mafiafan123 Posted December 29, 2017 Posted December 29, 2017 Two quick questions I can run Sega model 2 emulator from rocketlauncher just fine. However it fails to load in Hyperspin everything is setup in hyperhq and using hyperlaunch. Below is a log from Hyperspin I press start on a game it looks like its opening and then doesn't do anythng LOG 03:13:28 AM | Sega Model 2 wheel loaded successfully 03:13:33 AM | Launching Game 03:13:33 AM | Using HyperLaunch 03:13:33 AM | Getting Launcher path 03:13:33 AM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 03:13:33 AM | Running Launcher 03:13:33 AM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "Sega Model 2" "hotd" 03:13:38 AM | Loading Main Menu.xml 03:13:38 AM | Main Menu.xml successfully loaded 03:13:39 AM | Main Menu wheel loaded successfully Also trying to configure joy2key for joystick and mouse support I am able to test in rocket launcher and it works great however when the game launches it loses the mouse bind to the joystick however they keys are still working. Any ideas? Its a late one if you can tell by the log file lol I have been at it for several hours and im sure its something simple
mafiafan123 Posted December 29, 2017 Author Posted December 29, 2017 Update I fixed the loading for some reason I had to put the animation to true. Do not understand why however.... Now I just need to figure Joy2Key and using the joystick for the cross hair on gun games it works in the test but losses mouse control in game keyboard joy2key shortcuts remain active however
