defre1976 Posted January 25, 2018 Posted January 25, 2018 Hi , I realy like this emu , runs games great . But i have a problem , when i select dualshock in the module . The analog sticks don't work from my xbox 360 controller . When i launch the game in Epsxe , no problem . I already open a topic on the rocketlauncher forum , but i don't get any help . http://www.rlauncher.com/forum/showthread.php?5283-Epsxe-module-problem I am almost sure its the module . I found some other posts on this problem , but never a solution . Don't know why , but psx runs like shit in Retroarch(i7 7700k , 16gig ram,1060 6gb) , thats why i want to use espxe for my hyperspin setup . Its just also that its more fun to play for example crash bandicoot with analog stick . And in epsxe it works . But not when i launch in Rocketlauncher . Any suggestion ? Thx
Guest hellsing001 Posted January 25, 2018 Posted January 25, 2018 Did you setup the dual shock pad in Epsxe? Press f5 to switch between digital and analog if they aren't working. hellsing
Guest hellsing001 Posted January 25, 2018 Posted January 25, 2018 Simply Austin has a great tutorial on Playsation 1 in Retroarch using Beetle PSX HW.
defre1976 Posted January 26, 2018 Author Posted January 26, 2018 21 hours ago, hellsing001 said: Did you setup the dual shock pad in Epsxe? Press f5 to switch between digital and analog if they aren't working. hellsing Yes tried different settings. Dualshock in epsxe and dualshock in module rocketlauncher. Buttons and d-pad works . But no analog sticks. Also after pressing f5. If i load the game in epsxe and i sellect dualshock. Ape escape works direct with anamog stick. Don't need to press f5. Also for example crash bandicoot . In epsxe I chose dualshock. Game start and i can play with the d-pad. After pressing f5 i can play the game with the analog sticks. But in rocketlzuncher it totally don't work. Ape escape i chose dualshock . Only d-pad and button works. No analog sticks. Crash bandicoot i must chose digital to be able to play the game. So for me 100% module problem. And its sad because the emulator is running great . Easy to set up.
