Can't get 3DO to run in Hyperlaunch.
Zuckerton
I searched the forums and although some had similar issues, they weren't quite the same and they were also for older versions of Hyperlaunch.
I've been trying for the last few days to get all my emulators running and got most of them working fine, but there seems to be an error with the Panasonic 3DO.
I'm using FreeDO (Because 4DO for some reason won't even LAUNCH on my computer) and it works fine outside of Hyperlaunch, but when I try to launch it from the inside, I get an error box with no error inside, just a red X. I then have to point to the bios file and to the rom to launch it. Here's my log file:
00:41:32:690 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.0 BETA (www.hyperlaunch.net)
00:41:32:750 | HL |     INFO  | +63    | Main - System Specs:
				HyperLaunch Dir: D:\Hyperspin\HyperLaunch
				HyperLaunch is: 32-bit
				OS: Microsoft Windows 7 Ultimate
				SKU: Ultimate
				Total Memory: 16325.53 MB
				Free Memory: 14024.90 MB
				Used Memory: 2300.625 MB
				SystemType: 64-bit
				Physical Processors: 1
				Logical Processors: 8
				GPU 1 Name: NVIDIA GeForce GTX 660
				GPU 1 RAM: -2048.00 MB
				GPU 1 Driver Version: 9.18.13.2723
				Sound 1 Device: NVIDIA High Definition Audio
				Sound 1 Status: Enabled
				Sound 2 Device: High Definition Audio Device
				Sound 2 Status: Enabled
				Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
				Sound 3 Status: Enabled
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1280x768 (1280x728 work)
				Monitor #1 Orientation: Landscape
				Current AHK Desktop Width: 1280
				Current AHK Desktop Height: 768
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
00:41:32:750 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
00:41:32:750 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
00:41:32:750 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
00:41:32:750 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Plugins\HyperSpin.plugin exists
00:41:32:750 | HL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
00:41:32:750 | HL |     INFO  | +0     | Main - HyperLaunch received "Panasonic 3DO" and "Alone in the Dark (USA)"
00:41:32:760 | HL |     INFO  | +15    | Main - Alone in the Dark (USA) is using the default emulator: FreeDO
00:41:32:760 | HL |     INFO  | +0     | Main - Checking for a [FreeDO] section in D:\Hyperspin\HyperLaunch\Settings\Panasonic 3DO\Emulators.ini
00:41:32:760 | HL |     INFO  | +0     | Main - Checking for a [FreeDO] section in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
00:41:32:760 | HL |     INFO  | +0     | Main - Found [FreeDO] in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
00:41:32:760 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Modules\FreeDO\FreeDO.ahk exists
00:41:32:760 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
00:41:32:760 | HL |     INFO  | +0     | Main - Alone in the Dark (USA) will use module: D:\Hyperspin\HyperLaunch\Modules\FreeDO\FreeDO.ahk
00:41:32:770 | HL |     INFO  | +16    | Main - Did not find a "D:\Hyperspin\HyperLaunch\Settings\Panasonic 3DO\Game Options.ini" file, skipping any game-specific options.
00:41:32:770 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
00:41:32:770 | HL |     INFO  | +0     | Main - INI Keys read
00:41:32:770 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists
00:41:32:770 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists
00:41:32:770 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\FontReg.exe exists
00:41:32:780 | HL |     INFO  | +0     | Main - "Alone in the Dark (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
00:41:32:780 | HL |     INFO  | +0     | CheckPaths - Started
00:41:32:780 | HL |     INFO  | +0     | CheckPaths - Found rom: D:\Hyperspin\Emulators\3DO\Games\Alone in the Dark (USA).iso
00:41:32:780 | HL |     INFO  | +0     | CheckPaths - Ended
00:41:32:780 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 8
				pluginPath = D:\Hyperspin\HyperLaunch\Plugins
				pluginName = HyperSpin
				pluginExt = .plugin
				hlMode =
				hlTitle = HyperLaunch
				hlVersion = 3.1.0.0 BETA
				hlAuthor = djvj
				hlURL = www.hyperlaunch.net
				langFile = D:\Hyperspin\HyperLaunch\Data\Language\Localization.ini
				frontendPID = 0
				frontendPath = D:\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = D:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = D:\Hyperspin\Emulators\3DO\FreeDO.exe
				emuPath = D:\Hyperspin\Emulators\3DO
				emuName = FreeDO
				emuExt = exe
				romPath = D:\Hyperspin\Emulators\3DO\Games
				romPathFromIni = D:\Hyperspin\Emulators\3DO\Games
				romExtension = .iso
				romExtensionOrig = .iso
				romExtensions = 7z|zip|iso|bin|cdi|nrg|img
				executable = FreeDO.exe
				systemName = Panasonic 3DO
				dbPath =
				dbName = Alone in the Dark (USA)
				dbExt =
				romName = Alone in the Dark (USA)
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				altArchiveNameOnly =
				altRomNameOnly =
				altArchiveAndRomName =
				altArchiveAndManyRomNames =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = true
				blockInputTime = 0
				blockInputFile = D:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				lockLaunch = false
				lockLaunchGame =
				screenRotationAngle = 0
				screenRotationAngleGame =
				logFile = D:\Hyperspin\HyperLaunch\HyperLaunch.log
				logLevel = 3
				logShowDebugConsole = false
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				hlDebugConsoleStdout =
				sysType = 64-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1280
				originalHeight = 768
				dtEnabled = false
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				servoStikEnabled = false
				ledblinkyEnabled = false
				ledblinkyFullPath =
				ledblinkyProfilePath = D:\Hyperspin\HyperLaunch\Profiles\LEDBlinky
				ledblinkyHLProfile = D:\Hyperspin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch
				emuIdleShutdown = 0
				launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig==
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeMuteEmulator = false
				fadeUseBackgrounds = false
				fadeXScale =
				fadeYScale =
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr2Prefix = Layer 2
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBar = 7zOnly
				fadeBarNon7zProgressTime = 0
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeText3 = Loading Game
				fadeText4 = Loading Complete
				fadeFont = Arial
				fadeExtractionTime = disabled
				fadeExtractionTimeTextX = 0
				fadeExtractionTimeTextY = 0
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = D:\Hyperspin\HyperLaunch\Media\Fade
				HLDataPath = D:\Hyperspin\HyperLaunch\Data
				HLMediaPath = D:\Hyperspin\HyperLaunch\Media
				HLErrSoundPath = D:\Hyperspin\HyperLaunch\Media\Sounds\Error
				modulesPath = D:\Hyperspin\HyperLaunch\Modules
				moduleFullName = D:\Hyperspin\HyperLaunch\Modules\FreeDO\FreeDO.ahk
				moduleName = FreeDO
				modulePath = D:\Hyperspin\HyperLaunch\Modules\FreeDO
				moduleExtension = ahk
				moduleExtensionsPath = D:\Hyperspin\HyperLaunch\Module Extensions
				libPath = D:\Hyperspin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = D:\Hyperspin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = D:\Hyperspin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\Users\MAME\Desktop
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgXScale = 1
				mgYScale = 1
				mgYOffset = 500
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = true
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = D:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {F5 down}{F5 up}
				hpLoadStateKeyCodes = {F8 down}{F8 up}
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper = ahk
				xpadderFullPath = D:\Hyperspin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = D:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = D:\Hyperspin\HyperLaunch\Profiles\ahk
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				rotateMethod = false
				FEProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\HyperSpin
				defaultProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\_Default
				systemProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Panasonic 3DO
				xPadderSystemProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Panasonic 3DO\_Default
				emuProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Panasonic 3DO\FreeDO
				romProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Panasonic 3DO\Alone in the Dark (USA)
				HyperLaunchProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\HyperLaunch
				blankProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\blank
				ahkFEProfile = D:\Hyperspin\HyperLaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = D:\Hyperspin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = D:\Hyperspin\HyperLaunch\Profiles\AHK\Panasonic 3DO
				ahkEmuProfile = D:\Hyperspin\HyperLaunch\Profiles\AHK\Panasonic 3DO\FreeDO
				ahkRomProfile = D:\Hyperspin\HyperLaunch\Profiles\AHK\Panasonic 3DO\Alone in the Dark (USA)
				ahkHyperLaunchProfile = D:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				bezelICEnabled = false
				statisticsEnabled = true
				pressDuration = -1
				emuVolume = 1
				dxwndIni = D:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini
				dxwndFullPath = D:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe
				mon1O = 0
				pacDrivedllFile = D:\Hyperspin\HyperLaunch\Module Extensions\PacDrive32.dll
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded HyperPause Init.ahk scripts
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Validating module
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Validation complete
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = FreeDO
				MEmuV = v2.1.1 alpha
				MURL = http://www.freedo.org/
				MAuthor = djvj
				MVersion = 2.0.2
				MCRC = E2050BB9
				iCRC = 7E0E6CF7
				MID = 635038268892864713
				MSystem = "Panasonic 3DO"
				; Notes:
				; The emu does not support CLI or a way of launching fullscreen by default. This is all done manually in the script.
				; Supported images are iso, cdi, nrg, bin, img. Cues are not supported. Set your extensions appropriately.
				; If your bios file is called fz10_rom.bin, rename it to fz10.rom, it should be placed in the same dir as the emu exe.
				; On first launch, FreeDO will ask you to point it to the fz10.rom. After you do that, exit the emu and select a game in HS and it should work.
				; If the Menu bar at top is present on launch, Hit F9 and exit to save.
				; If you do not have an English windows, set the language you use for the MLanguage setting in HLHQ. Currently only Spanish/Portuguese is supported.
				; Create a restore.xml or follow the next line. For info on how to do this, go here http://www.hyperspin-fe.com/forum/showpost.php?p=58411&postcount=12
				; In the emu dir, rename config.xml to restore.xml then open it in notepad. Remove the entire section including <cdrom> and </cdrom> (this fixes not being able to play the game twice in a row)
				; If you change inputs or make any other changes, make sure to copy the changes from the config.xml into your restore.xml
				StartModule()
				FadeInStart()
				ToolbarWait := IniReadCheck(settingsFile, "Settings", "ToolbarWait","300",,1) ; increase this if toolbar is staying visible
				dialogOpen := i18n("dialog.open")	; Looking up local translation
				freeDOFile := CheckFile(emuPath . "\config.xml","Cannot find " . emuPath . "\config.xml`nPlease run FreeDO manually first so it is created for you.")
				hideEmuObj := Object(dialogOpen . " ahk_class #32770",0,"FreeDO ahk_class TForm1",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
				If romExtension in .7z,.rar,.zip,.cue
					ScriptError("Pheonix does not support archived or cue files. Only ""iso, cdi, nrg, bin & img"" files can be loaded. Either enable 7z support, or extract your games first.")
				; restoring a proper config.xml
				FileDelete, %emuPath%\config.xml
				FileCopy, %emuPath%\restore.xml, %emuPath%\config.xml
				HideEmuStart()	; This fully ensures windows are completely hidden even faster than winwait
				Run(executable, emuPath)
				DetectHiddenWindows, on
				; Sleep, 500
				WinWait("FreeDO ahk_class TForm1")
				IfWinNotActive, FreeDO ahk_class TForm1
					WinActivate, FreeDO ahk_class TForm1
				WinWaitActive("FreeDO ahk_class TForm1")
				Send, {ALTDOWN}{ALTUP}{UP}{ENTER} ; open ISO
				WinWait(dialogOpen)
				IfWinNotActive, %dialogOpen% ahk_class #32770, , WinActivate, %dialogOpen% ahk_class #32770
				OpenROM(dialogOpen . " ahk_class #32770", romPath . "\" . romName . romExtension)
				If Fullscreen = true
					Send, {F11}
				Sleep, %ToolbarWait%	; increase this if toolbar is staying visible
				Send, {F9}	; disable toolbar
				HideEmuEnd()
				FadeInExit()
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				CloseProcess:
					WinClose("FreeDO ahk_class TForm1")
				Return
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded HyperPause scripts
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
00:41:32:780 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
00:41:32:790 | HL |     INFO  | +15    | Main - Module is built
00:41:32:790 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
00:41:32:790 | HL |     INFO  | +0     | Main - Running module
00:41:32:900 | MD |     INFO  | +N/A   | Module initialized
00:41:32:900 | MD |     INFO  | +0     | StartModule - Started
00:41:32:900 | MD |     INFO  | +0     | StartModule - MEmu: FreeDO
				MEmuV: v2.1.1 alpha
				MURL: http://www.freedo.org/
				MAuthor: djvj
				MVersion: 2.0.2
				MCRC: E2050BB9
				iCRC: 7E0E6CF7
				MID:
				MSystem: "Panasonic 3DO"
00:41:32:900 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Panasonic 3DO"
00:41:32:900 | MD |     INFO  | +0     | PluginInit - Started
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Logo_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Logo_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Artwork_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Artwork_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Backgrounds_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Backgrounds_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Controller_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Controller_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Guides_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Guides_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Manuals_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Manuals_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Videos_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Videos_Labels" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fe_Disc_Artwork_Label" in section: "HyperSpin" in ""
00:41:32:900 | MD |  WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fe_Disc_Artwork_Label" in section: "HyperSpin" in ""
00:41:32:930 | MD |     INFO  | +31    | CheckFile - Checking if D:\Hyperspin\Databases\Panasonic 3DO\Panasonic 3DO.xml exists
00:41:32:930 | MD |     INFO  | +0     | PluginInit - Ended
00:41:32:930 | MD |     INFO  | +0     | StartModule - Ended
00:41:32:930 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
00:41:32:930 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
00:41:32:930 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
00:41:32:930 | MD |     INFO  | +0     | Module Setting - [settings] - ToolbarWait: 300
00:41:32:930 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\3DO\config.xml exists
00:41:32:930 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\Emulators\3DO\FreeDO.exe
00:41:32:960 | MD |     INFO  | +31    | WinWait - Waiting for "FreeDO ahk_class TForm1"
00:41:33:538 | MD |     INFO  | +577   | WinWaitActive - Waiting for "FreeDO ahk_class TForm1"
00:41:33:741 | MD |     INFO  | +203   | WinWait - Waiting for "Open"
00:41:33:850 | MD |     INFO  | +109   | OpenROM - Started
00:41:33:850 | MD |     INFO  | +0     | WinWait - Waiting for "Open ahk_class #32770"
00:41:33:957 | MD |     INFO  | +109   | WinWaitActive - Waiting for "Open ahk_class #32770"
00:41:34:082 | MD |     INFO  | +125   | OpenROM - Ended
00:41:34:082 | MD |     INFO  | +0     | WinWait - Waiting for "FreeDO ahk_class TForm1"
00:41:34:191 | MD |     INFO  | +109   | WinWaitActive - Waiting for "FreeDO ahk_class TForm1"
00:41:42:964 | MD |     INFO  | +8768  | WinWait - Waiting for "FreeDO ahk_class TForm1"
00:41:43:066 | MD |     INFO  | +109   | WinWaitActive - Waiting for "FreeDO ahk_class TForm1"
00:41:43:991 | MD |     INFO  | +920   | Process - WaitClose FreeDO.exe
00:41:58:624 | MD |     INFO  | +14633 | StopGlobalUserFeatures - Starting
00:41:58:624 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
00:41:58:624 | MD |     INFO  | +0     | ExitModule - Started
00:41:58:624 | MD |     INFO  | +0     | Starting Updating Statistics:
00:41:58:694 | MD |     INFO  | +62    | Game section statistics updated.
00:41:58:694 | MD |     INFO  | +0     | ExitModule - Ended
00:41:58:694 | MD |     INFO  | +0     | End of Module Logs
00:41:58:764 | HL |     INFO  | +25974 | Main - Module ended, exiting HyperLaunch normally
00:41:58:764 | HL |     INFO  | +0     | ExitScript - Started
00:41:58:774 | HL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
00:41:58:784 | HL |     INFO  | +16    | ExitScript - Ended
It looks to be a module issue. Any help would be appreciated.
