ZSnes
legin
Gday all
I am having a problem with hyperlaunch and ZSnesw
I can run a rom just fine with ZSnesw outside of hyperlaunch.
I have set my resolution in Zsnesw to 640x480.
If I run it with hyperlaunch I get a black screen. After that if I open ZSnes outside of hyperlaunch I get a black screen again.
Looking at the zsnes.cfg for ZSnes i see the resolution has changed to 1024x768. (I cant run res over 800x600 on my arcade monitor), whch explains the black screen
If I change the res back to 640x480 in the config file i can open and run a rom in zsnesw again, but a soon I run it in hyperlaunch or hyperlaunchHQ it changes the resolution again.
I cant seem to find out why it is doing this. am i missing a setting somewhere?
It is always the way. just after you post you find it
In HyperlaunchHQ I checked the global setting for the module in Zsnesw and found the screen res there.
Changed it, works good now
  • 4 weeks later...
