HELP - Launch Single .exe from main menu using hyperlaunch
loggio
Hi guys,
As the tittle suggests.
I want to launch the PC Game Pinball Arcade, directly from Hyperspins main menu... But i want to use Hyperlaunch to take care of the launching because i want to take advantage of the Fade feature.
I use the fade-in feature of hyperlaunch to display the System controls before the game boots.
Problem is, i'm not sure how to do this.
I can easily create a main menu wheel called PC Games, then launch the program from within the PC Games sub menu, however i don't want this... I want Pinball Arcade as a wheel in the Main Menu.
Is there a guide to this?
I'm assuming you use PCLauncher to take care of this, but how do i set it up in this instance?
There's plenty of tutorials to set up PCLauncer to work with PC Games sub menu items, but not from main menu.
Thanks in advance guys.
Loggio.
  • 1 year later...
Would you mind explaining how you got it working?  I'm in the same boat.  I've got the application on the main menu wheel, with a video and everything.  But in hyperlaunch i'm kinda stumped.  I manually added an emulator, with the launch path to my executable, but it's yelling at me about not setting a rom path, and when I do it's complaining about not finding any matches.  I just want it to launch the application!!
