the "X" is an invalid system name or "Y" isnt supported yet issue
Arkren
where X is Sony PlayStation and Y is ePSXe.exe in my case, but i have seen that this happens with almost every console, there are threads open with this same issue for dreamcast, mame or even atari (on other forums around the internet). first of all here is the log:
12:56:59 AM |  HyperSpin Started
12:56:59 AM |  Going FullScreen
12:57:00 AM |  Checking for updates
12:57:00 AM |  Update Check Complete
12:57:00 AM |  Startup program unavailable
12:57:00 AM |  Playing intro video
12:57:01 AM |  Menu Mode is multi
12:57:01 AM |  Loading Main Menu.xml
12:57:01 AM |  Main Menu.xml successfully loaded
12:57:02 AM |  Main Menu wheel loaded successfully
12:57:02 AM |  Loading Sony PlayStation.xml
12:57:02 AM |  roms_only is true, checking files
12:57:03 AM |  Main Menu.xml successfully loaded
12:57:03 AM |  Sony PlayStation wheel loaded successfully
12:57:07 AM |  Launching Game
12:57:07 AM |  Using HyperLaunch
12:57:07 AM |  Getting HyperLaunch path
12:57:07 AM |  HyperLaunch located at C:\HyperSpin\HyperSpin\HyperLaunch.exe
12:57:07 AM |  Running HyperLaunch.exe
12:57:07 AM |  HyperLaunch Command Line is: C:\HyperSpin\HyperSpin\HyperLaunch.exe "Sony PlayStation" "Megaman X4"
12:57:11 AM |  Loading Main Menu.xml
12:57:11 AM |  Main Menu.xml successfully loaded
12:57:12 AM |  Main Menu wheel loaded successfully
12:57:15 AM |  Exit program unavailable
12:57:15 AM |  Quiting Hyperspin
12:57:15 AM |  Bye!
the games work if i try them on the emulator by itself. if i can provide more info about this issue i would gladly do it. but as i have said, is something that happens to more people and with other systems, so i suppose that the problem has more to do with the configuation of hyperspin, but i dont really know where to look.
thanks for helping!
thanks for answering, i am using a 1.3.2 version of hs also, i have read that you should use 1.3.3 and then update it to to 1.4, and then use rocket launcher. i think that im going to do that them.
