drjea2010 Posted February 8, 2022 Posted February 8, 2022 I thought I had this working but apparently not. Using Fusion to play Sega CD. Outside of HS/RL it loads the Sega CD title screen, asks me to push "start," and after I do that the game loads. However, if I launch the game through RL or in HS I get the same Sega CD title screen but it says to push reset to open and close the drive, and if I push "start" I get the CD player. I've googled this and not found anything helpful. I did select in Fusion under "options" and CD drive my SCSI Daemon Tools drive, despite not using that to load any files. I'm using .bin/.cue files. Unzipped. File is good since it works outside RL/HS. Name matches exactly according to the games tab. I have all the CD Bios files as well. I am convinced it is a setting or something in RL I need to do, since it works fine through the emulator itself. Probably an easy fix, but as usual, I get caught up on this stuff. (In my defense, I have added Game Gear, 32X, and Master System all by myself without issue!). Thanks in advance!
drjea2010 Posted February 8, 2022 Author Posted February 8, 2022 Nevermind, got it working. Had to delete the zip file from the roms directory to get it to work. All good now. Feel free to delete this thread if need be (or leave it here in case anyone else has the same problem).
