PC (hotd3) Game starts minimised (or behind HS)
Chillijason
Hi,
having a problem with hotd3 and windows 10.
firstly, the game works perfectly with my Aimtrak etc.. if run outside of RL.
but when run in RL or HS, it loses focus and minimises after the main menu.
I have narrowed it down to the startup script in RL that changes a reg key to jump past the game menu and start the game.
it doesn't appear to work in windows 10?
I have check the script (as per ninja2bceen) and it works just fine, and changes the registry key as it is supposed to... however the game still starts up at the main menu.
when I click 'Start Game" on the HOTD3 main menu … the game starts, but loses focus to Hyperspin, as HS sees it as 'game exit' .
the game stays minimised and paused in the taskbar.
is there something I can add to the module or startup script to bypass this behaviour?
or is there something else for windows 10.....
im new but im learning :)
appreciate any help, cheers.
 here's the log.. something isn't right, im just not sure how to fix it (newbie) thanks :)
11:30:58:914 | MD |      INFO  | +0     | File.CheckFile - Checking if "D:\Arcade\Games\PC Games\THE HOUSE OF THE DEAD3_EU\hod3launch.exe" exists
11:30:58:915 | MD |      INFO  | +0     | CheckSettings - Ended
11:30:58:915 | MD |      INFO  | +0     | PCLauncher - Launching a standard application.
11:30:58:915 | MD |      INFO  | +0     | Process.Run - Running: "D:\Arcade\Games\PC Games\THE HOUSE OF THE DEAD3_EU\hod3launch.exe"
11:30:58:952 | MD |      INFO  | +47    | PCLauncher - FadeTitle and AppWaitExe not set by user, but a PID for the primary application was found. Waiting for PID: 456
11:30:58:952 | MD |      INFO  | +0     | PCLauncher - Creating a window based on the Primary Application "hod3launch.exe" because FadeTitle nor AppWaitExe were set
11:30:58:952 | MD |      INFO  | +0     | Window.Wait - Waiting for window "ahk_pid 456"
11:30:59:095 | MD |      INFO  | +140   | PCLauncher - Waiting for the Primary Application PID "456" to close.
11:30:59:095 | MD |      INFO  | +0     | Process.Process - "WaitClose" "hod3launch.exe"
11:31:05:993 | MD |      INFO  | +6891  | ExitModule - Started
11:31:05:993 | MD |      INFO  | +0     | UpdateStatistics - Starting Updating Statistics
11:31:06:178 | MD |      INFO  | +188   | UpdateStatistics - Game section statistics updated.
11:31:06:179 | MD |      INFO  | +0     | ServoStik - Started
11:31:06:179 | MD |   WARNING  | +0     | ServoStik - No devices found on system
11:31:06:179 | MD |      INFO  | +0     | ServoStik - Ended
11:31:06:180 | MD |      INFO  | +0     | ExitModule - Ended
