hectorj Posted February 3, 2018 Posted February 3, 2018 Ive tried everything i can possibly think of i know it might be something easy but i just cant figure it out, ive been having this issue for days and ive thought about just uninstalling hyperspin from frustration So far i only have PC Games, Fusion, SNES, and MAME. Issue is i run a rom on MAME then exit to choose another rom but it wont launch anything after that, it just does that skip like it wants to load it but nothing happens it just stays on the hyperspin menu. I uploaded the log here logrocketlauncherlog.html Please help, i would really appreciate it, thank you!
hectorj Posted February 3, 2018 Author Posted February 3, 2018 23 minutes ago, agent47 said: Yup, I was correct. You need to set the "Hyperlaunch_path" in the HyperSpin/Settings/Settings.ini to point at your RocketLauncher.exe location. Its actually already set up, it does launch a game but when i exit to choose another it doesnt do anything... i attached my settings.ini file Settings.ini
hectorj Posted February 3, 2018 Author Posted February 3, 2018 14 minutes ago, agent47 said: It's not using RL, it's using HyperLaunch as shown in your log. If the path is set correctly then it's either a permissions issue in which case you'll probably have to set HS to run as admin, or you're not using HS 1.4. Yes! It was the old version, thank you so much this was giving me a headache.. I upgraded and now its working fine.. I appreciate the help!
