fightnightfz Posted December 28, 2019 Posted December 28, 2019 Hey Y'all, need some help here. I'm using a vertical arcade setup and have only been able to find HyperV to use as a frontend. It works fine for arcade, but the orientation doesn't with pinball because it needs to be in portrait mode to work, but HyperV only shows up correctly in Landscape. I've tried to open HyperTheme and load the menu to flip it, but I can't even figure out how to open all the menu's/etc. Along with that, even playing around in HyperTheme I don't see how to change orientation. Can I get some guidance on how to do that? Is there an ini file that I can change the degrees? Here is the link to the program I'm using if want to see the file/theme structure: https://www.arcadepunks.com/download-hyperspin-versions-2019/ Any help would be greatly appreciated and I look to pay it forward with a comprehensive n00b guide and hosted file that will help those who have limited to no knowledge in this space. Thanks in advance!
