Kleyon Posted February 28, 2021 Posted February 28, 2021 Hi everyone, I have an issue concerning Daphne, when I launch content using an higher resolution, image is out of scope, I mean it is not centred correctly, I only have a part of image on screen! Issue occurs using Hyperspin or not. Resolution can be set on batch file, when you use a non-conventional resolution, under daphne-log we can read : Quote WARNING : You have specified an abnormal screen resolution! Normal screen resolutions are: 640 x 480 800 x 600 1024 x 768 1280 x 960 1280 x 1024 1600 x 1200 Expand Well ok so let's use "normal screen resolution", so I tried using these resolutions, issue is the same from 1600x1200 to 1280x960 and start to work correctly at 1024x768 resolution. It is working fine using a 16/9 resolution too like 1280x720 so 720p(but again not centred using 1080p) but game is showing in 4/3 and so did not use all screen. I see some users are using higher resolutions. Can someone can explain me what I missed here please? I need to add I use Daphne v1.0.9 and Daphne Singe v1.0.10, seems like a Daphne v1.0.12 exist but I didn't find it on the net, seems like we can update Daphne via DaphneLoader too... again didn't find how! So if someone could share Daphne v1.0.12 it would be really cool! Thanks. Edit : Well I suppose we can forget about it.... just realized Singe 2 exist and I found content I want for it, should fix issue... Also found a Daphne 4K pack but I'm not sure it can be used with a launcher when Singe 2 can.
