zebi Posted March 7, 2018 Posted March 7, 2018 hi Guys I have a problem closing hyperspin. i need an emulator alt + f4 if i put a button in my cabinet there. however, if I give this command out not only the emulator (epsxe) but also hyperspinn is completely closed. Is there a way to disable alt + f4 in hyperspinning? sorry, my english is still out of school = D Emu Samler
Guest Posted March 7, 2018 Posted March 7, 2018 Don’t use alt+f4 as the emulator exit key. Sent from my iPhone using Tapatalk Pro
zebi Posted March 7, 2018 Author Posted March 7, 2018 the emulator exit key can not be changed. esc would be a better choice for the emulator key. Now the question is if there is a function in Hyperspinn to disable alt + f4 Emu Samler
acpowell Posted March 8, 2018 Posted March 8, 2018 What emulator requires ALT+F4? Using rocket launcher I have player 1 coin + player 2 start as my exit command. it works for ALL of my emulators (TTX/MAME/Demul/Daphne)
zebi Posted March 9, 2018 Author Posted March 9, 2018 OK. but no matter which one I touch the alt and f4 assign it always includes hyperspin Emu Samler
acpowell Posted March 13, 2018 Posted March 13, 2018 On 3/9/2018 at 9:31 AM, zebi said: OK. but no matter which one I touch the alt and f4 assign it always includes hyperspin I still don't get why you need to use Alt+F4. Are you using Rocket Launcher or Hyper launcher? If you are then you can setup almost any key stoke to exit the emulator with out exiting Hyperspin.
zebi Posted March 13, 2018 Author Posted March 13, 2018 I had always used xpadder for the exit key, so my mistake why hyperspin was also terminated. have changed the attitude, in the rocket launcher and so it works.have only the playstation control problem in the other thread. Emu Samler
acpowell Posted March 13, 2018 Posted March 13, 2018 Wish I could help with the other issue but I don't use it. Good Luck.
