dbeste Posted February 1, 2020 Posted February 1, 2020 Looking for help with a HyperSpin error after adding the HyperSpin Startup script. I downloaded the .exe and ran it first to generate the .ini. I then added it to the Startup section in HyperHQ. I launched HyperSpin and it gave the attached error. No changes to the .ini file. I did notice that the value being displayed is the value of the %TEMP% environment variable. I changed The end variable to C:\Temp as shown in the message and still get the error. If I go into HyperHQ and remove the script I no longer receive the error. Also if I launch the script outside of HyperSpin I do not get the error. That’s whether I leave the .ini file as is or simple have it launch LEDBlinky. Any thoughts would be much appreciated.
FETTABUBA Posted February 5, 2020 Posted February 5, 2020 Hi I'm having the same issue, although now I’ve lost all controls as well - this work with notepad Did you get this resolved?? Ian
dbeste Posted February 8, 2020 Author Posted February 8, 2020 Unfortunately, I have not been able to resolve the issue.
