Net framework problems.
rust2dust
Moved my hyperspin setup from my external hd to my new internal on my new cab...
Here is the issue ....having followed all the normal steps for new install, and thought I would test it before shelling it
Hyperspin loads fine. Everything is still there. But when I try to use HL or HLHQ it tells me it cant find net framework. The same when I try to load a game. Ive gotten so spoiled by HLHQ I'm not really sure where to look. INI files?
If you're hooking this drive to another computer make sure it has netframework isntalled (though I have the feeling, I'm telling the obvious and you already know this).
Net framework is installed. I think I may have found the problem however.
I looked in the INI file in my hyperlaunch folder and it is looking for files on my C: primary drive. My hyperspin files and all net framework installed on my D: drive. After I get off work today I will explore it further....
(Crossed fingers)
Found the problem...UPDATE MOTHERBOARD BIOS.....thats what I get for building a system instead of buying a pre-setup...
On the plus side...no bloatware.
Thanks to all who helped...
