 1.0.2
08:52:36:114 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
08:52:36:130 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:130 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			73772 bytes
08:52:36:145 | RL |   DEBUG1  | +16    | Rom Mapping Launch Menu.ahk Version: 1.0.5
08:52:36:145 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Shared.ahk exists
08:52:36:177 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:177 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			116503 bytes
					Modified:			8/30/2015 - 6:53:45 AM
08:52:36:177 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.2
08:52:36:192 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics.ahk exists
08:52:36:192 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:192 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26143 bytes
					Modified:			5/4/2015 - 9:16:52 AM
08:52:36:208 | RL |   DEBUG1  | +15    | Statistics.ahk Version: 1.0.3
08:52:36:208 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk exists
08:52:36:223 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:239 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			33 bytes
08:52:36:239 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
08:52:36:239 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk exists
08:52:36:239 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:255 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			17070 bytes
08:52:36:255 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.1
08:52:36:255 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey.ahk exists
08:52:36:286 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:286 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26540 bytes
					Modified:			8/30/2015 - 6:53:48 AM
08:52:36:286 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
08:52:36:301 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk exists
08:52:36:301 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:52:36:301 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1063 bytes
					Modified:			8/30/2015 - 6:53:38 AM
08:52:36:317 | RL |   DEBUG1  | +15    | XHotkey Init.ahk Version: 1.0.2
08:52:36:317 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r 1943_v1.2 -f D:\Arcade\HyperSpin.exe -p HyperSpin -c 1"
08:52:36:317 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "1943_v1.2"
08:52:36:317 | RL |   DEBUG1  | +0     | Main - dbName: 1943_v1.2
08:52:36:333 | RL |     INFO  | +16    | Main - Loading Front End Plugin: "HyperSpin"
08:52:36:333 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "1943_v1.2"
08:52:36:348 | RL |     INFO  | +16    | Main - Did not find a "D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.
08:52:36:348 | RL |     INFO  | +0     | Main - 1943_v1.2 is using the default emulator: WinUAE
08:52:36:348 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Emulators.ini
08:52:36:348 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:52:36:364 | RL |     INFO  | +15    | Main - Found [WinUAE] in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:52:36:364 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists
08:52:36:364 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			23651 bytes
					Created:			9/23/2015 - 10:21:16 PM
					Modified:			8/30/2015 - 6:53:51 AM
08:52:36:379 | RL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
08:52:36:379 | RL |     INFO  | +0     | Main - 1943_v1.2 will use module: D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
08:52:36:411 | RL |     INFO  | +31    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
08:52:36:457 | RL |     INFO  | +47    | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\winuae.exe exists
08:52:36:473 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					FileDescription         	WinUAE
					FileVersion             	3.1.0.0
					InternalName            	WinUAE
					LegalCopyright          	� 1996-2015 under the GNU Public License (GPL)
					OriginalFilename        	WinUAE.exe
					ProductName             	WinUAE
					ProductVersion          	3.1.0.0
					File Size:			12417112 bytes
					Created:			6/30/2017 - 10:03:59 PM
					Modified:			6/7/2015 - 6:41:10 AM
08:52:36:473 | RL |     INFO  | +0     | Main - INI Keys read
08:52:36:473 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.exe exists
08:52:36:473 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
08:52:36:489 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.dll exists
08:52:36:489 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
08:52:36:520 | RL |     INFO  | +31    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\FontReg.exe exists
08:52:36:520 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	Font Registration Utility (x86-32)
					FileVersion             	2.1.3.0
					OriginalFilename        	FontReg.exe
					File Size:			6144 bytes
08:52:36:551 | RL |     INFO  | +31    | Main - "1943_v1.2" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
08:52:36:551 | RL |     INFO  | +0     | CheckPaths - Started
08:52:36:551 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.adf
08:52:36:567 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.adf
08:52:36:567 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.adf
08:52:36:567 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.hdf
08:52:36:567 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.hdf
08:52:36:567 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.hdf
08:52:36:567 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.cue
08:52:36:567 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.cue
08:52:36:567 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.cue
08:52:36:582 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.iso
08:52:36:582 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.iso
08:52:36:582 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.iso
08:52:36:582 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip
08:52:36:582 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip
08:52:36:582 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: 1943_v1.2
08:52:36:598 | RL |   DEBUG1  | +15    | CheckPaths - Current romPath: D:\Arcade\Commodore Amiga\roms
08:52:36:598 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
08:52:36:598 | RL |     INFO  | +0     | CheckPaths - Ended
08:52:36:598 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Arcade\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.3
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Arcade\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Arcade
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc|H1000:1joy7
					restoreFE = Restore
					exitScriptKey = `
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Arcade\emulators\WinUAE 3.1\winuae.exe
					emuPath = D:\Arcade\emulators\WinUAE 3.1
					emuName = WinUAE
					emuExt = exe
					romPath = D:\Arcade\Commodore Amiga\roms
					romPathFromIni = D:\Arcade\Commodore Amiga\roms
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = adf|hdf|cue|iso|zip|lha|7z|uae|adz|dms|fdi|uss|slave
					executable = winuae.exe
					systemDbName = Commodore Amiga
					systemName = Commodore Amiga
					dbPath =
					dbName = 1943_v1.2
					dbExt =
					romName = 1943_v1.2
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = true
					blockInputTime = 0
					blockInputFile = D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Arcade\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = false
					vdDriveLetter =
					vdAddDrive = false
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Arcade\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Arcade\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 5000
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Arial
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Arcade\RocketLauncher\Media\Fade
					RLDataPath = D:\Arcade\RocketLauncher\Data
					RLMediaPath = D:\Arcade\RocketLauncher\Media
					RLErrSoundPath = D:\Arcade\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Arcade\RocketLauncher\Modules
					moduleFullName = D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
					moduleName = WinUAE
					modulePath = D:\Arcade\RocketLauncher\Modules\WinUAE
					moduleExtension = ahk
					moduleExtensionsPath = D:\Arcade\RocketLauncher\Module Extensions
					libPath = D:\Arcade\RocketLauncher\Lib
					7zEnabled = false
					7zPath = D:\Arcade\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Arcade\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = D:\Arcade\cache
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = false
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = Pause
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Arcade\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Arcade\Tools\Xpadder\xpadder.exe
					joyToKeyFullPath = C:\Windows\Utilities\VJoy\VJoy.exe
					keymapperProfilePath = D:\Arcade\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = ahk
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Rock Candy Gamepad for Xbox 360)|Controller (XBOX 360 For Windows)|Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit = Controller (Rock Candy Gamepad for Xbox 360)|Controller (Xbox 360 Wireless Receiver for Windows)
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga
					xPadderSystemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default
					emuProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE
					romProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\1943_v1.2
					RocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Arcade\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Arcade\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga
					ahkEmuProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAE
					ahkRomProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\1943_v1.2
					ahkRocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Arcade\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Arcade\RocketLauncher\Lib\User Fade Animations.ini
08:52:36:598 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
08:52:36:598 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
08:52:36:613 | RL |     INFO  | +16    | BuildScript - Loaded Statistics Init.ahk scripts
08:52:36:613 | RL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
08:52:36:613 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
08:52:36:613 | RL |     INFO  | +0     | BuildScript - Validating module
08:52:36:613 | RL |     INFO  | +0     | BuildScript - Validation complete
08:52:36:629 | RL |     INFO  | +15    | BuildScript - Module:
					MEmu = WinUAE
					MEmuV =  v3.0.0
					MURL = http://www.winuae.net/
					MAuthor = brolly,Turranius
					MVersion = 2.1.9
					MCRC = 4C755A18
					iCRC = AFD49B34
					mId = 635138307631183750
					MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
					; Notes:
					; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
					; Just name them the same as the game name on the XML file.
					; Make sure you create a host config files with these names:
					; CD32 : cd32host.uae and cd32mousehost.uae;
					; CDTV : cdtvhost.uae and cdtvmousehost.uae;
					; Amiga : amigahost.uae;
					; Amiga CD : amigacdhost.uae;
					; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
					; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
					; a joystick and a mouse on Port1 and only a joystick on Port2.
					; Set all your other preferences like video display settings. And make sure you are saving a HOST
					; configuration file and not a general configuration file.
					; If you want to configure an exit key through WinUAE:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
					; If you want to configure a key to toggle fullscreen/windowed mode:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
					; CD32 and CDTV:
					; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
					; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
					; [Lemmings (Europe)]
					; UseMouse=true
					; [Project-X & F17 Challenge (Europe)]
					; DelayHack=true
					; Amiga:
					; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
					; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
					; END+SHIFT+1-0 = insert image from swapper slot 11-20
					; END+CTRL+1-4 = select drive
					; To do that follow the same procedure as above for the exit
					; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
					; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
					; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
					; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
					; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
					; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
					; Amiga CD:
					; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.
					; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).
					; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set
					; RequiresWB to false.
					; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:
					; http://www.winuae.net/
					; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory
					StartModule()
					BezelGUI()
					FadeInStart()
					settingsFile := modulePath . "\" . systemName . ".ini"
					; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.
					mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
					ident := mType[systemName]	; search object for the systemName identifier MESS uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
					specialcfg = %emuPath%\Configurations\%romName%.uae
					If romExtension in .hdf,.vhd
						DefaultRequireWB := "true"
					Else
						DefaultRequireWB := "false"
					If romExtension in .zip,.lha,.rar,.7z
						SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")
						If (SlaveFile) {
							If romName contains (AGA)
								defaultCycleExact := "false"
								defaultCpuSpeed := "max"
							} Else {
								defaultCycleExact := "true"
								defaultCpuSpeed := "real"
							defaultImmediateBlittler = "false"
							defaultCpuCompatible := "false"
							defaultCacheSize := "0" ;8192
					If (ident = "amigacd") {
						DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to true
						defaultz3Ram := "128"
						isAmigaCd := "true"
					; Settings
					FS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)
					quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)
					kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)
					options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)
					bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)
					bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)
					bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)
					bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)
					use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)
					floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)
					PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
					PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
					pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)
					If (pathtoextradrive)
						pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive)
					usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32
					delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32
					requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
					; Display
					videomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)
					gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)
					gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)
					gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)
					gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)
					gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)
					gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)
					gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)
					gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)
					gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)
					gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)
					gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1)
					; CPU
					cpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)
					cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)
					cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)
					cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)
					mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)
					cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)
					fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)
					fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)
					fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)
					cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)
					24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1)
					; Chipset
					cycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)
					immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
					blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)
					collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1)
					; RAM
					chipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)
					fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)
					autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)
					slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)
					z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)
					megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)
					processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1)
					; Expansions
					rtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)
					rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)
					rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1)
					; WHDLoad
					PathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
					PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
					whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)
					neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1)
					BezelStart()
					; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modes
					If bezelPath {
						FS := "fullwindow"
						gfx_filter_autoscale := "scale"
					windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
					If (FS = "true" or FS = "fullwindow")
						windowClass = AmigaPowah
					If (cpucycleexact and blittercycleexact)
						cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
					if (cpu != "68060" and cpu_no_unimplemented)
						cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.}
					; Make sure 24bitaddressing is false if using Z3 memory.
					If z3fastmemory
						24bitaddressing := "false"
					;Fill both z3 slots when amount of RAM requires it
					If (z3fastmemory = "384") {
						z3fastmemory = "256"
						z3fastmemoryb = "128"
					} Else If (z3fastmemory = "768") {
						z3fastmemory = "512"
						z3fastmemoryb = "256"
					} Else If (z3fastmemory = "1536") {
						z3fastmemory = "1024"
						z3fastmemoryb = "512"
					videomode := If videomode = "NTSC" ? "-s ntsc=true" : ""
					If (requireswb = "true") {
						ident := "a1200"
						CheckFile(PathToWorkBenchBase)
						wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
						ident := "a1200"
						gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
						CheckFile(pathtoextradrive,,,,,,1) ;allow folders
						If InStr(FileExist(pathtoextradrive), "D") ;it's a folder
							extraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"
						Else ;it's a file
							SplitPath, pathtoextradrive,,,extradriveExtension
							If extradriveExtension in .hdf,.vhd
								extraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"
							Else
								extraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"
					options := options . " " . videomode
					If (ident = "a500" or ident = "a1200") {
						If romName contains (AGA),(LW)
							ident := "a1200"
						If (SlaveFile) {
							CheckFolder(PathToWHDFolder)
							ident := "a1200"
							;Create the user-startup file to launch the game
							WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
							SplitPath, SlaveFile, SlaveName, SlaveFolder
							FileDelete, %WHDUserStartupFile%
							FileAppend, echo "";`n, %WHDUserStartupFile%
							FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
							FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
							FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
					hideEmuObj := Object("ahk_class " . windowClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
					If FileExist(specialcfg) {
						;Game specific configuration file exists
						configFile = %romName%.uae
					} Else {
						;Game specific configuration file doesn't exist
						If (ident = "cd32" or ident = "cdtv") {
							configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
							quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						} Else {
							;Amiga or Amiga CD game
							configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
							If quickstartmode
								quickcfg := "-s quickstart=" . quickstartmode
							Else
								quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")
					;--- Setting up command line arguments to use ---
					; Global command line arguments.
					If use_gui
						options := options . " -s use_gui=" . use_gui
					If (FS = "true") {
						options := options . " -s gfx_width_fullscreen=" . gfx_width
						options := options . " -s gfx_height_fullscreen=" . gfx_height
					} Else If (FS = "false") {
						If (gfx_width != "native" and gfx_height != "native") {
							options := options . " -s gfx_width_windowed=" . gfx_width
							options := options . " -s gfx_height_windowed=" . gfx_height
					If gfx_linemode
						options := options . " -s gfx_linemode=" . gfx_linemode
					If gfx_filter_autoscale
						options := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscale
					If gfx_blacker_than_black
						options := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_black
					If gfx_flickerfixer
						options := options . " -s gfx_flickerfixer=" . gfx_flickerfixer
					If gfx_filter_mode
						options := options . " -s gfx_filter_mode=" . gfx_filter_mode
					If (gfx_lores_mode = "true")
						options := options . " -s gfx_lores_mode=filtered"
					Else If (gfx_lores_mode = "false")
						options := options . " -s gfx_lores_mode=normal"
					If gfx_resolution {
						options := options . " -s gfx_resolution=" . gfx_resolution
						If (gfx_resolution = "lores") {
							options := options . " -s gfx_autoresolution_vga=false"
							options := options . " -s gfx_lores=true"
						Else {
							options := options . " -s gfx_lores=false"
					If gfx_filter_mask {
						gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_mask
						LOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)
						If FileExist(gfx_filter_mask_path)
							options := options . " -s gfx_filter_mask=" . gfx_filter_mask
					If gfx_filter {
						If (SubStr(gfx_filter, 1, 4) = "D3D:") {
							StringTrimLeft, FilterFileName, gfx_filter, 4
							FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileName
							If FileExist(FilterFile)
								options := options . " -s gfx_filter=" . gfx_filter
						} Else {
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					} Else {
						If floppyspeed
							options := options . " -s floppy_speed=" . floppyspeed
						If kickstart_rom_file
							options := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"
						If (cachesize || cachesize = "0")
							options := options . " -s cachesize=" . cachesize
						If immediateblitter
							options := options . " -s immediate_blits=" . immediateblitter
						If cycleexact
							options := options . " -s cycle_exact=" . cycleexact
						If cpucycleexact
							options := options . " -s cpu_cycle_exact=" . cpucycleexact
						If blittercycleexact
							options := options . " -s blitter_cycle_exact=" . blittercycleexact
						If cpucompatible
							options := options . " -s cpu_compatible=" . cpucompatible
						If cpuspeed
							options := options . " -s cpu_speed=" . cpuspeed
						If cpu
							options := options . " -s cpu_model=" . cpu
						If cpu_no_unimplemented
							options := options . " -s cpu_no_unimplemented=" . cpu_no_unimplemented
						If (mmu_model = "true")
							options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.
						If 24bitaddressing
							options := options . " -s cpu_24bit_addressing=" . 24bitaddressing
						If fpu
							options := options . " -s fpu_model=" . fpu
						If fpu_strict
							options := options . " -s fpu_strict=" . fpu_strict
						If fpu_no_unimplemented
							options := options . " -s fpu_no_unimplemented=" . fpu_no_unimplemented
						If collisionlevel
							options := options . " -s collision_level=" . collisionlevel
						If chipmemory
							options := options . " -s chipmem_size=" . chipmemory
						If fastmemory
							options := options . " -s fastmem_size=" . fastmemory
						If autoconfigfastmemory
							options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
						If slowmemory
							options := options . " -s bogomem_size=" . slowmemory
						If z3fastmemory
							options := options . " -s z3mem_size=" . z3fastmemory
						If z3fastmemoryb
							options := options . " -s z3mem2_size=" . z3fastmemoryb
						If megachipmemory
							options := options . " -s megachipmem_size=" . megachipmemory
						If processorslotfastmemory
							options := options . " -s mbresmem_size=" . processorslotfastmemory
						If rtgcardtype
							options := options . " -s gfxcard_type=" . rtgcardtype
						If rtgvramsize
							options := options . " -s gfxcard_size=" . rtgvramsize
						If rtghardwaresprite
							options := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite
						If (SlaveFile) {
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive) {
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
							;Check if there's also a CD to load
							IfExist, %romPath%\%romName%.cue
								cdDrive := romPath . "\" . romName . ".cue"
							IfExist, %romPath%\%romName%.iso
								cdDrive := romPath . "\" . romName . ".iso"
							IfExist, %romPath%\%romName%.mds
								cdDrive := romPath . "\" . romName . ".mds"
							If extraDrive
								options := options . " " . extraDrive
							If cdDrive
								options := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else If romExtension in .cue,.iso,.mds
							;Amiga CD game
							;Check if game has a HDD installation
							IfExist, %romPath%\%romName%.hdf
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"
							IfExist, %romPath%\%romName%.vhd
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """"
							options := options . " " . wbDrive . installedHdd
							If extraDrive
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else {
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menu
								If romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							If romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
					configFileFullPath := EmuPath . "\Configurations\" . configFile
					;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfg
					If FileExist(configFileFullPath)
					param1 := param1 . " " . quickcfg
					param2 := "-s gfx_fullscreen_amiga=" . FS
					param3 := options
					HideEmuStart()
					Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
					If (use_gui = "true") {
						WinWait("WinUAE Properties",,60)
						FadeInExit()
						WinWaitClose("WinUAE Properties")
						Sleep, 100
						Process("Exist",executable)
						If (ErrorLevel=0) {
							7zCleanUp()
							ExitModule()
					WinWait("ahk_class " . windowClass)
					WinWaitActive("ahk_class " . windowClass)
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					Process("WaitClose",executable)
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					MultiGame:
						If currentButton = 10
							diskslot = 0
						Else If currentButton > 10
							diskslot := currentButton - 10
						Else
							Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
						Else
							Send, {End Down}%diskslot%{End Up}
					Return
					CloseProcess:
							If (SlaveFile) {
								;Copy default-user-startup to user-startup if file exists
								IfExist, %PathToWHDFolder%\S\default-user-startup
									FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
						FadeOutStart()
						WinClose, ahk_class %windowClass%
					Return
08:52:36:629 | RL |     INFO  | +0     | BuildScript - Loaded Pause scripts
08:52:36:645 | RL |     INFO  | +16    | BuildScript - Loaded Multi-Player scripts
08:52:36:660 | RL |     INFO  | +16    | BuildScript - Loaded Statistics.ahk script
08:52:36:660 | RL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
08:52:36:660 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
08:52:36:660 | RL |     INFO  | +0     | Main - Module is built
08:52:36:660 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\AutoHotkey.dll exists
08:52:36:676 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			12/28/2014 - 12:53:35 PM
08:52:36:676 | RL |     INFO  | +0     | Main - Hiding taskbar
08:52:36:894 | RL |     INFO  | +219   | Main - Hiding desktop
08:52:36:894 | RL |     INFO  | +0     | Main - Running module
08:52:36:894 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
08:52:37:050 | MD |     INFO  | +N/A   | Module initialized
08:52:37:050 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:52:37:081 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
08:52:37:113 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 1 check
08:52:37:159 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 2 check
08:52:37:159 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
08:52:37:206 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Ended
08:52:37:253 | MD |   DEBUG2  | +46    | XHotkeyTableCreation - Started
08:52:37:284 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - KeyGroup ~1joy7 not in TableKeyGroups ~Esc,
08:52:37:331 | MD |   DEBUG2  | +46    | XHotkeyTableCreation - Post loop 1 check
08:52:37:378 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Post loop 2 check
08:52:37:378 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
08:52:37:425 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Ended
08:52:37:425 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:52:37:471 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - KeyGroup ~Pause not in TableKeyGroups ~Esc,~1joy7,
08:52:37:471 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:52:37:471 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:52:37:471 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Pause" to call label: "TogglePauseMenuStatus"
08:52:37:471 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:52:37:503 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:52:37:503 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1joy7,~Pause,
08:52:37:503 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:52:37:503 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:52:37:503 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
08:52:37:534 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Ended
08:52:37:534 | MD |     INFO  | +0     | StartModule - Started
08:52:37:534 | MD |     INFO  | +0     | StartModule - MEmu: WinUAE
					MEmuV: v3.0.0
					MURL: http://www.winuae.net/
					MAuthor: brolly,Turranius
					MVersion: 2.1.9
					MCRC: 4C755A18
					iCRC: AFD49B34
					MID:
					MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
08:52:37:534 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
08:52:37:534 | MD |     INFO  | +0     | PluginInit - Started
08:52:37:534 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
08:52:37:534 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\Databases\Commodore Amiga\Commodore Amiga.xml exists
08:52:37:565 | MD |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			568042 bytes
					Created:			4/5/2014 - 6:11:31 AM
					Modified:			3/20/2015 - 5:37:41 PM
08:52:37:612 | MD |   DEBUG1  | +47    | BuildDatabaseTable - Searching for a "Game Name" in the database
08:52:37:612 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
08:52:37:612 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
08:52:37:612 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "1943 - The Battle of Midway"
08:52:37:643 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Cloneof
08:52:37:690 | MD |   DEBUG1  | +47    | BuildDatabaseTable - Could not find: Cloneof
08:52:37:737 | MD |   DEBUG1  | +47    | BuildDatabaseTable - Searching database for: Manufacturer
08:52:37:783 | MD |   DEBUG1  | +47    | BuildDatabaseTable - Could not find: Manufacturer
08:52:37:815 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Year
08:52:37:861 | MD |   DEBUG1  | +47    | BuildDatabaseTable - Could not find: Year
08:52:37:861 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
08:52:37:861 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre
08:52:37:861 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
08:52:37:861 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
08:52:37:893 | MD |   DEBUG2  | +31    | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value:
					GameInfo Label: Rating | GameInfo Value:
08:52:37:893 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
08:52:37:893 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
08:52:37:893 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\Media\Commodore Amiga\Images\Wheel\1943_v1.2.png
08:52:37:924 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a System Logo: D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png
08:52:37:955 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Wheel\1943_v1.2.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system
08:52:37:955 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:52:37:955 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
08:52:37:986 | MD |   DEBUG1  | +32    | BuildAssetsTable - Searching for a Artwork1: D:\Arcade\Media\Commodore Amiga\Images\Artwork1\1943_v1.2.png
08:52:37:986 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Arcade\Media\Commodore Amiga\Images\Artwork2\1943_v1.2.png
08:52:37:986 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Arcade\Media\Commodore Amiga\Images\Artwork3\1943_v1.2.png
08:52:37:017 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Flyers: D:\Arcade\Media\Commodore Amiga\Images\Artwork4\1943_v1.2.png
08:52:38:017 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Arcade\Media\Commodore Amiga\Images\Letters
08:52:38:080 | MD |   DEBUG1  | +62    | BuildAssetsTable - Searching for a Other: D:\Arcade\Media\Commodore Amiga\Images\Other
08:52:38:111 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Box Art | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Artwork2\1943_v1.2.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Cartridge | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Artwork3\1943_v1.2.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Letters | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Arcade\media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Arcade\media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Arcade\media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Arcade\media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Arcade\media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Arcade\media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Arcade\media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Arcade\media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Arcade\media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Arcade\media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Arcade\media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Arcade\media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Arcade\media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Arcade\media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Arcade\media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Arcade\media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Arcade\media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Arcade\media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Arcade\media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Arcade\media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Arcade\media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Arcade\media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Arcade\media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Arcade\media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Arcade\media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Arcade\media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Arcade\media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Arcade\media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Arcade\media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Arcade\media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Arcade\media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Arcade\media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Arcade\media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Arcade\media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Arcade\media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Arcade\media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Arcade\media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Arcade\media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
08:52:38:158 | MD |   DEBUG1  | +47    | BuildAssetsTable - Ended
08:52:38:189 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
08:52:38:220 | MD |   DEBUG1  | +32    | BuildAssetsTable - Searching for a MP4 Game Video: D:\Arcade\Media\Commodore Amiga\Video\1943_v1.2.*
08:52:38:220 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a FLV Game Video: D:\Arcade\Media\Main Menu\Video\Commodore Amiga.*
08:52:38:220 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  D:\Arcade\Media\Main Menu\Video\Commodore Amiga.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Video\1943_v1.2.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
08:52:38:220 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:52:38:220 | MD |     INFO  | +0     | PluginInit - Ended
08:52:38:251 | MD |   DEBUG1  | +31    | StartModule - Setting romName to the dbName sent to RocketLauncher: 1943_v1.2
08:52:38:251 | MD |     INFO  | +0     | Hiding mouse cursor
08:52:38:283 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:52:38:314 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,
08:52:38:314 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:52:38:314 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:52:38:361 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
08:52:38:361 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:52:38:361 | MD |     INFO  | +0     | StartModule - Ended
08:52:38:361 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
08:52:38:392 | MD |     INFO  | +31    | StartGlobalUserFeatures - Ending
08:52:38:548 | MD |     INFO  | +156   | Module Setting - [Settings] - ScreenMode: true
08:52:38:548 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - ScreenMode: true
08:52:38:548 | MD |     INFO  | +0     | Module Setting - [Settings] - QuickStartMode:
08:52:38:579 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - QuickStartMode:
08:52:38:626 | MD |     INFO  | +47    | Module Setting - [Settings] - KickstartFile:
08:52:38:626 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - KickstartFile:
08:52:38:626 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:
08:52:38:626 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - Options:
08:52:38:657 | MD |     INFO  | +31    | Module Setting - [Settings] - Bezel_Top_Offset: 0
08:52:38:657 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - Bezel_Top_Offset: 0
08:52:38:657 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Bottom_Offset: 0
08:52:38:657 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - Bezel_Bottom_Offset: 0
08:52:38:688 | MD |     INFO  | +32    | Module Setting - [Settings] - Bezel_Right_Offset: 0
08:52:38:735 | MD |     INFO  | +46    | Module Setting - [1943_v1.2] - Bezel_Right_Offset: 0
08:52:38:735 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 0
08:52:38:782 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - Bezel_Left_Offset: 0
08:52:38:782 | MD |     INFO  | +0     | Module Setting - [Settings] - UseGui: false
08:52:38:782 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - UseGui: false
08:52:38:782 | MD |     INFO  | +0     | Module Setting - [Settings] - FloppySpeed: turbo
08:52:38:860 | MD |     INFO  | +78    | Module Setting - [1943_v1.2] - FloppySpeed: turbo
08:52:38:860 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:52:38:860 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:52:38:907 | MD |     INFO  | +47    | Module Setting - [Settings] - PathToExtraDrive:
08:52:38:907 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - PathToExtraDrive:
08:52:38:907 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - UseMouse: false
08:52:38:907 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - DelayHack: false
08:52:38:938 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - RequiresWB: false
08:52:38:938 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: NTSC
08:52:38:938 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - VideoMode: NTSC
08:52:38:938 | MD |     INFO  | +0     | Module Setting - [Display] - XResolution: 1920
08:52:38:969 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - XResolution: 1920
08:52:38:969 | MD |     INFO  | +0     | Module Setting - [Display] - YResolution: 1080
08:52:38:969 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - YResolution: 1080
08:52:38:969 | MD |     INFO  | +0     | Module Setting - [Display] - BlackerThanBlack: false
08:52:38:969 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - BlackerThanBlack: false
08:52:38:000 | MD |     INFO  | +32    | Module Setting - [Display] - RemoveInterlaceArtifacts: false
08:52:39:047 | MD |     INFO  | +46    | Module Setting - [1943_v1.2] - RemoveInterlaceArtifacts: false
08:52:39:047 | MD |     INFO  | +0     | Module Setting - [Display] - LineMode:
08:52:39:047 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - LineMode:
08:52:39:079 | MD |     INFO  | +32    | Module Setting - [Display] - AutoScale: scale
08:52:39:126 | MD |     INFO  | +46    | Module Setting - [1943_v1.2] - AutoScale: scale
08:52:39:126 | MD |     INFO  | +0     | Module Setting - [Display] - ShaderMask:
08:52:39:173 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - ShaderMask:
08:52:39:173 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:
08:52:39:173 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FilterShader:
08:52:39:173 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShaderScale:
08:52:39:204 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - FilterShaderScale:
08:52:39:204 | MD |     INFO  | +0     | Module Setting - [Display] - FilteredLowResolution:
08:52:39:204 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FilteredLowResolution:
08:52:39:204 | MD |     INFO  | +0     | Module Setting - [Display] - ResolutionMode: superhires
08:52:39:204 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - ResolutionMode: superhires
08:52:39:282 | MD |     INFO  | +78    | Module Setting - [CPU] - CPU:
08:52:39:282 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CPU:
08:52:39:282 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuSpeed: real
08:52:39:329 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - CpuSpeed: real
08:52:39:329 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCycleExact:
08:52:39:329 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CpuCycleExact:
08:52:39:329 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCompatible: false
08:52:39:360 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - CpuCompatible: false
08:52:39:360 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false
08:52:39:360 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - MMU: false
08:52:39:360 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedCPU: true
08:52:39:360 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - DisableUnimplementedCPU: true
08:52:39:391 | MD |     INFO  | +32    | Module Setting - [CPU] - FPU:
08:52:39:438 | MD |     INFO  | +46    | Module Setting - [1943_v1.2] - FPU:
08:52:39:438 | MD |     INFO  | +0     | Module Setting - [CPU] - MoreCompatibleFPU: false
08:52:39:438 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - MoreCompatibleFPU: false
08:52:39:438 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedFPU: true
08:52:39:469 | MD |     INFO  | +32    | Module Setting - [1943_v1.2] - DisableUnimplementedFPU: true
08:52:39:469 | MD |     INFO  | +0     | Module Setting - [CPU] - CacheSize: 0
08:52:39:469 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CacheSize: 0
08:52:39:469 | MD |     INFO  | +0     | Module Setting - [CPU] - 24-BitAddressing: true
08:52:39:500 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - 24-BitAddressing: true
08:52:39:532 | MD |     INFO  | +31    | Module Setting - [Chipset] - CycleExact: true
08:52:39:532 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CycleExact: true
08:52:39:578 | MD |     INFO  | +47    | Module Setting - [Chipset] - ImmediateBlitter: "false"
08:52:39:625 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - ImmediateBlitter: "false"
08:52:39:656 | MD |     INFO  | +31    | Module Setting - [Chipset] - BlitterCycleExact:
08:52:39:688 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - BlitterCycleExact:
08:52:39:734 | MD |     INFO  | +47    | Module Setting - [Chipset] - CollisionLevel:
08:52:39:766 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - CollisionLevel:
08:52:39:766 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:
08:52:39:766 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - ChipMemory:
08:52:39:766 | MD |     INFO  | +0     | Module Setting - [RAM] - FastMemory:
08:52:39:766 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FastMemory:
08:52:39:797 | MD |     INFO  | +31    | Module Setting - [RAM] - AutoConfigFastMemory:
08:52:39:828 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - AutoConfigFastMemory:
08:52:39:828 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:
08:52:39:828 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - SlowMemory:
08:52:39:828 | MD |     INFO  | +0     | Module Setting - [RAM] - Z3FastMemory:
08:52:39:859 | MD |     INFO  | +32    | Module Setting - [1943_v1.2] - Z3FastMemory:
08:52:39:859 | MD |     INFO  | +0     | Module Setting - [RAM] - MegaChipMemory:
08:52:39:859 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - MegaChipMemory:
08:52:39:859 | MD |     INFO  | +0     | Module Setting - [RAM] - ProcessorSlotFast:
08:52:39:890 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - ProcessorSlotFast:
08:52:39:937 | MD |     INFO  | +47    | Module Setting - [Expansions] - RTGCardType:
08:52:39:968 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - RTGCardType:
08:52:39:968 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGVRAMSize:
08:52:39:968 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - RTGVRAMSize:
08:52:39:968 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGHardwareSprite:
08:52:39:968 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - RTGHardwareSprite:
08:52:39:000 | MD |     INFO  | +31    | Module Setting - [WHDLoad] - PathToWHDFolder: .\HDD\WHD
08:52:40:000 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - PathToWHDFolder: .\HDD\WHD
08:52:40:000 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD
08:52:40:000 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - WHDLoadOptions: PRELOAD
08:52:40:031 | MD |     INFO  | +31    | Module Setting - [WHDLoad] - NeverExtract: false
08:52:40:078 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - NeverExtract: false
08:52:40:111 | MD |     INFO  | +31    | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:52:40:111 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			0 bytes
					Created:			6/30/2017 - 10:03:57 PM
					Modified:			6/30/2017 - 10:07:49 PM
08:52:40:204 | MD |     INFO  | +94    | Run - Running: D:\Arcade\emulators\WinUAE 3.1\winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip"  -portable
08:52:40:407 | MD |   DEBUG1  | +203   | Run - "winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip"  -portable" Process ID: 5200
08:52:40:438 | MD |   DEBUG1  | +31    | GetActiveWindowStatus - Title: BlackScreen | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0xa0320 | Process ID: 704 | Process Path: D:\Arcade\RocketLauncher\RocketLauncher.exe
08:52:40:485 | MD |     INFO  | +47    | WinWait - Waiting for "ahk_class AmigaPowah"
08:52:41:153 | MD |   DEBUG1  | +670   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xc0322 | Process ID: 5200 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:52:41:155 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xc0322 | Process ID: 5200 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:52:41:157 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
08:52:41:265 | MD |   DEBUG1  | +110   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xc0322 | Process ID: 5200 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:52:41:297 | MD |     INFO  | +31    | Process - WaitClose winuae.exe
08:53:06:022 | MD |   DEBUG1  | +24726 | CloseProcess - Started, user requested to end launched application
08:53:06:025 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:53:06:028 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			0 bytes
08:53:06:144 | MD |   DEBUG1  | +125   | CloseProcess - Ended
08:53:06:264 | MD |     INFO  | +109   | StopGlobalUserFeatures - Starting
08:53:06:264 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
08:53:06:264 | MD |     INFO  | +0     | ExitModule - Started
08:53:06:264 | MD |     INFO  | +0     | Starting Updating Statistics:
08:53:06:295 | MD |   DEBUG2  | +31    | Total Elapsed Time in Pause in seconds: 0
08:53:06:295 | MD |   DEBUG2  | +0     | gameSectionStartTime:3886624
08:53:06:295 | MD |   DEBUG2  | +0     | ElapsedTime:27
08:53:06:295 | MD |   DEBUG2  | +0     | Statistics cleared game name: 1943_v1.2
08:53:06:420 | MD |   DEBUG2  | +125   | Loaded game statistics from ini files:
					Number_of_Times_Played: 9
					Last_Time_Played: Friday June 30, 2017 09:47:04 PM
					Average_Time_Played: 22
					Total_Time_Played: 199
					System_Total_Played_Time: 1007
					Total_Global_Played_Time: 2663
08:53:06:420 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 10
					Last_Time_Played: Saturday July 1, 2017 08:52:38 AM
					Average_Time_Played: 23
					Total_Time_Played: 226
					System_Total_Played_Time: 1034
					Total_Global_Played_Time: 2690
08:53:06:483 | MD |     INFO  | +62    | Game section statistics updated.
08:53:06:514 | MD |     INFO  | +32    | Restoring mouse cursor
08:53:06:514 | MD |     INFO  | +0     | ExitModule - Ended
08:53:06:514 | MD |     INFO  | +0     | End of Module Logs
08:53:06:639 | RL |     INFO  | +29733 | Main - Module ended, exiting RocketLauncher normally
08:53:06:639 | RL |     INFO  | +0     | ExitScript - Started
08:53:06:670 | RL |   DEBUG1  | +32    | ExitScript - Unhiding taskbar
08:53:06:904 | RL |     INFO  | +234   | SystemCursor - Restoring mouse cursor
08:53:06:919 | RL |     INFO  | +15    | ExitScript - Ended
[/code]
[code]
08:55:03:546 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
08:55:03:656 | RL |     INFO  | +109   | Main - System Specs:
					RocketLauncher Dir: D:\Arcade\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8163.35 MB
					Free Memory: 5358.93 MB
					Used Memory: 2804.418 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: NVIDIA GeForce 210
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 21.21.13.4201
					Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
					Sound 1 Status: Enabled
					Sound 2 Device: NVIDIA High Definition Audio
					Sound 2 Status: Enabled
					Sound 3 Device: NVIDIA High Definition Audio
					Sound 3 Status: Enabled
					Sound 4 Device: Realtek High Definition Audio
					Sound 4 Status: Enabled
					Sound 5 Device: Bluetooth Audio
					Sound 5 Status: Enabled
					Sound 6 Device: NVIDIA High Definition Audio
					Sound 6 Status: Enabled
					Sound 7 Device: NVIDIA High Definition Audio
					Sound 7 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
08:55:03:656 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
08:55:03:656 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.3
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2061824 bytes
					Created:			9/23/2015 - 10:21:14 PM
					Modified:			8/30/2015 - 6:53:55 AM
08:55:03:656 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk exists
08:55:03:671 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:55:03:671 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4961 bytes
					Modified:			12/28/2014 - 12:53:36 PM
08:55:03:671 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
08:55:03:671 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk exists
08:55:03:687 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:55:03:687 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Modified:			8/30/2015 - 6:53:49 AM
08:55:03:687 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
08:55:03:718 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
08:55:03:718 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
08:55:03:718 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk exists
08:55:03:734 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
08:55:03:734 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
08:55:03:749 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk exists
08:55:03:749 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:03:765 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			5895 bytes
					Modified:			7/6/2015 - 6:15:22 AM
08:55:03:765 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
08:55:03:765 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gsdll32.dll exists
08:55:03:765 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			13090816 bytes
					Modified:			1/8/2015 - 5:54:04 PM
08:55:03:765 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\itextsharp.dll exists
08:55:03:780 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			9/23/2015 - 10:21:15 PM
08:55:03:780 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Java.ahk exists
08:55:03:780 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:03:780 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
08:55:03:780 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
08:55:03:796 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk exists
08:55:03:796 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
08:55:03:796 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			9203 bytes
08:55:03:796 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk exists
08:55:03:812 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:55:03:812 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
					Modified:			5/4/2015 - 9:16:07 AM
08:55:03:812 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
08:55:03:812 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk exists
08:55:03:843 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Extension.
08:55:03:843 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
08:55:03:858 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk exists
08:55:03:874 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
08:55:03:874 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
08:55:03:874 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
08:55:03:890 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk exists
08:55:03:890 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:03:890 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5347 bytes
					Modified:			5/4/2015 - 9:16:38 AM
08:55:03:905 | RL |   DEBUG1  | +15    | Steam.ahk Version: 1.0.2
08:55:03:905 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA.ahk exists
08:55:03:905 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
08:55:03:905 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
08:55:03:921 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk exists
08:55:03:921 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:03:952 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			3833 bytes
					Modified:			1/30/2015 - 8:39:01 PM
08:55:03:952 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
08:55:03:952 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\7z.ahk exists
08:55:03:983 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:55:03:999 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			29013 bytes
					Modified:			8/30/2015 - 6:53:50 AM
08:55:03:999 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.1
08:55:03:999 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Bezel.ahk exists
08:55:03:014 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:014 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			102587 bytes
					Modified:			7/6/2015 - 6:15:20 AM
08:55:04:030 | RL |   DEBUG1  | +15    | Bezel.ahk Version: 1.1.2
08:55:04:030 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade.ahk exists
08:55:04:030 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:046 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			38048 bytes
					Modified:			9/18/2015 - 8:22:33 AM
08:55:04:046 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.2
08:55:04:046 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Init.ahk exists
08:55:04:061 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:061 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			999 bytes
08:55:04:061 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
08:55:04:061 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk exists
08:55:04:077 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:077 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			79882 bytes
08:55:04:092 | RL |   DEBUG1  | +16    | Fade Animations.ahk Version: 1.1.8
08:55:04:092 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause.ahk exists
08:55:04:108 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:108 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392698 bytes
08:55:04:124 | RL |   DEBUG1  | +16    | Pause.ahk Version: 1.1.4
08:55:04:124 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause Init.ahk exists
08:55:04:124 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:139 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			553 bytes
					Modified:			8/30/2015 - 6:53:41 AM
08:55:04:139 | RL |   DEBUG1  | +15    | Pause Init.ahk Version: 1.0.3
08:55:04:139 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper.ahk exists
08:55:04:155 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:155 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Modified:			5/21/2015 - 10:33:10 PM
08:55:04:170 | RL |   DEBUG1  | +16    | Keymapper.ahk Version: 1.1.2
08:55:04:170 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk exists
08:55:04:170 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:186 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			3461 bytes
08:55:04:186 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
08:55:04:186 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame.ahk exists
08:55:04:217 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:233 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			40753 bytes
					Modified:			8/30/2015 - 6:53:37 AM
08:55:04:233 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
08:55:04:233 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk exists
08:55:04:248 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:248 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
08:55:04:248 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
08:55:04:248 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk exists
08:55:04:264 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:295 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			58770 bytes
					Modified:			7/9/2015 - 7:36:01 AM
08:55:04:326 | RL |   DEBUG1  | +32    | MultiPlayer.ahk Version: 1.0.6
08:55:04:326 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Password.ahk exists
08:55:04:326 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:342 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			10025 bytes
					Modified:			8/30/2015 - 6:53:44 AM
08:55:04:342 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
08:55:04:358 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
08:55:04:373 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:373 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			73772 bytes
08:55:04:373 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
08:55:04:373 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Shared.ahk exists
08:55:04:389 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:389 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			116503 bytes
					Modified:			8/30/2015 - 6:53:45 AM
08:55:04:404 | RL |   DEBUG1  | +16    | Shared.ahk Version: 1.3.2
08:55:04:404 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics.ahk exists
08:55:04:404 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:404 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26143 bytes
					Modified:			5/4/2015 - 9:16:52 AM
08:55:04:420 | RL |   DEBUG1  | +15    | Statistics.ahk Version: 1.0.3
08:55:04:420 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk exists
08:55:04:420 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:436 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			33 bytes
08:55:04:436 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
08:55:04:436 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk exists
08:55:04:436 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:451 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			17070 bytes
08:55:04:451 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.1
08:55:04:451 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey.ahk exists
08:55:04:482 | RL |   DEBUG1  | +32    | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:498 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			26540 bytes
					Modified:			8/30/2015 - 6:53:48 AM
08:55:04:498 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
08:55:04:498 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk exists
08:55:04:498 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
08:55:04:514 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			1063 bytes
					Modified:			8/30/2015 - 6:53:38 AM
08:55:04:514 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
08:55:04:514 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r 1943_v1.2 -f D:\Arcade\HyperSpin.exe -p HyperSpin -c 1"
08:55:04:514 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "1943_v1.2"
08:55:04:514 | RL |   DEBUG1  | +0     | Main - dbName: 1943_v1.2
08:55:04:529 | RL |     INFO  | +15    | Main - Loading Front End Plugin: "HyperSpin"
08:55:04:529 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "1943_v1.2"
08:55:04:545 | RL |     INFO  | +16    | Main - Did not find a "D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.
08:55:04:545 | RL |     INFO  | +0     | Main - 1943_v1.2 is using the default emulator: WinUAE
08:55:04:545 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Commodore Amiga\Emulators.ini
08:55:04:545 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:55:04:560 | RL |     INFO  | +16    | Main - Found [WinUAE] in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
08:55:04:560 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists
08:55:04:560 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			23651 bytes
					Created:			9/23/2015 - 10:21:16 PM
					Modified:			8/30/2015 - 6:53:51 AM
08:55:04:576 | RL |     INFO  | +15    | Main - CRC Check - CRC matches, this is an official unedited module.
08:55:04:576 | RL |     INFO  | +0     | Main - 1943_v1.2 will use module: D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
08:55:04:607 | RL |     INFO  | +31    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
08:55:04:623 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\winuae.exe exists
08:55:04:623 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	WinUAE
					FileVersion             	3.1.0.0
					InternalName            	WinUAE
					LegalCopyright          	� 1996-2015 under the GNU Public License (GPL)
					OriginalFilename        	WinUAE.exe
					ProductName             	WinUAE
					ProductVersion          	3.1.0.0
					File Size:			12417112 bytes
					Created:			6/30/2017 - 10:03:59 PM
					Modified:			6/7/2015 - 6:41:10 AM
08:55:04:623 | RL |     INFO  | +0     | Main - INI Keys read
08:55:04:638 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.exe exists
08:55:04:638 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
08:55:04:638 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.dll exists
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
08:55:04:654 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\FontReg.exe exists
08:55:04:654 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	Font Registration Utility (x86-32)
					FileVersion             	2.1.3.0
					OriginalFilename        	FontReg.exe
					File Size:			6144 bytes
08:55:04:670 | RL |     INFO  | +16    | Main - "1943_v1.2" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
08:55:04:670 | RL |     INFO  | +0     | CheckPaths - Started
08:55:04:670 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.adf
08:55:04:670 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.adf
08:55:04:685 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.adf
08:55:04:685 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.hdf
08:55:04:685 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.hdf
08:55:04:685 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.hdf
08:55:04:685 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.cue
08:55:04:685 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.cue
08:55:04:685 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.cue
08:55:04:685 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.iso
08:55:04:701 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Commodore Amiga\roms\1943_v1.2\1943_v1.2.iso
08:55:04:701 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Commodore Amiga\roms\1943_v1.2\*.iso
08:55:04:701 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip
08:55:04:701 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip
08:55:04:701 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: 1943_v1.2
08:55:04:701 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Arcade\Commodore Amiga\roms
08:55:04:701 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
08:55:04:701 | RL |     INFO  | +0     | CheckPaths - Ended
08:55:04:716 | RL |     INFO  | +16    | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Arcade\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.3
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Arcade\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Arcade
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc|H1000:1joy7
					restoreFE = Restore
					exitScriptKey = `
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Arcade\emulators\WinUAE 3.1\winuae.exe
					emuPath = D:\Arcade\emulators\WinUAE 3.1
					emuName = WinUAE
					emuExt = exe
					romPath = D:\Arcade\Commodore Amiga\roms
					romPathFromIni = D:\Arcade\Commodore Amiga\roms
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = adf|hdf|cue|iso|zip|lha|7z|uae|adz|dms|fdi|uss|slave
					executable = winuae.exe
					systemDbName = Commodore Amiga
					systemName = Commodore Amiga
					dbPath =
					dbName = 1943_v1.2
					dbExt =
					romName = 1943_v1.2
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = true
					blockInputTime = 0
					blockInputFile = D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Arcade\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = false
					vdDriveLetter =
					vdAddDrive = false
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Arcade\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Arcade\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 5000
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Arial
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Arcade\RocketLauncher\Media\Fade
					RLDataPath = D:\Arcade\RocketLauncher\Data
					RLMediaPath = D:\Arcade\RocketLauncher\Media
					RLErrSoundPath = D:\Arcade\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Arcade\RocketLauncher\Modules
					moduleFullName = D:\Arcade\RocketLauncher\Modules\WinUAE\WinUAE.ahk
					moduleName = WinUAE
					modulePath = D:\Arcade\RocketLauncher\Modules\WinUAE
					moduleExtension = ahk
					moduleExtensionsPath = D:\Arcade\RocketLauncher\Module Extensions
					libPath = D:\Arcade\RocketLauncher\Lib
					7zEnabled = false
					7zPath = D:\Arcade\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Arcade\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = D:\Arcade\cache
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = false
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = Pause
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Arcade\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Arcade\Tools\Xpadder\xpadder.exe
					joyToKeyFullPath = C:\Windows\Utilities\VJoy\VJoy.exe
					keymapperProfilePath = D:\Arcade\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = ahk
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Rock Candy Gamepad for Xbox 360)|Controller (XBOX 360 For Windows)|Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit = Controller (Rock Candy Gamepad for Xbox 360)|Controller (Xbox 360 Wireless Receiver for Windows)
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga
					xPadderSystemProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default
					emuProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE
					romProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\Commodore Amiga\1943_v1.2
					RocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Arcade\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Arcade\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Arcade\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga
					ahkEmuProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAE
					ahkRomProfile = D:\Arcade\RocketLauncher\Profiles\AHK\Commodore Amiga\1943_v1.2
					ahkRocketLauncherProfile = D:\Arcade\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Arcade\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Arcade\RocketLauncher\Lib\User Fade Animations.ini
08:55:04:716 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
08:55:04:716 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
08:55:04:716 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
08:55:04:716 | RL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
08:55:04:732 | RL |   DEBUG1  | +15    | BuildScript - Module starts on line: 2
08:55:04:732 | RL |     INFO  | +0     | BuildScript - Validating module
08:55:04:732 | RL |     INFO  | +0     | BuildScript - Validation complete
08:55:04:732 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = WinUAE
					MEmuV =  v3.0.0
					MURL = http://www.winuae.net/
					MAuthor = brolly,Turranius
					MVersion = 2.1.9
					MCRC = 4C755A18
					iCRC = AFD49B34
					mId = 635138307631183750
					MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
					; Notes:
					; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
					; Just name them the same as the game name on the XML file.
					; Make sure you create a host config files with these names:
					; CD32 : cd32host.uae and cd32mousehost.uae;
					; CDTV : cdtvhost.uae and cdtvmousehost.uae;
					; Amiga : amigahost.uae;
					; Amiga CD : amigacdhost.uae;
					; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
					; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
					; a joystick and a mouse on Port1 and only a joystick on Port2.
					; Set all your other preferences like video display settings. And make sure you are saving a HOST
					; configuration file and not a general configuration file.
					; If you want to configure an exit key through WinUAE:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
					; If you want to configure a key to toggle fullscreen/windowed mode:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
					; CD32 and CDTV:
					; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
					; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
					; [Lemmings (Europe)]
					; UseMouse=true
					; [Project-X & F17 Challenge (Europe)]
					; DelayHack=true
					; Amiga:
					; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
					; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
					; END+SHIFT+1-0 = insert image from swapper slot 11-20
					; END+CTRL+1-4 = select drive
					; To do that follow the same procedure as above for the exit
					; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
					; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
					; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
					; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
					; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
					; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
					; Amiga CD:
					; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.
					; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).
					; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set
					; RequiresWB to false.
					; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:
					; http://www.winuae.net/
					; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory
					StartModule()
					BezelGUI()
					FadeInStart()
					settingsFile := modulePath . "\" . systemName . ".ini"
					; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.
					mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
					ident := mType[systemName]	; search object for the systemName identifier MESS uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
					specialcfg = %emuPath%\Configurations\%romName%.uae
					If romExtension in .hdf,.vhd
						DefaultRequireWB := "true"
					Else
						DefaultRequireWB := "false"
					If romExtension in .zip,.lha,.rar,.7z
						SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")
						If (SlaveFile) {
							If romName contains (AGA)
								defaultCycleExact := "false"
								defaultCpuSpeed := "max"
							} Else {
								defaultCycleExact := "true"
								defaultCpuSpeed := "real"
							defaultImmediateBlittler = "false"
							defaultCpuCompatible := "false"
							defaultCacheSize := "0" ;8192
					If (ident = "amigacd") {
						DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to true
						defaultz3Ram := "128"
						isAmigaCd := "true"
					; Settings
					FS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)
					quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)
					kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)
					options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)
					bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)
					bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)
					bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)
					bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)
					use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)
					floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)
					PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
					PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
					pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)
					If (pathtoextradrive)
						pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive)
					usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32
					delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32
					requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
					; Display
					videomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)
					gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)
					gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)
					gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)
					gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)
					gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)
					gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)
					gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)
					gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)
					gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)
					gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)
					gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1)
					; CPU
					cpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)
					cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)
					cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)
					cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)
					mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)
					cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)
					fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)
					fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)
					fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)
					cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)
					24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1)
					; Chipset
					cycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)
					immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
					blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)
					collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1)
					; RAM
					chipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)
					fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)
					autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)
					slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)
					z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)
					megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)
					processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1)
					; Expansions
					rtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)
					rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)
					rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1)
					; WHDLoad
					PathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
					PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
					whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)
					neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1)
					BezelStart()
					; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modes
					If bezelPath {
						FS := "fullwindow"
						gfx_filter_autoscale := "scale"
					windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
					If (FS = "true" or FS = "fullwindow")
						windowClass = AmigaPowah
					If (cpucycleexact and blittercycleexact)
						cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
					if (cpu != "68060" and cpu_no_unimplemented)
						cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.}
					; Make sure 24bitaddressing is false if using Z3 memory.
					If z3fastmemory
						24bitaddressing := "false"
					;Fill both z3 slots when amount of RAM requires it
					If (z3fastmemory = "384") {
						z3fastmemory = "256"
						z3fastmemoryb = "128"
					} Else If (z3fastmemory = "768") {
						z3fastmemory = "512"
						z3fastmemoryb = "256"
					} Else If (z3fastmemory = "1536") {
						z3fastmemory = "1024"
						z3fastmemoryb = "512"
					videomode := If videomode = "NTSC" ? "-s ntsc=true" : ""
					If (requireswb = "true") {
						ident := "a1200"
						CheckFile(PathToWorkBenchBase)
						wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
						ident := "a1200"
						gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
						CheckFile(pathtoextradrive,,,,,,1) ;allow folders
						If InStr(FileExist(pathtoextradrive), "D") ;it's a folder
							extraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"
						Else ;it's a file
							SplitPath, pathtoextradrive,,,extradriveExtension
							If extradriveExtension in .hdf,.vhd
								extraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"
							Else
								extraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"
					options := options . " " . videomode
					If (ident = "a500" or ident = "a1200") {
						If romName contains (AGA),(LW)
							ident := "a1200"
						If (SlaveFile) {
							CheckFolder(PathToWHDFolder)
							ident := "a1200"
							;Create the user-startup file to launch the game
							WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
							SplitPath, SlaveFile, SlaveName, SlaveFolder
							FileDelete, %WHDUserStartupFile%
							FileAppend, echo "";`n, %WHDUserStartupFile%
							FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
							FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
							FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
					hideEmuObj := Object("ahk_class " . windowClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
					If FileExist(specialcfg) {
						;Game specific configuration file exists
						configFile = %romName%.uae
					} Else {
						;Game specific configuration file doesn't exist
						If (ident = "cd32" or ident = "cdtv") {
							configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
							quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						} Else {
							;Amiga or Amiga CD game
							configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
							If quickstartmode
								quickcfg := "-s quickstart=" . quickstartmode
							Else
								quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")
					;--- Setting up command line arguments to use ---
					; Global command line arguments.
					If use_gui
						options := options . " -s use_gui=" . use_gui
					If (FS = "true") {
						options := options . " -s gfx_width_fullscreen=" . gfx_width
						options := options . " -s gfx_height_fullscreen=" . gfx_height
					} Else If (FS = "false") {
						If (gfx_width != "native" and gfx_height != "native") {
							options := options . " -s gfx_width_windowed=" . gfx_width
							options := options . " -s gfx_height_windowed=" . gfx_height
					If gfx_linemode
						options := options . " -s gfx_linemode=" . gfx_linemode
					If gfx_filter_autoscale
						options := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscale
					If gfx_blacker_than_black
						options := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_black
					If gfx_flickerfixer
						options := options . " -s gfx_flickerfixer=" . gfx_flickerfixer
					If gfx_filter_mode
						options := options . " -s gfx_filter_mode=" . gfx_filter_mode
					If (gfx_lores_mode = "true")
						options := options . " -s gfx_lores_mode=filtered"
					Else If (gfx_lores_mode = "false")
						options := options . " -s gfx_lores_mode=normal"
					If gfx_resolution {
						options := options . " -s gfx_resolution=" . gfx_resolution
						If (gfx_resolution = "lores") {
							options := options . " -s gfx_autoresolution_vga=false"
							options := options . " -s gfx_lores=true"
						Else {
							options := options . " -s gfx_lores=false"
					If gfx_filter_mask {
						gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_mask
						LOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)
						If FileExist(gfx_filter_mask_path)
							options := options . " -s gfx_filter_mask=" . gfx_filter_mask
					If gfx_filter {
						If (SubStr(gfx_filter, 1, 4) = "D3D:") {
							StringTrimLeft, FilterFileName, gfx_filter, 4
							FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileName
							If FileExist(FilterFile)
								options := options . " -s gfx_filter=" . gfx_filter
						} Else {
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					} Else {
						If floppyspeed
							options := options . " -s floppy_speed=" . floppyspeed
						If kickstart_rom_file
							options := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"
						If (cachesize || cachesize = "0")
							options := options . " -s cachesize=" . cachesize
						If immediateblitter
							options := options . " -s immediate_blits=" . immediateblitter
						If cycleexact
							options := options . " -s cycle_exact=" . cycleexact
						If cpucycleexact
							options := options . " -s cpu_cycle_exact=" . cpucycleexact
						If blittercycleexact
							options := options . " -s blitter_cycle_exact=" . blittercycleexact
						If cpucompatible
							options := options . " -s cpu_compatible=" . cpucompatible
						If cpuspeed
							options := options . " -s cpu_speed=" . cpuspeed
						If cpu
							options := options . " -s cpu_model=" . cpu
						If cpu_no_unimplemented
							options := options . " -s cpu_no_unimplemented=" . cpu_no_unimplemented
						If (mmu_model = "true")
							options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.
						If 24bitaddressing
							options := options . " -s cpu_24bit_addressing=" . 24bitaddressing
						If fpu
							options := options . " -s fpu_model=" . fpu
						If fpu_strict
							options := options . " -s fpu_strict=" . fpu_strict
						If fpu_no_unimplemented
							options := options . " -s fpu_no_unimplemented=" . fpu_no_unimplemented
						If collisionlevel
							options := options . " -s collision_level=" . collisionlevel
						If chipmemory
							options := options . " -s chipmem_size=" . chipmemory
						If fastmemory
							options := options . " -s fastmem_size=" . fastmemory
						If autoconfigfastmemory
							options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
						If slowmemory
							options := options . " -s bogomem_size=" . slowmemory
						If z3fastmemory
							options := options . " -s z3mem_size=" . z3fastmemory
						If z3fastmemoryb
							options := options . " -s z3mem2_size=" . z3fastmemoryb
						If megachipmemory
							options := options . " -s megachipmem_size=" . megachipmemory
						If processorslotfastmemory
							options := options . " -s mbresmem_size=" . processorslotfastmemory
						If rtgcardtype
							options := options . " -s gfxcard_type=" . rtgcardtype
						If rtgvramsize
							options := options . " -s gfxcard_size=" . rtgvramsize
						If rtghardwaresprite
							options := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite
						If (SlaveFile) {
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive) {
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
							;Check if there's also a CD to load
							IfExist, %romPath%\%romName%.cue
								cdDrive := romPath . "\" . romName . ".cue"
							IfExist, %romPath%\%romName%.iso
								cdDrive := romPath . "\" . romName . ".iso"
							IfExist, %romPath%\%romName%.mds
								cdDrive := romPath . "\" . romName . ".mds"
							If extraDrive
								options := options . " " . extraDrive
							If cdDrive
								options := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else If romExtension in .cue,.iso,.mds
							;Amiga CD game
							;Check if game has a HDD installation
							IfExist, %romPath%\%romName%.hdf
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"
							IfExist, %romPath%\%romName%.vhd
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """"
							options := options . " " . wbDrive . installedHdd
							If extraDrive
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else {
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menu
								If romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							If romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
					configFileFullPath := EmuPath . "\Configurations\" . configFile
					;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfg
					If FileExist(configFileFullPath)
					param1 := param1 . " " . quickcfg
					param2 := "-s gfx_fullscreen_amiga=" . FS
					param3 := options
					HideEmuStart()
					Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
					If (use_gui = "true") {
						WinWait("WinUAE Properties",,60)
						FadeInExit()
						WinWaitClose("WinUAE Properties")
						Sleep, 100
						Process("Exist",executable)
						If (ErrorLevel=0) {
							7zCleanUp()
							ExitModule()
					WinWait("ahk_class " . windowClass)
					WinWaitActive("ahk_class " . windowClass)
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					Process("WaitClose",executable)
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					MultiGame:
						If currentButton = 10
							diskslot = 0
						Else If currentButton > 10
							diskslot := currentButton - 10
						Else
							Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
						Else
							Send, {End Down}%diskslot%{End Up}
					Return
					CloseProcess:
							If (SlaveFile) {
								;Copy default-user-startup to user-startup if file exists
								IfExist, %PathToWHDFolder%\S\default-user-startup
									FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
						FadeOutStart()
						WinClose, ahk_class %windowClass%
					Return
08:55:04:748 | RL |     INFO  | +16    | BuildScript - Loaded Pause scripts
08:55:04:748 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
08:55:04:748 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
08:55:04:748 | RL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
08:55:04:763 | RL |     INFO  | +15    | BuildScript - Finished injecting functions into module
08:55:04:763 | RL |     INFO  | +0     | Main - Module is built
08:55:04:763 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\AutoHotkey.dll exists
08:55:04:763 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			12/28/2014 - 12:53:35 PM
08:55:04:763 | RL |     INFO  | +0     | Main - Hiding taskbar
08:55:04:997 | RL |     INFO  | +234   | Main - Hiding desktop
08:55:04:997 | RL |     INFO  | +0     | Main - Running module
08:55:04:997 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
08:55:05:153 | MD |     INFO  | +N/A   | Module initialized
08:55:05:153 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:55:05:184 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
08:55:05:184 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:55:05:216 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
08:55:05:216 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
08:55:05:216 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:55:05:247 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:55:05:278 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~1joy7 not in TableKeyGroups ~Esc,
08:55:05:278 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:55:05:278 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:55:05:278 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
08:55:05:309 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Ended
08:55:05:309 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
08:55:05:356 | MD |   DEBUG2  | +47    | XHotkeyTableCreation - KeyGroup ~Pause not in TableKeyGroups ~Esc,~1joy7,
08:55:05:356 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:55:05:356 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:55:05:356 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Pause" to call label: "TogglePauseMenuStatus"
08:55:05:356 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
08:55:05:387 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:55:05:387 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1joy7,~Pause,
08:55:05:387 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:55:05:387 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:55:05:387 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
08:55:05:418 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Ended
08:55:05:418 | MD |     INFO  | +0     | StartModule - Started
08:55:05:418 | MD |     INFO  | +0     | StartModule - MEmu: WinUAE
					MEmuV: v3.0.0
					MURL: http://www.winuae.net/
					MAuthor: brolly,Turranius
					MVersion: 2.1.9
					MCRC: 4C755A18
					iCRC: AFD49B34
					MID:
					MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
08:55:05:418 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
08:55:05:418 | MD |     INFO  | +0     | PluginInit - Started
08:55:05:450 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
08:55:05:450 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\Databases\Commodore Amiga\Commodore Amiga.xml exists
08:55:05:450 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			568042 bytes
					Created:			4/5/2014 - 6:11:31 AM
					Modified:			3/20/2015 - 5:37:41 PM
08:55:05:481 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
08:55:05:481 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
08:55:05:481 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
08:55:05:481 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "1943 - The Battle of Midway"
08:55:05:512 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Cloneof
08:55:05:512 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
08:55:05:512 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
08:55:05:512 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Manufacturer
08:55:05:543 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Year
08:55:05:543 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
08:55:05:543 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
08:55:05:559 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre
08:55:05:574 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Searching database for: Rating
08:55:05:574 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
08:55:05:574 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value:
					GameInfo Label: Rating | GameInfo Value:
08:55:05:574 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
08:55:05:606 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
08:55:05:606 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\Media\Commodore Amiga\Images\Wheel\1943_v1.2.png
08:55:05:606 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png
08:55:05:606 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Wheel\1943_v1.2.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Arcade\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system
08:55:05:606 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:55:05:637 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
08:55:05:637 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: D:\Arcade\Media\Commodore Amiga\Images\Artwork1\1943_v1.2.png
08:55:05:637 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Arcade\Media\Commodore Amiga\Images\Artwork2\1943_v1.2.png
08:55:05:637 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Arcade\Media\Commodore Amiga\Images\Artwork3\1943_v1.2.png
08:55:05:668 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Flyers: D:\Arcade\Media\Commodore Amiga\Images\Artwork4\1943_v1.2.png
08:55:05:668 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Arcade\Media\Commodore Amiga\Images\Letters
08:55:05:730 | MD |   DEBUG1  | +63    | BuildAssetsTable - Searching for a Other: D:\Arcade\Media\Commodore Amiga\Images\Other
08:55:05:762 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Box Art | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Artwork2\1943_v1.2.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Cartridge | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Images\Artwork3\1943_v1.2.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Letters | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Arcade\media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Arcade\media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Arcade\media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Arcade\media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Arcade\media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Arcade\media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Arcade\media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Arcade\media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Arcade\media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Arcade\media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Arcade\media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Arcade\media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Arcade\media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Arcade\media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Arcade\media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Arcade\media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Arcade\media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Arcade\media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Arcade\media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Arcade\media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Arcade\media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Arcade\media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Arcade\media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Arcade\media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Arcade\media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Arcade\media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Arcade\media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Arcade\media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Arcade\media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Arcade\media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Arcade\media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Arcade\media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Arcade\media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Arcade\media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Arcade\media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Arcade\media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Arcade\media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Arcade\media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Arcade\media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
08:55:05:762 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:55:05:793 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
08:55:05:793 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a MP4 Game Video: D:\Arcade\Media\Commodore Amiga\Video\1943_v1.2.*
08:55:05:793 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a FLV Game Video: D:\Arcade\Media\Main Menu\Video\Commodore Amiga.*
08:55:05:793 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  D:\Arcade\Media\Main Menu\Video\Commodore Amiga.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Arcade\Media\Commodore Amiga\Video\1943_v1.2.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
08:55:05:793 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
08:55:05:824 | MD |     INFO  | +31    | PluginInit - Ended
08:55:05:824 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: 1943_v1.2
08:55:05:824 | MD |     INFO  | +0     | Hiding mouse cursor
08:55:05:855 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
08:55:05:855 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy7,~Pause,PrintScreen,
08:55:05:855 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
08:55:05:855 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
08:55:05:855 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
08:55:05:886 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Ended
08:55:05:886 | MD |     INFO  | +0     | StartModule - Ended
08:55:05:886 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
08:55:05:918 | MD |     INFO  | +31    | StartGlobalUserFeatures - Ending
08:55:06:011 | MD |     INFO  | +93    | Module Setting - [Settings] - ScreenMode: true
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - ScreenMode: true
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [Settings] - QuickStartMode:
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - QuickStartMode:
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [Settings] - KickstartFile:
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - KickstartFile:
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - Options:
08:55:06:011 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Top_Offset: 0
08:55:06:042 | MD |     INFO  | +32    | Module Setting - [1943_v1.2] - Bezel_Top_Offset: 0
08:55:06:075 | MD |     INFO  | +31    | Module Setting - [Settings] - Bezel_Bottom_Offset: 0
08:55:06:075 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - Bezel_Bottom_Offset: 0
08:55:06:075 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Right_Offset: 0
08:55:06:075 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - Bezel_Right_Offset: 0
08:55:06:075 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 0
08:55:06:106 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - Bezel_Left_Offset: 0
08:55:06:106 | MD |     INFO  | +0     | Module Setting - [Settings] - UseGui: false
08:55:06:106 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - UseGui: false
08:55:06:106 | MD |     INFO  | +0     | Module Setting - [Settings] - FloppySpeed: turbo
08:55:06:106 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FloppySpeed: turbo
08:55:06:137 | MD |     INFO  | +31    | Module Setting - [Settings] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:55:06:137 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - PathToWorkBenchBase: D:\Arcade\emulators\WinUAE 3.1\HDD\Workbench31_Lite.vhd
08:55:06:137 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToExtraDrive:
08:55:06:168 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - PathToExtraDrive:
08:55:06:199 | MD |     INFO  | +32    | Module Setting - [1943_v1.2] - UseMouse: false
08:55:06:199 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - DelayHack: false
08:55:06:231 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - RequiresWB: false
08:55:06:231 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: NTSC
08:55:06:231 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - VideoMode: NTSC
08:55:06:231 | MD |     INFO  | +0     | Module Setting - [Display] - XResolution: 1920
08:55:06:231 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - XResolution: 1920
08:55:06:262 | MD |     INFO  | +31    | Module Setting - [Display] - YResolution: 1080
08:55:06:262 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - YResolution: 1080
08:55:06:262 | MD |     INFO  | +0     | Module Setting - [Display] - BlackerThanBlack: false
08:55:06:293 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - BlackerThanBlack: false
08:55:06:293 | MD |     INFO  | +0     | Module Setting - [Display] - RemoveInterlaceArtifacts: false
08:55:06:293 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - RemoveInterlaceArtifacts: false
08:55:06:293 | MD |     INFO  | +0     | Module Setting - [Display] - LineMode:
08:55:06:324 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - LineMode:
08:55:06:371 | MD |     INFO  | +47    | Module Setting - [Display] - AutoScale: scale
08:55:06:371 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - AutoScale: scale
08:55:06:402 | MD |     INFO  | +31    | Module Setting - [Display] - ShaderMask:
08:55:06:402 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - ShaderMask:
08:55:06:402 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:
08:55:06:402 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FilterShader:
08:55:06:402 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShaderScale:
08:55:06:433 | MD |     INFO  | +32    | Module Setting - [1943_v1.2] - FilterShaderScale:
08:55:06:433 | MD |     INFO  | +0     | Module Setting - [Display] - FilteredLowResolution:
08:55:06:433 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FilteredLowResolution:
08:55:06:433 | MD |     INFO  | +0     | Module Setting - [Display] - ResolutionMode: superhires
08:55:06:465 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - ResolutionMode: superhires
08:55:06:465 | MD |     INFO  | +0     | Module Setting - [CPU] - CPU:
08:55:06:465 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CPU:
08:55:06:496 | MD |     INFO  | +31    | Module Setting - [CPU] - CpuSpeed: real
08:55:06:496 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CpuSpeed: real
08:55:06:496 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCycleExact:
08:55:06:527 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CpuCycleExact:
08:55:06:527 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCompatible: false
08:55:06:527 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CpuCompatible: false
08:55:06:527 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false
08:55:06:527 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - MMU: false
08:55:06:558 | MD |     INFO  | +31    | Module Setting - [CPU] - DisableUnimplementedCPU: true
08:55:06:558 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - DisableUnimplementedCPU: true
08:55:06:558 | MD |     INFO  | +0     | Module Setting - [CPU] - FPU:
08:55:06:558 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FPU:
08:55:06:558 | MD |     INFO  | +0     | Module Setting - [CPU] - MoreCompatibleFPU: false
08:55:06:589 | MD |     INFO  | +32    | Module Setting - [1943_v1.2] - MoreCompatibleFPU: false
08:55:06:589 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedFPU: true
08:55:06:589 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - DisableUnimplementedFPU: true
08:55:06:589 | MD |     INFO  | +0     | Module Setting - [CPU] - CacheSize: 0
08:55:06:589 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CacheSize: 0
08:55:06:621 | MD |     INFO  | +31    | Module Setting - [CPU] - 24-BitAddressing: true
08:55:06:667 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - 24-BitAddressing: true
08:55:06:699 | MD |     INFO  | +31    | Module Setting - [Chipset] - CycleExact: true
08:55:06:699 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CycleExact: true
08:55:06:730 | MD |     INFO  | +31    | Module Setting - [Chipset] - ImmediateBlitter: "false"
08:55:06:777 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - ImmediateBlitter: "false"
08:55:06:777 | MD |     INFO  | +0     | Module Setting - [Chipset] - BlitterCycleExact:
08:55:06:823 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - BlitterCycleExact:
08:55:06:823 | MD |     INFO  | +0     | Module Setting - [Chipset] - CollisionLevel:
08:55:06:823 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - CollisionLevel:
08:55:06:823 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:
08:55:06:855 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - ChipMemory:
08:55:06:855 | MD |     INFO  | +0     | Module Setting - [RAM] - FastMemory:
08:55:06:855 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - FastMemory:
08:55:06:886 | MD |     INFO  | +31    | Module Setting - [RAM] - AutoConfigFastMemory:
08:55:06:933 | MD |     INFO  | +47    | Module Setting - [1943_v1.2] - AutoConfigFastMemory:
08:55:06:933 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:
08:55:06:933 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - SlowMemory:
08:55:06:964 | MD |     INFO  | +31    | Module Setting - [RAM] - Z3FastMemory:
08:55:06:964 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - Z3FastMemory:
08:55:06:964 | MD |     INFO  | +0     | Module Setting - [RAM] - MegaChipMemory:
08:55:06:964 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - MegaChipMemory:
08:55:06:964 | MD |     INFO  | +0     | Module Setting - [RAM] - ProcessorSlotFast:
08:55:06:995 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - ProcessorSlotFast:
08:55:06:995 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGCardType:
08:55:06:995 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - RTGCardType:
08:55:06:995 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGVRAMSize:
08:55:06:026 | MD |     INFO  | +31    | Module Setting - [1943_v1.2] - RTGVRAMSize:
08:55:07:057 | MD |     INFO  | +32    | Module Setting - [Expansions] - RTGHardwareSprite:
08:55:07:093 | MD |     INFO  | +46    | Module Setting - [1943_v1.2] - RTGHardwareSprite:
08:55:07:093 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - PathToWHDFolder: .\HDD\WHD
08:55:07:093 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - PathToWHDFolder: .\HDD\WHD
08:55:07:093 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD
08:55:07:093 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - WHDLoadOptions: PRELOAD
08:55:07:124 | MD |     INFO  | +32    | Module Setting - [WHDLoad] - NeverExtract: false
08:55:07:124 | MD |     INFO  | +0     | Module Setting - [1943_v1.2] - NeverExtract: false
08:55:07:124 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:55:07:155 | MD |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			0 bytes
					Created:			6/30/2017 - 10:03:57 PM
					Modified:			6/30/2017 - 10:07:49 PM
08:55:07:249 | MD |     INFO  | +93    | Run - Running: D:\Arcade\emulators\WinUAE 3.1\winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip"  -portable
08:55:07:436 | MD |   DEBUG1  | +188   | Run - "winuae.exe  -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true  -s ntsc=true -s use_gui=false -s gfx_width_fullscreen=1920 -s gfx_height_fullscreen=1080 -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=superhires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Arcade\emulators\WinUAE 3.1\HDD\WHD" -s filesystem=ro,Games:"D:\Arcade\Commodore Amiga\roms\1943_v1.2.zip"  -portable" Process ID: 4464
08:55:07:436 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: BlackScreen | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x19030c | Process ID: 5484 | Process Path: D:\Arcade\RocketLauncher\RocketLauncher.exe
08:55:07:436 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"
08:55:08:094 | MD |   DEBUG1  | +655   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x110324 | Process ID: 4464 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:55:08:096 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x110324 | Process ID: 4464 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:55:08:098 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
08:55:08:202 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x110324 | Process ID: 4464 | Process Path: D:\Arcade\emulators\WinUAE 3.1\winuae.exe
08:55:08:235 | MD |     INFO  | +31    | Process - WaitClose winuae.exe
08:55:33:933 | MD |   DEBUG1  | +25694 | CloseProcess - Started, user requested to end launched application
08:55:33:937 | MD |     INFO  | +0     | CheckFile - Checking if D:\Arcade\emulators\WinUAE 3.1\HDD\WHD exists
08:55:33:963 | MD |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			0 bytes
08:55:34:116 | MD |   DEBUG1  | +156   | CloseProcess - Ended
08:55:34:231 | MD |     INFO  | +109   | StopGlobalUserFeatures - Starting
08:55:34:231 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
08:55:34:231 | MD |     INFO  | +0     | ExitModule - Started
08:55:34:231 | MD |     INFO  | +0     | Starting Updating Statistics:
08:55:34:262 | MD |   DEBUG2  | +31    | Total Elapsed Time in Pause in seconds: 0
08:55:34:262 | MD |   DEBUG2  | +0     | gameSectionStartTime:4034139
08:55:34:262 | MD |   DEBUG2  | +0     | ElapsedTime:28
08:55:34:262 | MD |   DEBUG2  | +0     | Statistics cleared game name: 1943_v1.2
08:55:34:387 | MD |   DEBUG2  | +125   | Loaded game statistics from ini files:
					Number_of_Times_Played: 10
					Last_Time_Played: Saturday July 1, 2017 08:52:38 AM
					Average_Time_Played: 23
					Total_Time_Played: 226
					System_Total_Played_Time: 1034
					Total_Global_Played_Time: 2690
08:55:34:387 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 11
					Last_Time_Played: Saturday July 1, 2017 08:55:05 AM
					Total_Time_Played: 254
					System_Total_Played_Time: 1062
					Total_Global_Played_Time: 2718
08:55:34:481 | MD |     INFO  | +94    | Game section statistics updated.
08:55:34:512 | MD |     INFO  | +31    | Restoring mouse cursor
08:55:34:543 | MD |     INFO  | +31    | ExitModule - Ended
08:55:34:543 | MD |     INFO  | +0     | End of Module Logs
08:55:34:621 | RL |     INFO  | +29625 | Main - Module ended, exiting RocketLauncher normally
08:55:34:621 | RL |     INFO  | +0     | ExitScript - Started
08:55:34:637 | RL |   DEBUG1  | +16    | ExitScript - Unhiding taskbar
08:55:34:871 | RL |     INFO  | +234   | SystemCursor - Restoring mouse cursor
08:55:34:886 | RL |     INFO  | +15    | ExitScript - Ended
[/code]
