Android HS reload background always on
CHIPPOSHIVA
Hi, i work a lot to make my perfect HS on android from scratch !
I understand there is some feature that don't work like animated wheel with swf but what i don't understand is why reload background seems blocked on true with android settings ?
With my pc no problem i set false and it doesn't happend, but when i switch my HS on my shield, every themes are on reload background=true. Is there a way to fix the only issue who stays in my way ^^
THX
As i'm looking for a workaround i was trying to lower the time and delay for artworks in theme that i don't want to reload specifically and i notice that if i set 0 on time and delay it kinda work but as some artworks for theme are .swf they simply don't appear, but if i set 0.1 or 0.0000001 it works for swf. But sadly there is still a liitle time without background artwork disapearing, is there a way to look into apk to maybe see if it's possible to disable background reloading ?
