Problem between wheels and emulators
Marcoco
 Hello everyone, i've been having this problem and i can't find any information about it.
As you can see in the video, when the first game is launched, the wheel is still working in the background, and every time I press the start button, it launches a new game since it's still in the game selection screen back there. I have looked around the HyperHQ screens and everyting seems ok to me.
 Also the weird thing is that it only happens sometimes, for instance you can play regularly for an entire day, even shutting down the machine and starting it again, and it may work properly. But eventually it will start working this way and then it will keep failing even after resetting. This is honestly the most confusing part of it and it drives me crazy because i think i have fixed it and then it fails again.
  If anyone has solved this, or has any clue on what could be causing it, that would be great. Thanks in advance!
