PCSX2 Bios PAL (Europe) Loading Issue
jspence3
Hi,
I'm running the latest version of PCSX2 - 1.2.1 with a USA bios and HyperLaunchHQ and I'm having an issue where it won't run any PAL (Europe) games when I launch from HyperLaunchHQ. It just goes to black screen and locks up. I can play a USA game fine from HyperLaunchHQ, but not any other region. The emulator will run the PAL version find outside of HyperLaunchHQ. I have the emulator set to Fast Boot . I dont know if anyone else has run into this problem.
I didn't think the bios I pick matters since it works outside of HyperLaunchHQ regardless of which bios I choose. I thought running fast boot skips the region check anyways. When I run it through HyperLaunchHQ, I get the error "There was an error detecting when PCSX2 finished loading, Please report this so the module can be fixed".
HyperLaunch.log
08:55:44:082 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.2 BETA (www.hyperlaunch.net)
08:55:44:141 | HL |     INFO  | +62    | Main - System Specs:
				HyperLaunch Dir: D:\HyperSpin\HyperLaunch
				HyperLaunch is: 32-bit
				OS: Microsoft Windows 7 Ultimate
				SKU: Ultimate
				Total Memory: 16313.39 MB
				Free Memory: 13908.78 MB
				Used Memory: 2404.609 MB
				SystemType: 64-bit
				Physical Processors: 1
				Logical Processors: 8
				GPU 1 Name: AMD Radeon R9 200 Series
				GPU 1 RAM: -2048.00 MB
				GPU 1 Driver Version: 14.501.1003.0
				Sound 1 Device: AMD High Definition Audio Device
				Sound 1 Status: Enabled
				Sound 2 Device: High Definition Audio Device
				Sound 2 Status: Enabled
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work)
				Monitor #1 Orientation: Landscape
				Current AHK Desktop Width: 1920
				Current AHK Desktop Height: 1080
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
08:55:44:142 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
08:55:44:142 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
08:55:44:142 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
08:55:44:143 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Plugins\HyperSpin.plugin exists
08:55:44:143 | HL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
08:55:44:143 | HL |     INFO  | +0     | Main - HyperLaunch received "Sony PlayStation 2" and "Agent Hugo - Hula Holiday (Europe)"
08:55:44:147 | HL |     INFO  | +0     | Main - Agent Hugo - Hula Holiday (Europe) is using the default emulator: PCSX2
08:55:44:147 | HL |     INFO  | +0     | Main - Checking for a [PCSX2] section in D:\HyperSpin\HyperLaunch\Settings\Sony PlayStation 2\Emulators.ini
08:55:44:147 | HL |     INFO  | +0     | Main - Checking for a [PCSX2] section in D:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
08:55:44:147 | HL |     INFO  | +0     | Main - Found [PCSX2] in D:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
08:55:44:147 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Modules\PCSX2\PCSX2.ahk exists
08:55:44:153 | HL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
08:55:44:153 | HL |     INFO  | +0     | Main - Agent Hugo - Hula Holiday (Europe) will use module: D:\HyperSpin\HyperLaunch\Modules\PCSX2\PCSX2.ahk
08:55:44:160 | HL |     INFO  | +0     | Main - Did not find a "D:\HyperSpin\HyperLaunch\Settings\Sony PlayStation 2\Game Options.ini" file, skipping any game-specific options.
08:55:44:160 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
08:55:44:161 | HL |     INFO  | +0     | Main - INI Keys read
08:55:44:161 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
08:55:44:162 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
08:55:44:162 | HL |     INFO  | +0     | CreateRomMapTable - Started
08:55:44:162 | HL |     INFO  | +0     | AltNameExistCheck - Found rom: D:\HyperSpin\Emulators\Sony Playstation 2\Roms\Agent Hugo - Hula Holiday (Europe)\Agent Hugo - Hula Holiday (Europe).cue
08:55:44:162 | HL |     INFO  | +0     | CreateRomMapTable - Ended, No mapping inis found.
08:55:44:162 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\Module Extensions\FontReg.exe exists
08:55:44:164 | HL |     INFO  | +0     | Main - "Agent Hugo - Hula Holiday (Europe)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
08:55:44:164 | HL |     INFO  | +0     | CheckPaths - Started
08:55:44:164 | HL |     INFO  | +0     | CheckPaths - Found rom by matching name in subfolder: D:\HyperSpin\Emulators\Sony Playstation 2\Roms\Agent Hugo - Hula Holiday (Europe)\Agent Hugo - Hula Holiday (Europe).cue
08:55:44:164 | HL |     INFO  | +0     | CheckPaths - Ended
08:55:44:164 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 8
				pluginPath = D:\HyperSpin\HyperLaunch\Plugins
				pluginName = HyperSpin
				pluginExt = .plugin
				hlMode =
				hlTitle = HyperLaunch
				hlVersion = 3.1.0.2 BETA
				hlAuthor = djvj
				hlURL = www.hyperlaunch.net
				langFile = D:\HyperSpin\HyperLaunch\Data\Language\Localization.ini
				frontendPID = 0
				frontendPath = D:\HyperSpin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = D:
				exitEmulatorKey = Esc|LControl&RControl
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = Restore and Click
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = D:\HyperSpin\Emulators\Sony Playstation 2\Emulators\PCSX2 1.0.0 R5350\pcsx2-r5350.exe
				emuPath = D:\HyperSpin\Emulators\Sony Playstation 2\Emulators\PCSX2 1.0.0 R5350
				emuName = PCSX2
				emuExt = exe
				romPath = D:\HyperSpin\Emulators\Sony Playstation 2\Roms\Agent Hugo - Hula Holiday (Europe)
				romPathFromIni = D:\HyperSpin\Emulators\Sony Playstation 2\Roms
				romExtension = .cue
				romExtensionOrig = .cue
				romExtensions = 7z|zip|cue|iso
				executable = pcsx2-r5350.exe
				systemName = Sony PlayStation 2
				dbPath =
				dbName = Agent Hugo - Hula Holiday (Europe)
				dbExt =
				romName = Agent Hugo - Hula Holiday (Europe)
				romMapPath = D:\HyperSpin\HyperLaunch\Settings\Sony PlayStation 2\Rom Mapping
				romMappingEnabled = true
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				altArchiveNameOnly =
				altRomNameOnly =
				altArchiveAndRomName =
				altArchiveAndManyRomNames =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = false
				blockInputTime = 0
				blockInputFile = D:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				lockLaunch = false
				lockLaunchGame =
				screenRotationAngle = 0
				screenRotationAngleGame =
				logFile = D:\HyperSpin\HyperLaunch\HyperLaunch.log
				logLevel = 3
				logShowDebugConsole = false
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				hlDebugConsoleStdout =
				sysType = 64-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = true
				dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
				dtUseSCSI = true
				dtAddDrive = true
				servoStikEnabled = false
				ledblinkyEnabled = false
				ledblinkyFullPath =
				ledblinkyProfilePath = D:\HyperSpin\HyperLaunch\Profiles\LEDBlinky
				ledblinkyHLProfile = D:\HyperSpin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch
				emuIdleShutdown = 0
				launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig==
				hideCursor = true
				hideEmu = false
				hideFE = false
				fadeIn = true
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = true
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeMuteEmulator = false
				fadeUseBackgrounds = false
				fadeXScale =
				fadeYScale =
				fadeLyr1Color = FF000000
				fadeLyr2Pos = No Alignment
				fadeLyr2X = 0
				fadeLyr2Y = 870|1575
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 450
				fadeLyr3Y = 450
				fadeLyr3Adjust = 0.8
				fadeLyr3PicPad = 0
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3StaticX = 0
				fadeLyr3StaticY = 870|1575
				fadeLyr3StaticAdjust = 1
				fadeLyr3StaticPicPad = 0
				fadeLyr4Adjust = 1
				fadeLyr4X = 1792|952
				fadeLyr4Y = 891|1596
				fadeLyr4Pos = No Alignment
				fadeLyr4FPS = 50
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = Image
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 900
				fadeBarWindowH = 180
				fadeBarWindowR = 30
				fadeBarWindowM = 30
				fadeBarWindowHatchStyle = 8
				fadeBar = 7zOnly
				fadeBarNon7zProgressTime = 0
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 30
				fadeBarR = 10
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 8
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 150
				fadeRomInfoSystemName = image
				fadeRomInfoManufacturer = text with label
				fadeRomInfoGenre = disabled
				fadeRomInfoRating = image
				fadeRomInfoTextMargin = 7
				fadeStatsInfoTextMargin = 7
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Extraction In Progress, Please Wait
				fadeText2X = 0
				fadeText2Y = 0
				fadeText3 = Loading Game
				fadeText4 = Loading Complete
				fadeFont = Bebas Neue
				fadeExtractionTime = disabled
				fadeExtractionTimeTextX = 0
				fadeExtractionTimeTextY = 0
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = D:\HyperSpin\HyperLaunch\Media\Fade
				HLDataPath = D:\HyperSpin\HyperLaunch\Data
				HLMediaPath = D:\HyperSpin\HyperLaunch\Media
				HLErrSoundPath = D:\HyperSpin\HyperLaunch\Media\Sounds\Error
				modulesPath = D:\HyperSpin\HyperLaunch\Modules
				moduleFullName = D:\HyperSpin\HyperLaunch\Modules\PCSX2\PCSX2.ahk
				moduleName = PCSX2
				modulePath = D:\HyperSpin\HyperLaunch\Modules\PCSX2
				moduleExtension = ahk
				moduleExtensionsPath = D:\HyperSpin\HyperLaunch\Module Extensions
				libPath = D:\HyperSpin\HyperLaunch\Lib
				7zEnabled = true
				7zPath = D:\HyperSpin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = D:\HyperSpin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = D:\HyperSpin\7z
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = true
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgXScale = 1
				mgYScale = 1
				mgYOffset = 500
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = true
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = D:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {F1 down}{F1 up}
				hpLoadStateKeyCodes = {F3 down}{F3 up}
				keymapperEnabled = true
				keymapperAHKMethod = false
				keymapper = xpadder
				xpadderFullPath = D:\HyperSpin\Utilities\Xpadder\Xpadder.exe
				joyToKeyFullPath = D:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = D:\HyperSpin\HyperLaunch\Profiles\xpadder
				keymapperFrontEndProfile = xpadder
				keymapperHyperLaunchProfileEnabled = xpadder
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				rotateMethod = false
				FEProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperSpin
				defaultProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default
				systemProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\Sony PlayStation 2
				xPadderSystemProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\Sony PlayStation 2\_Default
				emuProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\Sony PlayStation 2\PCSX2
				romProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\Sony PlayStation 2\Agent Hugo - Hula Holiday (Europe)
				HyperLaunchProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperLaunch
				blankProfile = D:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default\blank
				ahkFEProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\Sony PlayStation 2
				ahkEmuProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\Sony PlayStation 2\PCSX2
				ahkRomProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\Sony PlayStation 2\Agent Hugo - Hula Holiday (Europe)
				ahkHyperLaunchProfile = D:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				bezelICEnabled = false
				statisticsEnabled = true
				pressDuration = -1
				emuVolume = 1
				dxwndIni = D:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini
				dxwndFullPath = D:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe
				mon1O = 0
				pacDrivedllFile = D:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll
08:55:44:166 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
08:55:44:166 | HL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
08:55:44:166 | HL |     INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
08:55:44:166 | HL |     INFO  | +0     | BuildScript - Loaded HyperPause Init.ahk scripts
08:55:44:166 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
08:55:44:166 | HL |     INFO  | +0     | BuildScript - Loaded MultiGame Init.ahk scripts
08:55:44:166 | HL |  WARNING  | +0     | BuildScript - "D:\HyperSpin\HyperLaunch\Lib\User Functions Init.ahk" not found
08:55:44:166 | HL |     INFO  | +0     | BuildScript - Validating module
08:55:44:168 | HL |     INFO  | +15    | BuildScript - Validation complete
08:55:44:168 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = PCSX2
				MEmuV =  1.1.0.r5695
				MURL = http://pcsx2.net/
				MAuthor = djvj
				MVersion = 2.1.1
				MCRC = 9FC47775
				iCRC = E6A9BAD3
				MID = 635038268913291718
				MSystem = "Sony PlayStation 2"
				; Notes:
				; This module has many settings that can be controlled via HyperLaunchHQ
				; If you want to customize settings per game, add the game to the module's ini using HyperLaunchHQ
				; If you use Daemon Tools, make sure you have a SCSI virtual drive setup. Not a DT one.
				; Tested DT support with the cdvdGigaherz CDVD plugin. Make sure you set it to use your SCSI drive letter.
				; Module will set the CdvdSource to Plugin or Iso depending on if you have Daemon Tools enabled or not.
				; If you have any problems closing the emulator, make sure noGUI module setting in HLHQ is set to default or false.
				; Per-game memory cards
				; This module supports per-game memory cards to prevent them from ever becoming full
				; To use this feature, set the PerGameMemoryCards to true in HLHQ
				; You need to create a default blank memory card in the path you have defined in pcsx's ini found in section [Folders], key MemoryCards.
				; Make sure one of the current memory cards are blank, then copy it in that folder and rename it to "default.ps2". The module will copy this file to a romName.ps2 for each game launched.
				; The module will only insert memory cards into Slot 1. So save your games there.
				; Linuz cdvd plugin stores its settings in the registry @ HKEY_CURRENT_USER\Software\PS2Eplugin\CDVD\CDVDiso
				; Run pcsx2 with the --help option to see current CLI parameters
				; Known CLI options not currently supported by this module:
				;  --console        	forces the program log/console to be visible
				;  --portable       	enables portable mode operation (requires admin/root access)
				;  --elf=<str>      	executes an ELF image
				;  --forcewiz       	forces PCSX2 to start the First-time Wizard
				StartModule()
				BezelGUI()
				FadeInStart()
				; PCSX2_ui.ini = default ini that contains memory card info and general settings
				If FileExist(emuPath . "\portable.ini") {	; portable install
					Log("Module - PCSX2 is operating in a portable mode")
					pcsx2IniFile := CheckFile(emuPath . "\inis\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.")
				} Else {	; default not portable install
					Log("Module - PCSX2 is operating in a standard installation mode")
					RegRead, pcsx2IniFolder, HKCU, Software\PCSX2, SettingsFolder
					pcsx2IniFile := CheckFile(pcsx2IniFolder . "\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.")
				; global settings
				noGUI := IniReadCheck(settingsFile, "Settings", "noGUI","false",,1)	; disables display of the gui while running games
				fullboot := IniReadCheck(settingsFile, "Settings", "fullboot","false",,1)	; disables the quick boot feature, forcing you to sit through the PS2 startup splash screens
				perGameMemCards := IniReadCheck(settingsFile, "Settings", "PerGameMemoryCards","true",,1)
				hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)	; Hides console window from view if it shows up
				cfgPath := IniReadCheck(settingsFile, "Settings", "cfgpath", emuPath . "\Game Configs",,1)	; specifies the config folder; applies to pcsx2 + plugins
				gs := IniReadCheck(settingsFile, "Settings|" . romName, "gs",,,1)	; override for the GS plugin
				pad := IniReadCheck(settingsFile, "Settings|" . romName, "pad",,,1)	; override for the PAD plugin
				spu2 := IniReadCheck(settingsFile, "Settings|" . romName, "spu2",,,1)	; override for the SPU2 plugin
				cdvd := IniReadCheck(settingsFile, romName, "cdvd",,,1)	; override for the CDVD plugin
				usb := IniReadCheck(settingsFile, "Settings|" . romName, "usb",,,1)	; override for the USB plugin
				fw := IniReadCheck(settingsFile, "Settings|" . romName, "fw",,,1)	; override for the FW plugin
				dev9 := IniReadCheck(settingsFile, "Settings|" . romName, "dev9",,,1)	; override for the DEV9 plugin
				dtOveride := IniReadCheck(settingsFile, romName, "DTOveride",,,1)
				nohacks := IniReadCheck(settingsFile, romName, "nohacks","false",,1)	; disables all speedhacks
				gamefixes := IniReadCheck(settingsFile, romName, "gamefixes",,,1)	; Enable specific gamefixes for this session. Use the specified comma or pipe-delimited list of gamefixes: VuAddSub,VuClipFlag,FpuCompare,FpuMul,FpuNeg,EETiming,SkipMpeg,OPHFlag,DMABusy,VIFFIFO,VI,FMVinSoftware
				cfgPath := GetFullName(cfgPath)
				IfNotExist % cfgPath
					FileCreateDir, %cfgPath%	; create the cfg folder if it does not exist
				BezelStart()
				Fullscreen := If Fullscreen = "true" ? " --fullscreen" : ""
				noGUI := If noGUI = "true" ? " --nogui" : ""
				If (noGUI != "")
					Log("Module - noGUI is set to true, THIS MAY PREVENT PCSX2 FROM CLOSING PROPERLY. If you have any issues, set it to false or default in HLHQ.",2)
				fullboot := If fullboot = "true" ? " --fullboot" : ""
				nohacks := If nohacks = "true" ? " --nohacks" : ""
				gamefixes := If gamefixes ? " --gamefixes=" . gamefixes : ""
				gs := If gs ? " --gs=""" . GetFullName(gs) . """" : ""
				pad := If pad ? " --pad=""" . GetFullName(pad) . """" : ""
				spu2 := If spu2 ? " --spu2=""" . GetFullName(spu2) . """" : ""
				usb := If usb ? " --usb=""" . GetFullName(usb) . """" : ""
				fw := If fw ? " --fw=""" . GetFullName(fw) . """" : ""
				dev9 := If dev9 ? " --dev9=""" . GetFullName(dev9) . """" : ""
				cfgRomPath := cfgPath . "\" . romName
				cfgPathCLI := If FileExist(cfgRomPath) ? " --cfgpath=""" . GetFullName(cfgRomPath) . """" : ""
				; Specify what main ini PCSX2 should use
				If (cfgPathCLI && FileExist(cfgRomPath . "\PCSX2_ui.ini")) {
					;We can't set both cfgpath and cfg CLI switches, so if only PCSX2_ui.ini file exists we use cfg otherwise we use cfgpath
					;--cfg specifies a custom configuration file to use instead of PCSX2.ini (does not affect plugins)
					filecount := 0
					Loop, %cfgRomPath%\*.ini
						filecount++
					If (filecount == 1)
						;Only PCSX2_ui.ini found
						pcsx2IniFile := cfgRomPath . "\PCSX2_ui.ini"
						Log("Module - Found a game-specific PCSX2_ui.ini in the cfgPath. Telling PCSX2 to use this one instead: " . pcsx2IniFile)
						cfg := " --cfg=""" . pcsx2IniFile . """"
						cfgPathCLI := ""
				Log("Module - " . (If cfgPathCLI != "" ? "Setting PCSX2's config path to """ . cfgRomPath . """" : "Using PCSX2's default configuration folder: """ . emuPath . "\inis"""))
				; Memory Cards
				If perGameMemCards = true
				{	IniRead, currentMemCard1, %pcsx2IniFile%, MemoryCards, Slot1_Filename
					IniRead, memCardPath, %pcsx2IniFile%, Folders, MemoryCards	; folder where memory cards are stored
					StringLeft, memCardPathLeft, memCardPath, 3
					memCardPathIsAbsolute := If (RegExMatch(memCardPathLeft, "[a-zA-Z]:\\") && (StrLen(memCardPath) >= 3))	; this is 1 only when path looks like this "C:\"
					memCardPath := If memCardPathIsAbsolute ? memCardPath : emuPath . "\" . memCardPath	; if only a folder name is defined for the memory card path, tack on the emuPath to find the memory cards, otherwise leave the full path as is
					defaultMemCard := memCardPath . "\default.ps2"	; defining default blank memory card for slot 1
					Log("Module - Default memory card for Slot 1 should be: " . defaultMemCard,4)
					romMemCard1 := memCardPath . "\" . romName . ".ps2"	; defining name for rom's memory card for slot 1
					Log("Module - Rom memory card for Slot 1 should be: " . romMemCard1,4)
					Log("Module - Current memory card inserted in PCSX2's ini in Slot 1 is: " . currentMemCard1)
					If (currentMemCard1 != romName . ".ps2") {	; if current memory card in slot 1 does not match this romName, switch to one that does if exist or load a default one
						IfNotExist, %romMemCard1%	; first check if romName.ps2 memory card exists
							IfNotExist, %defaultMemCard%
								Log("Module - A default memory card for Slot 1 was not found in """ . memCardPath . """. Please create an empty memory card called ""default.ps2"" in this folder for per-game memory card support.",3)
							Else {
								FileCopy, %defaultMemCard%, %romMemCard1%	; create a new blank memory card for this game
								Log("Module - Creating a new blank memory card for this game in Slot 1: " . romMemCard1)
						IniWrite, %romName%.ps2, %pcsx2IniFile%, MemoryCards, Slot1_Filename	; update the ini to use this rom's card
						Log("Module - Switched memory card in Slot 1 to: " . romMemCard1)
				hideEmuObj := Object("ahk_class wxWindowClassNR",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
				pcsx2Ini := LoadProperties(pcsx2IniFile)	; load the config into memory
				dvdSource := ReadProperty(pcsx2Ini,"CdvdSource")	; read value
				; Mount the CD using DaemonTools
				If dtOveride	; this allows per-game DT support because some games boot to black when DT is enabled
					dtEnabled := dtOveride
				If (dtEnabled = "true" && InStr(".mds|.mdx|.b5t|.b6t|.bwt|.ccd|.cue|.isz|.nrg|.cdi|.iso|.ape|.flac", romExtension)) {	; if DT enabled and using an image type DT can load
					If !cdvd {
						dtCDVDPlugin := IniReadCheck(settingsFile, "Settings", "DT_CDVD_Plugin",,,1)
						If dtCDVDPlugin
							cdvd := dtCDVDPlugin
					cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : ""
					If dvdSource != Plugin
					{	Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can read from Daemon Tools.")
						WriteProperty(pcsx2Ini,"CdvdSource","Plugin")	; write a new value to the pcsx2IniFile
						SaveProperties(pcsx2IniFile,pcsx2Ini)	; save pcsx2IniFile to disk
					DaemonTools("mount",romPath . "\" . romName . romExtension)
					HideEmuStart()
					errLvl := Run(executable . " --usecd" . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath,  "UseErrorLevel")
					usedDT = 1	; tell the rest of the script to use DT methods
				} Else If romExtension in .iso,.mdf,.nrg,.bin,.img	; the only formats PCSX2 supports loading directly
					If !cdvd {
						imageCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Image_CDVD_Plugin",,,1)
						If imageCDVDPlugin
							cdvd := imageCDVDPlugin
					If dvdSource != Iso
					{	Log("Module - CdvdSource was not set to ""Iso"", changing it so PCSX2 can launch this " . romExtension . " image directly")
						WriteProperty(pcsx2Ini,"CdvdSource","Iso")	; write a new value to the pcsx2IniFile
					HideEmuStart()
					errLvl := Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath,  "UseErrorLevel")
				} Else If romExtension in .bz2	; special case format that requires plugin mode and pcsx2 loads it directly
					If !cdvd {
						linuzCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Linuz_CDVD_Plugin",,,1)
						If linuzCDVDPlugin
							cdvd := linuzCDVDPlugin
					If dvdSource != plugin
					{	Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can launch this " . romExtension . " image directly")
					oldHex := ReadReg("IsoFile")	; read last used bz2 image
					newHex := StrToHex(romPath . "\" . romName . romExtension)	; convert new bz2 image path to hex
					i := 512 - StrLen(newHex)	; get total amount of 0's to add to end of hex to make it 512 bytes
					Loop, %i%
						newHex := newHex . "0"	; add required bytes to end
					If (oldHex != newHex) {
						Log("Module - Writing new bz2 path to registry",4)
						WriteReg("IsoFile", newHex)	; write new bz2 path to registry
					HideEmuStart()
				} Else
					ScriptError("You are trying to run a rom type of """ . romExtension . """ but PCSX2 only supports loading iso|mdf|nrg|bin|img directly. Please turn on Daemon Tools and/or 7z support or put ""cue"" last in your rom extensions for " . MEmu . " instead.")
				If errLvl
					ScriptError("Error launching emulator, closing script.")
				WinWait("ahk_class wxWindowClassNR",,, "PCSX2")
				WinWaitActive("ahk_class wxWindowClassNR",,, "PCSX2")
				BezelDraw()
				If hideConsole = true
					SetTimer, HideConsole, 10
				SetTitleMatchMode 2 ;Wrong window might be detected in the next loop if we only use the class name for WinGetTitle so we will add fps to it
				Loop { ; looping until pcsx2 is done loading game
					; tooltip, loop %A_Index%,0,0
					Sleep, 200
					WinGetTitle, winTitle, fps ahk_class wxWindowClassNR,, PCSX2 ; excluding the title of the GUI window so we can read the title of the game window instead
					Log("Detected Window Title is " . winTitle,4)
					StringSplit, winTextSplit, winTitle, |, %A_Space%
					If ( winTextSplit10 != "" ) ; 10th position in the array is empty until game actually starts
						break
					If A_Index > 150	; after 30 seconds, error out
						ScriptError("There was an error detecting when PCSX2 finished loading your game. Please report this so the module can be fixed.")
				HideEmuEnd()
				FadeInExit()
				If usedDT
					DaemonTools("unmount")
				7zCleanUp()
				BezelExit()
				FadeOutExit()
				ExitModule()
				ReadReg(var1) {
					regValue := RegRead("HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1)
					Return %regValue%
				WriteReg(var1, var2, ValueType="REG_BINARY") {
					RegWrite(ValueType, "HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1, var2)
				StrToHex(S) {
					Return S="" ? "":Chr((*&S>>4)+48) Chr((x:=*&S&15)+48+(x>9)*7) StrToHex(SubStr(S,2))
				MultiGame:
					; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = "  . mgRomName
					; Unmount the CD from DaemonTools
					If usedDT
					Sleep, 500	; Required to prevent  DT from bugging
					If usedDT
						DaemonTools("mount",selectedRom)
				Return
				HideConsole:
					hideConsoleTimer++
					IfWinExist, Booting ahk_class wxWindowClassNR
					{	Log("Module - HideConsole - Console window found, hiding it out of view.")
						WinSet, Transparent, 0, Booting ahk_class wxWindowClassNR,,fps:,fps:	; hiding the console window
						WinSet, Transparent, 0, PCSX2 ahk_class wxWindowClassNR,,fps:,fps:	; hiding the GUI window with the menubar
						SetTimer, HideConsole, Off
					} Else If hideConsoleTimer >= 200
				Return
				CloseProcess:
					FadeOutStart()
					WinMenuSelectItem, PCSX2 ahk_class wxWindowClassNR,, System, Pause
					WinClose("PCSX2 ahk_class wxWindowClassNR") ; sending command to the GUI window to properly close the entire emu
				Return
08:55:44:176 | HL |     INFO  | +0     | CheckFile - Checking if C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe exists
08:55:44:182 | HL |     INFO  | +0     | BuildScript - Loaded HyperPause scripts
08:55:44:183 | HL |     INFO  | +0     | BuildScript - Loaded MultiGame scripts
08:55:44:184 | HL |     INFO  | +16    | BuildScript - Loaded Multi-Player scripts
08:55:44:185 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
08:55:44:185 | HL |  WARNING  | +0     | BuildScript - "D:\HyperSpin\HyperLaunch\Lib\User Functions.ahk" not found
08:55:44:185 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
08:55:44:187 | HL |     INFO  | +0     | Main - Module is built
08:55:44:187 | HL |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
08:55:44:187 | HL |     INFO  | +0     | Main - Hiding taskbar
08:55:44:414 | HL |     INFO  | +218   | Main - Running module
08:55:44:570 | MD |     INFO  | +N/A   | Module initialized
08:55:44:570 | MD |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\Utilities\Xpadder\Xpadder.exe exists
08:55:44:570 | MD |     INFO  | +0     | Keymapper - Loading xpadder
08:55:44:570 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
08:55:44:570 | MD |     INFO  | +0     | GetJoystickArray - Started
08:55:44:617 | MD |     INFO  | +47    | GetJoystickGUID - Started
08:55:44:617 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: E0EDE277EAE3E3118001444553540000
08:55:44:617 | MD |     INFO  | +0     | GetJoystickArray - Ended
08:55:44:617 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> D:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
08:55:44:617 | MD |     INFO  | +0     | RunXpadder - Started
08:55:44:617 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
08:55:44:617 | MD |     INFO  | +0     | Run - Running: D:\HyperSpin\Utilities\Xpadder\Xpadder.exe /C
08:55:44:679 | MD |     INFO  | +63    | Process - WaitClose Xpadder.exe 2
08:55:44:788 | MD |     INFO  | +109   | Run - Running: D:\HyperSpin\Utilities\Xpadder\Xpadder.exe "D:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile" /M
08:55:44:788 | MD |     INFO  | +0     | RunXpadder - Ended
08:55:44:788 | MD |     INFO  | +0     | RunKeymapper - Ended
08:55:44:820 | MD |     INFO  | +31    | StartModule - Started
08:55:44:820 | MD |     INFO  | +0     | StartModule - MEmu: PCSX2
				MEmuV: 1.1.0.r5695
				MURL: http://pcsx2.net/
				MAuthor: djvj
				MVersion: 2.1.1
				MCRC: 9FC47775
				iCRC: E6A9BAD3
				MID:
				MSystem: "Sony PlayStation 2"
08:55:44:820 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Sony PlayStation 2"
08:55:44:820 | MD |     INFO  | +0     | PluginInit - Started
08:55:44:820 | MD |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\Databases\Sony PlayStation 2\Sony PlayStation 2.xml exists
08:55:44:820 | MD |     INFO  | +0     | PluginInit - Ended
08:55:44:820 | MD |     INFO  | +0     | Hiding mouse cursor
08:55:44:835 | MD |     INFO  | +16    | StartModule - Ended
08:55:44:835 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Started
08:55:44:835 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
08:55:45:339 | MD |     INFO  | +514   | DefaultAnimateFadeIn - Ended
08:55:45:339 | MD |     INFO  | +0     | Module - PCSX2 is operating in a portable mode
08:55:45:339 | MD |     INFO  | +0     | CheckFile - Checking if D:\HyperSpin\Emulators\Sony Playstation 2\Emulators\PCSX2 1.0.0 R5350\inis\PCSX2_ui.ini exists
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - noGUI:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - fullboot: false
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - PerGameMemoryCards: true
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - HideConsole: true
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - cfgpath: ..\Emulators\Sony Playstation 2\Emulators\PCSX2 1.2.1\Game Configs
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - gs:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - gs:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - pad:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - pad:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - spu2:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - spu2:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - cdvd:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - usb:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - usb:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - fw:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - fw:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [settings] - dev9:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - dev9:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - DTOveride:
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - nohacks: false
08:55:45:339 | MD |     INFO  | +0     | Module Setting - [Agent Hugo - Hula Holiday (Europe)] - gamefixes:
08:55:45:339 | MD |     INFO  | +0     | Module - Using PCSX2's default configuration folder: "D:\HyperSpin\Emulators\Sony Playstation 2\Emulators\PCSX2 1.0.0 R5350\inis"
08:55:45:339 | MD |     INFO  | +0     | Module - Current memory card inserted in PCSX2's ini in Slot 1 is: Agent Hugo - Hula Holiday (Europe).ps2
08:55:45:339 | MD |     INFO  | +0     | 7z - Started, received D:\HyperSpin\Emulators\Sony Playstation 2\Roms\Agent Hugo - Hula Holiday (Europe)\Agent Hugo - Hula Holiday (Europe).cue. If rom is an archive, it will extract to D:\HyperSpin\7z
08:55:45:339 | MD |     INFO  | +0     | 7z - This rom type does not need 7z: ".cue"
08:55:45:339 | MD |     INFO  | +0     | DefaultFadeAnimation - Started
08:55:45:339 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade Info Bar will use D:\HyperSpin\HyperLaunch\Media\Fade\_Default\Info Bar.png
08:55:45:417 | MD |     INFO  | +78    | 7z - Ended
08:55:45:417 | MD |     INFO  | +0     | Module Setting - [settings] - DT_CDVD_Plugin: ..\Emulators\Sony Playstation 2\Emulators\PCSX2 1.2.1\Plugins\cdvdGigaherz.dll
08:55:45:417 | MD |     INFO  | +0     | DaemonTools - Started - action is mount
08:55:45:542 | MD |     INFO  | +125   | DefaultFadeAnimation - Ended
08:55:45:683 | MD |     INFO  | +141   | DaemonTools - Running DT with: C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe -mount scsi, 0, "D:\HyperSpin\Emulators\Sony Playstation 2\Roms\Agent Hugo - Hula Holiday (Europe)\Agent Hugo - Hula Holiday (Europe).cue"
08:55:50:131 | MD |     INFO  | +4446  | DaemonTools - Ended
08:55:50:131 | MD |     INFO  | +0     | Run - Running: D:\HyperSpin\Emulators\Sony Playstation 2\Emulators\PCSX2 1.0.0 R5350\pcsx2-r5350.exe --usecd --fullscreen --cdvd="D:\HyperSpin\Emulators\Sony Playstation 2\Emulators\PCSX2 1.2.1\Plugins\cdvdGigaherz.dll"
08:55:50:131 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class wxWindowClassNR"
08:55:50:647 | MD |     INFO  | +514   | WinWaitActive - Waiting for "ahk_class wxWindowClassNR"
08:56:30:379 | MD |    ERROR  | +39734 | There was an error detecting when PCSX2 finished loading your game. Please report this so the module can be fixed.
08:56:30:379 | MD |     INFO  | +0     | ExitModule - Started
08:56:30:379 | MD |     INFO  | +0     | Starting Updating Statistics:
08:56:30:447 | MD |     INFO  | +62    | Game section statistics updated.
08:56:30:447 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
08:56:30:448 | MD |     INFO  | +0     | GetJoystickArray - Started
08:56:30:452 | MD |     INFO  | +0     | GetJoystickGUID - Started
08:56:30:453 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: E0EDE277EAE3E3118001444553540000
08:56:30:453 | MD |     INFO  | +0     | GetJoystickArray - Ended
08:56:30:453 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> D:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperSpin\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
08:56:30:453 | MD |     INFO  | +0     | RunXpadder - Started
08:56:30:453 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
08:56:30:470 | MD |     INFO  | +31    | Run - Running: D:\HyperSpin\Utilities\Xpadder\Xpadder.exe /C
08:56:30:477 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
08:56:30:596 | MD |     INFO  | +125   | Run - Running: D:\HyperSpin\Utilities\Xpadder\Xpadder.exe "D:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperSpin\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile" /M
08:56:30:619 | MD |     INFO  | +16    | RunXpadder - Ended
08:56:30:619 | MD |     INFO  | +0     | RunKeymapper - Ended
08:56:30:625 | MD |     INFO  | +0     | Restoring mouse cursor
08:56:30:626 | MD |     INFO  | +15    | ExitModule - Ended
08:56:30:626 | MD |     INFO  | +0     | End of Module Logs
08:55:44:414 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
08:56:30:641 | HL |     INFO  | +46239 | Main - Module ended, exiting HyperLaunch normally
08:56:30:641 | HL |     INFO  | +0     | ExitScript - Started
08:56:30:871 | HL |     INFO  | +218   | SystemCursor - Restoring mouse cursor
08:56:30:880 | HL |     INFO  | +16    | ExitScript - Ended
