Guest hellsing001 Posted January 11, 2018 Posted January 11, 2018 Can anyone explain why the xml database files have issues with certain symbols. For example the Super Nintendo xml file shows Super Ghouls'n Ghosts (USA) it should read Super Ghouls'n Ghosts (USA) I'm having to manually edit the files to fix them. hellsing
Guest hellsing001 Posted January 11, 2018 Posted January 11, 2018 Yes the one from Sept 2017. Still has the above. hellsing
Guest hellsing001 Posted January 11, 2018 Posted January 11, 2018 OK - thanks for the explanation. I have noticed it does correct the text when it displays it. hellsing
Guest Posted January 12, 2018 Posted January 12, 2018 Can anyone explain why the xml database files have issues with certain symbols. For example the Super Nintendo xml file shows Super Ghouls'n Ghosts (USA) it should read Super Ghouls'n Ghosts (USA) I'm having to manually edit the files to fix them. hellsingActually that’s exactly how it should be. The XML standard dictates that special characters should be replaced with their appropriate symbols.Do not edit these out of the xmls or you will potentially break elements of your setup.Sent from my iPhone using Tapatalk Pro
