jspence3 Posted January 9, 2015 Posted January 9, 2015 Hi, I'm current running Dolphin 4.0.4991 and the latest version of HyperLaunch. Some where along the line this stopped working, but it used to work. The problem is when I try to play a game with more than 1 player the 2nd, 3rd, 4th controllers aren't recognized. I'm using wireless Xbox 360 controllers. If I go into the Dolphin Emulator and set all players to "Emulated Wiimote" then play the game directly from Dolphin it works fine, but once I try to boot from HyperlaunchHQ or Hyperspin, it resets my 2, 3, 4 wiimote to "None". I have the game.ini set up per game so it should set all four wiimotes to "Emulated Wiimote" with the correct user config. So I don't know if I'm missing a setting where it's defaulting Dolphin back to a single wiimote or what.
jspence3 Posted January 10, 2015 Author Posted January 10, 2015 I found the issue. Apparently either the latest version of dolphin or the latest version of hyperlaunch changed the folder structure and naming. If this issue happens to anyone, just look at your config folder for dolphin (typically found in Documents) and any ini files. They either might be in the wrong place or are using out of date versions.
