RocketLauncher can't find the ini file
ddog
Here is the info so that ya'll ca
[code]
16:54:39:494 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com)
16:54:39:557 | RL |   WARNING  | +63    | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance.
16:54:39:809 | RL |     DEBUG  | +250   | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
16:54:39:848 | RL |     DEBUG  | +31    | Registry.Read - Registry Read finished, returning 0
16:54:39:882 | RL |      INFO  | +47    | Main - System Specs:
                    RocketLauncher Dir: D:\Arcade\RocketLauncher
                    RocketLauncher is: 32-bit
                    OS: Microsoft Windows 10 Home
                    SKU: Windows 8
                    Total Memory: 16250.46 MB
                    Free Memory: 10602.03 MB
                    Used Memory: 5648.430 MB
                    SystemType: 64-bit
                    Physical Processors: 1
                    Logical Processors: 4
                    GPU 1 Name: NVIDIA GeForce GTX 1050
                    GPU 1 RAM: -1.00 MB
                    GPU 1 Driver Version: 30.0.14.9729
                    GPU 2 Name: Intel(R) HD Graphics 630
                    GPU 2 RAM: 1024.00 MB
                    GPU 2 Driver Version: 27.20.100.9664
                    Sound 1 Device: Realtek Audio
                    Sound 1 Status: Enabled
                    Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
                    Sound 2 Status: Enabled
                    System Locale: en-US
                    Formats Locale: en-US
                    Windows UI Language: en-US
                    Text Encoding: Windows-1252
                    OS Admin Status: Yes
                    RL Compatibility Flags:  HIGHDPIAWARE
                    Latest .Net Version: v4.0.30319
                    Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1030 work) [32bit] [60hz] [Landscape]  (Primary)
                    Current AHK Desktop Width: 1920
                    Current AHK Desktop Height: 1080
                    Monitor #1 DPI: 125
                    ErrorMode: 0
                    AutoHotkey Path:
                    AHK Version: 1.1.13.00
                    Unicode: No
16:54:39:883 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
16:54:39:887 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             RocketLauncher
                    FileVersion                 1.2.0.1
                    LegalCopyright              �2016 RocketLauncher
                    ProductName                 djvj's one swell guy!
                    ProductVersion              1.2.0.1
                    CompanyName                 Your favorite Front End companion! Visit us @ www.rlauncher.com
                    File Size:            2195456 bytes
                    Created:            1/22/2022 - 1:28:55 PM
                    Modified:            2/15/2021 - 9:46:15 PM
16:54:39:888 | RL |      INFO  | +0     | Main - Raw CLI received: "-s Nintendo 3DS -r Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA) -f D:\Arcade\HyperSpin.exe -p HyperSpin -c 1 -o 1"
16:54:39:895 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "D:\Arcade\RocketLauncher\Module Extensions\RocketLauncher.dll"
16:54:39:898 | RL |      INFO  | +16    | File.CheckFile - Checking if "D:\Arcade\RocketLauncher\Module Extensions\RocketLauncher.dll" exists
16:54:39:899 | RL |     TRACE  | +0     | File.Exist - This file exists: D:\Arcade\RocketLauncher\Module Extensions\RocketLauncher.dll
16:54:39:900 | RL |     DEBUG  | +0     | File.CheckFile - Attributes:
                    FileDescription             RocketLauncher Utils
                    FileVersion                 1.1.0.0
                    InternalName                RocketLauncher.dll
                    LegalCopyright              Copyright � RocketLauncher 2013-2016
                    OriginalFilename            RocketLauncher.dll
                    ProductName                 RocketLauncher
                    ProductVersion              1.1.0.0
                    File Size:            81408 bytes
                    Created:            1/22/2022 - 3:29:49 PM
                    Modified:            2/16/2021 - 5:27:34 AM
16:54:39:909 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: D:\Arcade\RocketLauncher\Module Extensions\Array.ahk
16:54:39:911 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            4926 bytes
                    Created:            1/22/2022 - 3:29:47 PM
                    Modified:            2/16/2021 - 5:27:37 AM
16:54:39:918 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk
16:54:39:920 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            5112 bytes
16:54:39:922 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe exists
16:54:39:926 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription
                    FileVersion                 1.1.09.04
                    InternalName
                    OriginalFilename
                    ProductName
                    ProductVersion              1.1.09.04
                    File Size:            657920 bytes
                    Modified:            2/16/2021 - 5:27:36 AM
16:54:39:932 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop
16:54:39:933 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            5503 bytes
16:54:39:940 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk
16:54:39:942 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            5716 bytes
                    Modified:            2/16/2021 - 5:27:33 AM
16:54:39:950 | RL |     ERROR  | +15    | CRC Check - No CRC defined on the header for: D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk
16:54:39:950 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            88789 bytes
                    Created:            1/22/2022 - 3:29:48 PM
16:54:39:957 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk
16:54:39:959 | RL |     DEBUG  | +16    | CheckFile - Attributes:
                    File Size:            5955 bytes
16:54:39:960 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gsdll32.dll exists
16:54:39:963 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            13090816 bytes
                    Modified:            2/16/2021 - 5:27:44 AM
16:54:39:965 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\itextsharp.dll exists
16:54:39:970 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             iTextSharp
                    FileVersion                 5.4.2.0
                    InternalName                itextsharp.dll
                    LegalCopyright              Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
                    OriginalFilename            itextsharp.dll
                    ProductName                 iTextSharp
                    ProductVersion              5.4.2.0
                    CompanyName                 1T3XT BVBA
                    File Size:            3743744 bytes
                    Modified:            2/16/2021 - 5:27:39 AM
16:54:39:976 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Module Extensions\Java.ahk
16:54:39:977 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            7859 bytes
16:54:39:982 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk
16:54:39:985 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            9227 bytes
                    Modified:            2/16/2021 - 5:27:35 AM
16:54:39:989 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk
16:54:39:990 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            4915 bytes
16:54:39:995 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk
16:54:39:996 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            6915 bytes
16:54:39:003 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk | v1.7
16:54:40:004 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            67872 bytes
16:54:40:005 | RL |      INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
16:54:40:010 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             SevenZipSharp
                    FileVersion                 0.64.5717.6837
                    InternalName                SevenZipSharp.dll
                    LegalCopyright              Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
                    OriginalFilename            SevenZipSharp.dll
                    ProductName                 SevenZipSharp
                    ProductVersion              0.64.5717.6837
                    CompanyName                 Markovtsev Vadim
                    File Size:            167424 bytes
16:54:40:015 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk
16:54:40:017 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            5517 bytes
16:54:40:023 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: D:\Arcade\RocketLauncher\Module Extensions\VA.ahk
16:54:40:025 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            34688 bytes
16:54:40:029 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk
16:54:40:030 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            3862 bytes
16:54:40:036 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\7z.ahk
16:54:40:037 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            33916 bytes
                    Created:            1/22/2022 - 1:28:59 PM
                    Modified:            2/16/2021 - 5:15:51 AM
16:54:40:044 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Bezel.ahk
16:54:40:045 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            121257 bytes
16:54:40:052 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Fade.ahk
16:54:40:054 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            39707 bytes
16:54:40:059 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Fade Init.ahk
16:54:40:061 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            1140 bytes
                    Modified:            2/16/2021 - 5:15:50 AM
16:54:40:066 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk
16:54:40:068 | RL |     DEBUG  | +15    | CheckFile - Attributes:
                    File Size:            77961 bytes
16:54:40:075 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Keymapper.ahk
16:54:40:076 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            33682 bytes
16:54:40:081 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk
16:54:40:082 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            3966 bytes
16:54:40:088 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\MultiGame.ahk
16:54:40:089 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            41583 bytes
16:54:40:094 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk
16:54:40:096 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            169 bytes
16:54:40:103 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk
16:54:40:105 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            67277 bytes
16:54:40:115 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Pause.ahk
16:54:40:117 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            408415 bytes
16:54:40:123 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Pause Init.ahk
16:54:40:124 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            563 bytes
16:54:40:131 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Password.ahk
16:54:40:132 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            10131 bytes
16:54:40:137 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk
16:54:40:138 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            31509 bytes
                    Created:            1/22/2022 - 1:29:00 PM
                    Modified:            2/16/2021 - 5:15:52 AM
16:54:40:143 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Log\Logger.ahk
16:54:40:145 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            3558 bytes
16:54:40:150 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk
16:54:40:151 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            6709 bytes
16:54:40:156 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk
16:54:40:157 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            2084 bytes
16:54:40:162 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\Environment\ArrayUtils.ahk
16:54:40:164 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            306 bytes
16:54:40:169 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\Environment\LocaleUtils.ahk
16:54:40:170 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            2104 bytes
16:54:40:178 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk
16:54:40:179 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            7754 bytes
16:54:40:185 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk
16:54:40:186 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            2948 bytes
16:54:40:191 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\ArchiveFile.ahk
16:54:40:193 | RL |     DEBUG  | +15    | CheckFile - Attributes:
                    File Size:            346 bytes
                    Modified:            2/16/2021 - 5:15:53 AM
16:54:40:198 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\DemulShooter.ahk
16:54:40:199 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            786 bytes
                    Created:            1/22/2022 - 1:29:02 PM
16:54:40:204 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk
16:54:40:206 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            1231 bytes
16:54:40:212 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\File.ahk
16:54:40:214 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            9522 bytes
16:54:40:221 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\FileUtils.ahk
16:54:40:222 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            339 bytes
16:54:40:228 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\Folder.ahk
16:54:40:231 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            643 bytes
                    Created:            1/22/2022 - 1:29:03 PM
16:54:40:236 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk
16:54:40:238 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            4364 bytes
                    Created:            1/22/2022 - 1:29:04 PM
16:54:40:243 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\Process.ahk
16:54:40:244 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            9711 bytes
16:54:40:250 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\PropertiesFile.ahk
16:54:40:251 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            4218 bytes
16:54:40:256 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk
16:54:40:259 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            3898 bytes
16:54:40:264 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\File\XMLFile.ahk
16:54:40:265 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            331 bytes
16:54:40:271 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk
16:54:40:272 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            5426 bytes
                    Created:            1/22/2022 - 1:29:05 PM
16:54:40:277 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\UI\Control.ahk
16:54:40:278 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            4603 bytes
16:54:40:284 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\UI\Window.ahk
16:54:40:285 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            24655 bytes
16:54:40:291 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk
16:54:40:292 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            1171 bytes
16:54:40:299 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk
16:54:40:301 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            72279 bytes
16:54:40:305 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Shader.ahk
16:54:40:306 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            4183 bytes
16:54:40:311 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Shader Init.ahk
16:54:40:313 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            412 bytes
16:54:40:322 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Shared.ahk
16:54:40:323 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            173248 bytes
16:54:40:330 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Statistics.ahk
16:54:40:331 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            27008 bytes
16:54:40:340 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk
16:54:40:342 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            43 bytes
16:54:40:347 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk
16:54:40:348 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            20294 bytes
16:54:40:353 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\XHotkey.ahk
16:54:40:355 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            26615 bytes
16:54:40:361 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk
16:54:40:362 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            1073 bytes
16:54:40:363 | RL |     DEBUG  | +0     | Main - Received this dbName with no path via CLI: "Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)"
16:54:40:363 | RL |     DEBUG  | +0     | Main - dbName: Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)
16:54:40:364 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
16:54:40:370 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: D:\Arcade\RocketLauncher\Plugins\HyperSpin.plugin
16:54:40:371 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            9590 bytes
                    Created:            1/22/2022 - 3:31:38 PM
                    Modified:            2/15/2021 - 9:51:36 PM
16:54:40:372 | RL |     TRACE  | +0     | Process.__New - Creating new process object for: "D:\Arcade\HyperSpin.exe"
16:54:40:373 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "D:\Arcade\HyperSpin.exe"
16:54:40:378 | RL |      INFO  | +0     | Main - RocketLauncher received "Nintendo 3DS" and "Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)"
16:54:40:385 | RL |      INFO  | +16    | Main - Did not find a "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Game Options.ini" file, skipping any game-specific options.
16:54:40:386 | RL |      INFO  | +0     | Main - Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA) is using the default emulator: Citra (3DS)
16:54:40:387 | RL |      INFO  | +0     | Main - Checking for a [Citra (3DS)] section in D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Emulators.ini
16:54:40:388 | RL |      INFO  | +0     | Main - Checking for a [Citra (3DS)] section in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
16:54:40:391 | RL |      INFO  | +0     | Main - Found [Citra (3DS)] in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
16:54:40:399 | RL |      INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Modules\Citra\Citra.ahk exists
16:54:40:403 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            4161 bytes
                    Created:            1/22/2022 - 3:30:19 PM
                    Modified:            2/16/2021 - 5:15:21 AM
16:54:40:406 | RL |      INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
16:54:40:407 | RL |      INFO  | +0     | Main - Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA) will use module: D:\Arcade\RocketLauncher\Modules\Citra\Citra.ahk
16:54:40:491 | RL |      INFO  | +93    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
16:54:40:510 | RL |      INFO  | +16    | CheckFile - Checking if D:\Arcade\emulators\Citra\nightly-mingw\citra-qt.exe exists
16:54:40:515 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            58363023 bytes
                    Created:            1/24/2022 - 8:36:27 PM
                    Modified:            1/24/2022 - 8:36:27 PM
16:54:40:515 | RL |      INFO  | +0     | Main - INI Keys read
16:54:40:520 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.exe exists
16:54:40:525 | RL |     DEBUG  | +16    | CheckFile - Attributes:
                    FileDescription             7-Zip Console
                    FileVersion                 15.06 beta
                    InternalName                7z
                    LegalCopyright              Copyright (c) 1999-2015 Igor Pavlov
                    OriginalFilename            7z.exe
                    ProductName                 7-Zip
                    ProductVersion              15.06 beta
                    CompanyName                 Igor Pavlov
                    File Size:            262144 bytes
16:54:40:526 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.dll exists
16:54:40:532 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             7z Plugin
                    InternalName                7z
                    OriginalFilename            7z.dll
                    ProductName                 7-Zip
                    File Size:            1012224 bytes
16:54:40:538 | RL |      INFO  | +15    | Main - "Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
16:54:40:540 | RL |      INFO  | +0     | CheckPaths - Started
16:54:40:541 | RL |      INFO  | +0     | CheckPaths - Looking for rom: D:\Arcade\Nintendo 3DS\roms\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).3ds
16:54:40:542 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Arcade\Nintendo 3DS\roms\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).3ds
16:54:40:543 | RL |      INFO  | +0     | CheckPaths - Looking for rom by extension: D:\Arcade\Nintendo 3DS\roms\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\*.3ds
16:54:40:544 | RL |      INFO  | +0     | CheckPaths - Looking for rom: D:\Arcade\Nintendo 3DS\roms\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).7z
16:54:40:545 | RL |      INFO  | +0     | CheckPaths - Found rom: D:\Arcade\Nintendo 3DS\roms\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).7z
16:54:40:546 | RL |     DEBUG  | +0     | CheckPaths - Current romName: Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)
16:54:40:547 | RL |     DEBUG  | +0     | CheckPaths - Current romPath: D:\Arcade\Nintendo 3DS\roms
16:54:40:548 | RL |     DEBUG  | +0     | CheckPaths - Current romExtension: .7z
16:54:40:549 | RL |      INFO  | +0     | CheckPaths - Ended
16:54:40:550 | RL |      INFO  | +0     | BuildScript - User Variables:
                    ; INJECTED VARIABLES
                    #NoTrayIcon
                    #InstallKeybdHook
                    MiscUtils.DetectHiddenWindows("On")
                    SetTitleMatchMode, 2
                    SendMode, Event
                    Global RLLog
                    Global RLObject
                    0 := "12"
                    rlPath := "D:\Arcade\RocketLauncher"
                    pluginPath := "D:\Arcade\RocketLauncher\Plugins"
                    pluginName := "HyperSpin"
                    pluginExt := ".plugin"
                    contextOnExit := "1"
                    rlMode := ""
                    rlTitle := "RocketLauncher"
                    rlVersion := "1.2.0.1"
                    rlAuthor := "djvj"
                    rlURL := "www.rlauncher.com"
                    langFile := "D:\Arcade\RocketLauncher\Data\Language\Localization.ini"
                    primMonitor := "1"
                    frontendPID := ""
                    frontendPath := "D:\Arcade"
                    frontendExe := "HyperSpin.exe"
                    frontendExt := "exe"
                    frontendName := "HyperSpin"
                    frontendDrive := "D"
                    exitEmulatorKey := "Esc|H1000:1joy7"
                    restoreFE := "Restore"
                    exitScriptKey := "~q & ~s"
                    toggleCursorKey := "~e & ~t"
                    emuFullPath := "D:\Arcade\emulators\Citra\nightly-mingw\citra-qt.exe"
                    emuPath := "D:\Arcade\emulators\Citra\nightly-mingw"
                    emuName := "Citra (3DS)"
                    emuExt := "exe"
                    baseRomPath := ""
                    romPath := "D:\Arcade\Nintendo 3DS\roms"
                    romPathFromIni := "D:\Arcade\Nintendo 3DS\roms"
                    romExtension := ".7z"
                    romExtensionOrig := ".7z"
                    romExtensions := "3ds|7z|zip|rar|cxi"
                    executable := "citra-qt.exe"
                    systemDbName := "Nintendo 3DS"
                    systemName := "Nintendo 3DS"
                    dbPath := ""
                    dbName := "Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)"
                    dbExt := ""
                    romFoundByExt := ""
                    romName := "Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)"
                    romMapPath := ""
                    romMappingEnabled := "false"
                    romMappingLaunchMenuEnabled := "false"
                    romMappingFirstMatchingExt := "false"
                    romMappingShowAllRomsInArchive := "true"
                    romMappingNumberOfGamesByScreen := "7"
                    romMappingHideParent := "false"
                    romMappingMenuWidth := "300"
                    romMappingMenuMargin := "50"
                    romMappingTextFont := "Bebas Neue"
                    romMappingTextOptions := "cFFFFFFFF r4 s40 Bold"
                    romMappingDisabledTextColor := "ff888888"
                    romMappingTextSizeDifference := "5"
                    romMappingTextMargin := "10"
                    romMappingTitleTextFont := "Bebas Neue"
                    romMappingTitleTextOptions := "cFFFFFFFF r4 s60 Bold"
                    romMappingTitle2TextFont := "Bebas Neue"
                    romMappingTitle2TextOptions := "cFFFFFFFF r4 s15 Bold"
                    romMappingGameInfoTextFont := "Bebas Neue"
                    romMappingGameInfoTextOptions := "cFFFFFFFF r4 s15 Regular"
                    romMappingGameNameTextFont := "Bebas Neue"
                    romMappingGameNameTextOptions := "cFFFFFFFF r4 s40 Regular"
                    romMappingBackgroundBrush := "aa000000"
                    romMappingColumnBrush := "33000000"
                    romMappingButtonBrush1 := "6f000000"
                    romMappingButtonBrush2 := "33000000"
                    romMappingBackgroundAlign := "Stretch and Lose Aspect"
                    romMappingMenuFlagWidth := "40"
                    romMappingMenuFlagSeparation := "5"
                    romMappingDefaultMenuList := "FullList"
                    romMappingSingleFilteredRomAutomaticLaunch := "false"
                    altArchiveNameOnly := ""
                    altRomNameOnly := ""
                    altArchiveAndRomName := ""
                    altArchiveAndManyRomNames := ""
                    altRomNamesOnly := ""
                    romMapScenario := ""
                    skipchecks := "false"
                    romMatchExt := "true"
                    blockInputTime := "0"
                    blockInputFile := "D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe"
                    errorLevelReporting := "false"
                    lockLaunch := "false"
                    lockLaunchGame := ""
                    screenRotationAngle := "0"
                    screenRotationAngleGame := ""
                    setResolution := ""
                    logFile := ""
                    logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]
                    logLevel := "10"
                    logShowDebugConsole := "false"
                    logShowCommandWindow := "false"
                    logCommandWindow := "false"
                    logIncludeModule := "true"
                    logIncludeFileProperties := "true"
                    logIncludeDLLLogs := "false"
                    errorSounds := "true"
                    rlDebugConsoleStdout := ""
                    sysLang := "English_United_States"
                    sysType := "64-bit"
                    broadcastWindowTitle := ""
                    navUpKey := "Up"
                    navDownKey := "Down"
                    navLeftKey := "Left"
                    navRightKey := "Right"
                    navSelectKey := "Enter"
                    navP2UpKey := "Numpad8"
                    navP2DownKey := "Numpad2"
                    navP2LeftKey := "Numpad4"
                    navP2RightKey := "Numpad6"
                    navP2SelectKey := "NumpadEnter"
                    originalWidth := "1920"
                    originalHeight := "1080"
                    vdEnabled := "true"
                    vdFullPath := "C:\Program Files\DAEMON Tools Lite\DTAgent.exe"
                    vdUseSCSI := "true"
                    vdDriveLetter := "K"
                    vdDriveLetterScsi := ""
                    vdAddDrive := "true"
                    demulShooterPath := ""
                    servoStikEnabled := "false"
                    servoStikExitMode := "false"
                    ledblinkyEnabled := "false"
                    ledblinkySystemName := ""
                    ledblinkyFullPath := ""
                    ledblinkyProfilePath := "D:\Arcade\RocketLauncher\Profiles\LEDBlinky"
                    ledblinkyRLProfile := "D:\Arcade\RocketLauncher\Profiles\LEDBlinky\RocketLauncher"
                    winIPACFullPath := ""
                    ultraMapEnabled := "false"
                    ultraMapFullPath := ""
                    emuIdleShutdown := "0"
                    launchPasswordHash := "UpUpDownDownLeftRightLeftRight"
                    cursorSize := ""
                    hideCursor := "true"
                    hideEmu := "false"
                    hideFE := "false"
                    suspendFE := "false"
                    fadeIn := "true"
                    fadeInDuration := "500"
                    fadeInTransitionAnimation := "DefaultAnimateFadeIn"
                    fadeInDelay := "2000"
                    fadeInExitDelay := "0"
                    fadeOutExitDelay := "0"
                    fadeOut := "true"
                    fadeOutExtraScreen := "true"
                    fadeOutDuration := "500"
                    fadeOutTransitionAnimation := "DefaultAnimateFadeOut"
                    fadeOutDelay := "0"
                    fadeLyrInterpolation := "7"
                    fadeMuteEmulator := "false"
                    fadeUseBackgrounds := "true"
                    fadeClickThrough := "false"
                    fadeSounds := "true"
                    fade7zProgressMode := "extraction"
                    fadeWidthBaseRes := "1920"
                    fadeHeightBaseRes := "1080"
                    fadeLyr1Color := "FF000000"
                    fadeLyr1AlignImage := "Stretch and Lose Aspect"
                    fadeLyr2Pos := "No Alignment"
                    fadeLyr2X := "0"
                    fadeLyr2Y := "0"
                    fadeLyr2W := "1910"
                    fadeLyr2H := "1070"
                    fadeLyr2Adjust := "1"
                    fadeLyr2PicPad := "5"
                    fadeLyr2Prefix := "Extra Layer 1 - Console"
                    fadeLyr3Pos := "Center"
                    fadeLyr3X := ""
                    fadeLyr3Y := ""
                    fadeLyr3W := "1600"
                    fadeLyr3H := "150"
                    fadeLyr3Adjust := "1"
                    fadeLyr3PicPad := "0"
                    fadeLyr3Speed := "750"
                    fadeLyr3Animation := "DefaultFadeAnimation"
                    fadeLyr37zAnimation := "DefaultFadeAnimation"
                    fadeLyr3Type := "image"
                    fadeLyr3ImgFollow7zProgress := "true"
                    fadeLyr3Repeat := "1"
                    fadeLyr3BackImageTransparency := "30"
                    fadeLyr3StaticPos := "No Alignment"
                    fadeLyr3StaticX := "0"
                    fadeLyr3StaticY := "870|1575"
                    fadeLyr3StaticW := ""
                    fadeLyr3StaticH := ""
                    fadeLyr3StaticAdjust := "1"
                    fadeLyr3StaticPicPad := "0"
                    fadeLyr3StaticPrefix := "Info Bar"
                    fadeLyr4Adjust := "1"
                    fadeLyr4X := "25"
                    fadeLyr4Y := "700"
                    fadeLyr4W := "300"
                    fadeLyr4H := "350"
                    fadeLyr4Pos := "No Alignment"
                    fadeLyr4FPS := "70"
                    fadeLyr4PicPad := "20"
                    fadeTranspGifColor := "FFFFFF"
                    fadeBarWindow := "Image"
                    fadeBarWindowX := ""
                    fadeBarWindowY := ""
                    fadeBarWindowW := "900"
                    fadeBarWindowH := ""
                    fadeBarWindowR := "30"
                    fadeBarWindowM := "30"
                    fadeBarWindowHatchStyle := "8"
                    fadeBar := "7zOnly"
                    fadeProgressDuration := "0"
                    fadeBarBack := "true"
                    fadeBarBackColor := "FF555555"
                    fadeBarH := "30"
                    fadeBarR := "10"
                    fadeBarColor := "DD00BFFF"
                    fadeBarHatchStyle := "8"
                    fadeBarPercentageText := "true"
                    fadeBarInfoText := "true"
                    fadeBarXOffset := "0"
                    fadeBarYOffset := "150"
                    fadeRomInfoDescription := "image"
                    fadeRomInfoSystemName := "disabled"
                    fadeRomInfoYear := "filtered text with label"
                    fadeRomInfoDeveloper := "disabled"
                    fadeRomInfoPublisher := "filtered text with label"
                    fadeRomInfoGenre := "disabled"
                    fadeRomInfoRating := "disabled"
                    fadeRomInfoOrder := "Description|SystemName|Year|Genre|Publisher|Developer|Rating"
                    fadeRomInfoTextPlacement := "User Defined"
                    fadeRomInfoTextMargin := "7"
                    fadeRomInfoText1Options := "w550|300 h90 x1255 y720 cFFE1E1E1 r4 s90 Top Regular"
                    fadeRomInfoText2Options := "c51555555"
                    fadeRomInfoText3Options := "w700 x365 y787 cFFE1E1E1 r4 s48 Regular Underline NoWrap"
                    fadeRomInfoText4Options := "cFFE1E1E1"
                    fadeRomInfoText5Options := "w700 x365 y840 cFF555555 r4 s48 Bold Underline NoWrap"
                    fadeRomInfoText6Options := "cFFCFCFCA"
                    fadeRomInfoText7Options := "cFFCFCFCA"
                    fadeStats_Number_of_Times_Played := "text with label"
                    fadeStats_Last_Time_Played := "text with label"
                    fadeStats_Average_Time_Played := "disabled"
                    fadeStats_Total_Time_Played := "text with label"
                    fadeStats_System_Total_Played_Time := "disabled"
                    fadeStats_Total_Global_Played_Time := "text with label"
                    fadeStatsInfoOrder := "Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time"
                    fadeStatsInfoTextPlacement := "User Defined"
                    fadeStatsInfoTextMargin := "7"
                    fadeStatsInfoText1Options := "w700 x368 y905 cFFB4B4B4 r4 s30 Bold NoWrap"
                    fadeStatsInfoText2Options := "w700 x368 y940 cFFB4B4B4 r4 s30 Bold NoWrap"
                    fadeStatsInfoText3Options := "cFFB4B4B4"
                    fadeStatsInfoText4Options := "w700 x368 y975 cFFB4B4B4 r4 s30 Bold NoWrap"
                    fadeStatsInfoText5Options := "cFFB4B4B4"
                    fadeStatsInfoText6Options := "w700 x368 y1010 cFFB4B4B4 r4 s30 Bold NoWrap"
                    fadeText1X := "0"
                    fadeText1Y := "0"
                    fadeText1Options := "cFFB4B4B4 r4 s30 Right Bold"
                    fadeText1 := "Loading Game"
                    fadeText2X := "0"
                    fadeText2Y := "0"
                    fadeText2Options := "cFFB4B4B4 r4 s30 Right Bold"
                    fadeText2 := "Extraction Complete, Ready"
                    fadeText3 := "Loading Game"
                    fadeText4 := "Loading Complete"
                    fadeFont := "Impact"
                    fadeSystemAndRomLayersOnly := "true"
                    fadeExtractionTime := "disabled"
                    fadeExtractionTimeTextX := "0"
                    fadeExtractionTimeTextY := "0"
                    fadeExtractionTimeTextOptions := "cFF555555 r4 s20 Bold"
                    fadeInterruptKey := ""
                    detectFadeErrorEnabled := "true"
                    fadeImgPath := "D:\Arcade\RocketLauncher\Media\Fade"
                    RLDataPath := "D:\Arcade\RocketLauncher\Data"
                    RLMediaPath := "D:\Arcade\RocketLauncher\Media"
                    RLErrSoundPath := "D:\Arcade\RocketLauncher\Media\Sounds\Error"
                    modulesPath := "D:\Arcade\RocketLauncher\Modules"
                    moduleFullName := "D:\Arcade\RocketLauncher\Modules\Citra\Citra.ahk"
                    moduleName := "Citra"
                    modulePath := "D:\Arcade\RocketLauncher\Modules\Citra"
                    moduleExtension := "ahk"
                    moduleExtensionsPath := "D:\Arcade\RocketLauncher\Module Extensions"
                    libPath := "D:\Arcade\RocketLauncher\Lib"
                    sevenZEnabled := "false"
                    sevenZPath := "D:\Arcade\RocketLauncher\Module Extensions\7z.exe"
                    sevenZDllPath := "D:\Arcade\RocketLauncher\Module Extensions\7z.dll"
                    sevenZExtractPath := "D:\Arcade\Tools\7z temp folder"
                    sevenZExtractPathOrig := ""
                    sevenZAttachSystemName := "false"
                    sevenZDelTemp := "false"
                    sevenZFormats := ".zip|.rar|.7z|.lha|.lzh|.gzip|.tar"
                    sevenZFormatsNoP := "zip|rar|7z|lha|lzh|gzip|tar"
                    sevenZFormatsRegEx := "\.zip|\.rar|\.7z|\.lha|\.lzh|\.gzip|\.tar"
                    sevenZGamesToKeep := ""
                    sevenZDeletePerSystem := "false"
                    sevenZExtensions := "zip|rar|7z|lha|lzh|gzip|tar"
                    7zExtractPath := "D:\Arcade\Tools\7z temp folder"
                    mgEnabled := "true"
                    mgKey := "~NumpadSub"
                    mgBackgroundColor := "FF5DA3BB"
                    mgSidePadding := "0.2"
                    mgWidthBaseRes := "1920"
                    mgHeightBaseRes := "1080"
                    mgYOffset := "500"
                    mgFont := "Arial"
                    mgText1Options := "x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic"
                    mgText1Text := "Please select a game"
                    mgText2Options := "w96p cFFFFFFFF r4 s50 Center BoldItalic"
                    mgText2Offset := "70"
                    mgUseSound := "true"
                    mgSoundfreq := "300"
                    mgExitEffect := "none"
                    mgSelectedEffect := "rotate"
                    mgUseGameArt := "false"
                    mgCandidate := ""
                    mgValidTypes := "\(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side"
                    mgOnLaunch := "true"
                    pauseEnabled := "false"
                    pauseKey := "~NumpadAdd|1joy10"
                    pauseBackToMenuBarKey := "X|1joy2"
                    pauseZoomInKey := "C"
                    pauseZoomOutKey := "V"
                    pauseScreenshotKey := "~PrintScreen"
                    pauseHiToTextPath := "D:\Arcade\HiToText.exe"
                    pauseSaveStateKeyCodes := ""
                    pauseLoadStateKeyCodes := ""
                    keyboardEncoder := ""
                    keyboardEncoderEnabled := "false"
                    keymapperEnabled := "true"
                    keymapperAHKMethod := "false"
                    keymapper := "joytokey"
                    xpadderFullPath := "D:\Xpadder\Application\Xpadder.exe"
                    joyToKeyFullPath := "D:\Arcade\RocketLauncher\Profiles\JoyToKey\JoyToKey.exe"
                    profilePath := "D:\Arcade\RocketLauncher\Profiles"
                    keymapperProfilePath := "D:\Arcade\RocketLauncher\Profiles\joytokey"
                    keymapperFrontEndProfileName := "Hyperspin"
                    keymapperFrontEndProfile := "xpadder"
                    keymapperRocketLauncherProfileEnabled := "true"
                    joyIDsEnabled := "true"
                    joyIDsPreferredControllersGlobal := "Controller (Rock Candy Gamepad for Xbox 360)|Controller (XBOX 360 For Windows)|Controller (Xbox 360 Wireless Receiver for Windows)"
                    joyIDsPreferredControllersSystem := "use_global"
                    joyIDsPreferredControllersOnExit := "Controller (Xbox 360 Wireless Receiver for Windows)|Controller (Rock Candy Gamepad for Xbox 360)"
                    CustomJoyNamesEnabled := "true"
                    CustomJoyNames := "Controller (Xbox 360 Wireless Receiver for Windows)|default wheel controller"
                    rotateMethod := "false"
                    FEProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\Hyperspin"
                    defaultProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\_Default"
                    systemProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS"
                    xPadderSystemProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\_Default"
                    emuProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Citra (3DS)"
                    romProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)"
                    RocketLauncherProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\RocketLauncher"
                    blankProfile := "D:\Arcade\RocketLauncher\Profiles\joytokey\blank"
                    ahkFEProfile := "D:\Arcade\RocketLauncher\Profiles\AHK\Hyperspin"
                    ahkDefaultProfile := "D:\Arcade\RocketLauncher\Profiles\AHK\_Default"
                    ahkSystemProfile := "D:\Arcade\RocketLauncher\Profiles\AHK\Nintendo 3DS"
                    ahkEmuProfile := "D:\Arcade\RocketLauncher\Profiles\AHK\Nintendo 3DS\Citra (3DS)"
                    ahkRomProfile := "D:\Arcade\RocketLauncher\Profiles\AHK\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)"
                    ahkRocketLauncherProfile := "D:\Arcade\RocketLauncher\Profiles\AHK\RocketLauncher"
                    bezelEnabled := "true"
                    bezelICEnabled := "false"
                    shaderName := "false"
                    shaderColor := ""
                    shaderTransparency := ""
                    statisticsEnabled := "true"
                    pressDuration := "-1"
                    emuVolume := "1"
                    dxwndIni := "D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini"
                    dxwndFullPath := "D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe"
                    qResFullPath := "D:\Arcade\RocketLauncher\Module Extensions\QRes.exe"
                    mon1O := ""
                    pacDrivedllFile := "D:\Arcade\RocketLauncher\Module Extensions\PacDrive32.dll"
                    userFadeAnimIniFile := "D:\Arcade\RocketLauncher\Lib\User Fade Animations.ini"
                    testFile := ""
                    testDuration := ""
                    initialErrorMode := "0"
16:54:40:552 | RL |      INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
16:54:40:553 | RL |      INFO  | +16    | BuildScript - Loaded Keymapper Init.ahk scripts
16:54:40:554 | RL |      INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
16:54:40:555 | RL |      INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
16:54:40:555 | RL |      INFO  | +0     | BuildScript - Loaded MultiGame Init.ahk scripts
16:54:40:556 | RL |     DEBUG  | +0     | BuildScript - Module starts on line: 2
16:54:40:557 | RL |      INFO  | +0     | BuildScript - Validating module
16:54:40:559 | RL |      INFO  | +0     | BuildScript - Validation complete
16:54:40:560 | RL |      INFO  | +0     | BuildScript - Module:
                    MEmu := "Citra"
                    MEmuV := "2016-11-23"
                    MURL := ["http://citra-emu.org/"]
                    MAuthor := ["djvj","bleasby"]
                    MVersion := "1.0.1"
                    MCRC := "B2CEA0A2"
                    iCRC := "8131AB6F"
                    MID := "635740704032217117"
                    MSystem := ["Nintendo 3DS"]
                    ; Notes:
                    ; Roms must be decrypted to run in the emu
                    ; See here for a guide on decrypting games you own: https://gbatemp.net/threads/tutorial-how-to-decrypt-extract-rebuild-3ds-roms-run-xy-oras-without-update.383055/
                    StartModule()
                    BezelGUI()
                    FadeInStart()
                    primaryExe := new Emulator(emuPath . "\" . executable)                    ; instantiate emulator executable object
                    primaryWindowClassName := "Qt5QWindowIcon"
                    emuPrimaryWindow := new Window(new WindowTitle("Citra",primaryWindowClassName))    ; instantiate primary emulator window object
                    emuConsoleWindow := new Window(new WindowTitle(,"ConsoleWindowClass"))
                    Fullscreen := moduleIni.Read("Settings", "Fullscreen","true",,1)
                    bezelTopOffset := moduleIni.Read("Settings", "Bezel_Top_Offset","30",,1)
                    bezelBottomOffset := moduleIni.Read("Settings", "Bezel_Bottom_Offset","8",,1)
                    bezelRightOffset := moduleIni.Read("Settings", "Bezel_Right_Offset", "8",,1)
                    bezelLeftOffset := moduleIni.Read("Settings", "Bezel_Left_Offset", "8",,1)
                    CitraIni := new IniFile(emuPath . "\user\config\qt-config.ini")
                    CitraIni.CheckFile("Could not find Citra's ini file. Please run Citra manually first and make sure that you use the module recomended emulator version.")
                    ; Disabling the emu exit confirmation
                    confirmClose := CitraIni.Read("UI", "confirmClose")
                    If (confirmClose = "true")
                        CitraIni.Write("false", "UI", "confirmClose")
                    ; Setting the game to launch on an extra window.
                    singleWindowMode := CitraIni.Read("UI", "singleWindowMode")
                    If (singleWindowMode = "true")
                        CitraIni.Write("false", "UI", "singleWindowMode")
                    BezelStart()
                    hideEmuObj := Object(emuConsoleWindow,0,emuPrimaryWindow,1)
                    7z(romPath, romName, romExtension, SevenZExtractPath)
                    HideAppStart(hideEmuObj,hideEmu)
                    primaryExe.Run("""" . romPath . "\" . romName . romExtension . """")
                    ; Waiting for main emu window
                    emuPrimaryWindow.Wait()
                    emuPrimaryWindow.WaitActive()
                    ; Hiding citra console window
                    emuConsoleWindow.Set("Transparent",0)
                    ; Waiting for game to load
                    TimeOut := 3000
                    StartTime := A_TickCount
                    Loop, {
                        WinGet, IDList, List, ahk_class %primaryWindowClassName% ; get a list of all windows which match this windowTitle
                        Loop, % IDList ; IDList set to number of matches found
                        {    id := IDList%A_Index%
                            ControlGet, OutputVar, Hwnd,, Qt5QWindowOwnDCIcon1, ahk_id %id%
                            If !ErrorLevel
                            {    gameWindowID := id
                                Break
                        If (TimeOut && A_TickCount - StartTime > TimeOut)
                            Break
                    ; Saving id of extra emulator window to be hidden
                    WinGet, IDList, List, ahk_class %primaryWindowClassName% ; Get a list of all windows which match this windowTitle
                        If !(id = gameWindowID) {
                            launchWindowID := id
                            launchWindow := new Window(new WindowTitle(,,,launchWindowID))
                            Break
                    ; Hiding extra emulator window
                    If (launchWindowID)  {
                        launchWindow.Hide()
                    ; Waiting for game window to be active if it is not
                    gameWindow := new Window(new WindowTitle(,,,gameWindowID))
                    gameWindow.WaitActive()
                    if (Fullscreen = "true"){  ; Creating fake full screen as the emu always launches in windowed mode
                        WinGet emulatorID, ID, A
                        emulatorWindow := new Window(new WindowTitle(,,,emulatorID))
                        RLObject.hideWindowTitleBar(emulatorID)
                        RLObject.hideWindowBorder(emulatorID)
                        emulatorWindow.Move(0,0,A_screenWidth,A_screenHeight + 38)
                    BezelDraw()
                    HideAppEnd(hideEmuObj,hideEmu)
                    FadeInExit()
                    primaryExe.Process("WaitClose")
                    7zCleanUp()
                    BezelExit()
                    FadeOutExit()
                    ExitModule()
                    CloseProcess:
                        FadeOutStart()
                        If (launchWindowID)
                            launchWindow.Close()
                        Else
                            gameWindow.Close()
                    Return
                    BezelLabel:
                        disableHideBorder := "true"
                        disableHideTitleBar := "true"
                        disableHideToggleMenu := "true"
                    Return
16:54:40:561 | RL |      INFO  | +0     | BuildScript - Loaded MultiGame scripts
16:54:40:563 | RL |      INFO  | +0     | BuildScript - Loaded Multi-Player scripts
16:54:40:564 | RL |      INFO  | +0     | BuildScript - Loaded Statistics.ahk script
16:54:40:565 | RL |      INFO  | +0     | BuildScript - "D:\Arcade\RocketLauncher\Lib\User Functions\Global.ahk" not found
16:54:40:566 | RL |      INFO  | +0     | BuildScript - "D:\Arcade\RocketLauncher\Lib\User Functions\Nintendo 3DS.ahk" not found
16:54:40:568 | RL |      INFO  | +15    | BuildScript - "D:\Arcade\RocketLauncher\Lib\User Functions\Emulators\Citra (3DS).ahk" not found
16:54:40:569 | RL |      INFO  | +0     | BuildScript - "D:\Arcade\RocketLauncher\Lib\User Functions\Nintendo 3DS\Emulators\Citra (3DS).ahk" not found
16:54:40:571 | RL |      INFO  | +0     | BuildScript - "D:\Arcade\RocketLauncher\Lib\User Functions\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).ahk" not found
16:54:40:572 | RL |      INFO  | +0     | BuildScript - Finished injecting functions into module
16:54:40:573 | RL |      INFO  | +0     | Main - Module is built
16:54:40:574 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\AutoHotkey.dll exists
16:54:40:579 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             AutoHotkey_H ANSI 32-bit
                    FileVersion                 1.1.13.00
                    InternalName                AutoHotkey_H
                    LegalCopyright              Copyright (C) 2003-2013
                    OriginalFilename            AutoHotkey.exe
                    ProductName                 AutoHotkey_H
                    ProductVersion              1.1.13.00
                    File Size:            802304 bytes
                    Modified:            2/15/2021 - 9:46:14 PM
16:54:40:581 | RL |      INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
16:54:40:582 | RL |      INFO  | +0     | Main - Running module
16:54:40:816 | MD |      INFO  | +N/A   | Module initialized
16:54:40:817 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:40:840 | MD |     DEBUG  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
16:54:40:841 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 1 check
16:54:40:842 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 2 check
16:54:40:843 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
16:54:40:843 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:40:845 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:40:846 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 not in TableKeyGroups ~Esc,
16:54:40:847 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 1 check
16:54:40:848 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 2 check
16:54:40:849 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
16:54:40:871 | MD |     DEBUG  | +31    | XHotkeyTableCreation - Ended
16:54:40:873 | MD |      INFO  | +0     | Keymapper - Creating Custom Joy Name Array for Name Replacements
16:54:40:874 | MD |     TRACE  | +0     | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Games JoyIDs.ini under section [Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)]
16:54:40:875 | MD |      INFO  | +0     | LoadPreferredControllers - Started
16:54:40:876 | MD |     TRACE  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = 1
16:54:40:877 | MD |     TRACE  | +0     | LoadPreferredControllers - Creating a list of currently connected joysticks
16:54:40:878 | MD |      INFO  | +0     | GetJoystickArray - Started
16:54:40:918 | MD |     TRACE  | +47    | GetJoystickArray - Joysticks Detected: 0000000000000000
16:54:40:920 | MD |      INFO  | +0     | GetJoystickArray - Ended
16:54:40:921 | MD |      INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
16:54:40:922 | MD |      INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
16:54:40:923 | MD |      INFO  | +0     | LoadPreferredControllers - Ended
16:54:40:925 | MD |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Profiles\JoyToKey\JoyToKey.exe exists
16:54:40:926 | MD |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             Convert joystick input to keyboard/mouse input
                    FileVersion                 5.7.0.355
                    InternalName                JoyToKey
                    LegalCopyright              Copyright(C) JTK, 1999-2013
                    OriginalFilename            JoyToKey
                    ProductName                 JoyToKey
                    ProductVersion              Version 5
                    File Size:            1747456 bytes
                    Modified:            2/16/2021 - 5:28:42 AM
16:54:40:971 | MD |      INFO  | +47    | Keymapper - Loading joytokey
16:54:40:972 | MD |      INFO  | +0     | RunKeymapper - Started, using method "load"
16:54:40:973 | MD |      INFO  | +0     | GetJoystickArray - Started
16:54:41:033 | MD |     TRACE  | +63    | GetJoystickArray - Joysticks Detected: 0000000000000000
16:54:41:034 | MD |      INFO  | +0     | GetJoystickArray - Ended
16:54:41:035 | MD |     TRACE  | +0     | RunKeymapper - Found your keymapper application here: "D:\Arcade\RocketLauncher\Profiles\JoyToKey\JoyToKey.exe"
16:54:41:036 | MD |     TRACE  | +0     | RunKeymapper - Looping through controllers to find joytokey profiles for each one
16:54:41:065 | MD |     TRACE  | +31    | GetProfile - Searching for these profiles (| delimited): D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)|D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Citra (3DS)\Citra (3DS)|D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Nintendo 3DS|D:\Arcade\RocketLauncher\Profiles\joytokey\_Default\_Default
16:54:41:066 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).cfg
16:54:41:067 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Citra (3DS)\Citra (3DS).cfg
16:54:41:097 | MD |     TRACE  | +31    | GetProfile - Searching for a Player 1 profile -> D:\Arcade\RocketLauncher\Profiles\joytokey\Nintendo 3DS\Nintendo 3DS.cfg
16:54:41:098 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Arcade\RocketLauncher\Profiles\joytokey\_Default\_Default.cfg
16:54:41:098 | MD |   WARNING  | +0     | GetProfile - Keymapper support is enabled for "joytokey", but could not find a "Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)", "Citra (3DS)", "Nintendo 3DS", default, a "" player 1 profile or a blank profile in "D:\Arcade\RocketLauncher\Profiles\joytokey" for controller ""
16:54:41:128 | MD |      INFO  | +31    | RunJoyToKey - Started
16:54:41:130 | MD |      INFO  | +0     | WinClose - Closing: JoyToKey ahk_class TMainForm
16:54:41:269 | MD |      INFO  | +141   | Process - WaitClose JoyToKey.exe 2
16:54:41:300 | MD |      INFO  | +31    | RunJoyToKey - Ended
16:54:41:300 | MD |      INFO  | +0     | RunKeymapper - Ended
16:54:41:301 | MD |     DEBUG  | +0     | fadeInTransitionAnimation: DefaultAnimateFadeIn
16:54:41:329 | MD |     DEBUG  | +31    | fadeOutTransitionAnimation: DefaultAnimateFadeOut
16:54:41:331 | MD |     DEBUG  | +0     | fadeLyr3Animation: DefaultFadeAnimation
16:54:41:332 | MD |     DEBUG  | +0     | fadeLyr37zAnimation: DefaultFadeAnimation
16:54:41:333 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:41:334 | MD |     DEBUG  | +16    | XHotkeyTableCreation - KeyGroup ~NumpadSub not in TableKeyGroups ~Esc,~1joy7,
16:54:41:335 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 1 check
16:54:41:336 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 2 check
16:54:41:338 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadSub" to call label: "StartMulti"
16:54:41:339 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:41:340 | MD |     TRACE  | +0     | CustomFunction.Init - Starting
16:54:41:341 | MD |     TRACE  | +0     | CustomFunction.Init - Ending
16:54:41:342 | MD |      INFO  | +0     | StartModule - Started
16:54:41:343 | MD |      INFO  | +0     | StartModule - MEmu: Citra
                    MEmuV: 2016-11-23
                    MURL: http://citra-emu.org/
                    MAuthor: djvj|bleasby
                    MVersion: 1.0.1
                    MCRC: B2CEA0A2
                    iCRC: 8131AB6F
                    MID: 635740704032217117
                    MSystem: Nintendo 3DS
16:54:41:345 | MD |      INFO  | +0     | StartModule - You have a supported System Name for this module: "Nintendo 3DS"
16:54:41:346 | MD |      INFO  | +0     | LocaleUtils.i18n - Started
16:54:41:347 | MD |     DEBUG  | +0     | LocaleUtils.i18n - Section "English_United_States" & key "dialog.open" not found, trying section "English"
16:54:41:348 | MD |      INFO  | +0     | LocaleUtils.i18n - Ended, using "Open" for "dialog.open"
16:54:41:349 | MD |      INFO  | +0     | LocaleUtils.i18n - Started
16:54:41:365 | MD |     DEBUG  | +31    | LocaleUtils.i18n - Section "English_United_States" & key "dialog.start" not found, trying section "English"
16:54:41:366 | MD |      INFO  | +0     | LocaleUtils.i18n - Ended, using "Start" for "dialog.start"
16:54:41:369 | MD |      INFO  | +0     | PluginInit - Started
16:54:41:371 | MD |     DEBUG  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating
16:54:41:372 | MD |      INFO  | +0     | CheckFile - Checking if D:\Arcade\Databases\Nintendo 3DS\Nintendo 3DS.xml exists
16:54:41:373 | MD |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            115200 bytes
                    Created:            1/27/2022 - 4:54:08 PM
                    Modified:            1/27/2022 - 4:54:08 PM
16:54:41:375 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
16:54:41:376 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Name
16:54:41:377 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Name" with a value: "Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)"
16:54:41:378 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Cloneof
16:54:41:379 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Cloneof
16:54:41:380 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Publisher
16:54:41:395 | MD |     DEBUG  | +16    | BuildDatabaseTable - Could not find: Publisher
16:54:41:396 | MD |     DEBUG  | +16    | BuildDatabaseTable - Searching database for: Year
16:54:41:397 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Year
16:54:41:398 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Genre
16:54:41:400 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Genre
16:54:41:401 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Rating
16:54:41:402 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Rating
16:54:41:403 | MD |     TRACE  | +0     | PluginInit - GameInfo:
                    GameInfo Label: Name | GameInfo Value: Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)
16:54:41:405 | MD |     DEBUG  | +0     | BuildDatabaseTable - Ended
16:54:41:458 | MD |   WARNING  | +62    | RIniLoadVar - Created missing System ini key: "Fe_Logo_Labels" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:508 | MD |   WARNING  | +47    | RIniLoadVar - Created missing System ini key: "Fe_Artwork_Labels" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:567 | MD |   WARNING  | +47    | RIniLoadVar - Created missing System ini key: "Fe_Backgrounds_Labels" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:633 | MD |   WARNING  | +78    | RIniLoadVar - Created missing System ini key: "Fe_Controller_Labels" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:688 | MD |   WARNING  | +47    | RIniLoadVar - Created missing System ini key: "Fe_Guides_Labels" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:755 | MD |   WARNING  | +62    | RIniLoadVar - Created missing System ini key: "Fe_Manuals_Labels" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:814 | MD |   WARNING  | +63    | RIniLoadVar - Created missing System ini key: "Fe_Videos_Labels" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:878 | MD |   WARNING  | +62    | RIniLoadVar - Created missing System ini key: "Fe_Disc_Artwork_Label" in section: "HyperSpin" in "D:\Arcade\RocketLauncher\Settings\Nintendo 3DS\Plugins.ini"
16:54:41:880 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
16:54:41:882 | MD |     DEBUG  | +16    | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\Media\Nintendo 3DS\Images\Wheel\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).png
16:54:41:882 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Arcade\Media\Main Menu\Images\Wheel\Nintendo 3DS.png
16:54:41:885 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
                    Asset Label: System Logo | Asset Path1:  D:\Arcade\Media\Main Menu\Images\Wheel\Nintendo 3DS.png | Asset Extension1:  png | Asset Type1:  system
16:54:41:886 | MD |      INFO  | +0     | BuildAssetsTable - Ended
16:54:41:887 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
16:54:41:888 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Artwork1: D:\Arcade\Media\Nintendo 3DS\Images\Artwork1\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).png
16:54:41:889 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Arcade\Media\Nintendo 3DS\Images\Artwork2\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).png
16:54:41:890 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Arcade\Media\Nintendo 3DS\Images\Artwork3\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).png
16:54:41:891 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Flyers: D:\Arcade\Media\Nintendo 3DS\Images\Artwork4\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).png
16:54:41:892 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Letters: D:\Arcade\Media\Nintendo 3DS\Images\Letters
16:54:41:920 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a Other: D:\Arcade\Media\Nintendo 3DS\Images\Other
16:54:41:923 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
                    Asset Label: Letters | Asset Path1:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
                    Asset Label: Letters | Asset Path2:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
                    Asset Label: Letters | Asset Path3:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
                    Asset Label: Letters | Asset Path4:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
                    Asset Label: Letters | Asset Path5:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
                    Asset Label: Letters | Asset Path6:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
                    Asset Label: Letters | Asset Path7:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
                    Asset Label: Letters | Asset Path8:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
                    Asset Label: Letters | Asset Path9:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
                    Asset Label: Letters | Asset Path10:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
                    Asset Label: Letters | Asset Path11:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
                    Asset Label: Letters | Asset Path12:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
                    Asset Label: Letters | Asset Path13:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
                    Asset Label: Letters | Asset Path14:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
                    Asset Label: Letters | Asset Path15:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
                    Asset Label: Letters | Asset Path16:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
                    Asset Label: Letters | Asset Path17:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
                    Asset Label: Letters | Asset Path18:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
                    Asset Label: Letters | Asset Path19:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
                    Asset Label: Letters | Asset Path20:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
                    Asset Label: Letters | Asset Path21:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
                    Asset Label: Letters | Asset Path22:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
                    Asset Label: Letters | Asset Path23:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
                    Asset Label: Letters | Asset Path24:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
                    Asset Label: Letters | Asset Path25:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
                    Asset Label: Letters | Asset Path26:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
                    Asset Label: Letters | Asset Path27:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
                    Asset Label: Letters | Asset Path28:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
                    Asset Label: Letters | Asset Path29:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
                    Asset Label: Letters | Asset Path30:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
                    Asset Label: Letters | Asset Path31:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
                    Asset Label: Letters | Asset Path32:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
                    Asset Label: Letters | Asset Path33:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
                    Asset Label: Letters | Asset Path34:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
                    Asset Label: Letters | Asset Path35:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
                    Asset Label: Letters | Asset Path36:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
                    Asset Label: Letters | Asset Path37:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
                    Asset Label: Letters | Asset Path38:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
                    Asset Label: Letters | Asset Path39:  D:\Arcade\Media\Nintendo 3DS\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
                    Asset Label: Other | Asset Path1:  D:\Arcade\Media\Nintendo 3DS\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
16:54:41:925 | MD |      INFO  | +0     | BuildAssetsTable - Ended
16:54:41:926 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video
16:54:41:942 | MD |     DEBUG  | +16    | BuildAssetsTable - Searching for a MP4 Game Video: D:\Arcade\Media\Nintendo 3DS\Video\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).*
16:54:41:944 | MD |     DEBUG  | +15    | BuildAssetsTable - Searching for a FLV Game Video: D:\Arcade\Media\Main Menu\Video\Nintendo 3DS.*
16:54:41:945 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
                    Asset Label: FLV Game Video | Asset Path1:  D:\Arcade\Media\Main Menu\Video\Nintendo 3DS.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
16:54:41:946 | MD |      INFO  | +0     | BuildAssetsTable - Ended
16:54:41:948 | MD |      INFO  | +0     | PluginInit - Ended
16:54:41:949 | MD |     DEBUG  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)
16:54:41:950 | MD |      INFO  | +0     | SystemCursor - Hiding mouse cursor
16:54:41:988 | MD |     DEBUG  | +32    | XHotkeyTableCreation - Started
16:54:41:990 | MD |     DEBUG  | +15    | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy7,~NumpadSub,
16:54:41:991 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 1 check
16:54:41:992 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 2 check
16:54:41:994 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
16:54:41:995 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:41:995 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "D:\Arcade\HyperSpin.exe"
16:54:41:996 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "D:\Arcade\HyperSpin.exe"
16:54:41:001 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "D:\Arcade\RocketLauncher\Modules\Citra\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA).ini"
16:54:42:018 | MD |     TRACE  | +16    | File.__New - Creating new file object of: "D:\Arcade\RocketLauncher\Modules\Citra\Nintendo 3DS.ini"
16:54:42:034 | MD |     TRACE  | +16    | File.__New - Creating new file object of: "D:\Arcade\RocketLauncher\Modules\Citra\Citra.ini"
16:54:42:038 | MD |     TRACE  | +15    | File.Exist - This file exists: D:\Arcade\RocketLauncher\Modules\Citra\Citra.ini
16:54:42:040 | MD |     DEBUG  | +0     | RIniFile.__New - "Module" at index 1, adding "GlobalModuleIni" from: "D:\Arcade\RocketLauncher\Modules\Citra\Citra.ini"
16:54:42:053 | MD |      INFO  | +16    | StartModule - Ended
16:54:42:055 | MD |      INFO  | +0     | BezelGUI - Started
16:54:42:207 | MD |      INFO  | +140   | BezelGUI - Ended
16:54:42:219 | MD |     DEBUG  | +16    | FadeInStart - Started
16:54:42:220 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:42:221 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadSub is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:42:223 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:42:223 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadSub"
16:54:42:224 | MD |     DEBUG  | +16    | XHotkeyTableCreation - Post loop 11 check
16:54:42:225 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabling "StartMulti" standard Hotkey method for key(s): "~NumpadSub"
16:54:42:227 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:42:228 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:42:229 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:42:230 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:42:231 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:42:233 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
16:54:42:233 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:42:235 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
16:54:42:235 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:42:236 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:42:237 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:42:238 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:42:239 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:42:253 | MD |     DEBUG  | +15    | XHotkeyTableCreation - Post loop 11 check
16:54:42:254 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7"
16:54:42:255 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:42:256 | MD |     DEBUG  | +16    | XHotkeyTableCreation - Ended
16:54:42:257 | MD |     DEBUG  | +0     | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
16:54:42:258 | MD |     TRACE  | +0     | FadeInStart - Fade screen scale factor: X=1.000000, Y= 1.000000
16:54:42:259 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Layer 1*.*
16:54:42:260 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Backgrounds\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Layer 1*.*
16:54:42:261 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Horizontal\Layer 1*.*
16:54:42:262 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Layer 1*.*
16:54:42:263 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Backgrounds\Nintendo 3DS\_Default\Horizontal\Layer 1*.*
16:54:42:264 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Backgrounds\Nintendo 3DS\_Default\Layer 1*.*
16:54:42:264 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Layer 1*.*
16:54:42:266 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.*
16:54:42:266 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.png
16:54:42:268 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Layer 1": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1 (1).png
16:54:42:268 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.gif
16:54:42:269 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.tif
16:54:42:270 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.bmp
16:54:42:285 | MD |     DEBUG  | +16    | GetFadeDirPicFile - Looking for Fade "Layer 1": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1*.jpg
16:54:42:287 | MD |      INFO  | +15    | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 1 (1).png
16:54:42:287 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Extra Layer 1 - Console*.*
16:54:42:289 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Horizontal\Extra Layer 1 - Console*.*
16:54:42:290 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Extra Layer 1 - Console*.*
16:54:42:291 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Extra Layer 1 - Console*.*
16:54:42:292 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Extra Layer 1 - Console*.*
16:54:42:461 | MD |      INFO  | +172   | DefaultAnimateFadeIn - Started, direction is: in
16:54:42:462 | MD |      INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
16:54:42:977 | MD |      INFO  | +516   | DefaultAnimateFadeIn - Ended
16:54:43:062 | MD |      INFO  | +78    | DefaultFadeAnimation - Started
16:54:43:063 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Info Bar*.*
16:54:43:064 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Horizontal\Info Bar*.*
16:54:43:065 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Info Bar*.*
16:54:43:066 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
16:54:43:067 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.*
16:54:43:078 | MD |     DEBUG  | +15    | GetFadeDirPicFile - Looking for Fade "Info Bar": D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.png
16:54:43:079 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Info Bar": D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar.png
16:54:43:080 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
16:54:43:082 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
16:54:43:083 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
16:54:43:084 | MD |     DEBUG  | +16    | GetFadeDirPicFile - Looking for Fade "Info Bar": D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
16:54:43:084 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\_Default\Info Bar.png
16:54:43:091 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Layer 3*.*
16:54:43:093 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Horizontal\Layer 3*.*
16:54:43:094 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Layer 3*.*
16:54:43:095 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Layer 3*.*
16:54:43:096 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3*.*
16:54:43:097 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3*.png
16:54:43:098 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Layer 3": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3.png
16:54:43:099 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3*.gif
16:54:43:112 | MD |     DEBUG  | +16    | GetFadeDirPicFile - Looking for Fade "Layer 3": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3*.tif
16:54:43:113 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3*.bmp
16:54:43:114 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3*.jpg
16:54:43:115 | MD |      INFO  | +15    | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\_Default\Layer 3.png
16:54:43:120 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Genre Logo|Rating Logo|Developer Logo|Publisher Logo|Year Logo
16:54:43:121 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Genre Logo:
16:54:43:122 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Rating Logo:
16:54:43:123 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Developer Logo:
16:54:43:124 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Publisher Logo:
16:54:43:125 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Year Logo:
16:54:43:126 | MD |      INFO  | +0     | BuildAssetsTable - Ended
16:54:43:127 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: System Logo|Game Logo|Game Logo
16:54:43:128 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Arcade\RocketLauncher\Media\Logos\Nintendo 3DS\_Default\
16:54:43:130 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Arcade\RocketLauncher\Media\Logos\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\
16:54:43:144 | MD |     DEBUG  | +16    | BuildAssetsTable - Searching for a Game Logo:
16:54:43:145 | MD |      INFO  | +0     | BuildAssetsTable - Ended
16:54:43:153 | MD |     DEBUG  | +16    | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\Adventure Time - Explore the Dungeon Because I DON'T KNOW! (USA)\Loading start*.*
16:54:43:155 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Horizontal\Loading start*.*
16:54:43:156 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: D:\Arcade\RocketLauncher\Media\Fade\Nintendo 3DS\_Default\Loading start*.*
16:54:43:157 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Horizontal\Loading start*.*
16:54:43:158 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: D:\Arcade\RocketLauncher\Media\Fade\_Default\Loading start*.*
16:54:43:159 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Loading start": D:\Arcade\RocketLauncher\Media\Fade\_Default\Loading start*.mp3
16:54:43:160 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Loading start": D:\Arcade\RocketLauncher\Media\Fade\_Default\Loading Start.mp3
16:54:43:161 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Arcade\RocketLauncher\Media\Fade\_Default\Loading Start.mp3
16:54:43:178 | MD |      INFO  | +31    | DefaultFadeAnimation - Playing D:\Arcade\RocketLauncher\Media\Fade\_Default\Loading Start.mp3
16:54:43:303 | MD |     DEBUG  | +125   | FadeInDelay - Started
16:54:43:372 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage
16:54:43:439 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage3
16:54:43:498 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage6
16:54:43:560 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage9
16:54:43:640 | MD |      INFO  | +78    | DefaultFadeAnimationLoop - percentage13
16:54:43:780 | MD |      INFO  | +141   | DefaultFadeAnimationLoop - percentage16
16:54:43:829 | MD |      INFO  | +46    | DefaultFadeAnimationLoop - percentage23
16:54:43:889 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage26
16:54:43:952 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage29
16:54:44:020 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage32
16:54:44:143 | MD |      INFO  | +125   | DefaultFadeAnimationLoop - percentage37
16:54:44:222 | MD |     DEBUG  | +78    | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
16:54:44:249 | MD |      INFO  | +31    | DefaultFadeAnimationLoop - percentage41
16:54:44:315 | MD |     DEBUG  | +63    | DefaultFadeAnimationLoop - AnimationLoop has finished
16:54:44:316 | MD |     DEBUG  | +0     | DefaultFadeAnimationLoop - Ended
16:54:44:404 | MD |     DEBUG  | +94    | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
16:54:45:079 | MD |     DEBUG  | +671   | FadeInDelay - Ended
16:54:45:081 | MD |      INFO  | +0     | DefaultFadeAnimation - Ended
16:54:45:082 | MD |     DEBUG  | +0     | FadeInStart - Ended
16:54:45:083 | MD |      INFO  | +0     | DxwndUpdateIniPath - DxwndIni set to D:\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
16:54:45:094 | MD |     TRACE  | +16    | CustomFunction.PreStart - Starting
16:54:45:095 | MD |     TRACE  | +0     | CustomFunction.PreStart - Ending
16:54:45:096 | MD |     DEBUG  | +0     | CoverFE - Started
16:54:45:112 | MD |     DEBUG  | +16    | CoverFE - Ended
16:54:45:114 | MD |     TRACE  | +15    | Emulator.__New - Creating new emulator object for: "D:\Arcade\emulators\Citra\nightly-mingw\citra-qt.exe"
16:54:45:115 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "D:\Arcade\emulators\Citra\nightly-mingw\citra-qt.exe"
16:54:45:116 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "D:\Arcade\emulators\Citra\nightly-mingw\citra-qt.exe"
16:54:45:120 | MD |     TRACE  | +0     | Window.__New - Created: "Citra ahk_class Qt5QWindowIcon"
16:54:45:121 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_class ConsoleWindowClass"
16:54:45:122 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Fullscreen: No value for this key
16:54:45:124 | MD |      INFO  | +0     | RIniFile.Read - Module - Fullscreen: true (DEFAULT)
16:54:45:125 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Bezel_Top_Offset: No value for this key
16:54:45:125 | MD |      INFO  | +0     | RIniFile.Read - Module - Bezel_Top_Offset: 30 (DEFAULT)
16:54:45:126 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Bezel_Bottom_Offset: No value for this key
16:54:45:127 | MD |      INFO  | +0     | RIniFile.Read - Module - Bezel_Bottom_Offset: 8 (DEFAULT)
16:54:45:128 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Bezel_Right_Offset: No value for this key
16:54:45:129 | MD |      INFO  | +0     | RIniFile.Read - Module - Bezel_Right_Offset: 8 (DEFAULT)
16:54:45:130 | MD |      INFO  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Bezel_Left_Offset: 2
16:54:45:144 | MD |     TRACE  | +16    | File.__New - Creating new file object of: "D:\Arcade\emulators\Citra\nightly-mingw\user\config\qt-config.ini"
16:54:45:173 | MD |     TRACE  | +31    | IniFile.__New - Created new ini object of: "D:\Arcade\emulators\Citra\nightly-mingw\user\config\qt-config.ini"
16:54:45:174 | MD |      INFO  | +0     | File.CheckFile - Checking if "D:\Arcade\emulators\Citra\nightly-mingw\user\config\qt-config.ini" exists
16:54:45:176 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "D:\Arcade\emulators\Citra\nightly-mingw\user\config\qt-config (Example).ini"
16:54:45:181 | MD |     DEBUG  | +16    | XHotkeyTableCreation - Started
16:54:45:183 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:45:184 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:45:185 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
16:54:45:186 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:45:187 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
16:54:45:188 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:45:189 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:45:190 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:45:191 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:45:207 | MD |     DEBUG  | +15    | XHotkeyTableCreation - Post loop 10 check
16:54:45:208 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:45:209 | MD |     DEBUG  | +16    | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7"
16:54:45:210 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:45:211 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:45:213 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:45:213 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:45:214 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:45:215 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
16:54:45:216 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:45:217 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError"
16:54:45:218 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:45:219 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:45:220 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:45:221 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:45:222 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:45:223 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:45:251 | MD |     DEBUG  | +31    | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
16:54:45:252 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:45:253 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:45:601 | MD |     DEBUG  | +360   | ScriptError - Playing error sound: error6.mp3
16:54:49:194 | MD |     DEBUG  | +3593  | XHotkeyTableCreation - Started
16:54:49:197 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:49:198 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:49:199 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
16:54:49:200 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:49:201 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc"
16:54:49:202 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:49:203 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:49:204 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:49:205 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:49:206 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:49:207 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:49:208 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7"
16:54:49:245 | MD |     DEBUG  | +47    | XHotkeyTableCreation - Post loop 12 check
16:54:49:246 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:49:247 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:49:248 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:49:250 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:49:251 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
16:54:49:252 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:49:253 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
16:54:49:255 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:49:288 | MD |     DEBUG  | +47    | XHotkeyTableCreation - Ended
16:54:49:290 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
16:54:49:291 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadSub,~e&~t,
16:54:49:292 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 10 check
16:54:49:293 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 11 check
16:54:49:295 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label
16:54:49:296 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 12 check
16:54:49:297 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
16:54:49:298 | MD |     ERROR  | +0     | ScriptError - Could not find Citra's ini file. Please run Citra manually first and make sure that you use the module recomended emulator version.
16:54:49:300 | MD |      INFO  | +0     | ExitModule - Started
16:54:49:301 | MD |      INFO  | +0     | UpdateStatistics - Starting Updating Statistics
16:54:49:302 | MD |     DEBUG  | +0     | UpdateStatistics - Total Elapsed Time in Pause in seconds: 0
16:54:49:325 | MD |     DEBUG  | +31    | UpdateStatistics - gameSectionStartTime:3557781
16:54:49:326 | MD |     DEBUG  | +0     | UpdateStatistics - ElapsedTime:7
16:54:49:327 | MD |     TRACE  | +0     | Statistics cleared game name: Adventure Time - Explore the Dungeon Because I DON'T KNOW!
16:54:49:363 | MD |     DEBUG  | +32    | UpdateStatistics - Loaded game statistics from ini files:
                    Number_of_Times_Played: -2
                    Last_Time_Played: -2
                    Average_Time_Played: -2
                    Total_Time_Played: -2
                    System_Total_Played_Time: -3
                    Total_Global_Played_Time: 12492
16:54:49:364 | MD |     DEBUG  | +0     | UpdateStatistics - Updated Statistics: Number_of_Times_Played: -1
                    Last_Time_Played: Thursday January 27, 2022 04:54:42 PM
                    Average_Time_Played: -5
                    Total_Time_Played: 5
                    System_Total_Played_Time: 4
                    Total_Global_Played_Time: 12499
16:54:49:493 | MD |      INFO  | +140   | UpdateStatistics - Game section statistics updated.
16:54:49:495 | MD |      INFO  | +0     | RunKeymapper - Started, using method "unload"
16:54:49:495 | MD |      INFO  | +0     | GetJoystickArray - Started
16:54:49:503 | MD |     TRACE  | +0     | GetJoystickArray - Joysticks Detected: 0000000000000000
16:54:49:523 | MD |      INFO  | +32    | GetJoystickArray - Ended
16:54:49:524 | MD |     TRACE  | +0     | RunKeymapper - Looping through controllers to find joytokey profiles for each one
16:54:49:525 | MD |      INFO  | +0     | RunJoyToKey - Started
16:54:49:526 | MD |      INFO  | +0     | WinClose - Closing: JoyToKey ahk_class TMainForm
16:54:49:650 | MD |      INFO  | +125   | Process - WaitClose JoyToKey.exe 2
16:54:49:654 | MD |      INFO  | +0     | RunJoyToKey - Ended
16:54:49:655 | MD |      INFO  | +0     | RunKeymapper - Ended
16:54:49:656 | MD |      INFO  | +0     | LoadPreferredControllers - Started
16:54:49:657 | MD |     TRACE  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows)|Controller (Rock Candy Gamepad for Xbox 360)
16:54:49:658 | MD |     TRACE  | +0     | LoadPreferredControllers - Creating a list of currently connected joysticks
16:54:49:659 | MD |      INFO  | +0     | GetJoystickArray - Started
16:54:49:697 | MD |     TRACE  | +46    | GetJoystickArray - Joysticks Detected: 0000000000000000
16:54:49:698 | MD |      INFO  | +0     | GetJoystickArray - Ended
16:54:49:698 | MD |      INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
16:54:49:700 | MD |      INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
16:54:49:700 | MD |      INFO  | +0     | LoadPreferredControllers - Ended
16:54:49:701 | MD |     TRACE  | +0     | CustomFunction.PostExit - Starting
16:54:49:702 | MD |     TRACE  | +0     | CustomFunction.PostExit - Ending
16:54:49:703 | MD |      INFO  | +0     | ExitModule - Ended
End of Module Logs
16:54:49:845 | RL |      INFO  | +9266  | Main - Module ended, exiting RocketLauncher normally
16:54:49:875 | RL |      INFO  | +31    | ExitScript - Started
16:54:49:887 | RL |     DEBUG  | +16    | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
16:54:49:889 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
16:54:49:890 | RL |     TRACE  | +0     | StringUtils.Contains - "false" does not contain "true|kill"
16:54:49:891 | RL |      INFO  | +0     | ExitScript - Restoring taskbar
16:54:49:892 | RL |     TRACE  | +0     | Window.__New - Created: "ahk_class Shell_TrayWnd"
16:54:49:894 | RL |     TRACE  | +0     | Window.__New - Created: "ahk_class Button"
16:54:49:896 | RL |     TRACE  | +16    | Window.Show - Unhiding window "ahk_class Shell_TrayWnd"
16:54:50:015 | RL |     TRACE  | +109   | Window.Show - Unhiding window "ahk_class Button"
16:54:50:041 | RL |      INFO  | +31    | SystemCursor - Restoring mouse cursor
16:54:50:058 | RL |      INFO  | +16    | ExitScript - Restored cursor
16:54:50:059 | RL |      INFO  | +0     | ExitScript - Ended
[/code]
