Please Could anyone help?
Deanoe
Hi, I've just installed Bandits no clutter 200gb hyperspin image to my 2017 nvidia shield, all is working good but I'm confused as to how I add a new system ( Atari 2600 ) as there are no tutorials that I can find.
I have 900 roms placed within a folder called Atari 2600/roms, how do I get the system to show in the platform list?
How do you download the artwork/music/bezels to the Nvidia shield?
How do I set up a default emulator for a system?
If someone could tell me step by step process that would be much appreciated
Hey, Deanoe.
So, you'll need to download the 'cores' in retroarch that correspond to what the .INI is looking for. Hyperspin uses .INI files to do... everything pretty much. Cores are basically emulators.
Then, you'll need a system .INI file for the 2600. I recommend you copy a working system, name it Atari 2600 and go from there.
Those .INI files are in the settings folder. This will serve as a good road map as to what's going on.
That should get you started, hope that helps!
-ghost
