Raccoon Posted February 10, 2015 Posted February 10, 2015 Lets start with the easy question: is there a FP BAM wheel? I thought that maybe I would do two separate wheels for FP and FP BAM so I don´t have to change the arcade mode setting, some poeple like BAM and some don´t. It´s just to make a copy of the whole FP folder and name the second one FP BAM. The second question is about the DMD When I run BAM the DMD isn´t updated and sometimes it doesn´t show anything at all. Is there a setting that I´m missing? I don´t have a pinball cab with two screens, just an arcade cab with vertically mounted widescreen. Where, were, ware - it´s not my thing, don´t remember when to use which
Raccoon Posted February 10, 2015 Author Posted February 10, 2015 Well, that didn´t work anyway as it saves the config file on the same place. FP doesn´t work in arcade mode and you lose some functions in BAM when not using arcade mode. Have to forget about this and use either one, I would like to use BAM, but I also want the DMD to work. Where, were, ware - it´s not my thing, don´t remember when to use which
