5thWolf Posted May 21, 2018 Posted May 21, 2018 I am searching for a square/4:3 monitor that would fit my arcade cabinet. Which is about 25"x25". I am guessing around a 24" monitor/tv would fit. An company or site, monitor or TV, hell I would even consider a CRT! Thanks in advance!! ~5thWolf~
fuzzystapler Posted June 5, 2018 Posted June 5, 2018 I’m using a square LG LM265SQ1 panel that I found after seeing one being used as square digital signage. I have to say, this is the perfect emulator LCD. Both horizontal and vertical games display large a bright. This must be the 6th or 7th display device that I’ve used in my Donkey Kong Jr. conversion cabinet since I built it in 2002, and it is by far the best! I found the panel with controller hardware on Alibaba for roughly $425.
5thWolf Posted June 5, 2018 Author Posted June 5, 2018 Hmmm... Looks perfect but demensions are a little small. Says its basicly 19" x 19". Unless they are wrong about the LxW. That what yours is? 19x19 ~5thWolf~
5thWolf Posted June 5, 2018 Author Posted June 5, 2018 Doesn't seem to be anything larger than 26.5". I might just get what your suggesting. What controller hardware are you refering to? I needs something special for output? ~5thWolf~
