taflad Posted July 20, 2014 Posted July 20, 2014 Hi All, Very odd situation here. I have had hyperspin/hyperlaunch working great for about 6 months now. I restarted my machine last night, now I get "Cannot find hyperlaunch.exe" error. Checked the ini file, its pointing to the correct path, tried adding a \ to the path and removing it. Fully removed the path to force hyperlaunchhq to ask to redefine it, grabbed a fresh hyperlaunch and set it on d/top and pointed ini to it. NOTHING has worked. Launch HS, select the emu then the game, then the error throws up. Any help at all? Cheers
taflad Posted July 20, 2014 Author Posted July 20, 2014 I have found the problem, but not the resolution..... Hyperspin log is telling me it is looking for the hyperlaunch exe in the wrong place, no matter that i have set it in hyperlaunchhq. is there a way to edit where hyperspin looks via an ini file or the like?
taflad Posted July 20, 2014 Author Posted July 20, 2014 Problem solved. For those that may have the same issue..... My settings file in hyperspin had wiped. I downloaded a fresh hyperspin, coped it to settings folder, pointed HL_Path to match hyperlaunchhq ini, job done
