SneakingSpin Posted December 17, 2019 Posted December 17, 2019 I have the newest Mednafen version setup with RocketLauncher and it launches correctly, the bezels are shown and all seems right. But it takes about 8 seconds from when the emulator is loaded to display it with the Bezels. So I can already hear the game sounds while the fade in screen is still showing. According to the RocketLauncher logs it tries to get the Window in the correct position multiple times and fails. But when I can finally see it, everything seems right. Attached is the log. Has anyone an idea how I could prevent this? Quote 23:14:43:357 | MD | INFO | +0 | BezelDraw - Started 23:14:43:443 | MD | TRACE | +94 | ReadBezelIniFile - Bezel ini file found. Defined screen positions: X1=240 Y1=2 X2=1670 Y2=1078 23:14:43:455 | MD | INFO | +0 | BezelDraw - Bezel Screen Offset: left= top= right= bottom= 23:14:43:478 | MD | INFO | +31 | HideWindowDecorators - Started 23:14:43:507 | MD | INFO | +31 | HideWindowDecorators - disableHideBorder=, disableHideTitleBar=, disableHideToggleMenu=, hideBorderFirst= 23:14:43:546 | MD | INFO | +32 | ToggleMenu - Started 23:14:44:074 | MD | WARNING | +531 | ToggleMenu - Timed out trying to restore MenuBar for 0x1608fa 23:14:44:075 | MD | INFO | +0 | ToggleMenu - Ended 23:14:44:106 | MD | INFO | +31 | HideWindowDecorators - Ended 23:14:44:136 | MD | INFO | +31 | MoveWindow - Moving window ahk_id 0x1608fa to X=320, Y=3, W=1907 H=1435 23:14:44:238 | MD | TRACE | +110 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:44:239 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:44:555 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:44:556 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:44:864 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:44:865 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:45:177 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:45:178 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:45:492 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:45:493 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:45:802 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:45:803 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:46:121 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:46:122 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:46:426 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:46:427 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:46:743 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:46:744 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:47:058 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:47:059 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:47:371 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:47:372 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:47:681 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:47:682 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:47:996 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:47:997 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:48:303 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:48:304 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:48:614 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:48:615 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:48:930 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:48:931 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:49:245 | MD | TRACE | +313 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:49:246 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:49:560 | MD | TRACE | +312 | WinMove - Moved ahk_id 0x1608fa to x:320 y:3 w: 1907 h: 1435 23:14:49:561 | MD | TRACE | +0 | WinGetPos - Retrieved x:320 y:3 w: 1911 h: 1468 from ahk_id 0x1608fa 23:14:49:562 | MD | WARNING | +0 | MoveWindow - Failed: Window ahk_id 0x1608fa at X=320, Y=3, W=1911 H=1468 23:14:49:636 | MD | TRACE | +78 | BezelDraw - Bezel Image Screen Position: BezelImage left=0 top=0 right=2560 bottom=1440 23:14:49:637 | MD | TRACE | +0 | BezelDraw - Game Screen Position: BezelImage left=320 top=3 right=2227 bottom=1438 23:14:49:637 | MD | TRACE | +0 | EnableBezelKeys - Bezel Keys Enabled 23:14:49:638 | MD | INFO | +0 | BezelDraw - Ended Expand
SneakingSpin Posted December 17, 2019 Author Posted December 17, 2019 I found a workaround. I edited the Mednafen.ahk module and send a Pause command to the emulator before and after the Bezeldraw command. It still takes unnecessarily long to show the emulator but at least the game doesn't start before it shows and I don't hear the sound from the game already while it's still not showing. Quote KeyUtils.SetKeyDelay(50) KeyUtils.Send("{Pause}") BezelDraw() KeyUtils.Send("{Pause}") Expand
