HyperLaunch Problem
gtannenb
I'm new to using Hyperspin and followed the directions on the "How To Install HyperSpin" link.  I changed the default settings to have everything installed on the D: drive.  I only got to installing the MAME emulator but cannot get it to work.  When I tried to test the rom via HyperLaunch, it does nothing.  Following is the log from HyperLaunch:
01:26:11 PM |  HyperLaunch v2.25c
01:26:11 PM |  System Specs:
        HyperSpin Dir: D:\Hyperspin
        OS: WIN_7
        OS Language: 0409
        OS Admin Status: No
        Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work)
        HyperSpin Res: 1920x1200
        AHK Version: 1.1.07.03
01:26:11 PM |  HyperLaunch received "MAME" and "39in1"
01:26:11 PM |  INI Keys read
01:26:11 PM |  Possible duplicate launch.  is already running, closing HyperLaunch
Following is the log for HyperSpin:
01:23:24 PM |  HyperSpin Started
01:23:24 PM |  Going FullScreen
01:23:24 PM |  Checking for updates
01:23:24 PM |  Update Check Complete
01:23:24 PM |  Startup program unavailable
01:23:24 PM |  Playing intro video
01:23:42 PM |  Error intializing joysticks
01:23:42 PM |  Menu Mode is multi
01:23:42 PM |  Loading Main Menu.xml
01:23:43 PM |  Main Menu.xml successfully loaded
01:23:43 PM |  Main Menu wheel loaded successfully
01:23:48 PM |  Loading MAME.xml
01:23:49 PM |  Main Menu.xml successfully loaded
01:23:50 PM |  MAME wheel loaded successfully
01:26:08 PM |  Launching Game
01:26:08 PM |  Using HyperLaunch
01:26:08 PM |  Getting Launcher path
01:26:08 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
01:26:08 PM |  Launcher located at D:\Hyperspin\HyperLaunch.exe
01:26:08 PM |  Running Launcher
01:26:08 PM |  Launcher Command Line is: D:\Hyperspin\HyperLaunch.exe "MAME" "39in1"
01:26:11 PM |  Launching Game
01:26:11 PM |  Using HyperLaunch
01:26:11 PM |  Getting Launcher path
01:26:11 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
01:26:11 PM |  Launcher located at D:\Hyperspin\HyperLaunch.exe
01:26:11 PM |  Running Launcher
01:26:11 PM |  Launcher Command Line is: D:\Hyperspin\HyperLaunch.exe "MAME" "39in1"
01:28:09 PM |  Loading Main Menu.xml
01:28:09 PM |  Main Menu.xml successfully loaded
01:28:09 PM |  Main Menu wheel loaded successfully
01:28:13 PM |  Exit program unavailable
01:28:13 PM |  Quiting Hyperspin
01:28:13 PM |  Bye!
I'm sure this is a simple fix but does anyone know why this is occurring?  Any help would be appreciated.
Thank you
