Missing main menu wheels (Resolved)
Mekquake
Hello all,
first off, I would like to say that I don't normally ask for help as I can normally find the answer I require from either the very helpful tutorials or previous forum answers, but this has me at a loss and I'm sure the members of the friendly Hyperspin community can help me.
I now have several emulators set up within Hyperspin and everything is dandy apart from one small issue. When I open Hyperspin the GameCube and PlayStation wheels are replaced by the default text. When I go in to either system then back out again the proper wheel logo comes back, but if I scroll through the main menu wheel again the system logo disappears once more. Does anyone has any solution to this?
Thanks
33 minutes ago, agent47 said:
The filenames of your wheel images don't match the system name exactly, most likely the capitalization. If your system names are GameCube and PlayStation and the images are named Gamecube and Playstation they will only show sometimes for whatever reason.
Thank you Agent 47. That worked perfectly. Sometimes you just need someone else to tell you the answer that is right in front of you.
