Xtra9268 Posted December 22, 2014 Posted December 22, 2014 Cabinet's Exterior Here's the arcade cabinet from the outside. The wall and marquee was designed by me in Illustrator CS2 using Recroom's printing templates. Cabinet's Interior Here's the arcade cabinet from the inside. The Pixel Qi controller is mounted to the back of the monitor mount for easy access. You can also see the keyboard controller cables and wiring. Because of the cable hole that runs through the middle of the cabinet's computer shelf I decided to mount the computer and power supply on separate pegboards. A little challenging to load and unload but not impossible. Cabinet In Action! Here's the arcade in action! As you can see whenever you select a game in Hyperspin, the game's logo appears in the marquee's LCD. Parts list Arcade cabinet with controller board - http://www.recroommasters.com/32_Pro_Upright_Xtension_Arcade_Cabinet_Emulator_p/rm-xt-32-pro-ee.htm Marquee LCD - https://www.adafruit.com/products/1303 Hyperspin and Hyperlaunch - http://www.hyperspin-fe.com/ HyperMarquee - http://www.hyperspin-fe.com/forum/showthread.php?31916-HyperMarquee Hyperspin Event Dispatch System - http://www.hyperspin-fe.com/forum/showthread.php?32782-HyperSpin-Event-Dispatch-System-(EDS) EmuMovies (30 seconds clips of the video game) - http://emumovies.com/forums/index.php/page/portal Computer Hardware - http://www.newegg.com/ Computer hardware is mounted onto standard pegboard with metric screws, and 14" ties. - http://www.homedepot.com/ I used shipping foam on the screws so that they don't scratch up the cabinet's computer shelf. Here's some photos Sprayed a Tubberware container black then cut slots for the power switch, components and wiring. This goes on the keyboard shelf for easy access to turn the computer on and off. Cabinet Computer mounted to pegboard
baddeolv Posted December 23, 2014 Posted December 23, 2014 That's a badass cab. I'm jealous for sure! Instagram : baddeolv Facebook : Brian Addeo
