Hyperspin Problems
Marc
Evening all,
Having a weird problem so let me try and explain it as best as I can:
I wanted to get rid of the duplicate roms and use only the parent roms so it would tidy up HS, so I used HyperHQ and ticked "Parent Roms" under the Wheel Settings => Navigation/Themes TAB for MAME.
When I loaded up HS it had done what I asked it to do but for some reason when I push left or right to get to the roms beginning with "B" nothing happens, the wheel moves and shows no wheel on the right but HS does not crash, I cannot move up and down but if I press and hold left or right it lets me move to another letter and works fine. This is only happening with the letter "B" all other letters are fine if I cycle through using left and right pushes of the joystick
Does anyone have any ideas at all please?
Also should I even be using Hyper HQ any more?
Thanks
Marc
Has anyone came across this please, its driving me nuts and starting to really get under my skin.
I have tried replacing the .xml for mame and its still the same, I have tried messing about with all option in HyperHQ with regards to the wheel setting for mame and its still doing it.
Someone must have came across this before?
Marc
Also to add to this:
I can look through all of the roms under "B" by going to "C" and going back and they are all there, this only seems to happen when I move to "B" by pressing the joystick left or right.
Very weird indeed
Sorry for the spam:
When I use the genre option for wrestling games, or any genre and use the left and right to cycle through the letters it works fine.
Its only when I am in the "all games" genre that it messes up when I go to the letter "B".
Marc
SOLVED:
Was a problem with the wheel artwork, eventually figured it out so I re-downloaded from HyperSync and all is solved.
Just in case anyone else ever has a similar problem to this
