Help with Sega Naomi Set-up with Demul
Jon.Damico
I am trying to set-up Demul, however I receive an error stating "Unable to find "monkeyba.bin" in romset "Monkeyba." I think it may be due to the fact that the rom is a .dat not .bin. The error is both within Hyperspin and outside Hyperspin. I tried finding a post regarding this error, but no luck. Here is my Demul.ini if it helps.
[main]
region = 1
broadcast = 1
cpumode = 1
lastEmuRunMode = 1
videomode = 768
timehack = true
activateBBA = false
VMUscreendisable = false
windowX = 296
windowY = 160
dcBios = 3
naomiBiosAuto =true
naomiLLEMIE = false
naomifreq = 1
hikaruBios = 1
[PORTA]
device = 16777216
port0 = 234881024
port1 = 65536
port2 = -1
port3 = -1
port4 = -1
[VMS]
VMSA0 = H:\Hyperspin\Emulators\Sega Naomi\memsaves\vms00.bin
VMSA1 =
VMSA2 =
VMSA3 =
VMSA4 =
VMSB0 =
VMSB1 =
VMSB2 =
VMSB3 =
VMSB4 =
VMSC0 =
VMSC1 =
VMSC2 =
VMSC3 =
VMSC4 =
VMSD0 =
VMSD1 =
VMSD2 =
VMSD3 =
VMSD4 =
[PORTB]
device =16777216
port0 = -1
port1 = -1
port2 = -1
port3 = -1
port4 = -1
[PORTC]
device = -1
port0 = -1
port1 = -1
port2 = -1
port3 = -1
port4 = -1
[PORTD]
device = -1
port0 = -1
port1 = -1
port2 = -1
port3 = -1
port4 = -1
[plugins]
directory = H:\Hyperspin\Emulators\Sega Naomi\plugins\
gdr = gdrCHD.dll
gpu =gpuDX11.dll
spu = spuDemul.dll
pad = padDemul.dll
net = netDemul.dll
[files]
nvram = H:\Hyperspin\Emulators\Sega Naomi\nvram\
roms0 = H:\Hyperspin\Emulators\Sega Naomi\Sega Naomi Roms\
roms1 = H:\Hyperspin\Emulators\Sega Naomi\Sega Naomi Roms\
romsPathsCount = 2
Thanks for any assistance. Also, try to keep it slightly simple, I am not an expert at code, I can read and write some, but I easily get lost sometimes.
Thanks again.
ok, I had several problems apparently. I was using version 582, not 57, so i set it up from scratch with version 57 and I noticed I have to click load decrypted rom for it to work. I also found out that my DirectX was out of date. I found this out by trying to access the video options and the emulator errored with a directX error. So, if you have this issue check your version # and DirectX. Lastly, I discovered that renaming the roms from .dat to .bin allows them to open properly. I haven't tried to get it to work with Hyperspin, but usually I can figure that out. If I have more issues or fixes I will post here and hopefully it might help someone out. Best of luck to anyone with this issue.
