jrose1184 Posted April 9, 2015 Posted April 9, 2015 hi hyperspin was working fine untill i reinstalled the pc. every time i play a mame game it works for 1 min then kicks me out? i am using the same hyperspin as it was on a external hard drive so all butons ect... are al ready working. i instaleed net frame work. am i missing somthink? cheers
esoteric Posted April 9, 2015 Posted April 9, 2015 Go into HyperlaunchHQ, click the General Settings tab and then the Controls tab within there. Make sure that "Exit Script Key" is set to something like F2 so that you're not accidentally exiting out of your games. If you play the game directly from MAME are you still getting the issue? http://www.reddit.com/r/HyperSpin/
bandit721 Posted April 9, 2015 Posted April 9, 2015 Have you tried running the games directly from MAME (not through HS)? Maybe it isn't and HS issue but an emulator issue with new config.
jrose1184 Posted April 9, 2015 Author Posted April 9, 2015 Go into HyperlaunchHQ, click the General Settings tab and then the Controls tab within there. Make sure that "Exit Script Key" is set to something like F2 so that you're not accidentally exiting out of your games. If you play the game directly from MAME are you still getting the issue? the game still plays in the back ground so i guess its not exiting?
jrose1184 Posted April 9, 2015 Author Posted April 9, 2015 Have you tried running the games directly from MAME (not through HS)? Maybe it isn't and HS issue but an emulator issue with new config. yes the game work
esoteric Posted April 9, 2015 Posted April 9, 2015 It sounds like you might be using a new version of MAME but an outdated MAME module in Hyperlaunch. Have you recently updated Hyperlaunch? If not, try that (you can use the guide here if you need to: http://www.rlauncher.com/wiki/index.php?title=RocketLauncher_Downloads http://www.reddit.com/r/HyperSpin/
jrose1184 Posted April 9, 2015 Author Posted April 9, 2015 It sounds like you might be using a new version of MAME but an outdated MAME module in Hyperlaunch. Have you recently updated Hyperlaunch? If not, try that (you can use the guide here if you need to: http://www.rlauncher.com/wiki/index.php?title=RocketLauncher_Downloads thanks for that but no i get this error when trying to select a game can not find c:\user\jamie\desktop\untitled folder\module extension\dxwnd\dxwnd.ini
spaceangel Posted April 9, 2015 Posted April 9, 2015 Mine is the same, it was working fine until i used instant sheller. After that the game would launch in the background and not in hyperspin. Since then i put my shell back and now its coming up with errors as well as launching in the background. Weird
jrose1184 Posted April 9, 2015 Author Posted April 9, 2015 I fixed this error but now have another one can't find mame.xml.
