MAME newbie question
cnterr
The atest HyperLaunch MAME module is for MAME 0.150, the latest HyperSpin XML is for MAME 0.155.
What's the correct MAME release?
If I use MAME 0.150 with an XML list for 0.155 I suppose that some titles don't work. Can alternatively use MAME 0.155 with an HyperLaunch module for 0.150?
Many thanks!
As far as I can tell you can pretty much use any Mame version you want with the module. I don't know, but I'd imagine the Hyperlaunch team only updates the mame module when updates to the emulator require it. I've been using 152 with it. I think Mame is doing monthly releases at this point. Some games may not work if you're using a different mame version than your romset, yes.
To Clarify: I'm pretty sure every mame release is backwards compatible. I think you may only run into problems if you're romset is more advanced than your mame version, but I could be wrong.
Walter:beerglass:
