Mame lightgun setup problem
Raccoon
I just got my EMS Topgun 3 lightgun and have it setup and it works fine in American laser games, but to set it up in MAME is a real pain.
I´ve made the changes to the ini file and now I´m trying to set the Lightgun X and Y with the gun.
After a few tries I managed to get the Y axis set, but every time I try to set the X axis it becomes either Gun 1 Y Gun 1 X or Gun 1 X Gun 1 Y.
Isn´t there a ini file for this where I could change that to Gun 1 X manually or do you have another tips on how to set this?
If I use the gun to steer the mouse cursor in windows I can make it reach each corner and the red pointer and cursor are aligned, but the cursor isn´t 100% stable, that could ofcourse be that it´s not so easy to hold it steady.
Where, were, ware - it´s not my thing, don´t remember when to use which
At last I succeeded in configuring the lightgun, but when I try to calibrate it in Terminator 2 I hit the calibration point wherever I point and press the trigger and there is no crosshair.
When the game starts it only shoots in the top left corner.
Don´t know which gun you have, but I found this guide for Aim-Trak, not the same I have but the procedure for MAME is the same: www.ultimarc.com/AimTrak%20Setup%20Guide.pdf
Start at page 11 and change your mame.ini (MAME/ini/mame.ini)
What I did wrong after that was that I started outside of the screen and then pointed across the screen.
Start with the gun pointed at the screen from the beginning.
Continue with page 12-16 and then have a look at the "Game specific settings"
I´ve tested Area 51 which worked fine, but haven´t succeeded with Terminator 2 (page 22) yet.
