sarlo Posted January 11, 2015 Posted January 11, 2015 I have a mame control panel and computer all set-up currently working great but with an older hyperspin version. How do I simply update hyperspin to 1.0 so I can use some of the newer features. Do I just download 1.0 and overwrite my old version?
boohiss Posted January 11, 2015 Posted January 11, 2015 I'd strongly recommend a fresh install, using the "HyperSpin Install Files v1.3.2.0" download from this site to start. After that, use this guide to update hyperlaunch: https://sites.google.com/site/hyperlaunch2/home/downloads And finally, use this link to update to the hyperlaunch beta: http://www.hyperlaunch.net/forum/showthread.php?295-HyperLaunch-v3-1-0-0-Beta After all of the updating, you will have tons of new features and things to set up in HyperlaunchHQ. HyperHQ still needs to be set up but it should be about the same as you know it from 1.0. It takes a while to go through everything new and it might be overwhelming, but take your time. Add just one wheel to the setup and work on it until you understand before you add more wheels. Also backup your old hyperspin folder in case you prefer the old version for whatever reason, and also if you want artwork files from the old setup.
