upod21 Posted April 4, 2015 Posted April 4, 2015 Hello, I'm sorry if this question has been posted before, but I can't seem to find an answer anywhere. How do I change the Rom extract path when using 7z files. Timestamp Thread Level Diff. Log Data 00:47:11:065 HL INFO +N/A Main - HyperLaunch v3.1.0.5b BETA (www.hyperlaunch.net) 00:47:11:143 HL INFO +78 Main - System Specs: HyperLaunch Dir: C:\Hyperspin HyperLaunch is: 32-bit OS: Microsoft Windows 7 Home Premium SKU: Home Premium Total Memory: 8082.21 MB Free Memory: 6853.29 MB Used Memory: 1228.926 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: Intel® HD Graphics GPU 1 RAM: -1984.00 MB GPU 1 Driver Version: 10.18.10.3958 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: High Definition Audio Device Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 00:47:11:143 HL INFO +0 CheckFile - Checking if C:\Hyperspin\HyperLaunch.exe exists 00:47:11:143 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Module Extensions\dxwnd\dxwnd.ini exists 00:47:11:143 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Module Extensions\dxwnd\dxwnd.exe exists 00:47:11:143 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Plugins\HyperSpin.plugin exists 00:47:11:143 HL INFO +0 Main - Loading Front End Plugin: "HyperSpin" 00:47:11:143 HL INFO +0 Main - HyperLaunch received "Nintendo Entertainment System" and "10-Yard Fight" 00:47:11:143 HL INFO +0 Main - 10-Yard Fight is using the default emulator: RetroArch 00:47:11:143 HL INFO +0 Main - Checking for a [RetroArch] section in C:\Hyperspin\Settings\Nintendo Entertainment System\Emulators.ini 00:47:11:143 HL INFO +0 Main - Checking for a [RetroArch] section in C:\Hyperspin\Settings\Global Emulators.ini 00:47:11:143 HL INFO +0 Main - Found [RetroArch] in C:\Hyperspin\Settings\Global Emulators.ini 00:47:11:143 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Modules\RetroArch\RetroArch.ahk exists 00:47:11:143 HL INFO +0 Main - CRC Check - CRC matches, this is an official unedited module. 00:47:11:143 HL INFO +0 Main - 10-Yard Fight will use module: C:\Hyperspin\Modules\RetroArch\RetroArch.ahk 00:47:11:159 HL INFO +15 Main - Did not find a "C:\Hyperspin\Settings\Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options. 00:47:11:159 HL INFO +0 Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 00:47:11:159 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Emulators\RetroArch\retroarch.exe exists 00:47:11:159 HL INFO +0 Main - INI Keys read 00:47:11:159 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Module Extensions\7z.exe exists 00:47:11:159 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Module Extensions\7z.dll exists 00:47:11:159 HL INFO +0 CreateRomMapTable - Started 00:47:11:159 HL INFO +0 AltNameExistCheck - Found rom: C:\Hyperspin\ROMs\Nintendo - Nintendo Entertainment System\10-Yard Fight.7z 00:47:11:159 HL INFO +0 CreateRomMapTable - Ended, No mapping inis found. 00:47:11:159 HL INFO +0 CheckFile - Checking if C:\Hyperspin\Module Extensions\FontReg.exe exists 00:47:12:857 HL INFO +1701 Main - "10-Yard Fight" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 00:47:12:857 HL INFO +0 CheckPaths - Started 00:47:22:696 HL ERROR +9844 You cannot have a Rom Path set to the same path used for your 7zExtractPath otherwise your roms may be deleted: C:\Hyperspin\ROMs\Nintendo - Nintendo Entertainment System 00:47:22:696 HL INFO +0 ExitScript - Started 00:47:22:696 HL INFO +0 SystemCursor - Restoring mouse cursor 00:47:22:696 HL INFO +0 ExitScript - Ended
Icarus86 Posted April 4, 2015 Posted April 4, 2015 Inside HyperLaunchHQ, select your system on the left. By the looks of your log im assuming you want to change SNES and NES. After selecting the system, click on the Settings tab (green gear icon). Scroll down to the 7z section, that's where you can change your path.
upod21 Posted April 6, 2015 Author Posted April 6, 2015 Thank you. It created a new HS temp folder for rooms to open up in.
