Sykurmoli Posted July 29, 2017 Posted July 29, 2017 Hello. I've been following the official video tutorials but obviously wrong because games are not launching. When I select a game, nothing happens. I've googled for the problem and nothing I have found has been of help. It's the same problem for all systems with different emulators. Some details: I use Windows 10 64bit Latest versions of Hyperspin and RocketLauncher installed. Roms have been audited with no problem. It's also can't start any game from HyperLaunch, but when I click on the red rocket button in RocketLauncher UI, it works. I've modified the HyperSpin settings file to include Hyperlaunch_Path=F:\RocketLauncher\RocketLauncher.exe (which is where it is on my hard drive) I do not have any HyperLaunch or HyperSpin process that wouldn't have closed properly in my TaskManager (I've read this could cause my problem so I checked). Any help would be greatly appreciated. It's probably something obvious but I've searched on my own for hours without putting my finger on it. Here is what my log looks like (looks normal to me) 08:11:03 PM | HyperSpin Started 08:11:03 PM | Going windowed mode 08:11:03 PM | Checking for updates 08:11:03 PM | Update Check Complete 08:11:03 PM | Startup program unavailable 08:11:03 PM | Playing intro video 08:11:05 PM | Menu Mode is multi 08:11:05 PM | Loading Main Menu.xml 08:11:05 PM | Main Menu.xml successfully loaded 08:11:05 PM | Main Menu wheel loaded successfully 08:11:07 PM | Loading Nintendo Entertainment System.xml 08:11:07 PM | Main Menu.xml successfully loaded 08:11:07 PM | Nintendo Entertainment System wheel loaded successfully 08:11:15 PM | Launching Game 08:11:15 PM | Using HyperLaunch 08:11:15 PM | Getting Launcher path 08:11:15 PM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 08:11:15 PM | Running Launcher 08:11:15 PM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "Nintendo Entertainment System" "Adventures of Bayou Billy, The (USA)" 08:11:17 PM | Loading Main Menu.xml 08:11:17 PM | Main Menu.xml successfully loaded 08:11:18 PM | Main Menu wheel loaded successfully 08:11:27 PM | Loading MAME.xml 08:11:27 PM | Main Menu.xml successfully loaded 08:11:28 PM | MAME wheel loaded successfully 08:11:36 PM | Launching Game 08:11:36 PM | Using HyperLaunch 08:11:36 PM | Getting Launcher path 08:11:36 PM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 08:11:36 PM | Running Launcher 08:11:36 PM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "MAME" "mgavegas21" 08:11:41 PM | Launching Game 08:11:41 PM | Using HyperLaunch 08:11:41 PM | Getting Launcher path 08:11:41 PM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 08:11:41 PM | Running Launcher 08:11:41 PM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "MAME" "vroulet" 08:11:44 PM | Loading Main Menu.xml 08:11:44 PM | Main Menu.xml successfully loaded 08:11:44 PM | Main Menu wheel loaded successfully 08:11:46 PM | Exit program unavailable 08:11:46 PM | Quiting Hyperspin 08:11:46 PM | Bye!
steptoeUK Posted August 2, 2017 Posted August 2, 2017 I had something similiar, some systems worked but other refused no matter what I tried so I started checking settinsg files by hand and found the global emulators.ini was causing all my problems Hyperspin is VERY picky when it comes to where files/emulators are. If it can't find EXACTLY what is in the various settings .ini files it WILL fail leaving you frustrated and wondering why. Once you have got the idea of what is where it is very easy to set-up and easy to add more systems, even if some emulators are not already set-up for some ROMs types adding more is easy once you know what settings are where I've managed to get MESS to work with more systems than the default Hyperspin is set up for and also use MESS 0.188 which supports a lot more systems than ever as running them via MAME had Hyperspin assuming it was arcade ROMs and failing. Running two separate systems as MAME and MESS allows me more control and doesn't confuse Hyperspin. I'm now using MAME and MAME 0.188 and can easily update as and when new systems are working without having to use multiple emulators unless they offer better support than MESS Basically, check your Hyperspin/settings/global emulators.ini and I think you will find your emulator filepath in RocketLauncherUI is different to what is stored in this simple text file. Manually edit the file and change the path to your emulator and you then should now find it works. I had exactly the same problem that it would via RocketLauncher or HyperLaunch but not via the wheels Creating the system in RocketLauncherUI, being aware the system names are VERY specific if you want all the GFX to work, sets the emulator paths correctly but doesn't change it in the Hyperspin/setting/global emulators.ini. Changing the paths by editing this file manually fixed every problem I was having with emulators not being recognised
