elphantomrebel Posted January 20, 2018 Posted January 20, 2018 Hello! Hyperspin noob here! I am trying to add systems and configure existing systems in a build i downloaded from the net. Got everything running except... I keep running into the message; "Can't find roms with any provided extensions". I have tried adding ColecoVision for example and the emulator (colEm) works on it's own... The extensions names both in Hyper HQ and settings file for the system are correct and separated by a coma and a space. This build does not have the HyperLaunch UI. Is this a problem that needs this program to be settled? If so can i add and use it in an existing build? Any help would be appreciated Thank you! P.S. Hope i posted this in the right forum!
