How the "Favorites" button works...
b4ld0
I think I have an improvement to the favorites function of Hyperspin.
1. When you're NOT into Favorites Menu and you press its assigned button, the interface asks you to view the list or to add/remove the current game from that list (depends if the game is already or not in that list).
2. When you're INTO Favorites Menu and you press its assigned button, the interface asks you to view the list (which its a non-sense cause you are already in) or to remove the current game from that list (because you're already in favorites and the current game can't be added again).
My question is, it would be possible in this second case, that the interface should ask you to EXIT the list or remove the game, instead. Because there's no direct way to exit favorites with single wheel mode. You have to select a genre to do the trick but that's another button, and the way I've though you can control all favorites options with just one button, let's say ENTER/EXIT/ADD GAME/REMOVE GAME.
Thanks
