Sammy Atomiswave issue - Some games not working
RyuHayabusa78
Ok, something really weird going on here. I've got Sammy Atomiswave up and running on Hyperspin now for the most part. Got the controls set up and everything. However, for some odd reason a few games simply will not launch within Hyperspin or Rocketlauncher, namely Fist of the North Star, Guilty Gear X and all the other ARC system games. They all work perfectly outside of HS using Demul 7a. I have all the bios files in the rom folder within the Demul folder. However, when I got to launch these particular games within HS I hear an error chime and nothing happens. I can't even see the damn error because I can't get HS to shut down to where I can see it. Any ideas? I've scoured Google looking for an answer.
3 hours ago, agent47 said:
Run them through RLUI so you can see the error message. If it's not something obvious that you can fix yourself turn set the logging in RLUI to Troubleshooting, run one of the problem games, upload the rocketlauncher.log to pastebin and link it here.
Thanks. I was able to locate the problem by looking at the log. For whatever reason the 5 or so games that weren't working were being pointed to a different module in the games.ini in the RL settings folder. I had honestly never used the log viewer before but it came in handy so next time I have a problem I can take a look at that and maybe figure it out from that. Thanks again.
One more question if you don't mind. Any idea on how to get Demul 7a to run better? It's running really choppy and the sound is garbled badly. I'm running an i3-6100 @3.7ghz, 8gb of RAM, and a Radeon HD 6450 with 1gb of RAM. It would seem more than enough to run these games smoothly but it isn't. The games run better on my crappy Dell PC that's half as powerful with a Pentium g3020. I've checked out all the settings and nothing seems to help.
