MAME select game volume
5thWolf
Some games are very low volume. I know you can increase volume in MAME but it affects all games, so when changing to different games I have to turn it back down for games with normal volume.
So does anyone know a way to have the low volume games not be so low without having to change volume all the time in mame?
~5thWolf~
I had this problem as well. For the few I noticed it in, I found this from the MAME FAQ:
"Mortal Kombat II / Mortal Kombat 3 / Ultimate Mortal Kombat 3
The volume for this game is TOO LOW!
When the game is running, hit F2 to get to the internal service menu. Hit F2 again to "close" the service switch so that you won't get stuck in the menu. Now, navigate to the "Volume Adjust" option (following the directions provided) and adjust the volume. It's best to keep the volume no more than 80-90% filled as it might cause your sound to be overdriven and crackle. When adjusted, simply exit the menu."
This seems to be the case with a good amount of Midway games.
AWESOME!!!!!!!!! Works great... some are already maxed :(
But helped a ton on games like MK3.
Hope they all save upon exit and return like MK3 did!!
Thanks a million Joe!!!!!!!
~5thWolf~
