Printerrepairdu Posted May 7, 2020 Posted May 7, 2020 hp printer repair service in dubai also Fix hp printer problem Paper jam The main and general issue with the printer is paper jam, it means that paper is stuck inside the printer and printer is not working. There are many reasons for paper jam some of them are given below. Sensor Issue: There is Optical sensor which give command to printer for picking up the paper from paper tray and print. Sometime that sensor doesn’t work and cause paper Jam for the solution for this is call UAE TECH for the professional replacement of sensor. Pick up roller: It is soft and rubbery surface which pick the paper from paper tray. Sometime dust or dirt in roller cause for paper jam issue. It is very sensitive thing if not done by care then it can head. Transfer belt: Transfer belt pick the paper and passes it through each component of hp printer to complete the printing process. Sometime due to dust, dirt or break down of transfer belt cause the Paper Jam. Paper Tray: Sometime putting wrong paper tray to wrong model of hp printer can cause the paper jam and we should clean paper tray time to time to make printing process smoothly. Printer repair dubai
