Tomkun Posted February 7, 2015 Posted February 7, 2015 Hello. If any of you have tried to change the region in some Sega Model 3 games from Japan to elsewhere, you may have discovered that they are locked. I understand that there are some codes you can input which will unlock the region and enable you to change it. Does anybody know where I might discover these codes? Unfortunately it seems that the Supermodel forums are closed. Many thanks. [Edit] I realised I put this in the wrong forum. Could one of the Admins please move it to support? [/Edit]
Tomkun Posted February 10, 2015 Author Posted February 10, 2015 UPDATE Looks like the Supermodel forum came back online; I don't know what happened there, but just in case they go offline again, I will post the codes here for anyone else to use. Found a list of all available Model 3 region codes online and thought you all might like to know them!DAYTONA USA 2: BATTLE ON THE EDGE and POWER EDITION (Model 3 Step 2) Method 1 Go into the test mode and push the service and test button on the PCB at the same time. Method 2 Go into the test mode and push Hold Start and Press GREEN, GREEN, BLUE, YELLOW, RED, YELLOW, BLUE. (Colours are the VR buttons). DIRT DEVILS (Model 3 Step 2) Region controlled by program roms EMERGENCY CALL AMBULANCE (Model 3 Step 2) Region controlled by program roms GET BASS/SEGA BASS FISHING (Model 3 Step 1.0) Go into test mode, select the crt test 2/2, push the service button 4 times, exit the crt test, select the Game assignments, push service 3 times (sound), hold service on push number 4 and then press test. HARLEY DAVIDSON LA RIDERS (Model 3 Step 2) Go into the test mode, select game assignments up, up, down, down, view, music, view, music. LA MACHINE GUNS (Model 3 Step 2) Go into the test mode and push start, start, service, start, start, start, service, test. (start = player 1 start button). LE MANS 24hr (Model 3 Step 1.5) Go into the test mode and push start, start, service, service, start, test. LOST WORLD (Model 3 Step 1.5) Go into the test mode and push start, start, service, start, service, test. (start = player 1 start button). MAGICAL TRUCK ADVENTURE (Model 3 Step 2) Enter Self-test Mode Press “Left Start Button” 2X Press “Service Button” Press “Left Start Button” Press “Service Button” Press “Test Button OCEAN HUNTER (Model 3 Step 2) Enter TEST MODE Enter GAME ASSIGNMENTS Press start button as follow:1P 2P 1P 2P 1P 2P 2P Select Country SCUD RACE/SUPER GT (Model 3 Step 1.5) Country setting can be changed in the menu (non-Australian version). SEGA RALLY 2 (Model 3 Step 2) Go into the test mode, using the service button do 4 short presses, 2 long, 2 short and 1 long. SKI CHAMP (Model 3 Step 2) Enter the self-test mode. Press the buttons on the control panel in the following sequence: Blue, Green, Blue, Green, Service, Service button. STAR WARS TRILOGY (Model 3 Step 2) Go into the test mode and using the service button do the following: Short, short, short, long, long, short, short, long. VIRTUA FIGHTER 3 (Model 3 Step 1) Country setting can be changed in menu (non-Australian version). VIRTUA STRIKER 2 ’98 (Model 3 Step 1.5/2) 1. Go into "Game Assignment " in the Test mode. 2. Press the Service Button once for about 5 seconds. 3. Press the Service Button three times shortly. 4. Press the Service Button one time for about 5 seconds again. VIRTUA STRIKER 2 ’99 (Model 3 Step 1.5/2) 1. Go into "Game Assignment " in the Test mode. 2. Press the Service Button once for about 5 seconds. 3. Press the Service Button three times shortly. 4. Press the Service Button one time for about 5 seconds again. 5. Press the Service Button twice shortly. 6. Press the Service Button once for about 5 seconds one more time. VIRTUA STRIKER 2’99.1 (Model 3 Step 2) Region controlled by program roms. Original post: http://www.supermodel3.com/Forum/viewtopic.php?f=3&t=50
twistedsymphony Posted April 22, 2016 Posted April 22, 2016 Looks like Supermodel Forums are offline again.Does anyone know the region codes for Virtual On? It does indeed have an English language mode:
